#31322 | Link | |
![]() Join Date: Oct 2001
It should work with BD-Rebuilder too. I'll have to do a test and see. Last edited by jdobbs; 11th November 2022 at 21:52. |
#31323 | Link |
Hello, id like to report a bug with dolby vision, ive done quite a few uhd discs with bd-rb without problems but every now & again i run into a black screen issue with dolby vision.
two discs that give me a black screen are: star trek 4 - the voyage home flash gordon both discs encode & rebuild fine but both have the message "bitstream exception adjusting success" & when i playback in a uhd player i get a black screen with dolby vision enabled (plays fine in hdr10). if i then demux bd-rb output the dolby vision stream is track_4114 instead of the usual track_4117 i think the bitstream exception success is forcing the wrong PID_ID on the dolby vision stream hence the black screen (audio is playing but blank screen) just as a test i ran these discs through dvdfab & the result plays fine in dolby vision below is the log for flash gordon & the settings i use for uhd encodes Thanks Last edited by yamyam; 16th October 2022 at 21:25. |
#31324 | Link |
- [16:46:11] Video Encode complete - [16:46:11] Processing audio tracks - [16:46:11] Multiplexing M2TS - [16:46:15] Processing: VID_00040 (31 of 57) - [16:46:15] Extracting A/V streams [VID_00040] - [16:46:18] Reencoding video [VID_00040] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 25 frames - Bitrate: 10,000 Kbs - [16:46:18] Reencoding: VID_00040, Pass 1 of 1 - [16:46:20] Video Encode complete - [16:46:20] Processing audio tracks - [16:46:20] Multiplexing M2TS - [16:46:24] Processing: VID_00041 (32 of 57) - [16:46:24] Extracting A/V streams [VID_00041] - [16:46:27] Reencoding video [VID_00041] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 25 frames - Bitrate: 10,000 Kbs - [16:46:27] Reencoding: VID_00041, Pass 1 of 1 - [16:46:29] Video Encode complete - [16:46:29] Processing audio tracks - [16:46:29] Multiplexing M2TS - [16:46:32] Processing: VID_00042 (33 of 57) - [16:46:32] Extracting A/V streams [VID_00042] - [16:46:36] Reencoding video [VID_00042] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 25 frames - Bitrate: 10,000 Kbs - [16:46:36] Reencoding: VID_00042, Pass 1 of 1 - [16:46:37] Video Encode complete - [16:46:37] Processing audio tracks - [16:46:37] Multiplexing M2TS - [16:46:41] Processing: VID_00043 (34 of 57) - [16:46:41] Extracting A/V streams [VID_00043] - [16:46:45] Reencoding video [VID_00043] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 25 frames - Bitrate: 10,000 Kbs - [16:46:45] Reencoding: VID_00043, Pass 1 of 1 - [16:46:46] Video Encode complete - [16:46:46] Processing audio tracks - [16:46:46] Multiplexing M2TS - [16:46:50] Processing: VID_00044 (35 of 57) - [16:46:50] Extracting A/V streams [VID_00044] - [16:46:54] Reencoding video [VID_00044] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 24 frames - Bitrate: 10,000 Kbs - [16:46:54] Reencoding: VID_00044, Pass 1 of 1 - [16:46:55] Video Encode complete - [16:46:55] Processing audio tracks - [16:46:55] Multiplexing M2TS - [16:46:59] Processing: VID_00045 (36 of 57) - [16:46:59] Extracting A/V streams [VID_00045] - [16:47:02] Reencoding video [VID_00045] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 24 frames - Bitrate: 10,000 Kbs - [16:47:02] Reencoding: VID_00045, Pass 1 of 1 - [16:47:04] Video Encode complete - [16:47:04] Processing audio tracks - [16:47:04] Multiplexing M2TS - [16:47:07] Processing: VID_00046 (37 of 57) - [16:47:07] Extracting A/V streams [VID_00046] - [16:47:11] Reencoding video [VID_00046] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 24 frames - Bitrate: 10,000 Kbs - [16:47:11] Reencoding: VID_00046, Pass 1 of 1 - [16:47:12] Video Encode complete - [16:47:12] Processing audio tracks - [16:47:12] Multiplexing M2TS - [16:47:16] Processing: VID_00047 (38 of 57) - [16:47:16] Extracting A/V streams [VID_00047] - [16:47:20] Reencoding video [VID_00047] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 24 frames - Bitrate: 10,000 Kbs - [16:47:20] Reencoding: VID_00047, Pass 1 of 1 - [16:47:21] Video Encode complete - [16:47:21] Processing audio tracks - [16:47:21] Multiplexing M2TS - [16:47:25] Processing: VID_00048 (39 of 57) - [16:47:25] Extracting A/V streams [VID_00048] - [16:47:28] Reencoding video [VID_00048] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 24 frames - Bitrate: 10,000 Kbs - [16:47:28] Reencoding: VID_00048, Pass 1 of 1 - [16:47:30] Video Encode complete - [16:47:30] Processing audio tracks - [16:47:30] Multiplexing M2TS - [16:47:33] Processing: VID_00049 (40 of 57) - [16:47:33] Extracting A/V streams [VID_00049] - [16:47:37] Reencoding video [VID_00049] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 24 frames - Bitrate: 10,000 Kbs - [16:47:37] Reencoding: VID_00049, Pass 1 of 1 - [16:47:38] Video Encode complete - [16:47:38] Processing audio tracks - [16:47:38] Multiplexing M2TS - [16:47:42] Processing: VID_00050 (41 of 57) - [16:47:42] Extracting A/V streams [VID_00050] - [16:47:46] Reencoding video [VID_00050] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 24 frames - Bitrate: 10,000 Kbs - [16:47:46] Reencoding: VID_00050, Pass 1 of 1 - [16:47:47] Video Encode complete - [16:47:47] Processing audio tracks - [16:47:47] Multiplexing M2TS - [16:47:51] Processing: VID_00051 (42 of 57) - [16:47:51] Extracting A/V streams [VID_00051] - [16:47:54] Reencoding video [VID_00051] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 24 frames - Bitrate: 10,000 Kbs - [16:47:54] Reencoding: VID_00051, Pass 1 of 1 - [16:47:56] Video Encode complete - [16:47:56] Processing audio tracks - [16:47:56] Multiplexing M2TS - [16:47:59] Processing: VID_00052 (43 of 57) - [16:47:59] Extracting A/V streams [VID_00052] - [16:48:03] Reencoding video [VID_00052] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 24 frames - Bitrate: 10,000 Kbs - [16:48:03] Reencoding: VID_00052, Pass 1 of 1 - [16:48:04] Video Encode complete - [16:48:04] Processing audio tracks - [16:48:04] Multiplexing M2TS - [16:48:08] Processing: VID_00053 (44 of 57) - [16:48:08] Extracting A/V streams [VID_00053] - [16:48:12] Reencoding video [VID_00053] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 24 frames - Bitrate: 10,000 Kbs - [16:48:12] Reencoding: VID_00053, Pass 1 of 1 - [16:48:13] Video Encode complete - [16:48:13] Processing audio tracks - [16:48:13] Multiplexing M2TS - [16:48:17] Processing: VID_00054 (45 of 57) - [16:48:17] Extracting A/V streams [VID_00054] - [16:48:20] Reencoding video [VID_00054] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 24 frames - Bitrate: 10,000 Kbs - [16:48:20] Reencoding: VID_00054, Pass 1 of 1 - [16:48:22] Video Encode complete - [16:48:22] Processing audio tracks - [16:48:22] Multiplexing M2TS - [16:48:25] Processing: VID_00055 (46 of 57) - [16:48:25] Extracting A/V streams [VID_00055] - [16:48:29] Reencoding video [VID_00055] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 24 frames - Bitrate: 10,000 Kbs - [16:48:29] Reencoding: VID_00055, Pass 1 of 1 - [16:48:30] Video Encode complete - [16:48:30] Processing audio tracks - [16:48:30] Multiplexing M2TS - [16:48:34] Processing: VID_00056 (47 of 57) - [16:48:34] Extracting A/V streams [VID_00056] - [16:48:38] Reencoding video [VID_00056] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 24 frames - Bitrate: 10,000 