1st April 2018, 01:52 | #15702 | Link | |
If you did "re install" 1.22.0, then ran auto update's, you should have got a LOT, and ended up with the very latest build, 1.22.2. After a re start. You do realize that it only "look's" for & installs update's every time the program is started ?? Atak needs to post a later build on the 1st page.... |
1st April 2018, 07:48 | #15703 | Link | ||||
1. I am running 1.22.0 (with auto update disabled) as downloaded and everything works. 2. I enable auto update, and restart RipBoot. 3. At start auto update is done, and it shows 1.22.2, I restart 1.22.2 4. I add a new job. Adding works without error. 5. I start encode of job and get error message. Error is consequence of missing Quote:
If you look at screenshot you see Quote:
Clearly RipBot changes behavior after auto update. |
1st April 2018, 08:04 | #15704 | Link | |
And just a heads up, attaching anything on this forum rarely gets cleared to open, so you either need to upload it a file sharing site, and paste the url, then it can be view, and or downloaded. Or, paste a screenshot directly "on here".... |
1st April 2018, 18:38 | #15707 | Link |
Windows is Windows.
1st April 2018, 19:57 | #15709 | Link |
I remember that some user even used some extremely stripped down version of windows for DE mode. WinPE (without taskbar!) or something like that. I don't remember now. It was couple years ago...
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 1st April 2018 at 20:00. |
1st April 2018, 21:32 | #15710 | Link |
Normalize Bug?
I think I found a bug with the Normalize function if Temp drive is something other then C:
The jobXX_EncodeAudio1.cmd command has the cd line to change in the beginning to change to the tools\ffmpeg\bin directory. Since my Temp is D:, this did not work. Adding C: to the beginning of the script allowed the command to work correctly. Then running jobXX_MuxFiles.cmd allowed the job to complete. BTW, I like the use of the *nix shell commands. So very useful. |
2nd April 2018, 12:44 | #15712 | Link |
ByteShare
DE Client Issues
I have a PC that is using a VPN, which creates two networks.
If I have a Encoding Server start on bootup, it starts and shows my local ip address (192.xxx..), but after that any new servers uses the VPN network (10.xxx..). I can see the computer from the my main machine via both a ping and by browsing to a fileshare. I can ping the 192.xxx.. address. Is there anything I can do to get this working, or am I out of luck if I need this Encoding Server to be on a VPN? |
2nd April 2018, 13:22 | #15713 | Link |
You could try to delay encoding server start. You can do that in Task Scheduler.
2nd April 2018, 14:08 | #15714 | Link | |
I've found, as long as the machine running the encoding server can reach the pc hosting, you shouldn't have a problem. go to file explorer, and type in from the computer that is not working \\computername to make sure you can see the ripbot share that it creates. could be a username permissions thing too, don't forget that part. |
2nd April 2018, 17:15 | #15715 | Link | |
ByteShare
Thank you! |
3rd April 2018, 16:52 | #15716 | Link |
ByteShare
HEVC Stable Branch bumped a version: http://msystem.waw.pl/x265/
2.7+3 |
6th April 2018, 11:11 | #15718 | Link |
Hiho. I am totally amazed by this Program, especially from the Distributed Encoding Feature. Thanks a lot.
I have some questions for 2 Issues i was unable to solve or find a solution. 1.) I there a way to tell Ripbot to index all files which are included in a Source MKV File? Example. When adding a MKV File in Ripbot with 2 HD Audio Tracks (True-HD or DTS-Master) only the first audio track is indexed. When i am selecting the second audio Track i have to wait until Ripbot has finished to index it before i can change any other value. While doing Batch Encoding this i really annoying. It would be better if Ripbot is doing it directly when it creates the Jobs. Is there a way to enable this? 2.) I was unable to do a x264 Encode with OpenCL Acceleration when using Intel Integrated Graphics. I have 2 Workstation, one with a i7-3770k and one with a i7-4790. On both Ripbot is doing an encoding only if Acceleration is disabled. I tried several different drivers, but none was working. I always get an unknown OpenCl Error. Any Ideas, I also tried to install the Intel OpenCl SDK but it won't work. If this would work, i could use DE Mode on 3 Machines, at the moment i am only using 2 after i installed a GTX 260 i one of my Workstations and that thing is loud :-) Thanks a lot. Greets Seb |
6th April 2018, 12:18 | #15719 | Link |
1) good idea. I will see what I can do.
2) Unfortunately I have Intel CPU without iGPU so I won't be able to help you in this case. Post whole error message so maybe other users here will be able to help you with this issue.
