8th February 2019, 16:25 | #241 | Link |
When I try to install FFTW I get this error
https://imgur.com/a/fnfGd6e Any ideas on how to fix this? Cheers |
11th February 2019, 14:17 | #242 | Link | |
1.) Copy 3 of them to \windows\system32 2.) Staxrip will detect them but it expects FFTW version 3.3.6. Press on "VERSION" in staxrip and type in: 3.3.8 |
11th February 2019, 21:33 | #243 | Link | |
11th February 2019, 21:37 | #244 | Link |
New Pipeline Build: https://ci.appveyor.com/project/Reva...uild/artifacts
Added Merge: Chapter Cutting Feature to MkvMuxer (Credit: wybb) Not Sure how it works yet, Since I have not tested it. |
12th February 2019, 04:02 | #245 | Link | ||
12th February 2019, 16:41 | #246 | Link |
NVEnc v4.3.1 by rigaya
Changelog: Finally NVENC SDK 9.0 was released, so I updated it with a scatch. [Common] Updated to NVENC SDK 9.0. NVIDIA graphics driver 418.81 or later required. Added B ref mode setting for HEVC encoder. (--bref-mode middle / each) [NVEnc.auo] - Added "quality (--preset)" and "B frame reference mode (--bref-mode)" on the setting screen. [NVEncC] Added --preset to readme. According to NVENC SDK, the update point of Turing's NVENC function is as follows. Improvement of compression efficiency by supporting B frame in HEVC. * Other improvements in both H.264 / HEVC. Support by referring to RDO (distortion rate optimization) and multiple frames. ** important point ** Of Turing, only TU 117 (GTX 1650x) Does not support HEVC B frame, that is, TU 116 (GTX 1660x) Supports HEVC B frame in reverse. Does it mean that TU117 does not change so much with GP 107, even if it is not bad? Even so, I do not want such a confusing thing. https://github.com/rigaya/NVEnc/blob..._Options.en.md Last edited by mcjordan; 12th February 2019 at 17:50. |
12th February 2019, 19:46 | #247 | Link | |
12th February 2019, 19:57 | #248 | Link |
FYI, Here New Released Program of mine, Contact Sheet Maker Using WPF Framework. Also There a Winform version if you prefer. It uses AVS+ Portable along with ffms2 / L-Smash source filters to create the Contact Sheet.
Link: https://github.com/Revan654/Thumbnailer/releases Last edited by Revan654; 12th February 2019 at 20:00. |
12th February 2019, 20:58 | #249 | Link | |
From the 1.9 distro (\Apps\Plugins\Both\FFMS2\): Code:
09/15/2018 08:28 PM 35,147 COPYING.GPLv3 02/12/2019 01:54 PM <DIR> doc 09/15/2018 08:28 PM 6,779 FFMS2.avsi 09/15/2018 08:28 PM 31,737,068 ffms2.dll 01/01/2018 03:25 PM 15,656,960 ffms2k.dll 09/15/2018 08:28 PM 3,462,877 ffmsindex.exe 5 File(s) 50,898,831 bytes Code:
02/10/2019 12:42 PM 35,147 COPYING.GPLv3 02/12/2019 01:52 PM <DIR> doc 02/10/2019 12:42 PM 6,779 FFMS2.avsi 02/10/2019 12:42 PM 31,737,068 ffms2.dll 02/10/2019 12:42 PM 13,276 ffms2.lib 02/10/2019 12:42 PM 16,110,080 ffms2k.dll 02/10/2019 12:42 PM 15,958,528 ffmsindex.exe 6 File(s) 63,860,878 bytes Last edited by jkilez; 13th February 2019 at 05:27. |
13th February 2019, 04:36 | #250 | Link |
I have a relatively easy enhancement (or fix) request.
The Problem: When encoding with xvid_encraw using the "-progress" option, the little status bar in the "job processing" window does not get used, and the actual log file gets filled up with many lines of progess updates. This is not a problem if the "-progress" option is not used, but that default output is not as useful as the "-progess" output, which looks like this: Code:
1441 frames( 19%) encoded, 40.45 fps, Average Bitrate = 4856kbps 1451 frames( 19%) encoded, 40.34 fps, Average Bitrate = 4884kbps 1461 frames( 20%) encoded, 40.28 fps, Average Bitrate = 4899kbps 1471 frames( 20%) encoded, 40.23 fps, Average Bitrate = 4911kbps In file "Encoding\VideoEncoder.vb" lines 517-527 (changes in red): Code:
Function GetSkipStrings(commands As String) As String() If commands.Contains("xvid_encraw") Then Return {"key=", "frames("} ElseIf commands.Contains("x264") Then Return {"%]"} ElseIf commands.Contains("NVEnc") Then Return {"frames: "} Else Return {" [ETA ", ", eta ", "frames: ", "frame= "} End If End Function Last edited by jkilez; 13th February 2019 at 04:41. |
13th February 2019, 08:19 | #251 | Link | |
13th February 2019, 11:27 | #252 | Link |
Hi Revan, I add a few additional AVS scripts such as FillBorders, BalanceBorders etc. into StaxRip Filter Profiles so they're there as selectable options in the menus.