Kbs - [16:48:38] Reencoding: VID_00056, Pass 1 of 1 - [16:48:39] Video Encode complete - [16:48:39] Processing audio tracks - [16:48:39] Multiplexing M2TS - [16:48:43] Processing: VID_00057 (48 of 57) - [16:48:43] Extracting A/V streams [VID_00057] - [16:48:46] Reencoding video [VID_00057] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 24 frames - Bitrate: 10,000 Kbs - [16:48:46] Reencoding: VID_00057, Pass 1 of 1 - [16:48:48] Video Encode complete - [16:48:48] Processing audio tracks - [16:48:48] Multiplexing M2TS - [16:48:51] Processing: VID_00058 (49 of 57) - [16:48:51] Extracting A/V streams [VID_00058] - [16:48:55] Reencoding video [VID_00058] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 24 frames - Bitrate: 10,000 Kbs - [16:48:55] Reencoding: VID_00058, Pass 1 of 1 - [16:48:56] Video Encode complete - [16:48:56] Processing audio tracks - [16:48:56] Multiplexing M2TS - [16:49:00] Processing: VID_00059 (50 of 57) - [16:49:00] Extracting A/V streams [VID_00059] - [16:49:04] Reencoding video [VID_00059] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 24 frames - Bitrate: 10,000 Kbs - [16:49:04] Reencoding: VID_00059, Pass 1 of 1 - [16:49:05] Video Encode complete - [16:49:05] Processing audio tracks - [16:49:05] Multiplexing M2TS - [16:49:09] Processing: VID_00060 (51 of 57) - [16:49:09] Extracting A/V streams [VID_00060] - [16:49:12] Reencoding video [VID_00060] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 24 frames - Bitrate: 10,000 Kbs - [16:49:12] Reencoding: VID_00060, Pass 1 of 1 - [16:49:14] Video Encode complete - [16:49:14] Processing audio tracks - [16:49:14] Multiplexing M2TS - [16:49:17] Processing: VID_00061 (52 of 57) - [16:49:17] Extracting A/V streams [VID_00061] - [16:49:21] Reencoding video [VID_00061] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 24 frames - Bitrate: 10,000 Kbs - [16:49:21] Reencoding: VID_00061, Pass 1 of 1 - [16:49:22] Video Encode complete - [16:49:22] Processing audio tracks - [16:49:22] Multiplexing M2TS - [16:49:26] Processing: VID_00062 (53 of 57) - [16:49:26] Extracting A/V streams [VID_00062] - [16:49:30] Reencoding video [VID_00062] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 24 frames - Bitrate: 10,000 Kbs - [16:49:30] Reencoding: VID_00062, Pass 1 of 1 - [16:49:31] Video Encode complete - [16:49:31] Processing audio tracks - [16:49:31] Multiplexing M2TS - [16:49:35] Processing: VID_01000 (54 of 57) - [16:49:35] Extracting A/V streams [VID_01000] - [16:53:05] Reencoding video [VID_01000] - Source Video: HEVC, 3840x2160 - Rate/Length: 24.000fps, 160,554 frames - Bitrate: 10,000 Kbs - [16:53:05] Reencoding: VID_01000, Pass 1 of 1 - [18:56:51] Video Encode complete - [18:56:51] Processing audio tracks - Track 4352 (eng): Keeping original audio - [18:56:51] Multiplexing M2TS - TSMUXER ERR: 0xFFFFFFFD - Bitstream exception. Adjusting... success. - [18:57:39] Processing: VID_02000 (55 of 57) - [18:57:39] Extracting A/V streams [VID_02000] - [18:57:58] Reencoding video [VID_02000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 40,089 frames - Bitrate: 10,000 Kbs - [18:57:58] Reencoding: VID_02000, Pass 1 of 1 - [18:59:43] Video Encode complete - [18:59:43] Processing audio tracks - Track 4352 (eng): Keeping original audio - [18:59:43] Multiplexing M2TS - [19:00:04] Processing: VID_02001 (56 of 57) - [19:00:04] Extracting A/V streams [VID_02001] - [19:00:24] Reencoding video [VID_02001] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 20,814 frames - Bitrate: 10,000 Kbs - [19:00:24] Reencoding: VID_02001, Pass 1 of 1 - [19:01:32] Video Encode complete - [19:01:32] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:01:32] Multiplexing M2TS - [19:01:38] Processing: VID_02002 (57 of 57) - [19:01:38] Extracting A/V streams [VID_02002] - [19:01:55] Reencoding video [VID_02002] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 2,871 frames - Bitrate: 10,000 Kbs - [19:01:55] Reencoding: VID_02002, Pass 1 of 1 - [19:02:04] Video Encode complete - [19:02:04] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:02:04] Multiplexing M2TS [19:02:11]PHASE ONE complete [19:02:11]PHASE TWO - Rebuild Started - [19:02:11] Rebuilding BD file Structure [19:02:11] - Encode and Rebuild complete [19:02:11] JOB: FLASH_GORDON finished. |
#31325 | Link |
[Options] VERSION=0.61.0.28 REENCODE_MENUS=1 IMPORT_THRESHOLD=1 MIN_PLAYLIST_MINS=0 MIN_M2TS_SIZE=0 KEEP_HD_LPCM=0 FORCE_ENCODE=0 FORCE_NOENCODE=0 ENABLE_TEST=1 ENABLE_BLANKING=0 BLANK_THRESHOLD=350 FIXED_BITRATE=10000 ENCODER=0 MODE=0 ENCODE_QUALITY=5 ONEPASS_ENCODING=2 AUTO_QUALITY=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AUDIO_DRC=0 DECODER=0 AVCHD=0 REMOVE_WORKFILES=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=1 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=1 FRIMSOURCE=0 COMPLETION_BEEP=1 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 PGSTOSRT=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=99999 TARGET_SIZE=23500 PRIORITY_CLASS=0 MENU_BACKGROUND=D:\BD-RBV06125 (1)\BD_Rebuilder\misc\menuback.jpg MENU_AUDIO=D:\BD-RBV06125 (1)\BD_Rebuilder\tools\blankclip\blank.ac3 QUICK_PLAY_THRESHOLD=10 MENU_AUTO_BACKGROUND=1 MENU_AUTO_DVDAUDIO=1 MENU_PLAY_SEQUENTIAL=0 MENU_START_WITH_MENU=1 IMPORT_LIMIT_LANG=0 IMPORT_KEEP_PLAYALL=0 IMPORT_PREPARE_MKV=0 MOVIEONLY_TYPE=0 ALTCRF=23 ALT_TARGET=1024 ALT_CRF_TARGET=1024 ALTMETHOD=1 ALTAUTOCROP=0 [Paths] SOURCE_PATH=D:\FLASH GORDON\ WORKING_PATH=G:\ Code:
[Status] LABEL=FLASH_GORDON VERSION=v0.61.28 SOURCE_SIZE=84278880515 SOURCE_VIDEO_SIZE=84218247168 TARGET_SIZE=24641536000 REDUCTION=.291871458734656 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=eng; BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=0 INSTANCES=1 DGDECNV=0 DGDECIM=0 FRIMSOURCE=0 FFMS2=0 SSIF_MODE=0 UHD_V3_MODE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=57 REBUILD_COMPLETE=1 [00000] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=428589 RATE=10000 NSIZE=215040 FLINK=0 MLINK=-1 [00002] AUDIO=1 PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=62781971 RATE=10000 NSTART=27000000 NEND=27901875 NSIZE=42485760 FLINK=0 MLINK=0 [00003] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=503906 RATE=10000 NSTART=27000000 NEND=27541875 NSIZE=3704832 FLINK=0 MLINK=0 [00004] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=925321 RATE=10000 NSTART=27000000 NEND=27294375 NSIZE=3508224 FLINK=0 MLINK=0 [00005] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=745995 RATE=10000 NSTART=27000000 NEND=27226875 NSIZE=3022848 FLINK=0 MLINK=0 [00006] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=96836 RATE=10000 NSTART=27000000 NEND=27225000 NSIZE=1038336 FLINK=0 MLINK=0 [00007] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1009604 RATE=10000 NSTART=27000000 NEND=27360000 NSIZE=2881536 FLINK=0 MLINK=0 [00008] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=294094 RATE=10000 NSTART=27000000 NEND=27360000 NSIZE=4227072 FLINK=0 MLINK=0 [00009] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=518252 RATE=10000 NSTART=27000000 NEND=27489375 NSIZE=5074944 FLINK=0 MLINK=0 [00010] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1377222 RATE=10000 NSTART=27000000 NEND=27450450 NSIZE=6844416 FLINK=0 MLINK=0 [00011] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=808759 RATE=10000 NSTART=27000000 NEND=27315000 NSIZE=2512896 FLINK=0 MLINK=0 [00012] AUDIO=111111 PGS=11010000000 