Old 4th September 2016, 05:00   #24841  |  Link
MrVideo
MrVideo's Avatar
The OP wanted menus as well as x265, hence my posting.
Old 4th September 2016, 09:17   #24842  |  Link
lauguru
yes, I know they do not work the way videos on bluray, I mean to keep those backups for future players uhd
hopefully someday, jdobbs build uhdrebuilder!
anyone knows for serving this tweak?
TWEAK_X265= --uhd-bd
http://x265.readthedocs.io/en/default/cli.html
You will never get x265 compiled videos to be played on a Blu-ray player. While the menu will show up, the video will not play.
I suspect that the menu structure for UHD discs/players is a little bit different than Blu-ray menu structures, so that means there will need to be a UHDRB program.
So, for the time being, if you want menus, you use x264 encoding.
lauguru is offline   Reply With Quote
Old 4th September 2016, 15:03   #24843  |  Link
Originally Posted by lauguru View Post
x264 currently use very slow, with the configuration rebuilder.ini I put a post above, I would like to use X265 ARCHIVE_MODE for maintaining full backup bd50tobd25 menu, although to this day can not be played on a player, sure if it will be possible soon
X265 ARCHIVE_MODE backups are unlikely to play as-is. They're just useful as a low-storage-requirement/high-quality archive backup. I don't currently have the specifications for UHD on BD, so I'm not aware of the differences that might exist specifically for UHD/HEVC encoding. The X265 "--uhd-bd" setting may take care of the stream portion of it (emphasizing the "experimental" qualifier) -- but there very likely may also be structural requirements that need to be met as well. For example, I currently use the stream type identifier that TSMUXER has chosen for HEVC (a value of "6") -- but I have no idea if that matches the specification.
Old 4th September 2016, 16:02   #24844  |  Link
lauguru
then, while not break uhd safety and the isos network and file structure, then look better to wait?
Old 4th September 2016, 16:25   #24845  |  Link
You have to think of HEVC archiving for what it is meant to be. It is a way to keep a very high quality backup of a disc - while using the very least amount of space necessary to maintain it.
If, however, someone wants to give it a try -- there are UHD/HEVC players available today. I'd love to hear feedback on exactly how the discs are structured and supported. I'd be happy to incorporate any information discovered. But, with no current method for monetary support for BD-RB, I have no intention of investing, from my own limited resources, in a player costing several hundred dollars.
Old 4th September 2016, 16:55   #24846  |  Link
lauguru
Indeed, a player uhd Samsung UBD-K8500 costs about 415 €, if you want the format to expand, should lower prices but .... the only thing I can think of is recording a BD25 and try to play in a reader uhd in a shop, because I do not even know anyone who has. If someone in the forum tubiese one uhd player would be nice to try if you play
with this confg ( 32,3gb to 23,1gb) in archive_ mode with x265
