29th August 2009, 02:44 | #5602 | Link | |
:/ I'm still lost on why the subtitles aren't working. |
29th August 2009, 05:16 | #5603 | Link |
If your resizing to 720 from 1080 i have noticed that you need to select the the subs last after you have selected the resize. If you select the subs before you select the resize the subs remain at 1080 and wont be converted to 720. This may be your problem gr1mmj0w btw Atak you may want to look into this problem could be a bug.
29th August 2009, 05:55 | #5604 | Link | |
I store my rips on a nasbox so I can easily stream to my PS3 (which I love oh so much) |
29th August 2009, 12:24 | #5606 | Link | |
29th August 2009, 17:10 | #5608 | Link | |
Thank you good sir, now if I can get this hanging issue fix I would be back on the grind what tool do you use for this? I would greatly appreciate, I would love to burn the subtitles to the video. Last edited by gr1mmj0w; 29th August 2009 at 17:17. |
29th August 2009, 18:09 | #5609 | Link | |
30th August 2009, 16:14 | #5611 | Link |
If I open up an "264" video, It should creat an Index file using DGIndex, right?
what if it does not? When I open it, the "Browse(...)" button gray-out and the "Abort" button become click-able, but it just stuck, nothing appear in temp folder I know it's my problem cause it works great on other PC but I have just no idea what's causing it. Thank you. |
30th August 2009, 16:18 | #5612 | Link | ||
30th August 2009, 17:22 | #5614 | Link |
Put 264 into mkv. Make sure You specify correct fps value!
30th August 2009, 17:28 | #5615 | Link |
Actually, this 264 came from an MKV.
I just extract it out cause I don't want to skip the index creating step. I loaded RipBot on the another computer wtih same folder and DGAVCDec ran without problem so I'm just wondering what could stop it from running. Thanx again. |
30th August 2009, 17:54 | #5616 | Link | |
30th August 2009, 19:09 | #5617 | Link |
Yah I understand that.
I'm just used to use index to find out if the video is corrupted due to some download failures. It did help me sometimes, plus it takes only few more secs, so I always run in this way oh by the way, this problem only occur after I upgrade to 1.14.3, was using 1.14.2. Last edited by NiGHTsC; 30th August 2009 at 19:42. |
31st August 2009, 03:14 | #5620 | Link |
I'm also having issues with VC1 encodes. Whenever I do a VC1 movie, the process finishes in about 1-2 minutes with no file produced. AVC encoded movies work fine. I do not get any errors though, it just stops encoding.
