Old 7th April 2020, 21:21   #7301  |  Link
angmav
Thanks Chris would love to unfortunately I am using iOS not android sadly
Sent from my iPhone using Tapatalk
angmav is offline   Reply With Quote
Old 7th April 2020, 22:04   #7302  |  Link
chros
chros's Avatar
There was an iOS version of it as well back in the day, search for it in the store. Or just get a used old android mobile for this very purpose
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v442. 92),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(2160p@23/24/25/29/30/50/59/60Hz) | madvr config
Old 8th April 2020, 13:10   #7303  |  Link
cmhrky
Originally Posted by cmhrky View Post
When opening a file, that is, "Opening ..." in the status bar, no mouse button functions work. The volume adjustment is especially important to me, but unfortunately it does not work. Especially due to the delay in Youtube video openings or for other online video openings mouse functions cannot be used.
Don't just think of sound related settings. Mouse functions for all other commands are not available in this case. No problem with keyboard keys.
Will there be a correction about this?
cmhrky is offline   Reply With Quote
Old 8th April 2020, 13:59   #7304  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Yes - it's correct. Disable while opening progress.
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Old 8th April 2020, 14:12   #7305  |  Link
cmhrky
Keyboard functions are working. Must mouse functions not work as well? Is there another problem with mouse functions?
Old 8th April 2020, 18:58   #7306  |  Link
Klaus1189
I encountered an issue in MPC VR. I tried older drivers of my RX5700 XT, older versions of MPC-BE and so on. But trial and error got me to the result that MPCVideoRenderer-v0.4.2.1180_git2020.03.10-09388c1 is latest fine version and the next build MPCVideoRenderer-v0.4.2.1185_git2020.03.13-f45ed38 is already affected.
The issue is a green vertical line at the right of the videoframe, but only when software decoding is used. It doesn't matter if I use LAV Filters or internal Filters. If I use DXVA the issue does not appear.
Old 9th April 2020, 00:13   #7307  |  Link
Aleksoid1978
Show screenshot with statistics and upload short sample file.
Old 9th April 2020, 05:10   #7308  |  Link
Klaus1189
I created screenshots with statistics, I maximized because in 100% scaling hard to see. And sample video is also in this folder:
https://drive.google.com/drive/folde...GT?usp=sharing
Old 9th April 2020, 06:34   #7309  |  Link
Aleksoid1978
Can you take small screenshot to see statistics normal ?
Old 9th April 2020, 07:18   #7310  |  Link
Klaus1189
Sorry, what do you need?
Old 9th April 2020, 07:47   #7311  |  Link
He wants it normal size so he can see everything.
Old 9th April 2020, 08:54   #7312  |  Link
Klaus1189
So videoframe at 100% scaling?
Old 9th April 2020, 09:10   #7313  |  Link
Aleksoid1978
Don't need anything
Old 9th April 2020, 11:13   #7314  |  Link
v0lt
@Klaus1189
Your problem is repeated in release v0.4.3.1215?
Old 9th April 2020, 11:20   #7315  |  Link
Klaus1189
Yes up to latest nightly
Old 9th April 2020, 11:26   #7316  |  Link
Aleksoid1978
Test in Nvidia 960/1030 - there is no green line. And as developers don't have such device RX5700 XT i don't think that we can help
Old 9th April 2020, 12:49   #7317  |  Link
v0lt
@Klaus1189
We had such a problem, but we still fixed it before v0.4.3.1215. We did not check on AMD. I will try to find a way to check on other AMD graphics cards.
Old 9th April 2020, 16:13   #7318  |  Link
Klaus1189
OK, what was changed between those two builds? 1180 is still fine for my RX 5700 XT.
Old 9th April 2020, 16:38   #7319  |  Link
v0lt
Klaus1189
The change was affected by 1183_git2020.03.11-26811b7. The size of the texture in which the frame is stored has been changed.
This has been fixed in 1210_git2020.03.29.29-70e6ea4.
I have some idea what AMD might have a problem with. But I need time for checks and tests.
Old 9th April 2020, 16:40   #7320  |  Link
Klaus1189
Thanks for info. If you need someone to test, here I am
