25th June 2016, 18:38 | #14442 | Link |
Update 2016-06-25
Added: Option to run mutiple EncodingServers at RipBot264 launch. Following line must be added manually to ripbot264.ini ActivateServers=x where x is number between 1 and 10 The same effect can be achieved by running EncodingServer.exe with /instances x switch. For example: EncodingServer.exe /show /instances 2 Fixed: DownloadPoster has been adapted to changes introduced on TMDB website Fixed: Various bugs in ModifyChapter tool
26th June 2016, 03:04 | #14443 | Link | |
And it's now 1.19.4 Last edited by burt123; 26th June 2016 at 03:29. |
2nd July 2016, 01:57 | #14445 | Link |
I think I may have found a bug with ripbot(latest version).
I encoded some movie's in HEVC. They play fine in WMP 12 after installing LAVfliters But if I start ripbot the video no longer plays & the video will not work if until I reinstall LAV filters again. Only reason I suspect ripbot is I can play HEVC fine until I start ripbot, but it might be a LAV filter bug as well. My system specs Windows 7 SP1 x64 i5 3570k OC to 4.4Ghz 8GB RAM GTX680SC |
2nd July 2016, 09:24 | #14446 | Link |
Do not use wmp. Use mpc-hc which has already built in lav filters.
2nd July 2016, 15:29 | #14448 | Link | |
2nd July 2016, 15:45 | #14449 | Link | |
Are you using DE ???, you can stop that, and resume, whenever you want to. |
4th July 2016, 06:59 | #14450 | Link |
Hi Atak,
I am having a really annoying problem, and I cant pin point when it started to do it. I generally run several instances of servers, in DE mode, and I have noticed that for what ever reason, once I start an encode (or a queue), that I can't get anymore than 2 instances of "help" from another PC (or more), but I can have 5 or more on the "main" machine. I'm pretty sure it hasn't got anything to do with the latest update, but have you made any changes that may be causing this behavior ?? It's annoying, as I generally don't have any weird problems with Ripbot, but this one is beyond me |
4th July 2016, 07:04 | #14451 | Link |
Another weird thing...I have several HEVC encodes that I wanted to convert back to x264, and once Ripbot is complete, and I play the file, after approx 6 - 7 minutes the audio instantly goes way out of sync, and then the video goes to black around half way thru. (it should play for approx an hour)
4th July 2016, 12:11 | #14452 | Link | ||
I would like to run DE, but I dont have a spare PC. If I can speed up the encode using 2 instances in a VM I would But I dont think it would speed it up that much Specs on my PC are 4.4Ghz i5 3570K, 8GB RAM, GTX680SC |
4th July 2016, 13:42 | #14453 | Link | ||
4th July 2016, 13:58 | #14454 | Link | |
You can use DE on the same PC, I do regularly, it WILL make a lot of difference to encode times |
4th July 2016, 14:04 | #14455 | Link | |
I have 5 servers on the main pc, and 5 on the other server, but... When watching the main "DE window", and I have each server enabled, it ONLY use's 2, of the 5 I have made available on the other PC, it just keeps trying to start, but it doesn't, so on, and so on...so I just enable 2. Didn't use to do this. |
4th July 2016, 14:10 | #14456 | Link | |
Yeah, again, it wasn't doing this the other day, and it actually changed during a queue I had going. Just like that, it happened mid way thru, of the "same set" of queued files, and then on a few other files, and again today. Some of them were x264, and some were x265....original's. Sorry I can't explain it any better |
4th July 2016, 19:38 | #14457 | Link | |
6th July 2016, 16:14 | #14459 | Link |
I have an anime DVD I'm trying to rip that has a progressive 29.97fps intro credits sequence, however the actual episode content is hard telecined. I don't want to necessarily drop frames from the intro so what I thought I would try in to split the source into 2 clips, then do a convertfps to 23.976 on the intro(clip1) whilst doing a detelecine and decimate on the rest of the episode(clip2). However when I try to join them back up again it says incorrect framerate even though if I process both clips separately they both say 23.976...
Here's what I did inside the ripbot script: #VideoSource video1=DirectShowSource("E:\Rips\Azumanga Daioh - 1x01.mkv",audio=false).ConvertToYV12() #Deinterlace video1a = Trim(video1,0,2723) video1b = Trim(video1,2724,0) video1a=Convertfps(video1a,23.976) #Deinterlace orig = last Loadplugin("C:\Program Files\Ripbot\RipBot264v1.19.2\Tools\AviSynth plugins\TIVTC\TIVTC.dll") video1b=tfm(video1b,order=1,pp=1,cthresh=4,MI=40) Loadplugin("C:\Program Files\Ripbot\RipBot264v1.19.2\Tools\AviSynth plugins\TDeint\TDeint.dll") video1b=TDeint(video1b,order=1,type=3,hints=true,clip2=orig) #Decimate Loadplugin("C:\Program Files\Ripbot\RipBot264v1.19.2\Tools\AviSynth plugins\TIVTC\TIVTC.dll") video1b=TDecimate(video1b) video = video1a ++ video1b Any ideas? Even if I specify a rate of 23.976 in TDecimate it still errors out. |
6th July 2016, 18:05 | #14460 | Link |
I wonder why can't you just do this task in this way?
#VideoSource video=DirectShowSource("E:\Rips\Azumanga Daioh - 1x01.mkv",audio=false).ConvertToYV12() #Decimate Loadplugin("C:\Program Files\Ripbot\RipBot264v1.19.2\Tools\AviSynth plugins\TIVTC\TIVTC.dll") video_part1=Trim(video,0,2723).Convertfps("ntsc_film") #ntsc_film=24000/1001 video_part2=Trim(video,2724,0).tfm(order=1).TDecimate video = video_part1 + video_part2
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 6th July 2016 at 18:16. |
