Old 26th March 2018, 14:18   #14621  |  Link
Originally Posted by richardpl View Post
Have you found actual EAC3 7.1 which are not test streams?
Maybe if you report such streams, there is higher chance of it being supported in FFmpeg.
There is several Blu-ray discs which use this channel setup. If you need more samples, let me know.
nevcairiel is offline
Old 27th March 2018, 07:37   #14622  |  Link
FrasierCrane
Issue with E-AC3 tracks?
Hi!
Whenever I try to demux a BluRay (m2ts files) containing an E-AC3 (7.1) audio track, eac3to fails. It can not even extract the core and it just aborts. See the log:
eac3to v3.34
command line: "F:\Clown_BD\eac3to\eac3to.exe" "V:" 1) 6: "T:\Clown_BD\Audio_6_German.AC3" -progressnumbers -LOG="T:\Clown_BD\LOGS\eac3to_PASS3_LOG.LOG"
M2TS, 1 video track, 6 audio tracks, 7 subtitle tracks, 1:45:00, 72p /1.001
1: Chapters, 28 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: DTS Master Audio, English, 7.1 channels, 24 bits, 48kHz, dialnorm: -3dB
(core: DTS, 5.1 channels, 1509kbps, 48kHz, dialnorm: -3dB)
4: DTS Hi-Res, English, 5.1 channels, 2046kbps, 48kHz, dialnorm: -3dB
5: AC3, English, 2.0 channels, 320kbps, 48kHz, dialnorm: -28dB
6: E-AC3, German, 7.1 channels, 896kbps, 48kHz, dialnorm: -27dB
(core: AC3, 5.1 channels, 512kbps, 48kHz, dialnorm: -27dB)
7: E-AC3, Italian, 7.1 channels, 896kbps, 48kHz, dialnorm: -27dB
8: AC3, English, 2.0 channels, 320kbps, 48kHz, dialnorm: -27dB
9: Subtitle (PGS), English
10: Subtitle (PGS), German
11: Subtitle (PGS), Italian
12: Subtitle (PGS), English
13: Subtitle (PGS), German
14: Subtitle (PGS), Italian
15: Subtitle (PGS), English
[v02] The video bitstream framerate field doesn't seem to match the timestamps. <WARNING>
[a06] Extracting audio track number 6...
[a06] Removing AC3 dialog normalization...
[a06] Extracting E-AC3 core...
[a06] Decoding with libav/ffmpeg...
[a06] The libav decoder reported error -22 while decoding. <ERROR>
Aborted at file position 1048576. <ERROR>
What is the problem and how do I fix it? When demuxxing the other tracks, they are mostly damaged as well (especially the subtitle tracks) - this only happens when there is such an E-AC3 track present in the m2ts file.
Cheers!
FrasierCrane is offline
Old 27th March 2018, 10:17   #14623  |  Link
tebasuna51
tebasuna51's Avatar
The issue is already reported to madshi.
The eac3 7.1 tracks reported by eac3to like:
6: E-AC3, German, 7.1 channels, XXXkbps, 48kHz, dialnorm: -27dB
(core: AC3, 5.1 channels, YYYkbps, 48kHz, dialnorm: -27dB)
Fails when try to extract to EAC3 with:
eac3to "INPUT" 1) 6: output.eac3
[a06] Applying (E-)AC3 delay failed. <ERROR>
Aborted at file position ... <ERROR>
Also fails when try to recode to AC3 (seems than can't extract the core):
eac3to "INPUT" 1) 6: output.ac3
The unique workaround than work is recode the core to AC3 with a explicit -core parameter:
eac3to "INPUT" 1) 6: output.ac3 -core
[a06] Remapping channels...
[a06] Encoding AC3 <640kbps> with libAften...
[a06] Creating file "output.ac3"...
Video track 1 contains X frames.
eac3to processing took Z seconds.
Done.
tebasuna51 is offline
Old 27th March 2018, 10:24   #14624  |  Link
So it is one of the usual "notorious" Blu-ray E-AC3 streams with 5.1 AC3 core + 2 differential E-AC3 channels as substream?
LigH is offline
Old 27th March 2018, 10:27   #14625  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Originally Posted by BonumMonstrum View Post
BUT I also would like to know whether there are forced subtitles or not. Normally eac3to creates a file like
"00125 - 7 - Subtitle (PGS), English, 1080 captions" or "1080 captions, 3 Forced captions"
So the automatic naming of eac3to for files would be nice now
I'm not sure I understand. eac3to (and all M2TS demuxers) cannot know if there are forced subtitles without analysing the content of the M2TS file, because that information is not stored in a header or in the MPLS file. So, you have to launch the analysis anyway, then inspect the output and manually give proper file names for the demuxed tracks. I suppose that a good GUI should be able to automate that, but with a GUI, you will have to select manually the streams you want to demux. So, unless you write yourself a tool to do exactly what you want, there will always be things to do manually.