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=213860391 RATE=10000 NSIZE=117743616 FLINK=-1 MLINK=-1 [00014] AUDIO=111111 PGS=11010000000 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=215043942 RATE=10000 NSIZE=118388736 FLINK=-1 MLINK=-1 [00023] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1387982 RATE=10000 NSIZE=835584 FLINK=0 MLINK=-1 [00024] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1461505 RATE=10000 NSIZE=835584 FLINK=0 MLINK=-1 [00025] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1006018 RATE=10000 NSIZE=559104 FLINK=0 MLINK=-1 [00026] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1040090 RATE=10000 NSIZE=700416 FLINK=0 MLINK=-1 [00027] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1335977 RATE=10000 NSIZE=872448 FLINK=0 MLINK=-1 [00028] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1375429 RATE=10000 NSIZE=817152 FLINK=0 MLINK=-1 [00029] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1450746 RATE=10000 NSIZE=927744 FLINK=0 MLINK=-1 [00030] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1154858 RATE=10000 NSIZE=786432 FLINK=0 MLINK=-1 [00031] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1348530 RATE=10000 NSIZE=1093632 FLINK=0 MLINK=-1 [00032] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1413087 RATE=10000 NSIZE=1056768 FLINK=0 MLINK=-1 [00033] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=823106 RATE=10000 NSIZE=454656 FLINK=0 MLINK=-1 [00034] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1465092 RATE=10000 NSIZE=1179648 FLINK=0 MLINK=-1 [00035] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1400535 RATE=10000 NSIZE=792576 FLINK=0 MLINK=-1 [00036] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1303699 RATE=10000 NSIZE=755712 FLINK=0 MLINK=-1 [00037] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1292939 RATE=10000 NSIZE=768000 FLINK=0 MLINK=-1 [00038] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1483025 RATE=10000 NSIZE=749568 FLINK=0 MLINK=-1 [00039] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1486611 RATE=10000 NSIZE=626688 FLINK=0 MLINK=-1 [00040] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1472265 RATE=10000 NSIZE=933888 FLINK=0 MLINK=-1 [00041] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1375429 RATE=10000 NSIZE=768000 FLINK=0 MLINK=-1 [00042] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=939667 RATE=10000 NSIZE=485376 FLINK=0 MLINK=-1 [00043] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1497371 RATE=10000 NSIZE=817152 FLINK=0 MLINK=-1 [00044] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=392724 RATE=10000 NSIZE=294912 FLINK=0 MLINK=-1 [00045] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=566670 RATE=10000 NSIZE=423936 FLINK=0 MLINK=-1 [00046] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=399897 RATE=10000 NSIZE=307200 FLINK=0 MLINK=-1 [00047] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=595362 RATE=10000 NSIZE=430080 FLINK=0 MLINK=-1 [00048] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=398103 RATE=10000 NSIZE=282624 FLINK=0 MLINK=-1 [00049] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=575636 RATE=10000 NSIZE=380928 FLINK=0 MLINK=-1 [00050] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=378377 RATE=10000 NSIZE=282624 FLINK=0 MLINK=-1 [00051] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=554117 RATE=10000 NSIZE=411648 FLINK=0 MLINK=-1 [00052] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=423209 RATE=10000 NSIZE=344064 FLINK=0 MLINK=-1 [00053] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=577429 RATE=10000 NSIZE=442368 FLINK=0 MLINK=-1 [00054] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=451901 