29th March 2020, 17:56 | #1864 | Link | |
I have another "Quick-Play" feature request I thought I'd suggest. It could be added as a hidden option for use with the BDREBUILDER.INI file. Details on said feature request provided below.
Currently only one "Menu Background Picture" is supported for a given Blu-ray menu. I'd love to see a hidden option added, so one could designate a unique menu background per page. Something like the below. MENU_BACKGROUND=D:\BD_Rebuilder\Resources\ncis_s06_p1.png (Current option.) MENU_BACKGROUND_PAGE_2=D:\BD_Rebuilder\Resources\ncis_s06_p2.png (Feature request.) In the above example the default menu background is used for Page 1, a different menu background being used for Page 2 and so forth. If the Blu-ray menu consisted of only one page or the given page didn't exist the "MENU_BACKGROUND_PAGE_x" line item(s) would be ignored where applicable. That being said, I do employ a workaround for this currently. When creating a "Quick-Play" backup I just overwrite the menu background image after the menu background is encoded for Page 1, but before the menu background is encoded for Page 2. Quote:
To accomplish the below I set the "MENU_BACKDROP_OPACITY" to "0=Transparent", then adding my own menu backdrops to the actual menu background images instead, the last step being to overwrite the default menu background image (used for Page 1) with the one I wanted to use for Page 2 when the time came as described above. In any event, see the examples below. They turned out great I think. I find the below a nice improvement over how I was working these up prior as everything to the right of the DVD cover image is centered up beautifully now from top to bottom and from page to page. Perfect symmetry. Gotta love it! NCIS: The Sixth Season NCIS: The Seventh Season NCIS: The Eighth Season NCIS: The Ninth Season NCIS: The Tenth Season NCIS: The Eleventh Season NCIS: The Thirteenth Season NCIS: The Fourteenth Season NCIS: The Fifteenth Season NCIS: The Sixteenth Season Last edited by Lowpro; 10th April 2020 at 04:01. |
30th March 2020, 12:45 | #1865 | Link |
I can do that. I'll probably just make it automatic. So if you select a menu background it will use it... but if there is another file with, say, an extension of some type -- it will look for it. I've done this for other things. For example:
The background image is "BACKGROUND_IMAGE.JPG" For the first page it would always use "BACKGROUND_IMAGE.JPG" For pages 2-x (for example) it would look for another jpg, but if it is not there it defaults to the first page. So for page 2 it would look for "BACKGROUND_IMAGE_2.JPG" and if it exists it would use it, if not, it would use "BACKGROUND_IMAGE.JPG" I may play with the name a little to see what works best, but you get where I'm coming from. |
30th March 2020, 14:14 | #1866 | Link | |
10th April 2020, 02:43 | #1867 | Link |
It would be awesome if BD Rebuilder offered a "Quick-Play" menu option specifically for the creation of "Double Feature" discs, i.e. a disc containing only 2 titles. The menu would contain two buttons, each button being 960x1080, the given button only being visible when selected. The first button would highlight the left side of the screen for selecting the first title. The second button would highlight the right side of the screen for selecting the second title. The menu background would be used to call out what each of the titles were. Example below, in this case two versions of the same film though this feature could be used for two completely different films naturally.
When neither title is selected: When the first title is selected: When the second title is selected: As far as the implementation, I could see there being a setting for the INI file per enabling the "Double Feature" QP menu option. When enabled, the normal QP functionality would not apply. There would also be settings for determining the color and opacity of the buttons, i.e. the highlight. In any event, I've had this on my wishlist for quite a while now. Thought it was a pretty cool idea, so I thought I'd share. I own a few retail "Double Feature" Blu-ray's that have menus similar to this. Could see this becoming a very popular feature. Last edited by Lowpro; 22nd January 2022 at 10:38. |
23rd April 2020, 18:11 | #1868 | Link |
Edit Mode
Hi jdobbs,
is it please possible to add Hotkeys for context menu entries "Preview this item" and "Blank this item" when in edit mode? Today I wanted to use this great feature and was tired from clicking :-) In the meantime I figured out that there is a Setting called "BLANK_THRESHOLD" which I hadn't in my config. Will try that next. Thanks and Keep healthy, ggtop |
30th July 2020, 12:15 | #1869 | Link | |
31st July 2020, 15:39 | #1870 | Link |
Elit Amans
https://github.com/domyd/mlp
Would that be something that is useful to BD-RB once it irons out some bugs? //LD |
1st August 2020, 09:51 | #1871 | Link |
If you want test mlp.exe use the version here: https://github.com/domyd/mlp/actions/runs/120022192
And you can select the stream to extract, now the official release only extract the first thd stream.
