Old 15th April 2013, 18:33   #1  |  Link
uciekamy
Runaway Slave..
uciekamy's Avatar
MeGUI MJpeg to Mp4 problem in One-Click mode.
Hello y'all.
I was using MeGUI to convert my Camera recordings (mjpeg MOVs) to mp4 but after some updates One-Click mode doesn't deal with it anymore.
It used to make 4 jobs in the queue: indexing, audio encode, video encode, and muxing. But now it makes: "mkvmerge mux", "mkvextract ext", "indexing", and "oneclick" job. And the first one doesn't even finish and reports error.
I don't know what changed, and how to get it back working.
It's still working fine in the manual process, but it takes too much time for me with several files i got to convert.
Appreciate any help.
• and i take 'em 3 at a time like steve kerr ! ..
uciekamy is offline   Reply With Quote
Old 15th April 2013, 18:42   #2  |  Link
Zathor
Please upload the log and if possible a short sample file.
Old 15th April 2013, 19:22   #3  |  Link
uciekamy
Runaway Slave..
uciekamy's Avatar
Log doesn't seem wrong, but job ends with error..
[Error] Log for job7 (mux, MVI_2909.MOV -> MVI_2909.mkv)
-[Information] [2013-04-15 20:10:41] Started handling job
-[Information] [2013-04-15 20:10:41] Preprocessing
-[Information] [2013-04-15 20:10:41] MediaInfo
--[Information] File: D:\2012-11\MVI_2909.MOV
--[Information] General
---[Information] Format: MPEG-4
---[Information] FormatString: MPEG-4
---[Information] FileSize: 437085596
---[Information] PlayTime: 00:01:42.227
--[Information] Video
---[Information] ID: 1
---[Information] StreamOrder: 0
---[Information] Width: 1920
---[Information] Height: 1080
---[Information] FrameCount: 2451
---[Information] FrameRate: 23.976
---[Information] FrameRateOriginal:
---[Information] FrameRateMode: CFR
---[Information] ScanType: Progressive
---[Information] Codec: AVC
---[Information] CodecString: AVC
---[Information] Format: AVC
---[Information] AspectRatio: 1.778
---[Information] AspectRatioString: 16:9
---[Information] Delay: 0
---[Information] Title:
---[Information] Language: en
---[Information] LanguageString: English
---[Information] Default:
---[Information] DefaultString:
---[Information] Forced:
---[Information] ForcedString:
--[Information] Audio
---[Information] ID: 2
---[Information] StreamOrder: 1
---[Information] Format: PCM
---[Information] FormatProfile:
---[Information] FormatSettingsSBR:
---[Information] FormatSettingsPS:
---[Information] SamplingRate: 48000
---[Information] SamplingRateString: 48.0 KHz
---[Information] Channels: 1
---[Information] ChannelsString: 1 channel
---[Information] ChannelPositionsString2:
---[Information] BitRateMode: CBR
-[Information] [2013-04-15 20:10:49] Job commandline: "C:\Program Files (x86)\MeGUI\tools\mkvmerge\mkvmerge.exe" -o "D:\2012-11\ie20n33w.45y\MVI_2909.mkv" "D:\2012-11\MVI_2909.MOV" "--compression" "0:none" --ui-language en
-[Information] [2013-04-15 20:10:49] Muxing started
-[Warning] [2013-04-15 20:10:53] A warning occurred: Warning: 'D:\2012-11\MVI_2909.MOV' track 0: The AVC video track is missing the 'CTTS' atom for frame timecode offsets. However, AVC/h.264 allows frames to have more than the traditional one (for P frames) or two (for B frames) references to other frames. The timecodes for such frames will be out-of-order, and the 'CTTS' atom is needed for getting the timecodes right. As it is missing the timecodes for this track might be wrong. You should watch the resulting file and make sure that it looks like you expected it to.
-[Error] [2013-04-15 20:12:01] Process exits with error: 1
-[Information] [2013-04-15 20:12:01] Standard output stream
--[NoImage] mkvmerge v6.1.0 ('Old Devil') built on Mar  2 2013 14:32:37
--[NoImage] 'D:\2012-11\MVI_2909.MOV': Using the demultiplexer for the format 'QuickTime/MP4'.
--[NoImage] 'D:\2012-11\MVI_2909.MOV' track 0: Using the output module for the format 'AVC/h.264'.
--[NoImage] 'D:\2012-11\MVI_2909.MOV' track 1: Using the output module for the format 'PCM'.
