14th October 2022, 12:37 | #201 | Link |
21 years and counting...
Folder permissions seem fine. Maybe something wrong with the path variables if Avisynth uses any.
EDIT: Found it. The plugin folder was not set correctly within the registry under HKEY_LOCAL_MACHINE\SOFTWARE\Avisynth. No idea why. Last edited by LeXXuz; 14th October 2022 at 12:45. |
6th December 2022, 16:14 | #203 | Link | |
One way is expr http://avisynth.nl/index.php/Expr e.g. In a YUV clip change all values in Y channel to power of 2 , copy Cb, Cr expr("x 2 ^", "x", "x") |
7th December 2022, 00:36 | #205 | Link | |
Big Bit Savings Now !
(just happened recently with RipBot 1.26.3): Do you have other GUIs like RipBot or StaxRip installed? I found that RipBot auto-updating forces its own AviSnth preferences. IIRC StaxRip did that too on me once, but I am not so sure anymore...
7th December 2022, 01:15 | #206 | Link |
Formerly davidh*****
I feel like I'm missing something obvious, but how do I convert from RGB32 to YUVA444? There is ConverttoYUV444 but there is no ConverttoYUVA444.
Edit: seems you have to ConverttoPlanarRGBA first, then ConverttoYUV444 will retain Alpha. Seems a bit of an oversight to me. Or maybe it's backwards compatability. Last edited by wonkey_monkey; 7th December 2022 at 01:23. |
7th December 2022, 03:49 | #207 | Link | |
ConvertToYUV444() AddAlphaPlane() |
8th December 2022, 01:14 | #210 | Link |
Thanx Qyot27,
Whata wonderfull fella. ( Chill a bit, sir ) that wonkey fella is a bit messed up, try not to take notice. (Sorry Wonkey )
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 8th December 2022 at 01:25. |
8th December 2022, 10:56 | #211 | Link | |
- ConvertToYUV444 is the generalization of ConvertToYV24 - Applying ConvertToYUV444 on old formats such as RGB32 must preserve the original behaviour and result in YV24 (YUV444P8) and not YUVA444P8 |
13th December 2022, 15:25 | #212 | Link |
Can anyone give a step by step guide to resizing in AVISynth? I will admit that I am still new to this and I am asking becuase I was recommened to deep resize on another thread.
13th December 2022, 19:39 | #213 | Link |
Broadcast Encoder
What do you wanna know? Which kernel is good and which ones should be avoided? The resampling page in the Avisynth wiki does a pretty good job.
As a rule of thumb, however, you can use SinPowResizeMT() to downscale and either Spline64Resize or NNEDI3 to upscale. |
18th December 2022, 21:59 | #214 | Link | ||
22nd December 2022, 20:49 | #215 | Link | ||
Broadcast Encoder
There are several resizing kernels nowadays, but the most known are: - PointResize() -> Nearest Neighbour - BilinearResize() -> Bilinear filtering - BicubicResize() -> Mitchell-Netravali two-part cubic filtering - LanczosResize() -> Two lobes Lanczos windowed sinc function (4 lobes, 2 on each side) - BlackmanResize() -> A modified version of Lanczos with better ringing control (higher taps) - GaussResize() -> Gaussian filter; unlike bicubic, it does not overshoot, but it's less sharp - SincResize() -> Truncated Sinc Function; very sharp but pronte to ringing artifacts - Spline16Resize() -> Cubic Spline Based resizer that fit a spline through √16 sample points - Spline36Resize() -> Cubic Spline Based resizer that fit a spline through √36 sample points - Spline64Resize() -> Cubic Spline Based resizer that fit a spline through √64 sample points We're gonna talk about NNEDI3 (Neural Network Edge Directed Interpolation 3) later. The most basic Algorithm -> PointResize() PointResize is a nearest neighbour algorithm which performs interpolation between points. Interpolation is the problem of approximating the value of a function for a non-given point in some space when given the value of that function in points around (neighboring) that point. The nearest neighbor algorithm selects the value of the nearest point and does not consider the values of neighboring points at all, yielding a piecewise-constant interpolant. Suppose we have a grid with pictures that have 8bit values like so: Let's move to Bilinear: Bilinear interpolation is performed using linear interpolation first in one direction, and then again in the other direction. Although each step is linear in the sampled values and in the position, the interpolation as a whole is not "linear" but rather "quadratic" in the sample location. Let's move to Spline based resizing: Spline16Resize, Spline36Resize and Spline64Resize are three Spline based resizers. They are the cubic spline based resizers from Panorama tools that fit a spline through the sample points and then derives the filter kernel from the resulting blending polynomials. The rationale for Spline is to be as sharp as possible with less ringing artifacts than LanczosResize produces. Spline16Resize uses √16 or 4 sample points, Spline36Resize uses √36 or 6 sample points. The more sample points used, the more accurate the resampling. Very loosely and poorly made graphs but that should give you an idea: Now a few comparisons: What you should learn from this is: 1) DO NOT use PointResize() 2) It's 2022, use NNEDI3 to upscale or at the very least Spline64Resize() 3) If you want to add black borders to keep aspect ratio, use AddBorders() manually or use ResizeKAR() or FrostyBorders() with frosty = false to do it for you automagically. Cheers, Frank Last edited by FranceBB; 19th May 2023 at 18:34. |
24th December 2022, 23:44 | #217 | Link |
Pixel-based (may be better pixel-art based) old game may be designed to be rendered as really square pixels. Also it may not contain any real number measured shifts or scaling or other transforms - only integer shifts. So only PointResize with integer ratio (2x,3x,...)is applicable to fit higher resolution screens. Different digital imaging methods of encode images require different visualization and different scaling.
10th January 2023, 18:47 | #218 | Link |
Simple question regarding Avisynth syntax.
In many scripts I see a decimal point behind numbers in operations. For example: x=(y/2.) Is this to make the output (x) a float instead of an (depending on y maybe rounded) integer? Or what purpose does this decimal point have? |
10th January 2023, 18:55 | #219 | Link | |
Pig on the wing
avisynth, faq |