RATE=10000 NSIZE=344064 FLINK=0 MLINK=-1 [00055] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=579222 RATE=10000 NSIZE=479232 FLINK=0 MLINK=-1 [00056] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=451901 RATE=10000 NSIZE=337920 FLINK=0 MLINK=-1 [00057] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=579222 RATE=10000 NSIZE=466944 FLINK=0 MLINK=-1 [00058] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=385551 RATE=10000 NSIZE=294912 FLINK=0 MLINK=-1 [00059] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=541564 RATE=10000 NSIZE=411648 FLINK=0 MLINK=-1 [00060] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=410656 RATE=10000 NSIZE=307200 FLINK=0 MLINK=-1 [00061] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=579222 RATE=10000 NSIZE=405504 FLINK=0 MLINK=-1 [00062] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=21519 RATE=10000 NSIZE=86016 FLINK=0 MLINK=-1 [01000] AUDIO=100000 PGS=10000000000 VIDEO2=79882620.6521739 V2MBRATE=0 M2TS_TARGET=22760932036 RATE=10000 NSTART=27001875 NEND=328040625 NSIZE=10443694080 FLINK=0 MLINK=0 [02000] AUDIO=1 PGS=100 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=475959430 RATE=10000 SPLITS=1 NSTART=27000000 NEND=102166875 NSIZE=2212061184 FLINK=0 MLINK=0 [02001] AUDIO=1 PGS=100 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=674885567 RATE=10000 SPLITS=1 NSTART=27000000 NEND=66026250 NSIZE=1169977344 FLINK=0 MLINK=0 [02002] AUDIO=1 PGS=111 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=134354494 RATE=10000 SPLITS=1 NSIZE=158564352 FLINK=0 MLINK=-1 |
#31326 | Link |
Get error messages Failed to REBUILD and EXIT CODE: -2
Hi there,
How do I configure BD Rebuilder to avoid these two errors. I'm using the latest version. [23:02:50]PHASE TWO - Rebuild Started - [23:02:50] Rebuilding stream 00007 [1 of 8] - [23:02:50] Multiplexing M2TS - [23:02:54] Rebuilding stream 00005 [2 of 8] - [23:02:54] Multiplexing M2TS - [23:02:58] Rebuilding stream 00011 [3 of 8] - [23:02:58] Multiplexing M2TS - [23:03:11] Rebuilding stream 00006 [4 of 8] - [23:03:11] Multiplexing M2TS - [23:03:29] Rebuilding stream 00003 [5 of 8] - [23:03:29] Multiplexing M2TS - [23:04:11] Rebuilding stream 00004 [6 of 8] - [23:04:11] Multiplexing M2TS - [23:04:48] Rebuilding stream 00012 [7 of 8] - [23:04:48] Multiplexing M2TS - [23:05:21] Rebuilding stream 00001 [8 of 8] - [23:05:21] Multiplexing M2TS - [23:13:16] Rebuilding BD file Structure [23:13:56] - Failed to REBUILD and at other times this [19:15:01]PHASE TWO - Rebuild Started - [19:15:01] Rebuilding stream 00005 [1 of 13] - [19:15:01] Multiplexing M2TS - [19:27:26] Rebuilding stream 00006 [2 of 13] - [19:27:26] Multiplexing M2TS EXIT CODE: -2 - Error in attempt to multiplex: MUX_00006.meta - Can't create file H:\BLURAY\NEW FOLDER\NEW FOLDER FROM REBUILDER\WORKFILES\TMP\BDMV\STREAM\00000.m2ts - Failed to rebuild BD file(s). Aborted. I've included the full log files here after I renamed them. EXIT CODE -2 BD-REBUILDER.txt FAILED TO REBUILD ERRORS BD-REBUILDER.txt |
#31327 | Link |
Instead of that long path, which might be the issue, change to: H:\BDRebuilder\Work\Workfiles
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 25th October 2022 at 00:48. |
#31328 | Link |
Oh! The good ol' days of BD Rebuilder when I would drop in here even before checking my email, lol. I was messing around with doing a 3D movie only encode and it seems it worked, log even shows MVC encoding. When I played it the 3D seemed flat but it is 3D cause it triggers my 3D glasses. Is there some trick I'm perhaps missing. I really need to do a quick play or a movie only because the menu and play selections are on a Japanese import 3D with Japanese text.
