Old 28th March 2013, 21:08   #16841  |  Link
Originally Posted by sieve View Post
Didn't solve it.
It did start pass number one and appeared to get stuck about 18k frames in. It just sat at that point for hours.
I just let it go and went to bed. In the A.M., I noticed that the computer rebooted itself. Presumably the result of a bluescreen. The odd thing is that it shouldn't have been a memory issue - I have 10GB RAM installed.
I've experienced this reboot problem before in recent times since this issue has arisen.
One thing I've also experienced is sometimes BDR will be in the first or second pass, and a Windows error message will pop up saying that the H.264 codec has stopped working. This likely has something to do with the problem I'm experiencing, but I'm admittedly not as knowledgeable as others in debugging.
I'll try that next. But I did just uninstall and reinstall them a couple days ago.
Based on your description it sounds like your system is experiencing a heat related instability. Pass two is where the processor is really under stress. I'd check all the fans and clean any dust out of the heatsinks. If you're handy with computers, you may also want to re-seat the processor and replace the heatsink compound.
Old 28th March 2013, 21:11   #16842  |  Link
Originally Posted by Nico8583 View Post
When do you think to release the new version of BD-RB ?
What's the rush? The last one is only 20 days old.
Old 28th March 2013, 21:32   #16843  |  Link
Nico8583
I would like to backup Ice Age 4 with your workaround for angles
Nico8583 is offline   Reply With Quote
Old 28th March 2013, 22:00   #16844  |  Link
I have a version that I can release -- but it would have be without the 3D SBS support.
Old 28th March 2013, 22:28   #16845  |  Link
BD Rebuilder v0.43.06 (beta)
I have updated the first post of this thread with links to a new release o BD-RB (v0.43.06). Changes for this version:
- Fixed a problem in which frame rates could be
  incorrectly reported when importing from an
  interlaced source.
- Modified IMPORT file pseudo structure so that
  it creates a CERTIFICATE folder.
- Improved the adjustments made on certain import
  sizes in order to become compliant.
- Changed the method used for stereo downmixing,
  this should correct "low volume" output when
  converting to stereo (especially for ALTERNATE
  output using lower bitrates).
- Added new ALTERNATE format selections for iPad
  2+, iPhone 4s+, and other devices that accept
  Level 4.1 output and 1080p in an MP4 container.
  Note: Since these new selections accept L4.1,
  settings in the "Encoder Setting" menu are used
  (older iPads & iPhones were more limited). This
  allows for better quality at similar bitrates &
  better sizing at similar CRF settings. Older
  iPad 1's & early iPhones will not accept output
  that uses this ALTERNATE selection.
- Corrected an issue in which it may be possible
  that odd angle count deviations within a single
  playlist might make some angles unavailable for
  movie-only selection.
- Fixed an issue in which selection of alternate
  angles from the movie-only playlist dialog was
  not correctly replacing primary angle playitems
  with the angle playitem in some cases.
- Corrected a problem in which aspect ratio for
  imported 16:9 DVDs could be incorrectly set to
  4:3 in the pseudo-BD import structure.
- Fixed an issue that could result in "Runtime
  Error 6" during import of a DVD.
- Corrected issue associated with DTS streams
  when attempting to import from DVD (v0.43.5).
Old 28th March 2013, 22:35   #16846  |  Link
Nico8583
Thanks a lot ! 3D SBS is not essential for me at now
Old 28th March 2013, 23:29   #16847  |  Link
Capsbackup
Thanks for the new version. I can confirm:
Fixed a problem in which frame rates could be incorrectly reported when importing from an interlaced source.
Old 29th March 2013, 00:06   #16848  |  Link
Ch3vr0n
i'm waiting on that SBS ^^ dying to test it out. would be a major breakthrough in shrinking 3D discs. Aint using DVDCrap.
Old 29th March 2013, 00:32   #16849  |  Link
Nico8583
I confirm also angle selection is working fine. Thanks again !
