13th March 2021, 16:15 | #19001 | Link | |
In some cases - but I canīt see which ones - there IS a "Copy video stream" option in RB. @Pauly Dunne Thanx. I did see the option too in a few cases, I am pretty sure I had none of the ones you mentioned as inputs. |
14th March 2021, 02:14 | #19003 | Link |
Grumpy Old Man.
Why don't you say what you REALLY mean ?? lol (or is that why it was edited ?)
OK, so to try and answer your question, the "Reconnect" when enabled, allows the server to reconnect automatically if there is some interruption in the connection, similar to having /restart-if-no-progress, added to the cmd line. Also, if this is enabled, and you have started an encode, then you decide to start another pc to help, once it's up & running, it will kick in and start encoding automatically. As for "suspend jobless server", if enabled, when you have one or more servers helping with DE, and you have a queue of jobs to get thru, when a job is coming to the end of the chunks, and a particular server has no more to do on that job, it should go to sleep (if it's set up to do so), and then once the next job is starting, then the sleeping server will be woken up, and should start encoding. Particularly helpful if the remaining chunks & completion process is going to take a while. I had this happen for me a couple of weeks ago, pretty impressive...saves a bit of electricity
14th March 2021, 02:33 | #19004 | Link | |
Grumpy Old Man.
/port 1000 /minimize /priority low /x264-opencl-device-type CPU /port 2000 /minimize /priority low /x264-opencl-device-type GPU or /port 1000 /minimize /priority low /x264-opencl-device-id 0 As for quality, it might depend on what filtering you're using. I tried some of these switches today, and I couldn't see that it enabled anything different
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 15th March 2021 at 07:44. |
15th March 2021, 07:42 | #19005 | Link |
Grumpy Old Man.
Update's
So I have spent a few hours looking around for updates to all the Tools used in RipBot, and I found quite a few, there are a lot that haven't been updated for years, and to be honest, there might be several that RipBot doesn't use anymore.
So I've incorporated them into the Tool's Folder, and modified the .ini's so that the new version/build numbers show up when you chose the Tool's tab. Removed picture, as it's now redundant, due to latest available updates
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 20th March 2021 at 09:45. |
15th March 2021, 16:32 | #19006 | Link | |
17th March 2021, 15:15 | #19008 | Link |
Just open any file which uses vp9 codec.
17th March 2021, 15:22 | #19009 | Link |
Sorry but, where is "MKV encoded" pane?
My current system is quite old. i7-4960X CPU with GTX 670 4GB. As far as I know it needs 6th. generation processor & like GTX 10xx GPU. RipBot264 Settings pane displays at right MPEG-2, VC1, AVC, HEVC and OTHER am I missing it here? Last edited by blacksapprow; 17th March 2021 at 15:43. |
17th March 2021, 18:24 | #19010 | Link |
It means that RipBot264 can decode files encoded by VP9 codec. I didn't write "Added: VP9 HARDWARE decoding"
18th March 2021, 02:01 | #19012 | Link | |
Grumpy Old Man.
You system might be a little dated, but it's better than some, I'm sure, and should be more than capable of encoding with RipBot. I have a few PC's that aren't as good as your's, and they work quite well. OK, there really isn't an "MKV encoded" pane", you choose what file type AFTER you've created a job (see pic) This :- MPEG-2, VC1, AVC, HEVC and OTHER, is ONLY where you choose what decoder you want to use, either CPU (recommended) or GPU (if you have good fast powerful video card, Intel or nVidia).
18th March 2021, 02:44 | #19013 | Link | |
Grumpy Old Man.
There are a lot of requests, and nothing gets done, because you don't see the need. The "other" free encoding app's, out there, are able to do all this, but unfortunately, RipBot is starting to fall behind.
21st March 2021, 11:32 | #19015 | Link |
@Atak,
Stumbled across some stuff, so I thought Iīd give feedback: - If filenames contain characters like "?", ripbot waits forever while preparing a job saying "waiting for file...." - Some files with variable framerates are impossible to get right with Ripbot, it seems the length (or the frame count, fps...) is misinterpreted wrong (I know, youīd need a sample - any private adress I can send it to?) - If an already encoded (or partially encoded file) is edited and only the audio section is changed, the whole file is re-encoded again, even if the video already is done and muxed in the temp-folder. - Canīt find under which conditions the "copy video" is possible or not, could you help ? - if the output folder somehow accidently points into nothingness (a non existand drive letter for example), ripbot is behaving like everything is normal, finishing without an error (but oobviously producing no output). Of course the workaround to manually call the mux-batch files etc.. is possible, so not much is lost - but maybe a small check would come in handy (or interpret the error from the muxer shown in the console). Keep up the good work, thanx for Ripbot! Last edited by ReinerSchweinlin; 21st March 2021 at 11:34. |
21st March 2021, 11:42 | #19016 | Link | |
What I like about Ripbot:
21st March 2021, 12:47 | #19018 | Link | |||||
21st March 2021, 13:20 | #19019 | Link | |
Old (DGHable) New (Tweaked by me BT2446)
21st March 2021, 14:02 | #19020 | Link | |
Grumpy Old Man.
Staxrip has a parallel encoding option, but that's just not the same Hybrid is insanely complicated. Handbrake is simple, has a plethora of video & audio encoding options, but single encoding. But a few extras would make RB, just so, so much better, and put it at the "top of the heap". I also have to say that "feauters", really confused me, but then I realised it was a typo. Oh, and just 3 or 4 new features would be plenty
