14th November 2019, 13:16 | #17721 | Link |
Use nmap to check If ports 1000,2000 and so on are open.
14th November 2019, 13:23 | #17722 | Link |
Grumpy Old Man.
I will get Nmap, and do what it does, and I will get back to you.
Nevertheless, you must have changed something, in the last update !!! Update:- got Nmap, don't know what I have to do.....
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 14th November 2019 at 13:34. |
14th November 2019, 13:31 | #17723 | Link |
Well, I canīt be sure this is valid for every dual CPU configuration. I switched NUMA off because I canīt get any grafix card to run in my DL380, so I am using the CPU for OPENCL (which is slow, but in some of my cases is better than nothing). This way all of the cores are used for OPENCL Filtering, which gave quite a bosst.
I then tested Encodes without OPENCL usage and encountered the CPU Usage to bee much higher than before when using only one encodingserver. Same time some updates came from RB Update Server - so I canīt be sure whatīs exactly the cause of this right now, would have to switch back to NUMA mode and compare. Didnīt have time for that, thatīs because I was asking here, if something had changed within x265/RB (after all, maxing out more cores while encoding can be usefull for bigger multicore CPUs as well). |
14th November 2019, 13:36 | #17724 | Link | |
Grumpy Old Man.
If so, are you have DE problems ??
14th November 2019, 13:51 | #17725 | Link |
14th November 2019, 14:09 | #17726 | Link | |
Grumpy Old Man.
OK, did a simple scan on the laptop that has the latest RB on it, and here's the results... Starting Nmap 7.80 ( https://nmap.org ) at 2019-11-15 00:01 Nmap scan report for DELL-XPS-M1330.gateway (10.0.0.132) Host is up (0.00s latency). PORT STATE SERVICE 1000/tcp closed cadlock 2000/tcp closed cisco-sccp 3000/tcp closed ppp 4000/tcp closed remoteanything 5000/tcp closed upnp 6000/tcp closed X11 7000/tcp closed afs3-fileserver 8000/tcp closed http-alt Nmap done: 1 IP address (1 host up) scanned in 0.78 seconds So what does this mean ?? I will run some test on the one of my "proper" RB pc's tomorrow.
14th November 2019, 14:55 | #17727 | Link |
This is how it should look...
All your ports are closed. Check anti-virus or other anti-malware software.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 14th November 2019 at 16:35. |
14th November 2019, 17:40 | #17729 | Link | |
Grumpy Old Man.
But it still MUST be something you've changed !!!!
14th November 2019, 17:45 | #17730 | Link | |
if PaulyDunnePC=true then BlockDEmode
14th November 2019, 18:02 | #17731 | Link | |
Grumpy Old Man.
Its like beating your head against a wall, why does the previous build work, and the latest one doesn't ?? It's not just me !!!
14th November 2019, 19:40 | #17732 | Link |
MeGUI Developers Hate Me
Hi, everyone!