TWEAK_X265=--output-depth 10 --profile main10 --tune grain --uhd-bd --pmode --pme
ARCHIVE_MODE=1
ARCHIVE_CRF=13.7
ARCHIVE_QUALITY=5
ARCHIVE_LIMIT=0
ARCHIVE_265=1
ARCHIVE_ENABLE=1
Old 4th September 2016, 20:20   #24847  |  Link
Ch3vr0n
Trying to build an SBS 3D MP4fails with an mp4box error
[09/04/16] BD Rebuilder v0.50.18
[19:51:24] Source:  GODS_OF_EGYPT_00000
  - Input BD size: 32,87 GB
  - Approximate total content: [02:07:29.308]
  - Windows Version: 6.2 [9200]
  - Quality: Good (Very Fast), ABR
  - Output folder: D:\Blu-ray\Rebuilds\BDRB\
  - Decoding/Frame serving: DirectShow [4-way]
[19:51:26] PHASE ONE, Encoding
 - [19:51:26] Processing: VID_00000 (1 of 3)
 - [19:51:26] Extracting A/V streams [VID_00000]
 - [19:58:03] Reencoding video [VID_00000]
   - Rate/Length: 23,976fps, 106*120 frames
 - [19:58:03] Reencoding: VID_00000, Pass 1 of 1
   - Analyzing 36,00 43,00 46,50 48,25 49,13 49,56 49,78 49,89 49,95 49,97 [49,97]
 - [20:37:44] Video Encode complete
 - [20:37:44] Processing audio tracks
 - [20:37:44] Processing: VID_00007 (2 of 3)
 - [20:37:44] Extracting A/V streams [VID_00007]
 - [20:40:53] Reencoding video [VID_00007]
   - Rate/Length: 23,976fps, 77*256 frames
 - [20:40:54] Reencoding: VID_00007, Pass 1 of 1
   - Analyzing 36,00 43,00 46,50 48,25 49,13 49,56 49,78 49,89 49,95 49,97 49,99 [49,99]
 - [21:05:52] Video Encode complete
 - [21:05:52] Processing: VID_00025 (3 of 3)
 - [21:05:52] Extracting A/V streams [VID_00025]
 - [21:05:56] Reencoding video [VID_00025]
   - Rate/Length: 23,976fps, 24 frames
 - [21:05:56] Reencoding: VID_00025, Pass 1 of 1
   - Analyzing 36,00 43,00 [43,00]
 - [21:05:58] Video Encode complete
[21:05:58]PHASE ONE complete
[21:05:58]PHASE TWO - Rebuild Started
 - [21:05:58] Converting PGS subs to SRT format...
 - [21:14:53] Building ALTERNATE OUTPUT Structure
 - ERROR in attempt to mux (MP4BOX)
[21:15:19] - Failed to REBUILD
[09/04/16] Checking System Settings
  - BD-Rebuilder v0.50.18
  - Working Path Free Space: 657,26GB
  - AVISYNTH Version: 2.6.0.6, Ok
  - LAVFILTERS:  Ok
  - AnyDVD settings check: Ok.
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
[09/04/16] Systems Settings Check complete
Old 5th September 2016, 09:31   #24848  |  Link
Sharc
  - LAVFILTERS:  Ok
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
Is your source 3D with SSIF structure? Then you should decode with FRIM rather than DS.
The final CRF of about 50 seems awkward ..... How would such video look? What target size did you enter?
I did 3D to .mkv and had no problems. Trying with MP4 now .......
Edit:
Hmmm...., MP4 just hangs here. No error message, MP4box.exe just hangs (25% CPU load) at:
- [11:38:51] Building ALTERNATE OUTPUT Structure
Edit2:
MP4 works when I re-encode the audio as well (to AAC in my case) instead of leaving it intact (DTS, 6 channel).
Old 5th September 2016, 16:00   #24849  |  Link
lauguru
Trying to build bd50tobd25 error
[09/05/16] BD Rebuilder v0.50.18
[13:42:29] Source:  FREDDY_JASON
  - Input BD size: 26,70 GB
  - Approximate total content: [03:59:26.209]
  - Target BD size: 23,75 GB
