Old 29th June 2020, 20:40   #2041  |  Link
JKyle
App Digger
JKyle's Avatar
Wouldn't it be easier putting custom filters in the settings folder? A customized startup folder cannot be replaced with a new staxrip version without loosing customized files.
Sounds reasonable.
But there's one thing I propose you need to consider in designing the %settings_dir%Plugins folder structure.
There's no folder under it for filters supporting dual mode.
Neo filters support both AVS and VS. Where am I supposed to put them?
If I put, for example, Neo FFT3D under %settings_dir%Plugins\AviSynth, isn't it NOT possible to use it for VapourSynth if I run VS in the portable mode because StaxRip loads only %settings_dir%Plugins\VapourSynth and its subfolders?
Since I'm running installed AVS and VS only, I'm not sure about this.
Anyway, I decided to make a subfolder named 'Dual' under %settings_dir%Plugins and put all dual mode plugins there, including DGDecNV itself. Although I need to modify AVS/VS Profiles code and DGIndexNV command code, I think it's very worth it.
The dependencies are loaded automatically, possibly this detection can be improved or replaced with another design.
Got it.
JKyle is offline
Old 29th June 2020, 21:54   #2042  |  Link
JKyle
App Digger
JKyle's Avatar
Originally Posted by Atlantis View Post
Suggestions: Add the ability to play a sound when an encode is finished. You can have settings for it to play after each file or at the end of the job list.
You can use Event Command... in Tools > Advanced menu.
See this for an example.
JKyle is offline
Old 30th June 2020, 04:15   #2043  |  Link
Atlantis
Thank you so much. Very useful.
Atlantis is offline
Old 30th June 2020, 09:59   #2044  |  Link
crystalfunky
I don't know if this has been posted or asked already:
Can you implement Neo_FFT3D and Neo_DFTest in the next build?
https://forum.doom9.org/showthread.php?t=181294&page=7
crystalfunky is offline
Old 30th June 2020, 12:23   #2045  |  Link
Atlantis
Yes. Please add this. It's faster and works well. I have already switched to this and encoded with it. It works.
Neo FFT3D
This seems is already in but needs integrated with avisynth
Neo DFTTest
Atlantis is offline
Old 3rd July 2020, 15:18   #2046  |  Link
Z'Hadum
Has anyone else trouble to use the portable version of avisynth with a networkshare?
I mapped the networkshare to an drive letter to use the same settings/job queue on different computers.
but I cant set the symlinks on the networkshare, because as normal user I'M not allowed to set the links,
as Administrator (UAC) I'm in another context and can't see the mapped drive letter from the user....
Has anyone any suggestion how to circumvent this? Many thanks in advance!
At the moment I switched back to the installed version of avisynth.
Z'Hadum is offline
Old 4th July 2020, 12:09   #2047  |  Link
Disturbance
Hello, bit of a strange thing happening, all of a sudden my encodes using the latest 2.1.3.0 Stable build have started having the frame rate messed with.
Instead of the input:
Framerate : 23.976023 (24000/1001) FPS
The output instead now reading as:
Frame rate           : 23.976 (23976/1000) FPS
Original frame rate  : 23.976 (24000/1001) FPS
I have even removed and then reinstalled the stable build making sure to have removed the settings and it still does it, I have tested also on another machine with a fresh copy of the stable build all on just the default encoder settings and also does it. It is not just this file but any file I try to encode (I have even tried to encode video that I have previously encoded just fine and the output fps was correct). I will even force the --fps 24000/1001 option to no avail. Attached is the log file in case there is anything anyone can spot causing this issue, stripped out everything besides the video on the source to make it easier and only encoded a clip for faster checking. I have also tested the files encoding with HandBreak as a sanity check and they come out at the right "23.976 (24000/1001) FPS"
https://pastebin.com/sBMWenNN - log
Disturbance is offline
Old 4th July 2020, 22:06   #2048  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Sometimes it is a piping mistake. If u using Avisynth, add this in your Avisynth Script:
AssumeFPS(24000, 1001)
If the target is a x264/AVC Stream, you can change the framerate in the bitstream with mkvtoolnix after the encoding process.
-QfG- is offline
Old 4th July 2020, 22:18   #2049  |  Link
Disturbance
Hello, I have tried adding that to the script as well as post encoding muxing the video and setting it as 24000/1001 and it will still show the same thing. I have done that via Avisynth as well as VS and they both do the same thing, also have tried switching piping method between avspmod and ffmpeg with no change, I have also tried between x264 and x265 and nothing seems to help :/
Old 4th July 2020, 23:01   #2050  |  Link
JKyle
App Digger
JKyle's Avatar
Just a suggestion: have you tried enabling developer mode?
JKyle is offline
Old 4th July 2020, 23:09   #2051  |  Link
JKyle
App Digger
JKyle's Avatar
Well, my suggestions are
1) Try another source filter.
