Old 17th November 2019, 16:40   #17781  |  Link
Try this
nmap.exe -Pn -sT -p 1000 192.168.0.101
Old 17th November 2019, 17:59   #17782  |  Link
Privateer5000
This Command Line work and Server reacts:
But when i open the EncodingClient there is no reaction.
Privateer5000 is offline   Reply With Quote
Old 17th November 2019, 18:11   #17783  |  Link
Ronski
Try this
I'm getting the same results as Privateer, the above line caused the encoding server to react - this works for each encoding server when the port and IP address is changed as required, the previous one did not.
No reaction from the encoding client though.
Ronski is offline   Reply With Quote
Old 17th November 2019, 18:15   #17784  |  Link
Originally Posted by Ronski View Post
I'm getting the same results as Privateer, the above line caused the encoding server to react, the previous one did not. No reaction from the encoding client.
That's still something.
This at least means that nothing is blocking connection and EncodingServer v1.16 is also ok. So it has to be some weird bug in EncodingClient...
Old 17th November 2019, 18:28   #17785  |  Link
byteshare
ByteShare
byteshare's Avatar
Did you maybe put in a too broad of a variable for when you setup the block Pauly Dunne pc command
Old 17th November 2019, 18:38   #17786  |  Link
Looks like my detection code is buggy...
Ok. Jokes aside! I will post debug version of encodingclient for those reporting this issue. It should help me to track down where in code bad things happens...
Old 18th November 2019, 01:14   #17787  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
WOW, I saw what you did there.....
OMG, you're now my new BFF
Live every day like it's your last, because one day, it will be !! (M$B)
Old 18th November 2019, 01:19   #17788  |  Link
Pauly Dunne
Grumpy Old Man.
Not sure if you had a look at the screenshots I posted back at #17756, but I kinda thought back then, (even tho I was swapping and changing EC's & ES's around), that EC seemed to be looking for, and/or detecting the wrong ports.
Old 18th November 2019, 09:14   #17789  |  Link
howzz
i thought i'd report back to everyone that looks like another update came out over the weekend that updated Lmash and Core. looks like this latest update fixed the slow "gathering information" problem once again, and when you click on "start" encoding, it doesn't take forever for CPU cores to load up anymore.
i am going to image this version of RB and set it aside for backup.
but i agree with Paul Dunne in regards to version control, it would be a good idea to either post all the versions for users to download, or at the very least, have some kind of pop up that notifies user a new update is available and only upon clicking "yes", the update goes through. this way users can at least get a chance to backup their RB version prior to updating. otherwise we'll constantly run into downloading and updating to the broken version. obviously, everyone's setup is different. so what's broken for one person may very well work fine for others. but some kind of measure should be implemented regarding updates. we love updates and new features, and thank the author for that, but a layer of version control/protection is much needed.
howzz is offline   Reply With Quote
Old 18th November 2019, 09:50   #17790  |  Link
MCFish
MCFish's Avatar
Atak, i see encodingclient/server uses ports 61200 and upwards (maybe) internally when it works (before the 1.16 update) maybe something with those ports...or the using of them.
MCFish
MCFish is offline   Reply With Quote
Old 18th November 2019, 12:54   #17791  |  Link
0gg
(Hard+Bett+Fast+Strong)er
Atak_Snajpera : thank you agin for this great job.
Could you be pleased to add these feature :
  • able to decode mxf files
  • adding custom timecode on mp4 or the timecode of the source
... to encode files from DSLR / Camera to lower resolution / proxy file but with the same timecode of the sources
0gg / augur.
Asic / CPU / GPU / Food farming
0gg is offline   Reply With Quote
Old 18th November 2019, 15:23   #17792  |  Link
Run this debug version and show me what messages you get
https://www.mediafire.com/file/9zic1...lient.exe/file
example screenshot from my machine
Old 18th November 2019, 15:58   #17793  |  Link
MCFish
MCFish's Avatar
CheckIP(192.168.0.8:1000)=false
CheckIP(192.168.0.2:1000)=false
CheckIP(192.168.0.12:1000)=false
etc etc etc
MCFish
Old 18th November 2019, 16:07   #17794  |  Link
etc etc etc
What happens if you enter 192.168.1.2:1000
Old 18th November 2019, 16:27   #17795  |  Link
MCFish
MCFish's Avatar
I assumed you meant i should enter it in 'Distributed Encoding Server IP'
it went so fast past me, but got something
IP="192.168.1.2:1000"
CheckIP(0.0.0.0:0)=false
Starting workerthread
Connecting to "192.168.1.2:1000"
There was a timout further down, guess it was for 192.168.1.2
MCFish
Old 18th November 2019, 16:32   #17796  |  Link
Privateer5000
[IMG][/IMG]
With correct IP it does not find it, with 192.168.1.101:1000 it seems to find something but Connection timed out
Old 18th November 2019, 16:36   #17797  |  Link
I have located a bug in my function CheckIP. This function basically checks if ip values entered by user are in valid range of 0-255. It also checks other things like number of dots and if port is divisible by 1000 but that was not a problem here. Problem was that if you had 0 in ip (for example 192.168.0.1) then function was returning FALSE and hence no connection to server. This explains why it worked for me since I have IPs without zero value (192.168.1.100)
Old 18th November 2019, 16:42   #17798  |  Link
This version should work now
https://www.mediafire.com/file/zat5j...lient.exe/file
Old 18th November 2019, 16:46   #17799  |  Link
MCFish
MCFish's Avatar
YES, great man. Thx
MCFish
Old 18th November 2019, 16:49   #17800  |  Link
Ok then BRACE YOURSELF! AUTO-UPDATE IS COMING!