  - Quality: Highest (Very Slow), Two Pass
  - X264 Tweak(s) enabled
  - Decoding/Frame serving: DGDecNV [6-way]
[13:42:29] PHASE ONE, Encoding
 - [13:42:29] Processing: VID_00000 (1 of 57)
 - [13:42:29] Extracting A/V streams [VID_00000]
 - [13:47:52] Reencoding video [VID_00000]
   - Rate/Length: 23,976fps, 140.023 frames
   - Bitrate: 19.520 Kbs
 - [13:47:52] Reencoding: VID_00000, Pass 1 of 2
 - [14:12:20] Reencoding: VID_00000, Pass 2 of 2
 - [16:03:14] Video Encode complete
 - [16:03:14] Processing audio tracks
   - Track 4353 (eng): Keeping original audio
   - Track 4354 (spa): Keeping original audio
   - Track 4355 (ita): Keeping original audio
 - [16:03:14] Multiplexing M2TS
 - [16:08:25] Processing: VID_00001 (2 of 57)
 - [16:08:25] Extracting A/V streams [VID_00001]
 - [16:08:46] Reencoding video [VID_00001]
   - Source Video: VC-1, 720x480
   - Rate/Length: 29,970fps, 18.643 frames
   - Bitrate: 4.348 Kbs
 - [16:08:46] Reencoding: VID_00001, Pass 1 of 2
 - [16:09:35] Reencoding: VID_00001, Pass 2 of 2
 - [16:11:55] Video Encode complete
 - [16:11:55] Processing audio tracks
 - [16:11:55] Multiplexing M2TS
 - [16:12:02] Processing: VID_00002 (3 of 57)
 - [16:12:02] Extracting A/V streams [VID_00002]
 - [16:12:11] Reencoding video [VID_00002]
   - Rate/Length: 29,970fps, 26.164 frames
   - Bitrate: 4.407 Kbs
 - [16:12:11] Reencoding: VID_00002, Pass 1 of 2
 - [16:13:11] Reencoding: VID_00002, Pass 2 of 2
 - [16:16:59] Video Encode complete
 - [16:16:59] Processing audio tracks
 - [16:16:59] Multiplexing M2TS
 - [16:17:07] Processing: VID_00003 (4 of 57)
 - [16:17:07] Extracting A/V streams [VID_00003]
 - [16:17:13] Reencoding video [VID_00003]
   - Rate/Length: 29,970fps, 11.074 frames
   - Bitrate: 3.504 Kbs
 - [16:17:13] Reencoding: VID_00003, Pass 1 of 2
 - [16:17:40] Reencoding: VID_00003, Pass 2 of 2
 - [16:19:21] Video Encode complete
 - [16:19:21] Processing audio tracks
 - [16:19:21] Multiplexing M2TS
 - [16:19:26] Processing: VID_00004 (5 of 57)
 - [16:19:26] Extracting A/V streams [VID_00004]
 - [16:19:34] Reencoding video [VID_00004]
   - Rate/Length: 29,970fps, 20.774 frames
   - Bitrate: 3.503 Kbs
 - [16:19:34] Reencoding: VID_00004, Pass 1 of 2
 - [16:20:20] Reencoding: VID_00004, Pass 2 of 2
 - [16:23:11] Video Encode complete
 - [16:23:11] Processing audio tracks
 - [16:23:11] Multiplexing M2TS
 - [16:23:17] Processing: VID_00005 (6 of 57)
 - [16:23:17] Extracting A/V streams [VID_00005]
 - [16:23:27] Reencoding video [VID_00005]
   - Rate/Length: 29,970fps, 38.915 frames
   - Bitrate: 3.502 Kbs
 - [16:23:27] Reencoding: VID_00005, Pass 1 of 2
 - [16:24:36] Reencoding: VID_00005, Pass 2 of 2
 - [16:29:24] Video Encode complete
 - [16:29:24] Processing audio tracks
 - [16:29:24] Multiplexing M2TS
 - [16:29:32] Processing: VID_00006 (7 of 57)
 - [16:29:32] Extracting A/V streams [VID_00006]
 - [16:29:39] Reencoding video [VID_00006]
   - Rate/Length: 29,970fps, 11.689 frames
   - Bitrate: 3.516 Kbs
 - [16:29:39] Reencoding: VID_00006, Pass 1 of 2
 - [16:30:05] Reencoding: VID_00006, Pass 2 of 2
