Old 10th October 2017, 18:04   #3661  |  Link
Reel.Deel
@davidhorman
See here for more info. http://avisynth.nl/index.php/Avisynthplus/Developers
There's a few post in this thread with a bit more info, unfortunately I'm away from my home computer ATM.
Reel.Deel is offline
Old 10th October 2017, 18:39   #3662  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
I've read that, but I'm still none-the-wiser as to what actually happens. I am 99% sure my current filter can never be MT-friendly, at least...
wonkey_monkey is offline
Old 10th October 2017, 22:56   #3663  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Originally Posted by davidhorman View Post
I'm guessing that MT_NICE_FILTER requests multiple frames in multiple threads, but only one instance of the filter, and that MT_MULTI_INSTANCE makes multiple instances, so it's a bit like calling the same plugin multiple times on trimmed/selecteveryed subclips and then joining or interleaving them? Or does it crop frames up into smaller frames then stack them back together, or something? (probably not) And that MT_SERIALIZED is the same as plain old single-threaded AviSynth?
Yes, if you're using Prefetch(8), MT_NICE_FILTER has 1 instance and 8 threads calling that one instance. That means the code must be thread-safe and you can't have class-level writable variables and buffers. Any work buffer must be initiated and destroyed within each GetFrame call.
MT_MULTI_INSTANCE creates 8 instances, and I'm not sure the thread creating the class is always the same as the thread calling GetFrame, in fact I think it can be any thread but always only 1 call at once.
MT_SERIALIZED, it will have 1 instance and only 1 call at once. However, there is currently a bug in the latest AVS+ where it can actually receive 2 calls at once in certain cases. Pinterf is working on fixing that, but for now, MT_SERIALIZED is broken.
MysteryX is offline
Old 11th October 2017, 13:13   #3664  |  Link
wonkey_monkey
Which is the only one my filter can work under. Oh well! It's working for now on whatever version of AVS+ I'm using.
Old 11th October 2017, 14:29   #3665  |  Link
pinterf
It's not broken, fixed since r2502
20170602 r2502
  - fix: (Important!) MT_SERIALIZED mode did not always protect filters (regression since r2069)
    Such filters sometimes were called in a reentrant way (like being MT_NICE_FILTER), which
    possibly resulted in using their internal buffers parallel.
pinterf is offline
Old 11th October 2017, 14:42   #3666  |  Link
pinterf
Originally Posted by raffriff42 View Post
It does look like a bug. The problem seems to be in ConvertTo8bit; its output is aprox. 1 step darker after each pass, probably a rounding issue.
While YUV 8<->16 conversion is a simple bit-shift, RGB conversion is full-scale, e.g. 8->16 bit conversion is something like x*65535/255. 255 becomes 65535. Similarly for 16->8 bits the formula is x*255/65535. Anyway, I'll check it (Sorry, I still have limited time for a couple of weeks).
Remark: do not worry about rounding errors in 8 bit conversions and in 8 bit filters in general. Most of the 8 bit functions work internally with 13-15 bits precision (like in classic Avisynth)
pinterf is offline
Old 11th October 2017, 18:09   #3667  |  Link
bxyhxyh
Is it bit-shifting or that (something like x*65535/255) arithmetic formula?
Bit shifting wouldn't work correct since 255 bit-shifted is not 65535.
But in avisynth they are equal white.
I'm pretty sure you know it, just pointing to it.
bxyhxyh is offline
Old 11th October 2017, 18:48   #3668  |  Link
wonkey_monkey
You can bitshift, and then OR in the original bits as well. It would be equivalent to the arithmetic formula (since 65535/255 = 257).
(x << 8) | x
Where does the convention that only a bitshift is used for YUV come from?
