20th November 2022, 12:49 | #63681 | Link | |
I only use madvr with my Win 10 install for my projector, because it works.
Charky "Rule #1 : If it works, don't change anything." |
22nd November 2022, 03:07 | #63683 | Link |
LAV Filters installation probably.
22nd November 2022, 11:26 | #63684 | Link |
I just installed libmfxsw64-v3.7z in MPC\LAVFilters64 folder (H 264 MVC 3D).
I have the reading in 3D :https://forum.doom9.org/attachment.p...=1&d=166911220 But in full screen (when I follow on the video projector) it does not display in Frame Packing 1920x1080 24Hz ... It worked fine in Windows 10... Edit: Is not the problem with HDR, my video projector and screen 2. (Currently it is not connected). The problem is when it is plugged in. Another bug with Windows 11: More in "display modes" "custom modes" ... Last edited by vanden; 22nd November 2022 at 18:02. |
22nd November 2022, 23:50 | #63685 | Link |
I have the same problem with just the projector (only screen).
https://forum.doom9.org/attachment.p...6&d=1669157229 https://forum.doom9.org/attachment.p...8&d=1669158258 Last edited by vanden; 14th December 2022 at 13:05. |
23rd November 2022, 17:25 | #63687 | Link | |
PowerDVD 19 (64-bit) and StereoPlayer 2.5.1 works fine... EDIT : Has anyone tested with Windows 11 22H2 and can tell me if it works ? Last edited by vanden; 1st December 2022 at 17:21. |
2nd December 2022, 04:53 | #63688 | Link |
Hello everyone.
I have so many dumb questions to ask... I have an AMD RX vega64, an LG 27GP850 (1440p hdr400) monitor, and most of my movies are on 1080p 1.Im gonna change my gpu. Is it better an AMD6900XT or Nvidia 3080 to max out madvr? 2.Whats the best settings for my setup? 3.I combined madvr +Lavfilters + potplayer. Is that the best combination? Thanks. |
2nd December 2022, 15:07 | #63689 | Link |
Personally, AMD has some issues with their card, see the driver thread but most wont experience these issues but it depends on your setup, how your movies are encoded / how your TV is setup and what type of TV you have, right now I think NVIDIA is the best bet, a 3060 would be best for most people i'd say as you have diminishing returns when upscaling 1080p stuff, it generally looks good on very low MADVR settings to most eyes so you dont need loads of raw power.
I use an amd RX5700, its got enough grunt for me and I see no issues when using KODI DS for 3D MVC SDR and HDR movies, but i'm aware others do have issues. See this thread for all AMD issues: https://forum.doom9.org/showthread.php?t=176013 PS: I mainly use AMD as it still has baked in 3DMVC support and fully supports 23,976 with zero frame drops for days, you can get this with NVIDIA cards but you need to create custom resolutions and it can be a faff for some people.
LG OLED EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 RX 5700 - https://www.videohelp.com/software/madVR/old-versions Last edited by mclingo; 2nd December 2022 at 15:10. |
3rd December 2022, 22:10 | #63690 | Link |
Troubleshooter
Small green line flashing on screen during playback
During playback I am encountering a couple of pixels grouped in a horizontal row together flashing neon green during video playback, when they don't flash the picture/scene displays perfectly fine. I will post screenshots later when I get a chance, but in the meantime does anyone have suggestions on what settings to check that may be causing it?
I'm running on a Windows 10 PC that has an Optimus Intel HD4000 series GPU with Nvidia 680M as well. Unfortunately the Nvidia drivers haven't worked for some time (I think either a Windows update or Intel driver update started the problem, and trying to revert to previous driver versions for both Intel and Nvidia have not fixed the issue to let me use the Nvidia GPU for anything in Windows), so I'm stuck running on the Intel GPU.
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV. |
5th December 2022, 13:06 | #63691 | Link |
Is it always the same pixels?
Try to change the decoding method used in the video decoder (DXVA/D3D11 native; DXVA/D3D11 copyback), or the presenting method of madVR (D3D11/D3D9).
6th December 2022, 00:07 | #63692 | Link | |
6th December 2022, 18:42 | #63694 | Link |
i've had a go at MPV as well, its great as a chuck anything at it player but having no on screen controls or gui accessible settings out of the box means its just not an option for most people, I just cant be arsed to invest in the time required to put into this to get anything more out of it, it really needs a more user-centric version, even something as basic as the MPC builds would be a start.
6th December 2022, 22:34 | #63696 | Link |
Randomly the 0-255 and 16-235 stop working when trying to change in madvr, why does it keep happening?
also 10bit still stop working randomly, when restarting explorer.exe it returns to work. Last edited by x7007; 7th December 2022 at 18:37. |