Also has anyone had any success with doing 3D Mkv's? Last edited by worknstiff; 7th November 2022 at 17:23. Reason: add info |
#31329 | Link | |
![]() For years I've been using CloneBD just for this purpose only for it to be plagued with artifacts and me learning to live with them. Early this morning, I converted Troy: Directors Cut (2004) and experienced such pixelated artifacts with CloneBD and thought there had to be another program that could deliver better results. Then I remembered how much better BD-Rebuilder did than DVDFab when I was created BD-Rs and I searched this thread for creating MKVs and sure enough, I struck gold! ![]() Once again, amazing quality for an amazing product... and it's still FREE!!! ![]() So thank you, sincerely yet again, my friend! You are the hero we all need right now. Last edited by SuperFist; 8th November 2022 at 14:18. |
#31330 | Link | |
#31331 | Link |
I'm trying to convert a Full SBS 3D file (ie a 3840x1080 2D file) to 3D MVC, but it's not working. I get the error
- [01:44:06] Rebuilding BD-3D file Structure - TSMUXER ERR: 0xFFFFFFFE - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta - Can't open file: A:\VIDEO\HOBBIT\TEST\WORKFILES\VID_00000.AVS.hevc VID_00000.AVS.hevc does not exist, but VID_00000.AVS.h264 does exist. BDR v0.61.28 Last edited by Magister Irrylio; 14th November 2022 at 01:55. |
#31332 | Link |
I just discovered an issue with the NVENCCRE program. When recoding HEVC 2160p material, it goes from constant frame rate to variable, with the listed frame rate as 23.976. That doesn't happen when BDRB rebuilds 2160p. Is there a reason this is happening?
UPDATE: Nevermind. The issue was caused by ffmpeg, which I used to re-wrap the mkv file to mp4.
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 24th November 2022 at 09:21. |
#31334 | Link |
any idea ??
[13:53:20] Importing MKV:
Video file.mkv - Scanning for Variable Frame Rate... - Collecting audio/video streams from source... - Building pseudo-BD source structure... - TSMUXER ERR: 0xFFFFFFFE - Source issue found, attempting correction... - Building pseudo-BD source structure... - TSMUXER ERR: 0xFFFFFFFE [13:53:33]ERROR: Failed to build BD structure. Aborted. any ideas what the problem is ?? Thanks |
#31336 | Link |
Format : Matroska Format version : Version 4 File size : 867 MiB Duration : 1 h 46 min Overall bit rate : 1 137 kb/s Encoded date : UTC 2022-11-29 15:48:13 Writing application : mkvmerge v67.0.0 ('Under Stars') 64-bit Writing library : libebml v1.4.2 + libmatroska v1.6.4 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 3 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 3 frames Codec ID : V_MPEG4/ISO/AVC Duration : 4 min 58 s Bit rate : 7 897 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 2.40:1 Frame rate mode : Variable Frame rate : 23.976 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.159 Stream size : 281 MiB (32%) Default : Yes Forced : No also get error on original source file which is 4k hdr, the info above is from an encode from the source to 1080 hdr to sdr conversion Last edited by Mike-uk; 29th November 2022 at 23:59. |
#31338 | Link |
Hi Everyone, included a twisted Hello to Lathe,
Is MULTIPROCESS=1 or any higher number broken when a GeForce RTX 3060 is added to the System? The Speed is of WOW/Amazing...when using nVIDIA Enc.. Same thing you commented so long ago when you got a hold of a FAST GPU, JD,. I've been looking and holding on.. So, anyway, I want to check the CPU, not GPU, but MULTIPROCESS which seems not functional when this new board is active. I discovered with my older board all I had t do was rename PSEUDO in some way from an Import item. Any Insights by anyone?
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 3rd December 2022 at 04:22. |
#31340 | Link | |
So, anyway, I want to check the CPU, not GPU, but MULTIPROCESS which seems not functional when this new board is active. I discovered with my older board all I had to do was rename PSEUDO in some way from an Import item. But that's not so with the new board.