I just want to calmly let everyone know that my corporate antivirus found an issue in the waitforprocess.exe file that is downloaded by the updater for RipBot264. The file is hosted here: http://atak-snajpera.5v.pl/ripbot264...ForProcess.zip according to the update.ini file. This is the entry from Cisco Umbrella: o Event Type: Executed malware o Computer: <REDACTED> o Hostname: <REDACTED> o IP: <REDACTED> o Detection: W32.31A417AE41-85.LP.RET.SBX.TG o File: WaitForProcess.exe o File path: file:///<REDACTED>RipBot264v1.24.0/tools/WaitForProcess/WaitForProcess.exe o Detection SHA-256: 31a417ae412e9e64799565f00ff1efbcd665caf2b8433e63af0a9c59653eaaf7 o Application SHA-256: 3685495d051137b1c4efde22c26df0883614b6453b762fa84588da55ed2e7744 o Severity: High o Timestamp: 2019-11-14 12:26:18 +0000 UTC The SHA-256 for the application shows very little detection information. When I run the Application SHA through Virustotal's search function, it shows clean. When I run the Detection SHA (the part of the file detected as "malware"), it shows detections by CrowdStrike Falcon, Panda, Microsoft, Trapmine, and Webroot. Anyone can check this themselves by copying the SHA256 values above, logging into VirusTotal, and clicking the Search function. It looks like the detected malware might be adware-related or part of an SEO inflation scheme. It also looks like there might be a trojan that modifies windows firewall settings. I want to scan the actual file through VirusTotal, but unfortunately, the application is blocked by Cisco Umbrella. I will test my home machine once I get home, but if the SHA values match, there should be no different information. I love RipBot264 and want to continue using it. I've updated the update.ini and installed_tools.ini files in the Tools directory and the update.ini file in the Updates directory to set waitforprocess's AllowUpdate value to 0 for now. I'm not sure what the application is used for at this point. I'd be interested to know what I'm breaking by not having it around. I think what I've found is credible and I feel it would be best to get this information out there ASAP. Please let me know if this is a known issue and a false positive. Like I said to start, I'm not trying to cause a panic here and I'm a huge fan of the program. Thanks -Donholio
Intel i7-9700k in an Asus Z390i
16GB Corsair memory | 1TB nvme Nvidia Geforce RTX2070 Windows 10 Ultimate 64bit |
14th November 2019, 19:55 | #17733 | Link |
WaitForProcess.exe is just a helping tool I wrote to spawn multiple executables and aggregate percentage progresses into single percentage progress (which is then displayed in ripbot264). It is used during indexing and encoding audio. Some anti-viruses are VERY allergic to executables compressed by UPX. ( https://upx.github.io/ )
If you delete WaitForProcess.exe then indexing and audio encoding won't work. It is obvious that it is false positive detection... https://www.virustotal.com/gui/file/...aaf7/detection
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 14th November 2019 at 20:16. |
14th November 2019, 20:25 | #17734 | Link | ||
ByteShare
Does an older version work for you like Pauly? On Core 2019.11.08 and Encoding Server 1.16.0.0 I have RB working in DE mode with two different Windows 10 computers, both 1903 (one Pro and one Home) I found this funny. Last edited by byteshare; 14th November 2019 at 21:29. |
14th November 2019, 21:37 | #17735 | Link | |
Grumpy Old Man.
Why can't he just say that's he's changed something... Just a sick IT sense of humour...it wouldn't have worked, anyway..
14th November 2019, 21:49 | #17736 | Link |
My last attempt to help you. Create virtual machine and then install fresh win10 1909. See If you can connect to servers within virtual machine. Virtual win10 also works on my pc. If still nothing then i give up.
14th November 2019, 21:52 | #17737 | Link | |
ByteShare
RB is working on 4 Win10 machines for me right now after testing the newest version. I have Windows Fire Wall on, but with exceptions for RB and Windows Defender exceptions for RB. |
15th November 2019, 05:24 | #17739 | Link | |
Grumpy Old Man.
Not interested in VM nonsense, I just installed W10 1909 on another pc, left it all default, vanilla settings, installed what RB needs to work, it ask to do the exceptions it needed, loaded a new job, and exactly the same non starting, non connecting behaviour. So I need some one to tell me exactly what they did, to get this latest build working in DE !! I still don't understand why a working app, stops working after an update, and the creator of that update can't or won't tell us what he's done, or how to fix it. I'll ask you again, did you view that screen capture I posted ??? That's what happens, just a lot of little boxes & icons flashing, not doing ANYTHING, no info in the TCP window..it's just dead !!! So for now, I will just have to run with the previous working build, and turn off auto updates.
15th November 2019, 05:50 | #17740 | Link |
i noticed that with the latest update, "gathering information" is once again taking a lonnnnng time. except this time, regardless of choosing Lmash, FFmp2 or GPU makes it any faster. i noticed the update log says the script was updated. just exactly what changed made Gathering Information so much slower now.
i also noticed that it takes forever for the encode to begin now. from the time i click "start", to seeing all the cores loaded, it takes like 2 mins. before it used to be instant. |
