#13501 | Link |
Are you sure you have posted whole log?
#13502 | Link |
Is there a particular Java version required? Mine is located here:
C:\ProgramData\Oracle\Java\javapath Your GUI don't detect it. Which Java tool do you rely on? In StaxRip Java and ProjectX are optional and I'm looking to retire it, currently I'm looking for a DGDecode replacement because it's not working on Win8 x64 so it might have to retire, that's why I look how other GUIs process VOB. I had a couple of bugs in my Java detection, ProjectX seem to work both with x64 and x86 Java so my Java detection is searching different locations, this is the code: Code:
ret = "C:\ProgramData\Oracle\Java\javapath\" + Filename If File.Exists(ret) Then Return ret ret = "C:\Windows\Sysnative\" + Filename If File.Exists(ret) Then Return ret ret = "C:\Windows\System32\" + Filename If File.Exists(ret) Then Return ret |
#13504 | Link | |
@stax76
Detection is ultra simple Code:
if Registry.KeyExists('SOFTWARE\JavaSoft\Java Runtime Environment')=true then java:=1 else java:=0; Quote:
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 3rd May 2015 at 12:53. |
#13505 | Link |
@Atak_Snajpera
following key exists on my system: Code:
HKEY_CURRENT_USER\Software\JavaSoft\Java Runtime Environment Java 8 Update 40 (64-bit) Code:
Really win8? |
#13506 | Link |
sorry I forgot one important line from code
Registry.RootKey:=(HKEY_LOCAL_MACHINE); if Registry.KeyExists('SOFTWARE\JavaSoft\Java Runtime Environment')=true then java:=1 else java:=0; Code:
[HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Runtime Environment] Code:
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\JavaSoft\Java Runtime Environment]
#13510 | Link |
You have to provide more information. Win8 is client or server? Record your desktop with fraps or similar software with opened server application. This way I will be able to see what is happening in server app.
#13511 | Link |
Hello Atak_Snajpera, I am using RipBot264 v.1.17.5 and I am running Windows 7 Ultimate x64
![]() When I load a .ts file at ripbot I get the following message ![]() Media Info from the .ts file Code:
General ID : 1 (0x1) Complete name : C:\Users\APOSTOLIS\Desktop\360_moires_20150506.ts Format : MPEG-TS File size : 239 MiB Duration : 8mn 38s Overall bit rate mode : Variable Overall bit rate : 3 859 Kbps Video ID : 1150 (0x47E) Menu ID : 100 (0x64) Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Format settings, GOP : M=3, N=15 Codec ID : 27 Duration : 8mn 38s Bit rate : 3 474 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : MBAFF Scan order : Top Field First Bits/(Pixel*Frame) : 0.335 Stream size : 215 MiB (90%) Audio ID : 1151 (0x47F) Menu ID : 100 (0x64) Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Codec ID : 3 Duration : 8mn 38s Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Delay relative to video : -80ms Stream size : 11.9 MiB (5%) Language : Greek Text ID : 1152 (0x480)-100 Menu ID : 100 (0x64) Format : Teletext Language : Greek Menu ID : 7007 (0x1B5F) Menu ID : 100 (0x64) Duration : 8mn 38s List : 1150 (0x47E) (AVC) / 1151 (0x47F) (MPEG Audio, Greek) / 1152 (0x480) () Language : / Greek ![]() Thank you for any help, I appreciate it!! |
#13513 | Link |
Usage logs?
Got another curly question for you Atak.
Let's say i have a rig set up, with my main machine which is a i5, and on my LAN i I have six more nodes set up. Various machines, different CPUs, ram etc. Six different nodes. I get an encoding job going and get it finished. Is there any tool or setting I can use to see how much work each particular node has completed? |
#13514 | Link |
I can add some summary after encoding is completed. What exactly would you like to see in log?
#13516 | Link | |
Master: 12652/183506 Node 1: 32257/183506 Node 2: 14865/183506 Node 3: 19668/183506 Node 4: 61896/183506 Node 5: 23557/183506 Node 6: 18611/183506 Or even put percentages perhaps. Like this: Master: 6.89% Node 1: 17.58% Node 2: 8.10% Node 3: 10.72% Node 4: 33.73% Node 5: 12.84% Node 6: 10.14% Just a thought. You could put graphs etc. in but It's probably best to keep things simple. It would be an easy way to compare the performance of each of your nodes, see how much work each is doing compared to the others and so forth. Perhaps even see if any networks problems exist or if one node isn't doing enough as it should? Many thanks ![]() Last edited by jonah; 9th May 2015 at 19:57. Reason: Incomplete! |
#13517 | Link |
@soneca
Are you using two audio streams? Could you check what bitrate is calculated in older version 1.18.1? @jonah I was thinking about something a little bit more complex like this Code:
Node 1: 192.168.0.1:1000 Encoded Chunks: 34 of 100 (34%) Average Encoding Speed: 23 fps Encoded Frames: 9876 Total Working Time: 00h:55m:23s Node 2: 192.168.0.2:1000 Encoded Chunks: 66 of 100 (66%) Average Encoding Speed: 21 fps Encoded Frames: 16492 Total Working Time: 00h:57m:13s
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 9th May 2015 at 20:25. |
#13518 | Link | |
The addition of a line with average encoding speed is a big plus. That way, you can easily see and compare the performance of any two particular nodes. |
#13520 | Link |
@Soneca
Ok thanks I will take a look ASAP.