 - [16:31:38] Video Encode complete
 - [16:31:38] Processing audio tracks
 - [16:31:38] Multiplexing M2TS
 - [16:31:43] Processing: VID_00007 (8 of 57)
 - [16:31:43] Extracting A/V streams [VID_00007]
 - [16:31:49] Reencoding video [VID_00007]
   - Rate/Length: 29,970fps, 6.211 frames
   - Bitrate: 4.351 Kbs
 - [16:31:49] Reencoding: VID_00007, Pass 1 of 2
 - [16:32:02] Reencoding: VID_00007, Pass 2 of 2
 - [16:32:46] Video Encode complete
 - [16:32:46] Processing audio tracks
 - [16:32:46] Multiplexing M2TS
 - [16:32:51] Processing: VID_00008 (9 of 57)
 - [16:32:51] Extracting A/V streams [VID_00008]
 - [16:32:57] Reencoding video [VID_00008]
   - Rate/Length: 29,970fps, 6.301 frames
   - Bitrate: 4.355 Kbs
 - [16:32:57] Reencoding: VID_00008, Pass 1 of 2
 - [16:33:11] Reencoding: VID_00008, Pass 2 of 2
 - [16:34:00] Video Encode complete
 - [16:34:00] Processing audio tracks
 - [16:34:00] Multiplexing M2TS
 - [16:34:05] Processing: VID_00009 (10 of 57)
 - [16:34:05] Extracting A/V streams [VID_00009]
 - [16:34:10] Reencoding video [VID_00009]
   - Rate/Length: 29,970fps, 2.071 frames
   - Bitrate: 4.334 Kbs
 - [16:34:10] Reencoding: VID_00009, Pass 1 of 2
 - [16:34:15] Reencoding: VID_00009, Pass 2 of 2
 - [16:34:31] Video Encode complete
 - [16:34:31] Processing audio tracks
 - [16:34:31] Multiplexing M2TS
 - [16:34:35] Processing: VID_00010 (11 of 57)
 - [16:34:35] Extracting A/V streams [VID_00010]
 - [16:34:40] Reencoding video [VID_00010]
   - Rate/Length: 29,970fps, 3.031 frames
   - Bitrate: 4.397 Kbs
 - [16:34:41] Reencoding: VID_00010, Pass 1 of 2
 - [16:34:47] Reencoding: VID_00010, Pass 2 of 2
 - [16:35:08] Video Encode complete
 - [16:35:08] Processing audio tracks
 - [16:35:08] Multiplexing M2TS
 - [16:35:12] Processing: VID_00011 (12 of 57)
 - [16:35:12] Extracting A/V streams [VID_00011]
 - [16:35:18] Reencoding video [VID_00011]
   - Rate/Length: 29,970fps, 3.421 frames
 - [16:35:18] Reencoding: VID_00011, Pass 1 of 2
 - [16:35:25] Reencoding: VID_00011, Pass 2 of 2
 - [16:35:50] Video Encode complete
 - [16:35:50] Processing audio tracks
 - [16:35:50] Multiplexing M2TS
 - [16:35:54] Processing: VID_00012 (13 of 57)
 - [16:35:54] Extracting A/V streams [VID_00012]
 - [16:36:00] Reencoding video [VID_00012]
   - Rate/Length: 29,970fps, 4.891 frames
   - Bitrate: 4.362 Kbs
 - [16:36:00] Reencoding: VID_00012, Pass 1 of 2
 - [16:36:10] Reencoding: VID_00012, Pass 2 of 2
 - [16:36:42] Video Encode complete
 - [16:36:42] Processing audio tracks
 - [16:36:42] Multiplexing M2TS
 - [16:36:47] Processing: VID_00013 (14 of 57)
 - [16:36:47] Extracting A/V streams [VID_00013]
 - [16:36:53] Reencoding video [VID_00013]
   - Rate/Length: 29,970fps, 5.551 frames
   - Bitrate: 4.354 Kbs
 - [16:36:53] Reencoding: VID_00013, Pass 1 of 2
 - [16:37:04] Reencoding: VID_00013, Pass 2 of 2
 - [16:37:41] Video Encode complete
 - [16:37:41] Processing audio tracks
 - [16:37:41] Multiplexing M2TS
 - [16:37:45] Processing: VID_00014 (15 of 57)
 - [16:37:45] Extracting A/V streams [VID_00014]
 - [16:37:52] Reencoding video [VID_00014]