I'll try 3D SBS when it will be avalaible
Old 29th March 2013, 02:33   #16850  |  Link
steveg32
Just for the sake of accuracy, BD Rebuilder does not encode DTS Express. It simply extracts it from the original stream and then remuxes it into the new stream during rebuild.
I stand corrected. Mahalo jdobbs!
steveg32 is offline   Reply With Quote
Old 29th March 2013, 10:27   #16851  |  Link
Sharc
If you are under time pressure you may want to try BD3D2MK3D. You can easily author the files to Blu-ray structure using tsMuxer. Works perfectly for movie only.
Old 29th March 2013, 14:07   #16852  |  Link
AGKnotUser
Originally Posted by AGKnotUser View Post
It did make a difference. Without the Threshold line no graphic was shown behind the menu, just black. Perhaps in this case the menu graphic is being stored differently from other discs.
Just an update. The menu problem also happens with "Lincoln".
AGKnotUser is offline   Reply With Quote
Old 29th March 2013, 14:23   #16853  |  Link
Unfortunately that's why it's still only activated through the "ENABLE_TEST" hidden option, and may stay that way. There is no definitive way to determine menus, or to say what is or isn't an extra. So the software has to just make educated guesses.
Old 29th March 2013, 15:26   #16854  |  Link
AGKnotUser
Thanks jdobbs, no problem, I understand.
Old 29th March 2013, 23:45   #16855  |  Link
steveg32
BATTLE: Los Angeles - Quick-Play mode error & Full Backup mode has no audio playback
@jdobbs
- When reencoding "BATTLE: Los Angeles" in Quick-Play Mode I get this error message (see attached).
- When reencoding in Full Backup Mode (with or without Edit Mode enabled) there is no main movie audio in either Main Menu "Play Movie" or from Special Features play movie mode which includes Secondary Video and DTS Express Audio. Amazingly the Secondary Audio works (on my standalone Panasonic DMP-BD85) but not the main movie audio (original HD or 5.1). In addition, there is no Descriptive Audio sound in either playback mode.
- When reencoding in Movie Only Mode ALL is good.
- Windows Version: 6.1 [7601]
- FFDSHOW: [4422], Ok
- AnyDVD settings check: Ok.
- BD Rebuilder v0.43.0.6, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
Added to my config/INI file:
DTSX_ENABLE=1
ENABLE_TEST=1
DVD_SUB_COLOR=0
Old 29th March 2013, 23:51   #16856  |  Link
Weird. That error means "file already exists"... but I looked at that location, and there isn't an attempt to open a file there.
[Edit] I'll have to do some testing with "Battle Los Angeles" and see what's up. Can you post your complete settings and the contents of INF file created for the encode?
Old 30th March 2013, 01:40   #16857  |  Link
steveg32
@jdobbs
In this Quick-Play Mode attempt, I added to my config/INI file:
DTSX_ENABLE=0
ENABLE_TEST=1
DVD_SUB_COLOR=0
Still got same error message. Attached are the settings & INF.
Old 30th March 2013, 02:00   #16858  |  Link
steveg32
Originally Posted by steveg32 View Post
@jdobbs
DTSX_ENABLE=0
ENABLE_TEST=1
DVD_SUB_COLOR=0
@jdobbs
Here's the BDREBUILDER.INI
File Type: txt BDREBUILDER.INI_BATTLE LA.txt (863 Bytes, 33 views)
Old 30th March 2013, 08:55   #16859  |  Link
brunchto
Angle selection works fine for me too now (tested on starwars & iceage3). Thanks !
brunchto is offline   Reply With Quote
Old 30th March 2013, 09:51   #16860  |  Link
richardrpg
LOL... I'm also waiting and I have been using DVDCrap in the interim, cant wait to see the difference between DVDCrap and BDrebuilder.
richardrpg is offline   Reply With Quote
