Old 7th March 2018, 20:00   #14601  |  Link
mtamimi
I tried to change an audio file from 29.970 to 25.000 using the following command
eac3to source29970.mp2 output25000.mp2 -29.970 -changeTo25.000
but the output file is identical to the source, nothing changed...am I doing it wrong?
Thnx
mtamimi is offline
Old 7th March 2018, 20:02   #14602  |  Link
Audio doesn't really have a frame rate as such, its a video property. What exactly do you want to happen?
nevcairiel is offline
Old 7th March 2018, 20:10   #14603  |  Link
mtamimi
So speedingup and down is just for video? Can I use the audio from 29.970 video in a 25.000 video?
mtamimi is offline
Old 7th March 2018, 20:59   #14604  |  Link
Richard1485
eac3to source29970.mp2 output25000.mp2 -speedup
Old 7th March 2018, 21:16   #14605  |  Link
It depends how those videos are made. Are they exactly the same length? Then yes, the audio doesn't need to be changed.
Often 29.97 to 25 would be IVTC'ed to 23.976 and then speed-up from there, so durations may differ slightly, but you would have to do that speedup step, and not a 29.97 -> 25 slowdown.
Old 23rd March 2018, 15:45   #14606  |  Link
thecoreyburton
Sometimes when dealing with AC3 tracks, I get the message "Reducing depth from 64 to 24 bits". The source audio in these cases is always reported by MediaInfo to be 16-bit. Is it practical to use "-down16" in these cases, or is it reducing (or increasing, rather?) the depth to 24 bit for a specific reason?
Old 23rd March 2018, 15:59   #14607  |  Link
sneaker_ger
You can ignore the MediaInfo information. AC3 tracks do not have any inherent bitdepth (TrueHD is different). The AC3 decoder decodes it at 64 bit. Then eac3to automatically dithers that down to 24 bit because humans cannot hear a difference anyways and 64 bit files would be huge (or the target format doesn't support 64 bit in the first place). You can reduce the bitdepth further to 16 bit if you want and will probably not hear any difference. But this only makes sense if you are compressing to a format that does have a set bitdepth (e.g. FLAC, wav), not if you target AC3, AAC, MP3, ...
sneaker_ger is offline
Old 23rd March 2018, 16:22   #14608  |  Link
thecoreyburton
Perfect! That not only resolves my question, but also also a few other nagging thoughts I had as well.
Old 25th March 2018, 06:38   #14609  |  Link
wolflop
Can someone tell me how I can demux a Dolby Digital Plus 7.1 into individual wavs?
thanks
wolflop
wolflop is offline
Old 25th March 2018, 08:13   #14610  |  Link
Music Fan
This should work (add s after wav) to get 24 bit ;
eac3to input.ac3 output.wavs
Or add -down16 if you need 16 bit ;
eac3to input.ac3 output.wavs -down16
Music Fan is offline
Old 25th March 2018, 18:19   #14611  |  Link
wolflop
This does not work with DD. with other tracks that goes (I use the eac3togui) with DD aborts the program with error message
wolflop is offline
Old 25th March 2018, 19:12   #14612  |  Link
And why do you believe that we do not want to know the exact error message? Or even better, a whole console output log, if the GUI doesn't hide that from the user.
LigH is offline
Old 25th March 2018, 19:12   #14613  |  Link
Music Fan
Did you get an error message ?
edit : LigH was faster
Old 26th March 2018, 00:10   #14614  |  Link
tebasuna51
tebasuna51's Avatar
EAC3 7.1 can't be decode to 7.1 channels with free soft.
ffmpeg can decode it to 5.1:
ffmpeg -i input.eac3 decoded.w64
and after to individual 6 wavs (maybe ffmpeg can do this directly):
eac3to decoded.w64 output.wavs
tebasuna51 is offline
Old 26th March 2018, 00:43   #14615  |  Link
BonumMonstrum
only subtitle demux
Hello everyone!
I'm using eac3to quite often, but by now i couldnt figure out how to ONLY demux subtitles.... maybe you guys can help me with that...? Demuxing the whole files only for the subtitles takes soo much time and I would love to reduce this ...
Thanks a lot in advance for your help!!!
BonumMonstrum is offline
Old 26th March 2018, 07:32   #14616  |  Link
Well, the main purpose of eac3to is processing audio streams. To demultiplex subtitles only, you may find tools better specialized in this task. It would help to know your source format (DVD Video, Blu-ray?) to suggest accordingly.
LigH is offline
Old 26th March 2018, 07:58   #14617  |  Link
richardpl
Have you found actual EAC3 7.1 which are not test streams?
Maybe if you report such streams, there is higher chance of it being supported in FFmpeg.
richardpl is offline
Old 26th March 2018, 09:37   #14618  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
You can demux the subtitles exactly like any other stream.
Example: demux English subtitles from a BD playlist.
First, issue this command to inspect the content of the playlist (assuming angle 1):
path\to\eac3to.exe V:\BDMV\PLAYLIST\00200.mpls 1)
You will see something like this:
M2TS, 2 video tracks, 6 audio tracks, 4 subtitle tracks, 0:07:13, 24p /1.001
1: Chapters, 3 chapters
2: h264/AVC  (left eye), 1080p24 /1.001 (16:9)
3: h264/MVC (right eye), 1080p24 /1.001 (16:9)
4: DTS Master Audio, English, 7.1 channels, 24 bits, 48kHz
   (core: DTS, 5.1 channels, 1509kbps, 48kHz)
5: DTS Hi-Res, English, 5.1 channels, 2046kbps, 48kHz
6: AC3 Surround, English, 2.0 channels, 320kbps, 48kHz, -24ms
7: AC3 Surround, English, 2.0 channels, 320kbps, 48kHz, -24ms
8: AC3, French, 5.1 channels, 640kbps, 48kHz, -24ms
9: AC3, Spanish, 5.1 channels, 640kbps, 48kHz, -24ms
10: Subtitle (PGS), English
11: Subtitle (PGS), English
12: Subtitle (PGS), French
13: Subtitle (PGS), Spanish
Now, demux the subtitle streams 10 and 11:
path\to\eac3to.exe V:\BDMV\PLAYLIST\00200.mpls 1) 10: english1.sup 11: english2.sup
Works perfectly for a BD. I suppose that the same method works with any input file.
r0lZ
Last edited by r0lZ; 27th March 2018 at 10:32. Reason: Added "1)" to specify angle 1 in the eac3to command examples
r0lZ is offline
Old 26th March 2018, 09:38   #14619  |  Link
Boulder
Pig on the wing
Boulder's Avatar
And as the subtitles are muxed into the corresponding files (m2ts, VOB, mkv etc.), eac3to needs to process the whole stream anyway so extracting only the subs is not much faster than extracting audio and subs.
Boulder is offline
Old 26th March 2018, 13:35   #14620  |  Link
BonumMonstrum
First, issue this command to inspect the content of the playlist:
Track 4 is used for destination file "1".
This audio conversion is not supported.
path\to\eac3to.exe V:\BDMV\PLAYLIST\00200.mpls 10: english1.sup 11: english2.sup
Thanks a lot, it works, but not perfectly for my goal: My problem was, that I couldn't get the subtitles from some sources due to some audio streams that wasn't supported - and I always only wanted the subtitles. BUT I also would like to know whether there are forced subtitles or not. Normally eac3to creates a file like
"00125 - 7 - Subtitle (PGS), English, 1080 captions" or "1080 captions, 3 Forced captions"
So the automatic naming of eac3to for files would be nice now
At least I can get the subtitles now, thanks a lot for your help!!!!
eac3to