--[NoImage] The file 'D:\2012-11\ie20n33w.45y\MVI_2909.mkv' has been opened for writing.
--[NoImage] The cue entries (the index) are being written...
--[NoImage] Muxing took 1 minute 12 seconds.
-[Information] [2013-04-15 20:12:02] Standard error stream
-[Information] [2013-04-15 20:12:02] Job completed
Why does it even use mkvmerge if i'm not making a mkv file but mp4..
Can't upload sample but here is mediainfo:
General
Complete name                  : D:\2012-11\MVI_2909.MOV
Format                         : MPEG-4
Format profile                 : QuickTime
Codec ID                       : qt
File size                      : 417 MiB
Duration                       : 1mn 42s
Overall bit rate               : 34.2 Mbps
Encoded date                   : UTC 2012-11-10 11:23:07
Tagged date                    : UTC 2012-11-10 11:23:07
CNTH                           : &RélcŰRĹă)ÓK¦P 	*’*·‡t&iĚf6éľqý[źŰ…
Video
Format                         : AVC
Format/Info                    : Advanced Video Codec
Format profile                 : Baseline@L5.0
Format settings, CABAC         : No
Format settings, ReFrames      : 1 frame
Format settings, GOP           : M=1, N=12
Codec ID                       : avc1
Codec ID/Info                  : Advanced Video Coding
Duration                       : 1mn 42s
Bit rate                       : 33.4 Mbps
Width                          : 1 920 pixels
Height                         : 1 080 pixels
Display aspect ratio           : 16:9
Frame rate mode                : Constant
Frame rate                     : 23.976 fps
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
Bits/(Pixel*Frame)             : 0.672
Stream size                    : 407 MiB (98%)
Language                       : English
Color primaries                : BT.709
Transfer characteristics       : BT.709
Matrix coefficients            : BT.601
Audio
Format                         : PCM
Format settings, Endianness    : Little
Format settings, Sign          : Signed
Codec ID                       : sowt
Duration                       : 1mn 42s
Bit rate mode                  : Constant
Bit rate                       : 768 Kbps
Channel(s)                     : 1 channel
Channel positions              : Front: C
Sampling rate                  : 48.0 KHz
Bit depth                      : 16 bits
Stream size                    : 9.36 MiB (2%)
Language                       : English
Old 16th April 2013, 23:07   #4  |  Link
Zathor
What happens when you use the created MKV file as input instead of the MOV?
Old 19th April 2013, 20:37   #5  |  Link
uciekamy
Runaway Slave..
uciekamy's Avatar
Don't have any to check. I use mp4.
But why does it use mkvmerge for mov files?
Old 20th April 2013, 16:51   #6  |  Link
Zathor
Please use the created MKV from MeGUI:
This way various files (mp4, avi, ...) can be demuxed resulting in stream copy or better video/audio encoding support. In your case MKVMerge seems to be able to handle this file but as a warning is shown MeGUI cannot proceed.
Old 20th April 2013, 21:49   #7  |  Link
uciekamy
Runaway Slave..
uciekamy's Avatar
Ok then: it works fine with that file, but an encoded mp4 is corrupted - audio is chopped and unsynced..
How can I force it to do the process old way, without mkvmerge?
Old 21st April 2013, 17:16   #8  |  Link
Zathor
Currently? Revert to an older MeGUI build.
I will add an option to disable intermediate MKV files in one of the next releases. As it is useful in general intermediate MKV files will be enabled by default.
Old 21st April 2013, 20:41   #9  |  Link
uciekamy
Runaway Slave..
uciekamy's Avatar
OK so i'll hold up untill U do it. Can U post here when it's done?
Old 23rd May 2013, 22:35   #10  |  Link
Zathor
Please try this build:
http://www.mediafire.com/download/jal572ld033y3vh/MeGUI.zip
You can disable the intermediate MKV files in the OneClick profile settings (other tab).
Please report back.
Old 28th May 2013, 18:27   #11  |  Link
uciekamy
Runaway Slave..
uciekamy's Avatar
Hahaaaaaaaaaa! Just found it myself at the moment and wanted to post it here! You added this option, or it was there all the time?
Thank a lot! Let the encode begiiiinnnn! ;D
Old 5th April 2015, 19:35   #12  |  Link
ditche
Same bug, same solution, thank you
ditche is offline   Reply With Quote
convert, megui, mjpeg, mjpeg to mp4
