Old 26th July 2020, 18:55   #7601  |  Link
v0lt
Originally Posted by Anima123 View Post
It appeared to be due to the file itself?
Your video seems to be fine.
I can get a sawtooth graph, but it will be justified by various factors that are reflected in the statistics parameters. Your statistics are clean and this is strange.
I would advise you to try enabling DXVA2 VP for NV12 format.
Old 28th July 2020, 13:32   #7602  |  Link
mogli
Originally Posted by mogli View Post
Also most youtube videos don't work for me anymore, hope it isn't related: The title and duration of the video is immediately found and shown in the playlist but it doesn't start and after a short time it says 'invalid' and 'file not found'. example youtube video
It's happening again, this time after only 2 months. Stupid YT.
mogli is offline   Reply With Quote
Old 28th July 2020, 23:42   #7603  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Update to latest SVN version.
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Old 29th July 2020, 07:07   #7604  |  Link
mogli
Thanks, it's working again.
Old 30th July 2020, 11:23   #7605  |  Link
brad86
Any way to change the main toolbar size like in MPC-HC advanced settings ?
I tried to add DefaultToolbarSize=24 to the ini but it doesn't change. Even when set to read-only.
I find the toolbar way too small at its default.
Also, rember audio volume at startup is gone too ?
brad86 is offline   Reply With Quote
Old 30th July 2020, 19:20   #7606  |  Link
v0lt
This is not MPC-HC. Settings from different players may not match.
You can use the toolbar with large buttons.Examples of toolbars.
Old 31st July 2020, 12:29   #7607  |  Link
Klaus1189
Updated german translation based on r5401
Old 31st July 2020, 22:40   #7608  |  Link
s0meone_new
New text?
s0meone_new is offline   Reply With Quote
Old 31st July 2020, 23:07   #7609  |  Link
Klaus1189
Yes, see here:
https://sourceforge.net/p/mpcbe/code...15b75022c:5400
Old 31st July 2020, 23:26   #7610  |  Link
s0meone_new
Ok thank.
Hungarian translation updated.
https://www24.zippyshare.com/v/aZDTcWa0/file.html
Old 1st August 2020, 13:39   #7611  |  Link
v0lt
@Klaus1189, @s0meone_new
Thanks. Updated in r5402 and r5403.
Old 2nd August 2020, 06:21   #7612  |  Link
wushantao
Simplified Chinese is coming :)
https://fil.email/mjLJFrJn
wushantao is offline   Reply With Quote
Old 3rd August 2020, 11:53   #7613  |  Link
v0lt
@wushantao
Thanks. Updated in r5404.
Old 14th August 2020, 21:03   #7614  |  Link
P.J
The aspect ratio of this video is wrong in MPC-BE but fine in MPC-HC:
https://drive.google.com/file/d/1FRB...ew?usp=sharing
P.J is offline   Reply With Quote
Old 15th August 2020, 13:19   #7615  |  Link
v0lt
@P.J
I think MPC-HC is wrong. Because LAV Filters doesn't support cropping.
MediaInfo gives out a little strange information about the aspect ratio:
Width                          : 720 pixels
Clean aperture width           : 720 pixels
Height                         : 512 pixels
Clean aperture height          : 480 pixels
Display aspect ratio           : 5:3
Clean aperture display aspect  : 16:9
Old 15th August 2020, 13:36   #7616  |  Link
volt can you check this file with mpc-be and internal filter with madVR. that are some chroma issues here.
Old 15th August 2020, 16:16   #7617  |  Link
v0lt
@huhn
There format P210 (or P216). madVR does chroma upsampling with DXVA. This is not possible for my video card, something in madVR is not working properly.
Old 15th August 2020, 17:49   #7618  |  Link
well the file works fine with lavfilter (ignoring the cropping) and madVR. else there wouldn't be a point in even assuming something could be done about this from your side.
and about DXVA to use DXVA for chroma on madVR you either have to hardware decode the file with DXVA native, deint the file or use image upscaling DXVA with chroma bilinear and this is working on my side too. so according to the OSD madVR is using DXVA scaling on 4:2:2.
Old 15th August 2020, 18:57   #7619  |  Link
v0lt
My GTX 950 cannot work with P210 format using DXVA Video Processor. The video renderer does frame cropping (not the player and not the decoder, which only transmit information about the crop). Conclusion: madVR does not work correctly.
Old 15th August 2020, 19:09   #7620  |  Link
i get the same on DXVA checker with my 1060 but that doesn't change that i don't have to use DXVA2 with madVR and it still working with DXVA2 processing when lavfilter is used.
so in short again. this video works with lav filter and madVR it doesn't work with mpc-be internal filters and madVR. DXVA is not been used here and doesn't have to be used.
