Old 25th November 2019, 20:11   #6901  |  Link
amayra
Quality Checker
amayra's Avatar
so if you don't use SourceForge how about use GitLab or Bitbucket as file host only if you don't like GitHub
I love Doom9
Old 26th November 2019, 00:47   #6902  |  Link
Liisachan
李姗倩 Lǐ Shān Qin
Liisachan's Avatar
Originally Posted by hubi73 View Post
There is a version of 1.5.4.4905 with different size and two virus scanners found something in it.
VirusTotal/Jotti are not so reliable. It has so many different engines (some of which may be crappy) that one or two false positives are not so rare.
Liisachan is offline   Reply With Quote
Old 26th November 2019, 03:56   #6903  |  Link
v0lt
MPC Video Renderer v0.3.4.956.
Description.
Old 26th November 2019, 05:38   #6904  |  Link
Anima123
When MPC Video Renderer Direct3d 11 route using together with XySubtitles, the subtitle would be surrounded by a black box. I assume it's a compatible issue, which disappeared with Direct3d 9EX.
Here's what it look like:
https://www.dropbox.com/s/5idgcww1e9...X11_2.png?dl=0
This is what it look like with Direct9Ex:
https://www.dropbox.com/s/01v12m88on...DX9Ex.png?dl=0
Anima123 is online now   Reply With Quote
Old 26th November 2019, 06:49   #6905  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Thanks - fixed.
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Old 27th November 2019, 05:33   #6906  |  Link
v0lt
@V0lt
Who compiled/created the exe in the link with the shorter file https://yadi.sk/d/hlf1lfC8mKU58/!_last, is it you?
Not. Our volunteer does this.
Old 27th November 2019, 22:41   #6907  |  Link
Anima123
@Aleksoid1978, is it possible that it may reveal some kind of bugs when playing back a 25i fps mkv file, the audio sometimes will feed to Audio Renderer with some dropouts. For comparison, there're no problems at all with progressive files.
Edit: Since the dropout usually occurred with very dynamical scenes which will have to require more bitrates, my wild guess is that the splitter only pre-read certain amount of data while in this case most of the data are used by video, thus not enough size for audio data to feed the decoder in time.
Old 28th November 2019, 02:59   #6908  |  Link
Aleksoid1978
Upload sample file and write timestamps where audio "dropout".
Old 28th November 2019, 05:32   #6909  |  Link
Anima123
pm'ed to you. Thanks for checking.
Old 29th November 2019, 07:34   #6910  |  Link
v0lt
MPC Video Renderer v0.3.6.970
Description.
Old 29th November 2019, 10:14   #6911  |  Link
yandex likes to drip feed me at ~30Kb/s these days. Glorious, also most of the time comes down corrupted. Wonderful.
Seems to have reached a cap so it bandwidth throttling leading to bad data.
Bad host.
Old 29th November 2019, 12:30   #6912  |  Link
Klaus1189
@ryrynz: visit: https://forum.doom9.org/showpost.php...postcount=6766
click on alternative, also possible download
@devs: Thank you for your work on MPC Video Renderer. Amongst other things I want to thank you especially for added rotation support I asked for. You are the best
Old 30th November 2019, 06:53   #6913  |  Link
Cheers Klaus, videohelp build downloaded a build in a few seconds.
Yandex taking about six minutes or more, probably corrupted too.
Old 30th November 2019, 18:13   #6914  |  Link
mclingo
got a strange bug with MPC-BE since I upgraded from an AMD RX 580 to a RX 5700, its playing everything in limted rather han full, swapping 255 to 235 does nothing in video settings or in filters, does this with EVR renderer on both MPC-BE and MPC-HC so must be an issue with driver maybe, anyone else had this?
OLED 4k HDR EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 1909 444 RGB -MD RX 5700 8GB 20.1.3 KODI DS - MAD/LAV 92.17+ 113 beta - 0.74.1 - 3D MVC / FSE:on / MADVR 10bit
Old 30th November 2019, 18:29   #6915  |  Link
driver issue. it's about 4 month old they don't care. deint is "broken" too
Old 30th November 2019, 18:41   #6916  |  Link
mclingo
i dont really use the EVR render much luckily, works fine with MADVR which is my main driver, i'll get it logged with AMD, ive had success before with driver issues. I'll have a look to see if it can be fixed changing dynamic settings in radeon mod
Old 30th November 2019, 18:48   #6917  |  Link
i already did lock it with them nothing changed.
they even told me that doesn't sound important.
they have far bigger problems anyway which are finally acknowledged after a huge number of user have reported them for 4 months now.
Old 30th November 2019, 18:54   #6918  |  Link
mclingo
are any of the driver versions working or is this a day one problem?
Old 30th November 2019, 19:01   #6919  |  Link
afaik day one.
i don't even test some of the bugs anymore as long as the obvious ones are not fixed.
the only major bug that affected every user and is mostly fixed is driver crash with hardware decoding.
Old 30th November 2019, 19:54   #6920  |  Link
mclingo
its odd that its only happening with EVR render is it not?, why would MADVR and windows players all be fine and EVR not do you think?
