Old 3rd November 2012, 09:03   #16061  |  Link
lukappaseidue
WINDOWS 8 compatibility issue
Hi everybody.
I've just installed latest release ob BD-Rebuilder but ,it seems that with WINDOWS 8 pro, the software doesn't start. Any solution to solve?
Thank You very much
lukappaseidue is offline   Reply With Quote
Old 3rd November 2012, 14:34   #16062  |  Link
Originally Posted by Crocluvr92 View Post
Yes, just not these titles:
V for Vendetta
The Matrix
Iron Man 2
Blood Diamond
Constantine
I've done all of those movies. In fact "The Matrix" is one of the test discs I keep on my harddrive and do for virtually every release.
I would suggest you completely remove HAALI, AVISYNTH, and FFDSHOW -- and they reinstall them all exactly as instructed in the first post of this thread.
Old 3rd November 2012, 15:13   #16063  |  Link
setarip_old
setarip_old's Avatar
@lukappaseidue
Hi!
The following (from Post #1 in this thread) is likely required for proper installation under Windows 8:
Note to Windows 7 Users: The first time (and only the first time) you run BD Rebuilder, you may have to "Run As Administrator". This is necessary so BD-RB can make CODEC preference changes in the Windows Registry.
Old 3rd November 2012, 15:43   #16064  |  Link
V for Vendetta
The Matrix
Iron Man 2
Blood Diamond
Constantine
I'm running "The Matrix" right now just to be sure -- it has already completed the secondary video encode with no issues.
Old 4th November 2012, 00:02   #16065  |  Link
lukappaseidue
@lukappaseidue
Hi!
thank you very much for your reply
I've followed the instruction of 1st page, but with no luck. the 1st time of usage a windows show ...OCX not registered.... soon after I tryed to "run as adiministrator".... but the system freeze
Old 4th November 2012, 14:03   #16066  |  Link
Aren't you glad you decided to upgrade to Windows 8 before the bugs are worked out?
I personally will wait until they wring it out. There has never been a clean major release of Windows (that I can remember) that didn't require patching after the first "final release" -- and I go all the way back to v1.00 in the 1980's. You can follow this very thread and see the issues they caused in Vista and Windows 7.
What OCX is it mentioning? There are several.
Old 4th November 2012, 14:51   #16067  |  Link
slimm
It's running fine for me under Windows 8. I had to right click on the
REG_MSCOMCTL.BAT file and select "run as administrator".
slimm is offline   Reply With Quote
Old 4th November 2012, 15:02   #16068  |  Link
So that means that Windows 8 no longer includes the MSCOMCTL.OCX as a part of its standard distribution. Interesting. I added that .BAT file because some distributions (not all) of Vista & Windows 7 had that issue.
I'll add that step to the installation instructions.
Old 4th November 2012, 16:23   #16069  |  Link
klas
But I think it is very slow.It is necessaryt to optimize for windows 8.
The extracting it is very, very slow.
Regards and zhanks for the program
klas is offline   Reply With Quote
Old 4th November 2012, 16:28   #16070  |  Link
lukappaseidue
thank You very much
I will try e let you know
Old 4th November 2012, 17:12   #16071  |  Link
That has absolutely nothing to do with BD Rebuilder. Call Microsoft and tell them their new operating system sucks and is slower than Windows 7.
Do they know how ridiculous it is for someone to have to "optimize their code" for a new release of an operating system? How do you think Apple would fair if suddenly those 10,000+ apps for the iPad stopped working because they needed to be "optimized"?
I realize Microsoft owns the PC world right now -- but based on their attitude and lack of vision, I have doubts this will still be a M$ world in 5 years.
...stepping down off my soapbox.
By the way -- if it is slow, you typically want to check some of the security or search settings. For example, you will find that a drive that has indexing enabled (look at its properties) is significantly slower than one without -- and frankly it really doesn't give you much in return. I also find that disabling anti-virus software when I'm running jobs makes a lot of difference too. Any new "security features" in Windows 8? If so, try disabling them.
Old 4th November 2012, 23:31   #16072  |  Link
abbadon
you should add Windows 8 to list of issues you don't support, would make life a lot easier
Win7x64...I had to...
RIP WinXP
abbadon is offline   Reply With Quote
Old 5th November 2012, 13:52   #16073  |  Link
lukappaseidue
systen still crashing
I've followed the "slimm" step:
Fist I've deleted BD_Rebuilder....
then unzipped the archive
Run "AS administrator" REG_MSCOMCTL.BAT
First time a window show that there is no MSCOMCTL.OCX
So i 've copyied the ocx file in windows directory a and system32 too.
again Run "AS administrator" REG_MSCOMCTL.BAT
and it was ok.
so, last step, I "run as administrator BDRB..
no luck.... system crash again (need to push reset button)
Old 5th November 2012, 13:54   #16074  |  Link
[SLiM]D12
and it was ok.
It's something in your setup. I've been using BD-RB in windows 8 since the original RC1 win8 release. I'm now using the RTM on more than one machine without any issues at all.
[SLiM]
[SLiM]D12 is offline   Reply With Quote
Old 5th November 2012, 13:59   #16075  |  Link
lukappaseidue
Please, could You let me know how Have You do it (step by step)?
Thank You
EDIT:
..... now it is ok.... just the time to go to bathroom, back again and see (after minutes, about 5) the application
Old 6th November 2012, 00:20   #16076  |  Link
klas
and it was ok.
Zhank you very much
Regards
Old 6th November 2012, 07:31   #16077  |  Link
omegaman7
omegaman7's Avatar
I plan to run Windows 8 for testing purposes soon. I seriously doubt I come across any problems, given how I like to run my OS's I disable the administrative crap. I'm the only one who uses my computer. They should almost ask this upon install. So we don't have to deal with this silly... stuff! And it sounds like more than a few are successfully using windows 8 and BD-Rebuilder.
Once again, I've stopped receiving updates to this thread. I guess I need to post here every so often :S I'm still running 4203, because I received no update. I should know better though
The program just works 99.9% of the time Heck, even Dvd rebuilder encounters the occasional problem. I forget what the last one was. Oh, that's right. It was an unstable Ram overclock. Oddly, it and another, were the only programs affected by it. (so technically, it wasn't the programs fault, an overclock was to blame).
Old 6th November 2012, 17:52   #16078  |  Link
lauguru
hello jdobbs
could be added in the next version of bd-rebuilder origin - iso folder?
thanks
lauguru is offline   Reply With Quote
Old 6th November 2012, 18:42   #16079  |  Link
Ch3vr0n
why? Just use a virtual drive like "Virtual Clone Drive" available on slysoft.com, mount the iso, point BDRB to the virtual drive & done
Old 6th November 2012, 22:41   #16080  |  Link
lauguru
yes, that I know, but I think it would be a good option for people who do not know. (A friend to another, I commented) but thanks for answering
