4th May 2010, 23:06 | #8081 | Link | |
You can also add SECONDARY_USE_QUALITY=1. That will lower the size of the output -- but make the encoding slower. 2. I'll have to test that disc to see if I can repeat the audio sync problem But it has been a long time since I've seen any reports of sync problems (other than one report related to secondary audio). 3. You need to remove those files after the rip and before the encode with BD-RB. I personally only copy the BDMV and CERTIFICATE folders to hard drive when I'm backing up a disc. As for the disc with two versions on it... a future version of BD-RB will have the ability to blank video, but that's a way down the road. Last edited by jdobbs; 4th May 2010 at 23:10. |
5th May 2010, 00:20 | #8083 | Link |
jdobbs, thanks for the fast reply. Sorry to have to ask twice but I felt like I was getting buried.
One other suggestion, would it be possible to change the Shutdown after REBUILD to something else like sleep or create options in the setup that'll tell it what to do? I like to sometimes login remotely to my computer and can't turn it on if it's shutdown. Thank you again for all you great work! |
5th May 2010, 03:58 | #8084 | Link | |
I'm gonna go buy a BD-RE Sony. I am tired of making BD-R coasters. What did you rip these titles with, DVDFAB or ANYDVD? Mine did not work with the old firmware or the new firmware. |
5th May 2010, 10:31 | #8085 | Link |
Still a PS3 problem?
Running PS3 slim FW 3.30 since two weeks without BD-RB backups reading difficulties (Last one was Avatar).
These last days, PS3 reading persists with error "invalid disk" with an Apollo13 backup... I tried all what I could imagine without success... BD-RB does'nt seems to see any difficulty with this backup - My computer config seems OK... Any idea or advice welcome... |
5th May 2010, 13:23 | #8086 | Link |
Hi jdobbs, just to say I finished testing all the possibilities to make work multi-m2ts movies with stuttering free but I had absolutely no success. A guy said it was the way TSMUXER demux/remux files that is not really compliant. He posted something to deal with these kind of BD in remuxing one of the mpls to have a one m2ts joined version, unfortunately it's more a workaround than a solution and can't be processed automatically (http://forum.doom9.org/showthread.php?t=150511). I heard you about your clpi interest and you are maybe right. I couldn't test the ATC values as nothing allow to edit it. So now I think only you or Pelican can go further about this. And I'm agree with Capsbackup about TSMUXER. Without saying it's a fantastic tool, I think this is just a good beginning and for many things it had to be improved. If you need help, someone to test things, I'm here.
5th May 2010, 14:50 | #8087 | Link | |
Sorry. I have nothing against the PS3 -- but it obviously is not a BD player. |
5th May 2010, 14:54 | #8088 | Link | |
I'll probably have a fix in the next release. TSMUXER isn't creating a non-compliant stream -- it just doesn't know there is seamless branching involved so there isn't any timing adjustments and links added to the CLPI. I highly recommend that no one try to merge the files together as a solution. That's just silly and will cause more problems than it solves. Patience is a virtue. Last edited by jdobbs; 5th May 2010 at 15:01. |
5th May 2010, 15:32 | #8089 | Link |
Programmer (or just 教务长)
When tsMuxeR creates playlists with seamlessly connected m2ts, the clpi files are properly generated, so it is not a bug in tsMuxeR. (edit: Well I must I've looked at something else - camcoder files - tsMuxeR clpi generated files do not contain the ATC for seamless connection).