   - Rate/Length: 29,970fps, 8.671 frames
   - Bitrate: 4.307 Kbs
 - [16:37:52] Reencoding: VID_00014, Pass 1 of 2
 - [16:38:09] Reencoding: VID_00014, Pass 2 of 2
 - [16:39:02] Video Encode complete
 - [16:39:02] Processing audio tracks
 - [16:39:02] Multiplexing M2TS
 - [16:39:07] Processing: VID_00015 (16 of 57)
 - [16:39:07] Extracting A/V streams [VID_00015]
 - [16:39:13] Reencoding video [VID_00015]
   - Rate/Length: 29,970fps, 6.121 frames
   - Bitrate: 4.338 Kbs
 - [16:39:13] Reencoding: VID_00015, Pass 1 of 2
 - [16:39:26] Reencoding: VID_00015, Pass 2 of 2
 - [16:40:08] Video Encode complete
 - [16:40:08] Processing audio tracks
 - [16:40:08] Multiplexing M2TS
 - [16:40:12] Processing: VID_00016 (17 of 57)
 - [16:40:12] Extracting A/V streams [VID_00016]
 - [16:40:18] Reencoding video [VID_00016]
   - Rate/Length: 29,970fps, 5.161 frames
   - Bitrate: 4.380 Kbs
 - [16:40:18] Reencoding: VID_00016, Pass 1 of 2
 - [16:40:30] Reencoding: VID_00016, Pass 2 of 2
 - [16:41:08] Video Encode complete
 - [16:41:08] Processing audio tracks
 - [16:41:08] Multiplexing M2TS
 - [16:41:12] Processing: VID_00017 (18 of 57)
 - [16:41:12] Extracting A/V streams [VID_00017]
 - [16:41:18] Reencoding video [VID_00017]
   - Rate/Length: 29,970fps, 9.061 frames
   - Bitrate: 4.369 Kbs
 - [16:41:18] Reencoding: VID_00017, Pass 1 of 2
 - [16:41:39] Reencoding: VID_00017, Pass 2 of 2
 - [16:42:50] Video Encode complete
 - [16:42:50] Processing audio tracks
 - [16:42:50] Multiplexing M2TS
 - [16:42:54] Processing: VID_00018 (19 of 57)
 - [16:42:54] Extracting A/V streams [VID_00018]
 - [16:43:00] Reencoding video [VID_00018]
   - Rate/Length: 29,970fps, 3.121 frames
   - Bitrate: 4.344 Kbs
 - [16:43:00] Reencoding: VID_00018, Pass 1 of 2
 - [16:43:08] Reencoding: VID_00018, Pass 2 of 2
 - [16:43:34] Video Encode complete
 - [16:43:34] Processing audio tracks
 - [16:43:34] Multiplexing M2TS
 - [16:43:38] Processing: VID_00019 (20 of 57)
 - [16:43:38] Extracting A/V streams [VID_00019]
 - [16:43:44] Reencoding video [VID_00019]
   - Rate/Length: 29,970fps, 7.110 frames
   - Bitrate: 4.360 Kbs
 - [16:43:44] Reencoding: VID_00019, Pass 1 of 2
 - [16:44:00] Reencoding: VID_00019, Pass 2 of 2
 - [16:44:51] Video Encode complete
 - [16:44:51] Processing audio tracks
 - [16:44:51] Multiplexing M2TS
 - [16:44:56] Processing: VID_00020 (21 of 57)
 - [16:44:56] Extracting A/V streams [VID_00020]
 - [16:45:01] Reencoding video [VID_00020]
   - Rate/Length: 29,970fps, 5.856 frames
   - Bitrate: 2.193 Kbs
 - [16:45:01] Reencoding: VID_00020, Pass 1 of 2
 - [16:45:16] Reencoding: VID_00020, Pass 2 of 2
 - [16:45:52] Video Encode complete
 - [16:45:52] Processing audio tracks
 - [16:45:52] Multiplexing M2TS
 - [16:45:56] Processing: VID_00021 (22 of 57)
 - [16:45:56] Extracting A/V streams [VID_00021]
 - [16:46:04] Reencoding video [VID_00021]
   - Rate/Length: 23,976fps, 5.200 frames
   - Bitrate: 10.894 Kbs
 - [16:46:04] Reencoding: VID_00021, Pass 1 of 2
 - [16:47:09] Reencoding: VID_00021, Pass 2 of 2
 - [16:50:36] Video Encode complete
