Old 7th July 2015, 22:29   #61  |  Link
chagomx
Great, I'll take a look at it. Thanks.
chagomx is offline   Reply With Quote
Old 30th July 2015, 00:23   #62  |  Link
real.finder
just add original guide in http://avisynth.nl/index.php/AnimeIVTC
will try update it as I have a time, your helps are welcome
See My Avisynth Stuff
Old 11th August 2015, 05:17   #63  |  Link
flacattack
The guide is very thorough, thank you!
I'm having trouble with a dvd source that seems to be progressive, but badly frame blended. I can't get rid of the bobbing artifacts, especially some haloing and image doubling.
http://www.mediafire.com/download/0y...gh4/as02e01.ts
Tried this, but didn't seem to fit the source.
AnimeIVTC(mode=4, aa=0,dark=0, precision=5,nnedi3pel=true,cbob=2,aapel=4,aablk=4,bbob=2,killcomb=0, bob4p="Slow",ediandnn=3,chrfix=false, cache=25,omode=2)
flacattack is offline   Reply With Quote
Old 12th August 2015, 01:29   #64  |  Link
real.finder
OMG! Is this original source?! I heard about avatar before, and see some episode on nickelodeon arabic in crt TV but never expect it will be like this in LCD PC screen!
edit: for fun I just write this http://pastebin.com/TvpRdQA8
anyway
AnimeIVTC(1,0,5, ediandnn=3, yadifrepwithtdeint=true, tfmm=0, micmatching=0, o3025cfr=true)
daa3 #or slow daa3mod or mcdaa3 if the source worth it
this look ok in most cases
and maybe with aa filters too, like maa2
halo should deal with it by halo filters
Old 14th August 2015, 05:29   #65  |  Link
flacattack
Awesome, thanks real.finder!
And indeed it is! That broadcast may have had better quality than the source DVDs, actually. The DVDs have terrible artifacts scattered throughout. I've been working on remastering the entire series since the quality is so low. Here's an example of bad debobbing in the pilot, which I have no idea what to do with, if you have any ideas.
https://www.mediafire.com/?jmfdjhlbfaqnyqi
Old 14th August 2015, 23:30   #66  |  Link
real.finder
what about
SeparateFields()
De Halo filter here
Weave()
ivtc here
Old 19th August 2015, 05:31   #67  |  Link
flacattack
Thanks for the tip! I used QTGMC instead and see better results instead of SeperateFields and Weave. But having Dehalo_alpha before AnimeIVTC helped. Still some issues with dehaloing but I can't expect too much considering the bad shape of the source!
Old 11th October 2015, 17:42   #68  |  Link
real.finder
new release in the 2nd post
Old 17th October 2015, 12:51   #69  |  Link
yesmanitsbearman
Thanks for your great work. If it's not too much trouble could you take a look at my sample and recommend the right settings, please. I tried a simple mode=2, but it still left ghosting/blending.
link
Thanks in advance.
yesmanitsbearman is offline   Reply With Quote
Old 17th October 2015, 20:02   #70  |  Link
real.finder
Originally Posted by yesmanitsbearman View Post
link
Thanks in advance.
the original FPS was 60i (at least in motions)
so there is no solution for this source, you must get the US (or at lest any NTSC) ver. for this show
Old 18th October 2015, 09:15   #71  |  Link
yesmanitsbearman
Thanks, that's too bad. Sadly this series is only released in Australia. I will just do them with a simple mode=2 I guess and live with the blends here and there.
Old 13th December 2015, 09:27   #72  |  Link
yesmanitsbearman
Was wondering if you can take a look at another sample for me please and perhaps suggest best settings. Thaks in advance
link
Old 13th December 2015, 18:43   #73  |  Link
real.finder
link
the link say:- Access to the file is restricted
Moderators, Attachments Pending Approval since 29th November
Old 13th December 2015, 19:49   #74  |  Link
yesmanitsbearman
Sorry, replaced file in original post.
Old 14th December 2015, 08:14   #75  |  Link
real.finder
tried play with it but always there some blend remains
seems it some kind of odd telecine, let see if someone else help you
Old 14th December 2015, 11:42   #76  |  Link
yesmanitsbearman
What did you find to be the best settings?
Old 16th December 2015, 10:00   #77  |  Link
real.finder
sanimebob()
srestore(omode=4, cache=10).srestore(frate=23.976)
#smam() #for more stability
Old 21st February 2016, 07:01   #78  |  Link
Elegant
sanimebob()
Wow that's actually really good... that's gotten rid of all the combing in some of my videos. Might have to look into that script on VapourSynth since QTGMC works.
Elegant is offline   Reply With Quote
Old 1st March 2016, 19:05   #79  |  Link
yesmanitsbearman
Yeah it's very good. Thanks a lot for providing it!
Edit: with smam() I get [error]: RequestLinear: internal error (frame not cached)! occurred while reading frame 95
Old 2nd March 2016, 17:24   #80  |  Link
kuchikirukia
Try cache=-1 (note the negative)
Note I'm a noob at srestore and have no idea how any setting actually affects how it works, but that's the default and it tends to stop that error.
kuchikirukia is offline   Reply With Quote
anime aa, animeivtc, chroma fix, deinterlace, mod
