23rd April 2021, 02:44 | #61421 | Link |
@ttnuagmada - Hey, nice to see you here. You should check our OLED thread, since you're the first one with a C1. We'd love to hear some feedback
23rd April 2021, 04:47 | #61422 | Link | |
Perhaps it would be good practice to not set any subtitle tracks as default when muxing matroska files.
madVR options explained |
1st May 2021, 07:31 | #61423 | Link |
Is http://madshi.net/madVRhdrMeasure131.zip the latest version? I updated to it but am still getting the annoying message about having to update my build.
2nd May 2021, 05:32 | #61427 | Link |
Not sure if you have been following, if not take a look at this: I explained in these two links a bug probably from madVR, or D3D11 related. I thought this was MPC-BE's fault.
https://forum.doom9.org/showthread.p...12#post1940912 https://forum.doom9.org/showthread.p...93#post1941893 I was told to disable D3D11, which I did, first for h.264, then for MPEG-2, and now for good. And so far the problems I reported have not returned. In fact they returned only when I tried today for the first time a DVDRip, which uses a different codec: MPEG-2. They haven't been seen ever since D3D11 was enabled and playing h.264 videos. Even so, I keep using madVR. And was using when the bug occured in MPC-BE. |
3rd May 2021, 15:09 | #61431 | Link |
I've been reading about resizable BAR.
https://www.guru3d.com/articles-page...chmarks,1.html Does this have any effect on madvr performance now or in the future? I figure I would ask before flashing my motherboard and GPU BIOS to try and get my system compatible. |
3rd May 2021, 17:43 | #61432 | Link |
there is no harm in updating this feature (if you know what you are doing) but madVR currently does not support it. if it makes sense to support it is not know until someone tested it.
if you have a zen 2/3 CPU updating the bios is generally not a bad idea just be aware of the risk. |
3rd May 2021, 21:58 | #61435 | Link | |
It don't think it is relevant for madVR. How often does madVR need to read or write from chunks of memory larger than 256MB? How much performance increase would madVR get from being able to combine two transfers into one?
4th May 2021, 05:05 | #61437 | Link |
The message is misleading, as there is no newer version at this time. Those who follow madshi's posts on AVS know that he's planning to implement a registration feature into future (beta) releases. We expect him to upload build 131 very soon, because 130 will expire at the end of May.
4th May 2021, 14:11 | #61438 | Link |
You're seeing a WARNING that the build WILL expire. You will know when it's expired as it will cease to work at all at that time. That will happen at the end of May. In theory, madshi will release a new beta build before that happens.