 - [16:50:36] Processing audio tracks
 - [16:50:36] Multiplexing M2TS
 - [16:50:42] Processing: VID_00022 (23 of 57)
 - [16:50:42] Extracting A/V streams [VID_00022]
 - [16:50:48] Reencoding video [VID_00022]
   - Rate/Length: 23,976fps, 747 frames
   - Bitrate: 11.409 Kbs
 - [16:50:48] Reencoding: VID_00022, Pass 1 of 2
 - [16:50:57] Reencoding: VID_00022, Pass 2 of 2
 - [16:51:27] Video Encode complete
 - [16:51:27] Processing audio tracks
 - [16:51:27] Multiplexing M2TS
 - [16:51:31] Processing: VID_00023 (24 of 57)
 - [16:51:31] Extracting A/V streams [VID_00023]
 - [16:51:37] Reencoding video [VID_00023]
   - Rate/Length: 23,976fps, 555 frames
   - Bitrate: 10.404 Kbs
 - [16:51:37] Reencoding: VID_00023, Pass 1 of 2
 - [16:51:43] Reencoding: VID_00023, Pass 2 of 2
 - [16:52:04] Video Encode complete
 - [16:52:04] Processing audio tracks
 - [16:52:04] Multiplexing M2TS
 - [16:52:07] Processing: VID_00024 (25 of 57)
 - [16:52:07] Extracting A/V streams [VID_00024]
 - [16:52:13] Reencoding video [VID_00024]
   - Rate/Length: 23,976fps, 522 frames
   - Bitrate: 10.708 Kbs
 - [16:52:13] Reencoding: VID_00024, Pass 1 of 2
 - [16:52:19] Reencoding: VID_00024, Pass 2 of 2
 - [16:52:38] Video Encode complete
 - [16:52:38] Processing audio tracks
 - [16:52:38] Multiplexing M2TS
 - [16:52:42] Processing: VID_00025 (26 of 57)
 - [16:52:42] Extracting A/V streams [VID_00025]
 - [16:52:48] Reencoding video [VID_00025]
   - Rate/Length: 23,976fps, 1.395 frames
   - Bitrate: 10.583 Kbs
 - [16:52:48] Reencoding: VID_00025, Pass 1 of 2
 - [16:53:02] Reencoding: VID_00025, Pass 2 of 2
 - [16:53:53] Video Encode complete
 - [16:53:53] Processing audio tracks
 - [16:53:53] Multiplexing M2TS
 - [16:53:57] Processing: VID_00026 (27 of 57)
 - [16:53:57] Extracting A/V streams [VID_00026]
 - [16:54:03] Reencoding video [VID_00026]
   - Rate/Length: 23,976fps, 1.045 frames
   - Bitrate: 10.522 Kbs
 - [16:54:03] Reencoding: VID_00026, Pass 1 of 2
  - Encode failed.  Aborting.
  - Working Path Free Space: 77,25GB
  - LAVFILTERS:  Ok
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
[16:54:14] - Failed video encode, aborted
[16:54:14] END - BATCH SEQUENCE
[09/05/16] Checking System Settings
  - LAVFILTERS:  Ok
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
[09/05/16] Systems Settings Check complete
Old 5th September 2016, 17:57   #24850  |  Link
Ch3vr0n
@shark i didn't enter anything. I went to movie only mode => alternate movie only output => MP4 container, full SBS, intact audio. BDRB is configured to use DS for discs until my GTX 1080 arrives to use DGdecNV. BDRB chose to use DS, not me. It's not up to me to tell it specifically to use FRIM, i was under the impression BDRB would select that itself (yes it has an SSIF structure). I only specified an estimated 1024MB CRF output size, BDRB did the analyzing. My guess is there's something wrong in the detection algorithm that makes it use DS instead of FRIM. Decoding & went fine. It's the rebuilding that failed. Though intact audio might be the problem. Kinda hard to squeeze HD audio into a 1GB file.