Once you add the delta entries it will probably be okay. I guess that since all individually encoded m2ts files start with nal/aud and IDR frames, most players manage to quickly continue the playback without noticeable glitch or stutter - especially when using software players or BD players with lower access times to the physical media. An important thing to mention is that the physical layout of 2 or more seamlessly connected clips (m2ts files) it also important. The maximum read-access time allowed for repositioning between the end of one and the start of the next is 706ms for single layer and 710ms for dual layer discs. If by any chance the burning application (like ImgBurn) decides to put these clips far apart, the access time from one to another may exceed the max allowed and cause a slight stutter, too. A simple example would be seamlessly connected AV clips 00001.m2ts 00603.m2ts 00311.m2ts 00000.m2ts. Their physical order on the media (BD-R disc) will most probably be SORTED, thus causing longer access times when doing the connection. Even with the correct delta entries the stutter may occur if the connected clips are not properly written to / positioned in the physical layer of the disc. If ImgBurn respects the order when project file is parsed to it, a simple test solution would be to parse CERTIFICATE and BDMV folders with their subfolders (except the BDMV\STREAM folder) and then add the m2ts files in respect to their usage in the main movie playlist and then add the rest of the m2ts files (those for extras, menus, etc). Dean Last edited by deank; 5th May 2010 at 16:59. |
5th May 2010, 17:07 | #8090 | Link |
jdobbs :My BD are in standby mode! I told you some other guys have the issue with their hardware players. Maybe players as I would say Powerdvd deal better to manage this, but if it's to well manage despite missing datas... When you say you can't repeat it on your systems, did you just tried to install TMT3 and test your backups with it? I don't know what you mean by 'I'll have to "farm out" the debugging (I'm looking for volunteers)', but if I can help...
deank : Interesting minds. These kind of files/playback management that cause issues are so obvious and could come from so many places. Unfortunately, from 3 frames freeze, everybody can see it! |
5th May 2010, 17:33 | #8091 | Link | |
By "farm out" -- I mean I'll have to ask someone who actually experiences the issue to test it for me before I release it. Since the software is "beta" I should be able to do it anyway -- but a lot of people are using as if it is a final product no matter what I say (as can be seen by some of the post referencing "coasters" or "wasted time") -- so I have to be careful with releases that change formats considerably so I don't get inundated with comments. Last edited by jdobbs; 5th May 2010 at 17:37. |
5th May 2010, 17:46 | #8092 | Link |
What deank and SoniG are trying to say is to use eac3to as a demuxer, because tsMuxer has a bug when it comes to joining m2ts files from branched titles. It freezes on standalone players at the joining point. It continues, but it stutters where tsmuxer joins them. But if you demux with eac3to and recompile with tsmuxer it is ok. Tested.
5th May 2010, 17:54 | #8094 | Link |
They can't, but demuxing with eac3to by eac3to.exe -demux movie.mpls would result a h264 stream that will not stutter in standalone players. For keeping the branched structure, you have to edit every single mpls by hand.
5th May 2010, 17:56 | #8095 | Link | |
@crl2007: It's inaccurate to call it a bug in TSMUXER... it was never designed to create seamless branched titles. That's like saying a hammer has a bug because it doesn't saw wood very well. By the way, there also isn't a bug in the way it demuxes seamless titles -- you just have to know how to use it correctly, and most people don't. I know how the CLPI is supposed to be built, and I'll rebuild it for seamless branched & multiangled titles. Now whether that will get around any seek/latency issues based on physical location of M2TS files on the disc remains to be seen. I'm optimistic, though, especially since the majority of standalone players don't even show issues with no ATC_Delta at all... Last edited by jdobbs; 5th May 2010 at 18:03. |
5th May 2010, 18:17 | #8096 | Link |
Yes, standalone players don't show issues if ATC Delta entries aren't present.
I've done 3 tests: 1. Only tsMuxer and in standalone stuttered at join point. 2. demuxed elementary streams with eac3to and feed them to tsmuxer, worked like a charm in standalone. ( no ATC in clpi ) 3. Used ClownBD ( eac3to + tsmuxer ) and the resulted BD disc played with no stutters in standalone player. ( no ATC in clpi ) BD-RB is not a tool for re-authoring, it just does for BD's what DVD Rebuilder does for DVD's. But I tell you, those ATC entries aren't the stutter cause. |
5th May 2010, 18:42 | #8099 | Link | |
You're also making some apples to oranges comparisons that don't apply at all. What in the world does your ClownBD movie-only output have to do with this issue even in the slightest????? Hell, BD-RB's movie-only output doesn't have the issue either. Last edited by jdobbs; 5th May 2010 at 18:54. |
5th May 2010, 18:45 | #8100 | Link | ||
A quote from the first post of this thread: Quote:
