#4901 | Link | |
If you can see if this matches your findings it would help. |
#4903 | Link | |
really thats the only thing i can tell other then that they didn't use 2 different M2TS files for regular/Extended cut. It seems all mixed up like a puzzle. KS |
#4904 | Link | |
It suprising as this has been done in conjunction with a new cinema release which is digitally remastered that the quality is perhaps not the best. All I was asking was for you to confirm the same error codes as I have listed - once the attached file is approved. |
#4905 | Link | |
#4906 | Link | |
Director's Cut = Extended Cut ![]() Last edited by Furiousflea; 31st August 2009 at 23:00. |
#4907 | Link | |
#4908 | Link | |
I'm new to BD Authoring but i'm not that new ![]() |
#4909 | Link |
Hi.
Win7 is really a pain in the ***. In MPC the WMVideo DMO Filter for m2ts with VC1 is loaded normally. Also Haali is loaded. But not for AVS. There Haali is loaded but the script times out (if opened via x264 or MPC). I tried alot of things suggested here or on other sites (I have not yet tried with other filters than WMVideo DMO, since it works with MPC) If you could NOT overwrite the AVS file when an encode is started, when it already exists, we could prepare our own AVS scripts (for example with a working graph file). Thx and best regards |
#4910 | Link | |
![]() The breakdown of the m2ts files is likely not the problem since BDRB has backed up similar discs with no problem in the past (King Kong for example uses this method). The problem most likely is an unintentional authoring error, the disc as a whole feels very badly made with "AUXDATA" folder missing etc. edit - looks like your saying the same thing...sorry about that...there's me jumping the gun again. |
#4911 | Link | |
#4912 | Link | |
#4913 | Link | |
It doesn't make alot of sense reporting problem with an OS that isn't supported at the moment and pre or post processing just eliminates any potential for jdobbs to even consider advising on the subject. It has absolutely nothing to do with bugs in BD Rebuilder... you're just out there on your own for now. |
#4915 | Link | |
BD-RB itself works fine with Win7. If you want to know, I have a MSDN account and I was able to get the final Version from there. Its basically its the only problem I ran into when using this OS, so if jdobbs decides to support this OS somewhen its good to know, where the problems are. Bye |
#4916 | Link | |
There are plenty of API changes in W7 which a developer has to consider. The fact that BD-RB works for you on W7 doesn't mean that it will behave the same way in all situations and configurations as it would on XP. However, I suppose it would be helpful for jdobbs if someone who is actually running the RTM build of W7 reported problems with BD-RB for future reference. |
#4917 | Link | |
There really aren't any changes in Windows 7 that cause any serious issues that aren't resolvable with some pretty basic meddling that is fully documented. Although I'm with you in that this isn't jdobbs problem and really wish the ignorant (no offense) would at least do a bit of googleing to sort out the issue themselves. It's just plain annoying, it just appears lazy really. |
#4918 | Link |
Pirates of the Caribbean 3 "At World's End"
BD-RB has locked up 3X on this in the same spot. I used AnyDVD HD to rip to disc. I tried 2X with new rips from one disc and then got another disc and ripped that. All locked up at the same point.
I have been successful backing up multiple BD-25s including the 1st 2 Pirate BDs as well as BD-5s with this setup so it's not hardware/drivers/software. Anyone got any ideas? Here's the log: [05:03:00] BD Rebuilder v0.28.03 (beta) - Source: PIRATES3 - Input BD size: 41.93 GB - Approximate total content: [03:05:16.980] - Target BD size: 22.46 GB [05:03:05] PHASE ONE, Encoding - [05:03:05] Extracting A/V streams [VID_00001] - [05:15:38] Reencoding: VID_00001 (1 of 14) - [14:07:30] Extracting A/V streams [VID_00002] - [14:07:31] Reencoding: VID_00002 (2 of 14) - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. [14:07:33] - Failed video encode, aborted Here's the INF file: [Status] LABEL=PIRATES3 VERSION=v0.28.03 (beta) SOURCE_SIZE=45025676366 SOURCE_VIDEO_SIZE=44407148544 TARGET_SIZE=24117248000 REDUCTION=.529165257136849 RESIZE_1080=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; BACKUP_MODE=0 QUICK=0 ENCODE_STEP=2 COMPLETED=1 [00001] AUDIO=1100 PGS=10000 M2TS_TARGET=21956407025 RATE=7910 NSIZE=20763838464 FLINK=0 MLINK=0 [00002] AUDIO= PGS= M2TS_TARGET=19507 RATE=500
Phenom II 940 GA-MA790FS-DS5 plus ATI 480 4 x 2 GB Mushkin Windows 7 64-bit 3.5 Terabytes Mass Storage 2 BD Burners, 2 DVD burners Lots of other "Stuff" Last edited by Imperial Zeppelin; 1st September 2009 at 23:44. |
#4919 | Link |
Beta v.23.04 is the current version. You might try using that.
I copied all the POTC movies back in January or February (Movie Only to BD9), so it must be a setting someplace. Did you happen to try restarting the process (resume)? |