Basically what i need is a 720p MP4 profile for my mom's Galaxy tab 3. I configured this but i have no idea if it's any good. I mainly do full disc, hardly never movie-only and hardly ever portable file
Caption=MP4 Container, 720p SBS, Auto-AC3
vBitrate=2000
aBitrate=*
aType=0
vFormat=6
vKeyint=Auto
cType=5
[19:05:16] Source:  GODS_OF_EGYPT_00000
[19:05:19] PHASE ONE, Encoding
 - [19:05:19] Processing: VID_00000 (1 of 3)
 - [19:05:19] Extracting A/V streams [VID_00000]
 - [19:11:50] Reencoding video [VID_00000]
 - [19:11:50] Reencoding: VID_00000, Pass 1 of 1
   - Analyzing 35,17 22,58 28,72 27,10 26,73 [26,64]
 - [19:24:09] Video Encode complete
 - [19:24:09] Processing audio tracks
 - [19:27:20] Processing: VID_00007 (2 of 3)
 - [19:27:20] Extracting A/V streams [VID_00007]
 - [19:30:28] Reencoding video [VID_00007]
 - [19:30:28] Reencoding: VID_00007, Pass 1 of 1
   - Analyzing 36,89 23,44 16,72 22,57 22,27 [22,16]
 - [19:39:29] Video Encode complete
 - [19:39:29] Processing: VID_00025 (3 of 3)
 - [19:39:29] Extracting A/V streams [VID_00025]
 - [19:39:33] Reencoding video [VID_00025]
 - [19:39:33] Reencoding: VID_00025, Pass 1 of 1
 - [19:39:34] Video Encode complete
[19:39:34]PHASE ONE complete
[19:39:34]PHASE TWO - Rebuild Started
 - [19:39:34] Converting PGS subs to SRT format...
 - [19:48:21] Building ALTERNATE OUTPUT Structure
[19:49:15] - Encode and Rebuild complete
 - WORKFILES folder removed.
[19:49:15] JOB: GODS_OF_EGYPT finished.
Edit well the encode worked with that profile but there's a few things (but since i rarely do portable file, i don't know if it's disc related or profile related)
First: The MP4 file when played in VLC shows a duration of over 3 hours instead of the normal duratio of just over 2 hours. When it reaches the normal end time, the file cuts off and playback stops.
Second: it's not in 3D (is it due to DS being used or does MP4 not support 3D)
I have no clue if it's due to DS being used, or because the main title is split into 3 files (2 containing the main title), 1 containing an 0.04MB black clip, or something wrong in that profile
Old 5th September 2016, 22:26   #24851  |  Link
Sharc
Your profile works well here, but did you .....
Settings=>Setup => tick "Enable SBS/OU 3D Movie-only output" AND deselect "Process 3D video sources as 2D for backup"?
FRIM will automatically kick in.
If you however want it as a 2D output you need to....
Settings=>Setup=> tick "Process 3D video sources as 2D for backup"
DS will kick in.
Old 5th September 2016, 23:22   #24852  |  Link
Ch3vr0n
No i hadn't. Cause up to now i had no use for it, hardly ever do movie-only remember Retrying
** edit **
[09/06/16] BD Rebuilder v0.50.18
[01:08:49] Source:  GODS_OF_EGYPT_00000
  - Mode: MP4 Container, 720p SBS, Auto-AC3
  - Quality: High Quality (Default)
  - 3D conversion mode enabled
  - Decoding/Frame serving: FRIMSource
- Resuming from previously started job.
[01:08:50] PHASE ONE, Encoding
 - [01:08:50] Processing: VID_00000 (1 of 3)
 - [01:08:50] Reencoding video [VID_00000]
   - Converting output to Side-By-Side 3D Format
 - [01:08:50] Reencoding: VID_00000, Pass 1 of 1
   - Analyzing 35,17 22,58 29,73 28,11 27,67 [27,55]
 - [03:53:11] Video Encode complete
 - [03:53:11] Processing audio tracks
 - [03:56:37] Processing: VID_00007 (2 of 3)
 - [03:56:37] Extracting A/V streams [VID_00007]
Yet "overall progress" is at 100%, hmmm. Yet after extracting, the progress jumps back down to 58% lol
Old 6th September 2016, 05:46   #24853  |  Link
Lathe
Lathe's Avatar
x264_64 CPU Utilization...
Hmmm, interesting...
