#49501 | Link | |
Why not use the gfx card set to RGB 8-bit? At least on Nvidia, HDR still works when using 8-bit RGB output and the quality would be better than having madVR set to 10-bit. It sounds like your TV is bad at processing 10-bit input.
madVR options explained |
#49502 | Link |
unfortunately I cant set MADVR to 8 bit, HDR stops working in that it no longer triggers HDR mode on my TV.
The other option is to configure calibration but calibrating it for BT709 still looks a bit too red and BT2020 a bit too yellow, the correct setting seems to be somewhere in middle, rock and hard place... Last edited by mclingo; 10th March 2018 at 01:20. |
#49503 | Link |
AMD's drivers are weird.
#49506 | Link |
ive gone back to using the calibration, i've calibrated for DCI-P3 with BT706/601 curve@2.20 - It seems to be good enough and I can run my full rig in 10 bit again. If anyone else has this issue or has an idea what it might be let me know.
Cheers all for your input. Last edited by mclingo; 10th March 2018 at 02:02. |
#49507 | Link | |
![]() I connected the laptop this morning via HDMI to a 2008 Panasonic plasma (HDready) and I still can't make it trip: HDMI 8, 10, 12 bits, any pixel format except RGB 4:4:4 Limited range (because it's not detected by the TV) from AMD driver, madVR set to 8 or 10 bits, D3D9 or 11, FSE or not, all look the same... I also tried an LG monitor, did have some trouble when switching between RGB and YCbCr in regard to the video range (crushed picture), but nothing that would resemble your case...sorry...let's wait for madshi, see what he sayz... |
#49509 | Link | |
#49511 | Link | |
but honestly i found as workaround to get rid of strange glowing reds and oversaturated colors, to use only windowed mode. It happens only with FSE. So now all looks perfect 8bit or 10 biit. I don't know what i'm missing using windowed mode, but it works very well. |
#49512 | Link | |
#49513 | Link |
madVR bypassed with DXVA2 (native) decoder
i have a question linked to the hardware decoder used with Lav Audio. When i select DXVA2 (native) on a 32 bits configuration , madVR is bypassed for any treatment but it is working fine on a 64 bits configuration.
Is it a known behaviour ? Today, is it better to select D3D11 or DXVA2 (copy back) ? |
#49515 | Link |
The only features that don't work are IVTC and black border detection. Scaling, including Chroma, work just fine. The same limitations apply to D3D11 native, because those are software algorithms not on the GPU.
#49517 | Link |
You need to uncheck Use DXVA chroma upscaling when doing native DXVA decoding in the Trade quality for performance settings screen.
HTPC: Windows 10 1909, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti |
#49519 | Link |
@filou: OK...got it...defaults seem to be favouring weaker gfx hardware (perhaps some autodetection of gfx card's performance and auto-configuraton would be nice, or I'm missing that too)...MadVR seems more complex than any post-production compositing software I'm using...
#49520 | Link |
DXVA chroma scaling for DXVA native decoding make a lot of sense because you will get worse chroma even with the trade quality for performance option.
if you want better quality use software, DXVA copy back or d3d11. and DXVA native is default in MPC-HC not in the stand alone version of lavfilter. no just no... |
