4th December 2020, 20:50 | #18763 | Link | |
It still dont work in the latest version when I edit a already added job (its added using the batch mode) See video: http://gofile.me/6GaFo/OOs8P2fb (7mb) Last edited by GZZ; 4th December 2020 at 21:00. |
4th December 2020, 22:02 | #18764 | Link |
Show me your custom scripts
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 5th December 2020 at 12:21. |
5th December 2020, 23:11 | #18765 | Link | |
They are just plain
6th December 2020, 05:53 | #18766 | Link | |
Grumpy Old Man.
(this is my MDgrain3 + enhance details custom filter, which will only work after the latest updates are installed) Also VERY important, the "address" in red text HAS to match where you have your RipBot located !!! #Custom Loadplugin("C:\RipBot264v1.26.0\Tools\AviSynth plugins\mvtools\mvtools2.dll") super=MSuper(video,pel=2) bv1=MAnalyse(super,blksize=8,isb=true,delta=1,overlap=4) bv2=MAnalyse(super,blksize=8,isb=true,delta=2,overlap=4) bv3=MAnalyse(super,blksize=8,isb=true,delta=3,overlap=4) fv1=MAnalyse(super,blksize=8,isb=false,delta=1,overlap=4) fv2=MAnalyse(super,blksize=8,isb=false,delta=2,overlap=4) fv3=MAnalyse(super,blksize=8,isb=false,delta=3,overlap=4) video=MDegrain3(video,super,bv1,fv1,bv2,fv2,bv3,fv3,thSAD=800) #After_Prefetch_Custom LoadPlugin("%AVISYNTHPLUGINS%\Plugins_JPSDR\Plugins_JPSDR.dll") LoadPlugin("%AVISYNTHPLUGINS%\CAS\CAS.dll") Import("%AVISYNTHPLUGINS%\Scripts\MCAS.avs") video=MCAS(video,1.0) It is also important to add these type of custom filters to the RipBot264.ini file. eg:- MTFiltersList=MDegrain1;MDegrain1_details;MDegrain2;MDegrain2_details;MDegrain3;MDegrain3_details;MDegrain4;QTGMC;HDRtoSDR;z_ConvertFormat; See what that does for you, good luck.
6th December 2020, 08:53 | #18767 | Link | |
6th December 2020, 11:17 | #18768 | Link | |
Grumpy Old Man.
It's just a combination of 2 filters, my custom MDgrain, and Ripbot's custom filter "EnhanceFineDetails"..that's all.
6th December 2020, 11:51 | #18769 | Link |
You do not have to add those extra lines to ripbot264.ini file. (MDegrain2_details,MDegrain3_details)
6th December 2020, 14:27 | #18770 | Link | |
https://forum.doom9.org/showthread.p...93#post1927793
6th December 2020, 19:51 | #18771 | Link | |
6th December 2020, 21:52 | #18772 | Link |
IT is funny because You have even quoted my reply...
7th December 2020, 00:50 | #18773 | Link | |
Grumpy Old Man.
You can't load 2 custom filters, (from the drop down) that's why I combined these, and added to the .ini.
7th December 2020, 11:40 | #18774 | Link |
Grumpy Old Man.
Atak, I had a strange occurrence today..I was processing a job, and it started "playing up" around chunk 117 (of 195), so I figured out that my Temp folder was full, so I went thru the completed jobs in RB, and deleted them.
When I re-started that Job, unfortunately it started from the beginning
12th December 2020, 13:33 | #18775 | Link |
What do i do regarding the procedure posting issues with encoding:
when indexing sometimes it gets stuck at random times (not repeatable and very random) sometimes when "gathering information" after the indexing it's also got stuck a few times (again not repeatable so this tells me the ripped disk is most likely not at fault). is there a main debug log i have to upload...i checked the temp folders and there seems a lot of files so was wandering what i need to post here to help with solution finding? thanks |
14th December 2020, 00:13 | #18776 | Link | |||
i found another error when using KNLMeansCL (i have a quadro p400)
when i use the avs meter i get the below error? Quote:
edit i went into the avisynth folder in ripbot264, i saw a install bat file...i ran this with admin level. now i'm getting this Quote:
i think maybe something was wrong with my avisynth install...perhaps that could also explain the strange issues with ripbot264 with stability, i will see in time...## however the speed of the quadro p400 is...terrible for KNLMeansCL...anyone with experience is this speed right for my cards abilities? or is something wrong. my script is Quote:
14th December 2020, 12:33 | #18777 | Link |
Have you checked spec for your GPU? https://www.techpowerup.com/gpu-specs/quadro-p400.c2934
0.6 TFlops in FP32 is a pathetic performance. My cheap RX 570 Has almost 10 times more (5 TFlops). https://www.techpowerup.com/gpu-spec...n-rx-570.c2939 No idea why you complain here...
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 14th December 2020 at 12:38. |
16th December 2020, 21:42 | #18778 | Link |
This bug is getting pretty annoying. I have to stop the encoding jobs. Close Ripbot, then start it back up, wait for it to load the jobs (800+ right now), then edit the file. Does not make any difference if I'm currently encoding or not. It's done it on five out of five jobs right now. Edit: It can even happen when I edit a job, make no changes, then click Done again. it happened 13 out of 15 times. Rebooting the system did not help. Last edited by Ryushin; 16th December 2020 at 21:56. Reason: Updated Information |
16th December 2020, 23:20 | #18779 | Link |
Record your desktop showing what you do from start to point where bug occurs. Upload video to YouTube or mediafire.com.
17th December 2020, 12:33 | #18780 | Link | |
Grumpy Old Man.
Now this may not have anything to do with your problem, but why the hell have you got so many Job's queued up !!!, that's just ridiculous. Some of those jobs must be pretty old, and have possibly gone thru many auto updates, which can impact on already queued Jobs. Haven't you got another pc, so you can spread the jobs around..it would be interesting to see if you loaded a couple of jobs on another "fresh" pc, the problem may disappear. Anyway, that's my 10 cents worth...if Atak comes up with a solution, then it's all good. Good luck.