You guys had been discussing before about how the newer version of BDRB the x264_64.exe is running slower than older versions. I was just now trying to do a pretty simple encode with BDRB using a movie only of about 25 Gigs with, GASP, 'auto' settings (I can see Ch3vr0n & Sharc nodding sagely...) I have always used the LAV frame server and it's been great, but this time I noticed, I THINK for the very first time, that when doing the 1 pass ABR encode (to BD-25) the CPU utilization was only about 70-75%. It has ALWAYS run close to 100 before. And then I remembered what you guys were talking about. So, I'm trying changing it to FRIM to see how it does (I still keep getting the eternal 'AnyDVD' error if I try to use DirectShow whatever the source)
What's interesting is that I'm also running off a bunch of fast encodes for my Dad's tablet (old movies) where I am using the CMD line with 'veryfast' and a CRF of 24, and in these cases the CPU seems to be running at full capacity. Now, the weird thing is that the path I am using for the CMD line encodes is: D:\EXECUTABLES\BD-RBV05018\BD_Rebuilder\Tools\x264-64.exe, HUH...? Soooo, I don't understand why when I run an encode through BDRB it appears to be using a lot less CPU, but when I call that exact same .exe from BDRB's folder for the CMD line encode it runs at full capacity.
How is that possible...?
Okay, my FRIM encode is running now and the x264_64 running at full CPU capacity.
Weird...
Old 6th September 2016, 07:18   #24854  |  Link
Ch3vr0n
Don't drag me into movie only bd25 discussions, I never said anything about it or will i make a claim in favor of against it, for the simple reason I don't do those. If your want to make those, by all means that's your choice and right. Neither will i make any judgement or have i ever made one against setting your own quality preferences. I only said that FOR ME, bdrb's automatic quality has never let me down for full disc bd25 copy. I'm not going to make any type of judgement, the settings you use won't bother me in any way nor will mine affect yours.
YOU decide YOUR settings based on YOUR needs and preferences, I do the same for ME and me alone. I'll leave it at that.
As to the speed of x264, if you'll look a couple posts back you'll see that jdobbs confirmed that behavior. Some changes that were done between 2 versions of a certain build caused a significant drop in processing fps.
Old 6th September 2016, 07:36   #24855  |  Link
Lathe
Lathe's Avatar
Heh... You must be REEEEEEEEEEEEEEEEEEEAL fun at parties Bro...
Old 6th September 2016, 07:54   #24856  |  Link
Lathe
Lathe's Avatar
Anyway, I'm running a CMD line CRF-18 encode right now, of the exact same Blu-ray as before it so happens, and I am using the x264_64.exe that is in the current version BDRB folder and it is running at full capacity. So, all I'm say'n is that I can't see how it can be the specific version of x264_64 that the current version of BDRB is using that is causing the slowdown, that's all. Unless I misunderstood the earlier discussion where it SOUNDED like everyone was saying that it WAS the specific current .exe that was causing it. But used by itself it isn't. However, when USING BDRB on the last encode as I mentioned, when I switched to FRIM instead of LAVF the utilization went from about 70-75% to full capacity.
Old 6th September 2016, 07:58   #24857  |  Link
Sharc
** edit **
Ah, now your log looks fine!
Just a thought: The final CRF is in the order of 27 means the quality may not be too exciting. You could increase the target size to bring the CRF down, or encode the audio to AAC instead of ac3 to leave more space for the video, or if size doesn't matter make a fix CRF encode right from the beginning.
Secondly, I wonder whether your tablet can decode 720-SBS 3D correctly and sync the 3D goggles. Well, that's just a question.....
Old 6th September 2016, 08:01   #24858  |  Link
varekai
+1
Check out his popularity, same nick, at redfox forum ROFL...
Old 6th September 2016, 08:06   #24859  |  Link
Lathe
Lathe's Avatar
Originally Posted by varekai View Post
Yeah, well... what can you do...?
Hey, I know! Maybe if we put together some money, JD would be willing to set up another Grassy Knoll...
Old 6th September 2016, 08:09   #24860  |  Link
Ch3vr0n
Don't worry about the 3d part. That's just an experiment to find out if mp4 supported SBS 3d. I just need a decent working 720p mp4 profile with ac3 audio. Why 720p, because if the tab 3 screen resolution.