6th April 2018, 15:30 | #15720 | Link |
Thanks for your answer.
Here is the Log File when i try to encode with OpenCL Acceleration on a Single Machine: C:\>"C:\MKV\RipBot264\Tools\ffmpeg\bin\ffmpeg.exe" -loglevel panic -i "C:\Temp\RipBot264temp\job6\job6.avs" -strict -1 -f yuv4mpegpipe - | "C:\MKV\RipBot264\tools\x264\x264_x64.exe" --colorprim bt709 --transfer bt709 --colormatrix bt709 --opencl --opencl-device 1 --opencl-clbin "C:\Users\User\AppData\Local\Temp\x264_lookahead.clbin" --crf 22 --fps 24000/1001 --force-cfr --min-keyint 24 --keyint 240 --frames 62088 --sar 1:1 --level 4.1 --tune film --aud --nal-hrd vbr --vbv-bufsize 62500 --vbv-maxrate 62500 --stdin y4m --output "C:\Temp\RipBot264temp\video.264" - y4m [info]: 1920x1080p 1:1 @ 24000/1001 fps (cfr) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 x264 [info]: OpenCL acceleration enabled with Intel(R) Corporation Intel(R) HD Graphics 4600 x264 [info]: Compiling OpenCL kernels... x264 [info]: profile High, level 4.1 x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: x264_encoder_encode failed x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode aborted at input frame 46, output frame 0 C:\>"C:\MKV\RipBot264\tools\mkvtoolnix\mkvmerge.exe" -o "C:\MKVWork\Encode\s02e06.mkv" --compression 0:none --title "s02e06" --default-duration 0:24000/1001fps "C:\Temp\RipBot264temp\video.264" --compression 0:none --language 0:ger --sync 0:0 "C:\Temp\RipBot264temp\job6\2_audio_German.dtsma" --compression 0:none --language 0:eng "C:\Temp\RipBot264temp\job6\Encoded_Audio_2.ac3" --default-track 0:yes --forced-track 0:yes --language 0:ger -s 0 -D -A "C:\Temp\RipBot264temp\job6\5_subtitles_German.sup" --default-track 0:no --language 0:ger -s 0 -D -A "C:\Temp\RipBot264temp\job6\4_subtitles_German.sup" --default-track 0:no --language 0:eng -s 0 -D -A "C:\Temp\RipBot264temp\job6\3_subtitles_English.sup" --chapters "C:\Temp\RipBot264temp\job6\chapters.txt" mkvmerge v22.0.0 ('At The End Of The World') 32-bit Error: The type of file 'C:\Temp\RipBot264temp\video.264' could not be recognized. ------------------------- Elapsed Time: 00h:00m:26s And this is the Output of the Encoding Server if i try DE Mode: Encoding started... ""\\VIPER\Ripbot264temp\Tools\ffmpeg\bin\ffmpeg.exe" -loglevel panic -i "\\VIPER\RipBot264temp\job6\Chunks\1.avs" -strict -1 -f yuv4mpegpipe - | "\\VIPER\Ripbot264temp\tools\x264\x264_x64.exe" --seek 0 --colorprim bt709 --transfer bt709 --colormatrix bt709 --opencl --opencl-device 1 --opencl-clbin "C:\Users\User\AppData\Local\Temp\x264_lookahead.clbin" --crf 22 --fps 24000/1001 --force-cfr --min-keyint 24 --keyint 240 --frames 1437 --sar 1:1 --level 4.1 --tune film --aud --nal-hrd vbr --vbv-bufsize 62500 --vbv-maxrate 62500 --stdin y4m --output "\\VIPER\RipBot264temp\job6\Chunks\1.264" -" y4m [info]: 1920x1080p 1:1 @ 24000/1001 fps (cfr) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 x264 [info]: OpenCL acceleration enabled with Intel(R) Corporation Intel(R) HD Graphics 4600 x264 [info]: profile High, level 4.1 x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: x264_encoder_encode failed x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode aborted at input frame 46, output frame 0 Encoding terminated. Connection Closed Gracefully. Maybe someone has an Idea. Another Question. In DE Mode, would it be possible that every Machine has a different Setting for the OpenCL Acceleration and the Encoding Servers are using the Setting of the Machine they are runnig on? With the actual Ripbot Version the Settings of the Host Machine will be used for every involved Server and overrides the Setting of the local machines running the Encoding Servers. If this would work it would be a Solution for the Intel Graphic Problem. Last edited by Privateer5000; 6th April 2018 at 15:33. |