I'm looking to migrate over to Vapoursynth but I can't seem to make any sense out of how the scripting works on a basic level. I've got FillBorders up and running in VS using clip = core.fb.FillBorders() through trial and error. But, for example, would you know how I can get VS script bbmod2 working in StaxRip please? I've got as far as saving the script as a .py file in C:\Program Files\VapourSynth\plugins64 anyway Thanks! |
13th February 2019, 16:48 | #253 | Link |
Found another little glitch...
The Problem: When running an Xvid compressibility check, the recorded time stats in the log are erroneous due to the start time not being set properly. It gives an output like this: Code:
Start: 12:00:00 AM End: 11:46:17 AM Duration: 17690435:46:17 53 % Another minor side glitch: The log file should probably be saved at the end of the routine so that the log gets flushed. As it stands, the compressibility percentage value does not make it into the log until something else is logged or the project closed. In file "Encoding\VideoEncoder.vb" lines 569- (Deletions in Blue, Additions in Red): Code:
Overrides Sub RunCompCheck() If CompCheckCommandLines = "" OrElse CompCheckCommandLines.Trim = "" Then ShowConfigDialog() Exit Sub End If If Not g.VerifyRequirements Then Exit Sub If Not g.IsValidSource Then Exit Sub Log.WriteHeader("Compressibility Check") Dim script As New VideoScript script.Engine = p.Script.Engine script.Filters = p.Script.GetFiltersCopy Dim code As String Dim every = ((100 \ p.CompCheckRange) * 14).ToString If script.Engine = ScriptEngine.AviSynth Then code = "SelectRangeEvery(" + every + ",14)" Else code = "fpsnum = clip.fps_num" + BR + "fpsden = clip.fps_den" + BR + "clip = core.std.SelectEvery(clip = clip, cycle = " + every + ", offsets = range(14))" + BR + "clip = core.std.AssumeFPS(clip = clip, fpsnum = fpsnum, fpsden = fpsden)" End If Log.WriteLine(code + BR2) script.Filters.Add(New VideoFilter("aaa", "aaa", code)) script.Path = p.TempDir + p.TargetFile.Base + "_CompCheck." + script.FileType script.Synchronize() Dim batchPath = p.TempDir + p.TargetFile.Base + "_CompCheck.bat" Dim batchCode = Proc.WriteBatchFile(batchPath, GetBatchCode(Macro.Expand(CompCheckCommandLines))) Log.WriteLine(batchCode + BR2) Using proc As New Proc proc.Header = "Compressibility Check" proc.WriteLog(code + BR2) proc.WriteLog(batchCode + BR2) proc.SkipStrings = GetSkipStrings(batchCode) proc.File = "cmd.exe" proc.Arguments = "/C call """ + batchPath + """" Try proc.Start() Catch ex As AbortException Exit Sub Catch ex As Exception g.ShowException(ex) Exit Sub End Try End Using Dim bits = (New FileInfo(p.TempDir + p.TargetFile.Base + "_CompCheck." + OutputExt).Length) * 8 p.Compressibility = (bits / script.GetFrames) / (p.TargetWidth * p.TargetHeight) OnAfterCompCheck() g.MainForm.Assistant() Log.WriteLine(CInt(Calc.GetPercent).ToString() + " %") Log.Save() End Sub Last edited by jkilez; 13th February 2019 at 16:50. |
13th February 2019, 18:56 | #254 | Link | |
Then you just need to use the import command to use them. It will usually always be clip = scriptname.function(source, syntax) bbmod2(c, cTop = None, cBottom = None, cLeft = None, cRight = None, thresh = 128, blur = 999) It should be something like this: import Scriptname clip = Scriptname.bbmod2(clip, options....) My suggestion is learn a bit of Python that way VS will be very easy to understand or have Staxrip build a script and use that as a reference point. Last edited by Revan654; 13th February 2019 at 19:01. |
13th February 2019, 18:58 | #255 | Link |
Your likely the only person who actually still uses XviD, XviD code hasn't been updated since 2016-. Instead of keep posting source code, just submit a merge on github. If it passes it could then possible be added to the Code if it passes Testing.
13th February 2019, 20:03 | #256 | Link | ||
But I've copied the script file into the Staxrip/Apps/Plugins/VS/Scripts folder and still can't get it to work unfortunately. Both the scriptname and function is bbmod2, but clip = bbmod2.bbmod2(c, cTop = None, cBottom = None, cLeft = None, cRight = None, thresh = 128, blur = 999) still throws up the following error :- Quote:
13th February 2019, 22:17 | #257 | Link | |
import ScriptName clip = bbmod2.bbmod2(c, cTop = None, cBottom = None, cLeft = None, cRight = None, thresh = 128, blur = 999) c should be replaced with clip ScriptName should be replaced with the name of the script. |
14th February 2019, 17:41 | #259 | Link | |
Hopefully, there will not be a need to post more code, but if I spot more glitches, I will check out the github merge process. |
14th February 2019, 22:45 | #260 | Link | |
Any Code Posted So far should also be added to merge. |
aac, hdr, hevc, nvenc, staxrip, x264, x265 |
