Old 29th March 2019, 08:25   #16841  |  Link
byteshare
ByteShare
byteshare's Avatar
Originally Posted by Arbelisk View Post
Hey. Anyone have a problem with using DE after updating to 1.24.1? I was using 1.23 and it was working fine. Now after updating, the host computer will not connect to itself but will connect to the remote computer just fine. Any ideas? Thanks.
No problems here.
Do you have a VPN or more than one network connection?
What are you seeing if you do a CMD > ipconfig?
Old 29th March 2019, 23:43   #16842  |  Link
Arbelisk
No problems here.
No, not anymore. I actually found out that the encoding server was not running. It was being blocked by other programs in the wait chain. Very odd. I ended the program it was waiting on and it worked. But I have to do that every time I use RipBot now.
Arbelisk is offline   Reply With Quote
Old 30th March 2019, 12:19   #16843  |  Link
https://forum.doom9.org/showthread.p...06#post1862506
Old 1st April 2019, 09:42   #16844  |  Link
duffbeer
I need some advice! My current PC is now 7 years old and in need of an upgrade. I'm trying to decide between 2700x/9700k/9900k and I have read a few threads regarding lower x264 image quality when using too many threads.
Does this mean I should avoid the 9900k and stick with the 9700k or have I misunderstood?
duffbeer is offline   Reply With Quote
Old 1st April 2019, 10:09   #16845  |  Link
Pino72
That's nonsense, quality of x264/x265 encodings does not change with the type of CPU you are using (not even if AMD or Intel). The faster the CPU the faster your encodings will be at the same quality. Threads do not impact quality in any way just speed.
Pino72 is offline   Reply With Quote
Old 1st April 2019, 12:30   #16846  |  Link
Uhm, well ... many threads do limit the scope in some kinds of parallelism, too many threads may indeed limit the quality. But depending on several factors (frame dimensions, bitrate per frame pixels, preset ~ encoding efforts), the loss will probably be negligible.
Old 1st April 2019, 13:26   #16847  |  Link
I think x264 has hard thread limit at 24 in order to avoid any possible quality degradation.
Ryzen 3xxx is around the corner (~3 months)! 12C Ryzen will destroy 9900k in x264 and x265 for the same price!
Old 1st April 2019, 14:17   #16848  |  Link
duffbeer
This is what concerns me. Maybe I should go for 2700x and look to drop in a Ryzen 3xxx CPU next year for an easy upgrade. The only thing that puts me off that plan is 2700x seems to be a fair bit behind 9900k in x265 benchmarks.
Old 1st April 2019, 15:17   #16849  |  Link
That's why I recommend to wait for Zen2 with improved AVX2 performance. New Ryzen (8c/16t) will be on par with intel 9900k in x265. While 12C/24T variant will be proportionally faster. I predict that 12C will have similar price to 9900k.
Old 1st April 2019, 15:36   #16850  |  Link
duffbeer
Thanks for the advice. I guess you're right - I should probably wait.
One other question about x265. I have just recently started to try some x265 encodes but the output did not look that good compared to my x264 encodes.
Most of my x264 encoding is done at CRF18 "Very Slow" with "Film" tune. I realise that you cannot compare x264 settings to x265 but what is the closest equivalent x265 settings?
Old 1st April 2019, 19:12   #16851  |  Link
Ryushin
Ryushin's Avatar
I switched everything to x265 last fall. I did CRF18 for x264 with similar settings as you. I'm still using CRF18 for x265 and always doing 10 bit regardless of it being a 8 or 10 bit source. I'm not doing any special tuning settings, just using x265 progressive with just adding the --par 1:1. I've not noticed a single case where the x265 looks worse then the x264. It either looks the same or better. File size is usually 25-50% smaller then the x264 source. Supposedly, x265 CRF20 is equivalent to CRG18 x264.
Atak lives and breaths this stuff, so he might have better insight.
Old 2nd April 2019, 02:42   #16852  |  Link
Ryushin
Ryushin's Avatar
VC-1 Sources
Atak, any idea on a solution to VC-1 sources? Just pulled in Jurassic Park 1-3 to redo them in x265 and it seems they are all VC-1. I'm thinking I might just go back to doing lossless x264 for the time being.
I downloaded ffms2 2.23.1 but it seems that dll was built in December. Maybe it would be best if I just open an issue on github to see if they can duplicate the problem and fix it.
Old 2nd April 2019, 08:57   #16853  |  Link
duffbeer
Is there a problem with VC-1 sources? I hope not as I have encoded quite a few recently. The encoded files looked OK but I haven't watched them all the way through yet.
Never had a problem with VC-1 in the past.
Old 3rd April 2019, 01:13   #16854  |  Link
Ryushin
Ryushin's Avatar
If you are using DE, then you will need to look where the chunks split. For me, a lot seems to be around the 4:00 minute mark. I had decoding issues before with VC-1 before the new update. Decoding issues are gone, but it is not frame accurate for some sources it seems. Blade Runner turned out fine, but four other sources now have not.
Old 5th April 2019, 15:00   #16855  |  Link
Ryushin
Ryushin's Avatar
Nothing like having a 250GB lossless file to do an encoding. Plus I have to modify the avs file for this. I think I may just try to do any vc-1 sources on a non DE machine and see how that works out.
Old 5th April 2019, 16:57   #16856  |  Link
byteshare
ByteShare
byteshare's Avatar
Would it be faster/smaller/easier to just encode to 264x CRF1 very fast preset in another application that doesn't have issues with VC-1?
Old 5th April 2019, 18:01   #16857  |  Link
If I were you I would encode to AVC-INTRA with CRF10 instead of lossless.
Reasons:
1) Much smaller filer size
2) Much faster encoding
3) Still visually "lossless"
You really do not need perfect 1:1 copy if you are going to compress later even further with some more aggressive bitrate/CRF.
Old 7th April 2019, 13:30   #16858  |  Link
Ryushin
Ryushin's Avatar
Well, VC-1 sources using a non DE came out fine. They decoded correctly and I don't see any kind of corruption. I will just have to do this until a ffms2 comes out that decodes correctly along with being frame accurate.
Atak, not sure how you want to deal with this in your code. Maybe have a popup when detecting a VC-1 source that using DE will cause corruption.
Old 8th April 2019, 16:42   #16859  |  Link
byteshare
ByteShare
byteshare's Avatar
KNLMeansCL OpenCL
TLDR: Install official drivers even if the Windows ones work
I have a Nvidia GTX 980.
I couldn't seem to get it listed in the settings as a device for "x264 OpenCL acceleration" or KNLMeansCL"
Guessing it is a drive/OpenCL issue.
I checked out this: https://streamhpc.com/blog/2015-03-1...cl-on-windows/
But under the link for Nvidia: https://www.nvidia.com/Download/index.aspx#
I don't see an option for OpenCL support.
I found this page: https://developer.nvidia.com/opencl
Which says the OpenCL is included in GPU drivers.
I re-downloaded the drivers for my card and installed them and then I could see my device as an option in RipBot.
Old 8th April 2019, 19:06   #16860  |  Link
If this happens at 4:00 mark then maybe you could cut out first 5 minutes from source video and send it to me?