2nd August 2020, 17:19 | #1872 | Link |
Is it possible for Movie Only backups that BD-Rebuilder can add the Source info into the INF? Currently it only shows the disc volume label.
Like for example.. the Entry in the BD-RB log shows.... Source: FINDING_DORY_00800 can that be added to the INF? |
6th August 2020, 13:59 | #1873 | Link | |
[00800] ...with data related to that source following it. |
8th August 2020, 15:25 | #1874 | Link | |
Let me try with Spies In Disguise as the example... BD-RB Log... Code:
[08/03/20] BD Rebuilder v0.61.09 [08:32:12] Source: SPIES_IN_DISGUISE_00857 - Input BD size: 14.27 GB - Approximate total content: [01:57:37.050] - Windows Version: 6.2 [9200] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - Quality: High Quality (Default) - Decoding/Frame serving: DGDecNV - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [08:32:14] PHASE ONE, Encoding - [08:32:14] Processing: VID_02975 (1 of 1) - [08:32:14] Reencoding video [VID_02975] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 169,200 frames - [08:32:14] Reencoding: VID_02975, Pass 1 of 1 - [08:40:05] Video Encode complete - [08:40:05] Processing audio tracks - Track 4352 (eng): Keeping original audio [08:40:05]PHASE ONE complete [08:40:05]PHASE TWO - Rebuild Started - [08:40:05] Building ALTERNATE OUTPUT Structure [08:44:06] - Encode and Rebuild complete [08:44:07] JOB: SPIES_IN_DISGUISE finished. Code:
[Status] LABEL=SPIES_IN_DISGUISE VERSION=v0.61.09 SOURCE_SIZE=15317760000 SOURCE_VIDEO_SIZE=15317760000 TARGET_SIZE=24641536000 REDUCTION=1.6086905657224 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=eng; BACKUP_MODE=1 MOVIEONLY_TYPE=11 USE_LAVF=0 INSTANCES=1 DGDECNV=-1 DGDECIM=0 FRIMSOURCE=0 FFMS2=0 SSIF_MODE=0 UHD_V3_MODE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=1 [02975] AUDIO=1 PGS=100 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=24641536000 NSIZE=0 FLINK=0 MLINK=0 In the case of Spies, I didn't realize there were two versions of the film, and that BD-RB picked the "super secret" version of the film when making the MKV. We didn't find out until we went to watch the movie for the first time (using the MKV via Plex). I had to then go back and re-encode it. I've had this happen on other movies too that have multiple play lists. Having the "SPIES_IN_DISGUISE_00857" also included in the INF, would help when going back to know which play list was selected before, so that I know which one to NOT pick when doing it again. |
11th August 2020, 04:15 | #1875 | Link | |
12th August 2020, 18:09 | #1876 | Link | |
I know there are other things you're working on... and this would be a "nice to have" not necessity. Thank you |
13th August 2020, 21:17 | #1877 | Link | ||
Sorry it took so long. I meant to do it a while back... but I just forgot about it. |
13th September 2020, 18:16 | #1879 | Link |
Elit Amans
Had an idea and just wanted to throw it out there. I haven't searched the thread so if it has been suggested already please ignore.
On UHD disc where there's extras that are in AVC/h264. Would it be possible to have an option in the setup menu to convert these to HEVC with either x265 or NVEncC, depending on what encoder that have been selected? For example on UHD of Waterworld where main movie is UHD version (135mins) and as extra there is the extended version (180mins) in 1080p AVC. I think there's some efficiency that can be made here with a switch to HEVC. Thoughts, anyone? //LD |
