29th October 2019, 19:34 | #17621 | Link | |
29th October 2019, 19:46 | #17622 | Link |
TrueHD before AC3 Causes Error
Hi Atak,
Still encountering the bug with pulling in a MKV that has the TrueHD stream before the AC3 stream: FFAudioSource: No audio track found (D:\Temp\RipBot264temp\job19\getinfo.avs, line 4) This is the default that MakeMKV creates as I need to use it to make a MKV file to pull into Ripbot264 if I have a seamless branching 4K. I'm having to remux it to put the AC3 track first before the TrueHD track and then it pulls in fine. |
29th October 2019, 19:48 | #17623 | Link | |
30th October 2019, 17:56 | #17624 | Link |
I'll try and get you a sample. Not sure if I can chop a Atmos TrueHD stream or not.
I know electronics are crazy expensive where you are, just wondering if you've been able to move to 4K ripping and encoding for yourself personally yet. |
31st October 2019, 12:42 | #17626 | Link |
Dont know if I did it correctly. But I used MKVToolNix and set the output to be devided by size and choose 350mb output files. Then it divide the file into 350mb chunks, but they are not equal in size, so I think it does it by keyframe or something. Then I choose one of the file as a sample and delete the others.
31st October 2019, 17:50 | #17627 | Link | |
ByteShare
Did you try MKVtoolnix? |
2nd November 2019, 07:16 | #17628 | Link | |
Grumpy Old Man.
Now I have no idea if someone else has thought of this, and not too sure how it would work, anyways. IF, you had the "remote" DE servers set to go to "sleep" once there were off a high cpu usage encode, would RB be able to "wake them" out of that sleep, once it started encoding the next job ??
2nd November 2019, 14:53 | #17629 | Link |
Resizing Video and Slow 4K Gathering Information
Hi Atak,
Would is be possible to add a "Add Padding" tick box to the resize video. So selecting a setting like HDReady (720p) will scale the video and keep the aspect ratio of the video (keeps cropping settings) to fit within the resize video window. Then clicking the Padding box will add boarders if necessary to make the video fit the 720p range. There also an issue with typing in the box to manually enter the size. I'm trying to type 960x720 (4x3 movies) and it keeps auto-correct the size to make it fit within a parameter before I can finish typing the size. The only way for me to do it is to copy 960 to the clipboard and paste it into the box. or selecting a different audio source.or selecting a different audio source. I wanted to wait to ask about an issue until I upgraded to SSDs on my server which I just completed yesterday. I bought six Crucial MX500 2TB drives and put then in a ZFS raidz2 (like raid6). I'm waiting on Supermicro to release a new Epyc Rome motherboard before upgrading the CPU (which is an old 4 core Xeon) to the 24 core Epyc. My RipBot server is a KVM Virtual Machine running on the linux server and it's only acting as a director to pull in the jobs and use DE to send them to other servers for encoding. It's virtual drive is now running on the SSD storage pool. Working with HD sources is fairly quick and it only takes a few seconds when it's "Gathering Information" when leaving the Avisynth window. 4K sources on the other hand, takes minutes. Selecting a second audio source also takes a very long time. Another issue is having it do auto cropping. I'll use this option for HD sources which might take a minute. 4K sources can be a 15-30 minute wait when having it do auto cropping. For 4K sources I'm selecting manual and entering the numbers manually.or selecting a different audio source.or selecting a different audio source. Even selecting New Frame takes a very long time to pull in. |
2nd November 2019, 15:42 | #17630 | Link | |||
2nd November 2019, 16:19 | #17631 | Link | |
2nd November 2019, 16:32 | #17632 | Link | |
Do you think I'm still CPU bound for the Gathering Information slowness? Before it looked like I was I/O bound and looking at the Task Manager that is no longer the case. CPU is running around 75% during this time. But since there are only three cores, that could be an issue. |
2nd November 2019, 16:48 | #17633 | Link | |
2nd November 2019, 16:50 | #17634 | Link | |
ByteShare
From my usage of RB, the time between jobs is not a lot. At most I could see a reason for another job to start once all of the chunks are done or in process, but even that wouldn't be a major difference IMO, unless you had a huge server farm, but at that point (no offense to RB) you should use different software or have more individual sessions of RB going. |
2nd November 2019, 18:34 | #17635 | Link | |
The VM has been fine, but a little slow in general, but overall, it got the job done. Now though the Gathering Information on anything related to 4K sources seems to take a very long time. Oh, one other thing, is it still necessary to convert .sup to .sub when rendering subtitles? |
2nd November 2019, 21:16 | #17637 | Link | |
To find the glitch What I did to find it, is to run MKVToolNix on the MKV file and then try load all the chunks into Ripbot264 (Use batch mode), one the chunks will fail with that error (no audio), it did on mine. Then try play this chunk and see if there is a glitch in the audio (you can hear it). To fix it Use MkvToolNix on your bluray/UHD source to extract the movie to mkv and then try load it into ripbot264 |
2nd November 2019, 23:30 | #17639 | Link | |
3rd November 2019, 01:32 | #17640 | Link | ||
Grumpy Old Man.
I know there's an option for RB to "wake up" DE server's, but I haven't had any success with that... So despite how long the "wait" times are between encodes, there is STILL a period where the servers aren't doing anything, and as in my case, I have 6 hungry servers eating up power, when they could be asleep, or even better, OFF. Under full load the "farm" uses approx 2400W, and I guess when they're idling, it would be maybe a 1/4 of that, so lets say 600W for say 10 - 15 minutes, several times a day, adds up to a lot of wasted energy. Quote:
And AFAIK, the only way to have individual sessions of RB, is to have another client pc "sharing" the "farm", but that kinda defeats the purpose of doing large encodes using the whole farm for a process as fast as possible.