BTW, I forgot to specify that if your M2TS is multi-angle, you have to specify the angle to demux with this (assuming angle 1):
path\to\eac3to.exe V:\BDMV\PLAYLIST\00200.mpls 1) 10: english1.sup 11: english2.sup
(I have edited my previous post accordingly.)
r0lZ
r0lZ is offline
Old 27th March 2018, 16:43   #14626  |  Link
mbcd
This is right, if you have a single forced subtitle at the end of the stream / film, you can not recognize it at beginning of the stream, so you have parse the whole stream to find it. If you dont have some addition file which contains a listing of all streams, you have to decode the complete stream.
mbcd is offline
Old 28th March 2018, 21:23   #14627  |  Link
Smithy
The NEW DD+ @ BD have 4 (EAC3) Surround Ch's that replace the 2 Surrounds of the 5.1 AC3 Core Track when 7.1 DD+ is playing !
32bit Vista SP2 (DX11 Platform Update), Nvidia GTX960 4GB AMP (365.19), 1. 27' FHD Benq / 2. 65' UHD HDR Sony XE93, madVR 0.92.17, LAV 0.73.1, MPC-HC 1.8.3
Smithy is offline
Old 29th March 2018, 09:18   #14628  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
After a stalled start with HD-DVD there's no doubt that Dolby Digital Plus is back and expanding it's feature-set, especially as more streaming services embrace object-based (Atmos) audio.
With Atmos in mind... Have any of you guys downloaded Dolby's 7.1.4 and 9.1.6 (DD+ with Atmos) samples, that were muxed into the .mp4 container?
SeeMoreDigital is offline
Old 29th March 2018, 09:22   #14629  |  Link
This is not exactly "new", this setup has been allowed on Blu-ray since forever, it was just rarely used. Still is somewhat rare, but it occurs sometimes.
All that said, FFmpeg should be able to handle this very soon. The patch is basically ready for inclusion. It should come to FFmpeg based players and tools then eventually.
Old 29th March 2018, 10:05   #14630  |  Link
tebasuna51
tebasuna51's Avatar
...FFmpeg should be able to handle this very soon.
Nice to know.
BTW, I suggest a parameter to extract/decode only the 5.1 part for users of 5.1 audio equipment (like me) without need downmix.
Old 29th March 2018, 10:18   #14631  |  Link
richardpl
Yes, there is already eac3_core bitstream filter in git master.
richardpl is offline
Old 29th March 2018, 14:26   #14632  |  Link
Only loosely related: After more than a year, the ffmpeg trac ticket #3595 is active again ... its title got renamed.
LigH is offline
Old 29th March 2018, 15:24   #14633  |  Link
richardpl
And everybody donated single penny.
Old 29th March 2018, 20:21   #14634  |  Link
If I knew it would certainly accelerate something, I would even donate more.
LigH is offline
Old 14th April 2018, 05:37   #14635  |  Link
pstn
does anyone know which command to use to demux a 3d bluray but isolate the 2d part?
pstn is offline
Old 14th April 2018, 08:31   #14636  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Isn't the video for both eyes as its own track? IIRC the left eye stream is the "main" one to demux.
Boulder is offline
Old 14th April 2018, 08:47   #14637  |  Link
This is true when the one eye's content is encoded as AVC video stream, and the other eye's content as MVC substream.
LigH is offline
Old 14th April 2018, 09:04   #14638  |  Link
That is the case for 3DBDs, always. Although left/right could be swapped and the AVC stream actually be the right eye, but there is always one main AVC stream you can just take without the MVC stream to get 2D.
Old 14th April 2018, 12:02   #14639  |  Link
pstn
yes that's what I'm talking about, is there any specific command?
thanks
pstn is offline
Old 15th April 2018, 08:55   #14640  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
To grab the 2D movie, you have to demux the MPLS, and select the AVC video stream and the audio and subtitle streams you are interested in, and drop the MVC. If you want to demux directly the M2TS file(s), you have to locate the one that contains the AVC stream. It's easy with a good player. The M2TS files with the MVC stream cannot be played directly.
The command to demux is exactly identical to the command to demux a 2D BD, just omit the MVC stream. But personally, I would use tsMuxeR instead of eac3to to demux a BD. It has a good GUI, easy to use.
r0lZ
r0lZ is offline
eac3to