Old 12th October 2017, 11:39   #3669  |  Link
TheFluff
Excessively jovial fellow
Can someone give me a dumbed-down summary of the different MT modes? I've read this:
http://avisynth.nl/index.php/AviSynt...orrect_MT_mode
But it's not very clear to me. It doesn't really state how the modes work, and especially the bit for MT_NICE_FILTER isn't clear at all on when it should be used, instead focusing on when it shouldn't.
I wrote this a while ago. May or may not help.
The tl;dr is that as a rule of thumb:
  • if your filter's GetFrame is threadsafe (basically, does not attempt to write to any memory that is not explicitly associated with this specific frame request) => MT_NICE_FILTER
  • if your GetFrame does depend on shared state of some kind, but your filter supports things like interleave(yourfilter().selecteven(), yourfilter().selectodd()) in vanilla Avisynth => MT_MULTI_INSTANCE
  • if you are a source filter, or rely on frame request order (i.e. stuff with side effects outside Avisynth such as writing to a file), or rely on internal state that changes with every frame request (i.e. pattern-tracking decimation filters) => MT_SERIALIZED
It also may or may not be relevant to note that all GetFrame calls that need to happen to produce a given output frame at the end of the script happen in the same single thread, regardless of what MT modes are in use. You probably shouldn't rely on this for anything, though.
TheFluff is offline
Old 12th October 2017, 14:20   #3670  |  Link
wonkey_monkey
Thanks TheFluff - that helps. I'm certain my filter will never be able to be MT'd. It's internally multi-threaded though.
Old 18th October 2017, 15:37   #3671  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Is the avs+ api stable now? I really don't want to waste time adding compatibility for it if I'm going to have to change things later.
Myrsloik is offline
Old 18th October 2017, 15:54   #3672  |  Link
pinterf
I'm not planning to change it.
pinterf is offline
Old 18th October 2017, 16:11   #3673  |  Link
real.finder
what about add support for vs api in avs+ to load vs plugins (dll) in avs+?
We discussed this in irc years ago and Myrsloik said it's possible
See My Avisynth Stuff
real.finder is offline
Old 18th October 2017, 16:13   #3674  |  Link
pinterf
Short developer news, I hope I'll have less busy months from now (finished a marathon with 2:55, this year I was preparing on this race instead of coding)
- "Levels" now allows 32 bit float inputs
- today I have successfully ported Expr filter from the VapourSynth project, with some additions (masktools syntax of built-in constants and some of the scaling helper functions).
pinterf is offline
Old 18th October 2017, 16:18   #3675  |  Link
pinterf
If he says it's possible then it's the question of someone's time isn't it? Not planning in the near future either, to tell the truth I cannot imagine the magnitude of the effort at the moment.
pinterf is offline
Old 19th October 2017, 11:07   #3676  |  Link
real.finder
good news
Expr will be part of internal avs+ functions?
Old 19th October 2017, 11:31   #3677  |  Link
pinterf
good news
Yes, it was more convenient and faster for me than putting it in a separate dll (masktools).
pinterf is offline
Old 19th October 2017, 20:00   #3678  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
and Expr really has nothing to do with masks, it's more of a core feature
MysteryX is offline
Old 21st October 2017, 16:59   #3679  |  Link
Myrsloik
Myrsloik's Avatar
What's the proper way to detect if a plugin is compiled for the avs 2.6 or avs+ api? By whether or not it calls SetFilterMTMode() on init? Is there some other way? I want to make sure 2.6 plugins don't get exposed to avs+ only formats.
And speaking of formats... are only formats with a pre-combined constant allowed or can I have some 16bit yuv with insanely high subsampling?
Btw, do any filters have meaningful planar YUVA or RGBA support or can I skip implementing it properly for now?
Oh, and is the threadpool and jobcompletion stuff actually documented somewhere?
Myrsloik is offline
Old 21st October 2017, 19:17   #3680  |  Link
ChaosKing
Maybe AVSMeter (src included) can help you for the detection part: https://forum.doom9.org/showthread.php?t=174797
ChaosKing is online now