2) Try the latest beta if 1) doesn't work.
BTW, your attachment cannot be read because it's pending approval. Why don't you post it on https://pastebin.com/ and put the URL here?
JKyle is offline
Old 5th July 2020, 00:12   #2052  |  Link
Disturbance
I have tried all of the source filters as well and they all seem to keep doing it, I have also tried the latest beta and it still occurs >_<
Versions I have tried - 2.0.8.0-stable, 2.1.3.0-stable, 2.1.3.7-Beta
also here is the paste for the log data - https://pastebin.com/sBMWenNN
Old 5th July 2020, 00:41   #2053  |  Link
JKyle
App Digger
JKyle's Avatar
According to the log, it seems like avs2pipemod/x265 pipes/encodes the video stream correctly at 24000/1001 but mkvmerge parses it arbitrarily and puts 23976/1000 in muxing.
Why don't you update mkvmerge to the latest version 48 and give it a try again?
(Extract mkvtoolnix-64-bit-48.0.0.7z and put mkvextract.exe, mkvinfo.exe, mkvmerge.exe in <StaxRip folder>\Apps\Support\MKVToolNix. Of course you need to update the version info in Apps > Manage...)
If it fails, the issue is something to be addressed by mkvmerge.
But I guess it's highly probable that this kind of issue will be ignored or given low priority if the developers think it's not something of critical importance.
My suggestion is like this: use mp4 unless the audio streams are of peculiar types that cannot be muxed into mp4.
JKyle is offline
Old 5th July 2020, 01:08   #2054  |  Link
Disturbance
It may be an mkvmerge issue, I changed the output to mp4 and it displays correctly as 24000/1001 in the info, however when I then try to use mkvmerge to mux the mp4 into an mkv with setting the video to 24000/1001 in the mkvmerge settings, the output video goes back to 23976/1000 like I mentioned before, this is also on v48 which I have updated to like you mentioned and it still does this, unfortunate because i need to use mkv for .ass subtitles >_<
Also if i remux a file that was encoded before this started happening (about 2 days ago) it will remux just fine and displays correctly. Just not anything that is encoded now.
Old 5th July 2020, 12:33   #2055  |  Link
Disturbance
Originally Posted by hevron View Post
Sometimes the resulting file has a video and audio desync. I can not solve this problem.
Checked, there is a problem with h.264 video demuxing.
I should mention that this is in x265 that I am encoding although I have tried in x264 and it still occurs. I have tried encoding files that have previously come out as intended to now on encoding again having the weird FPS showing. If I encode with no muxing and get just the .hevc video output and mediainfo it, it will show the 24000/1001 fps, it is only when I go to mux it and no matter which mkvtoolnix version I use it will bork and spit out the
Old 5th July 2020, 13:03   #2056  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Original Framerate is the framerate, how the framerate is written in the HEVC Raw String. The Framerate is correct! You have only a muxing problem, i don't know why mkvtoolnix do this. Open the file with mkvtoolnix-gui and change the framerate in the video settings on the right side. Then this will be fixed.
-QfG- is offline
Old 5th July 2020, 13:13   #2057  |  Link
Disturbance
Yes it is quite annoying, I have also set the framerate option in mkvmerge-gui every time I have tried manually muxing and it does nothing >_<
Old 5th July 2020, 16:22   #2058  |  Link
sneaker_ger
@Disturbance:
Unlike for mp4, Matroska timestamps aren't exact for 24/1.001 fps. So with a very short file like yours MediaInfo might display such unexpected fps. It is not a bug in mkvmerge. My guess is for files longer than a few seconds MediaInfo will show fps as you expect.
sneaker_ger is offline
Old 5th July 2020, 16:51   #2059  |  Link
hevron
It will not help, there is an error in Video encoding.
Folder _temp before encoding:
00001.h264 - Frame rate: 23.976 (24000/1001) FPS
Folder _temp after encoding:
00001_out.h264 - Frame rate: 24.000 FPS
This is the reason for the desync.
The Godfather I,II,III \BDMV\STREAM\00001.m2ts
Tulitikkutehtaan tyttö \BDMV\STREAM\00001.m2ts
and other similar. I do it through NVEncC (x64) 5.06.
How to fix this?
hevron is offline
Old 5th July 2020, 16:52   #2060  |  Link
lordalibaski
Why do I have this out of sync problem all the time when trying a new beta and this is a fresh install.
Small clip of the original file
https://fromsmash.com/QKXLk4kKHN-bt
Converted file out of sync (this is the full file conversion)
https://fromsmash.com/UumR.w.GNn-bt
No matter what format I try to convert it to it goes out of sync.
ok it will keep that small file in sync but won't keep the full file in sync!!
Here is the full file if anyone wants to see if they have the same problem I'm using the latest beta.
https://fromsmash.com/7clueZsqO.-bt
lordalibaski is offline
