Old 6th August 2015, 02:13   #13761  |  Link
burt123
burt123's Avatar
I didn't forget. There is bug in this forum. After few years you lose rights to change thread's title.
http://forum.doom9.org/showthread.php?t=172423
http://forum.doom9.org/showthread.php?t=171711
OK, sorry about that, then......so I hope you can get to the bottom of that, and get that "fixed", as that was the most obvious way, "we" knew there was a version update.
Cheers
burt123 is offline   Reply With Quote
Old 6th August 2015, 13:16   #13762  |  Link
Wishbringer
Silent Reader
Wishbringer's Avatar
Or start a new thread with same starting post and reference to this one.
my2ct
Btw: can't even thank enough for this nice little piece of software.
Did all tasks manually before.
Wishbringer is offline   Reply With Quote
Old 7th August 2015, 03:42   #13763  |  Link
byteshare
ByteShare
byteshare's Avatar
Silly question
I was trying to search for this but can't seem to get a good answer. How does ripbot handle if one server goes down when using Multi-computer Distributed Encoding? Examples, one computer crashes, or if the power goes out and one of my battery backups doesn't last as long as the others before the power comes back?
I'm just wondering if one goes down if it takes out the chain (assuming the main server doesn't go down)?
Old 7th August 2015, 13:37   #13764  |  Link
slalom
slalom's Avatar
Yes it does take it out
Old 7th August 2015, 18:52   #13765  |  Link
If client loses connection with specific server then chunk assigned with that server will come back to queue. Encoding client will assign again unfinished chunk to next IDLE server.
Old 7th August 2015, 19:33   #13766  |  Link
byteshare
ByteShare
byteshare's Avatar
Oh, sweet! I was just worried with four computers that using this method would make it even less stable, but looks like you have that base covered. Thank you for responding.
Old 9th August 2015, 21:06   #13767  |  Link
slalom
slalom's Avatar
@Atak
For v.1.19
// it will use 64bit version of x264 or x265 on 64bit Windows. up to 10% faster encoding speed.
is set to 1 rather than 0.2. Is that ok?
Old 10th August 2015, 07:07   #13768  |  Link
Wishbringer
Silent Reader
@slalom:
Use64bitEncoder=1
// Sharpening Strength after resizing (Default=0.2)
SharpeningStrength=0.2
Maybe you read the wrong line.
64bit is a switch (true/false = 1/0)
and was implemented long ago:
v1.13.0
Added: support for x264 64bit (up to 10% faster encoding)
Old 10th August 2015, 08:55   #13769  |  Link
slalom
slalom's Avatar
You're right
There must be a mistake on that .ini, checked older versions too, the value is 1
Old 12th August 2015, 02:16   #13770  |  Link
soneca
There seems to be a problem in the aspect ratio...
Preview is correct
Settings
Result
Aspect ratio by mediainfo > 3.184
Already converted some bd's with the same ratio without problems using the latest version of Ripbot, but I'll redo it from scratch.
Edit: The problem is the strange blu-ray, nonstandard...
Old 12th August 2015, 08:06   #13771  |  Link
Jake802
Hi everyone,
My completed files are not showing up at all. Any ideas?
Jake802 is offline   Reply With Quote
Old 12th August 2015, 09:53   #13772  |  Link
check log.
Old 12th August 2015, 13:57   #13773  |  Link
g0th1ckn1ght
DTS MA and True HD
I was wondering how do I keep the 7.1 DTS MA / True HD audio tracks in my mkv.
In the select stream window i select the DTS Master Audio, English, 7.1 channels, 24bits, 48khz option. At the Encoding Settings window it only show 6 channels i have the profile set to XX.Copy Stream.XX.
I would really like all audio channels (7.1) in my converts, so any help would be appreciated
g0th1ckn1ght is offline   Reply With Quote
Old 12th August 2015, 15:13   #13774  |  Link
If you selected demux option and then Copy Stream then your final mkv should have original untouched 7.1 audio. You can verify number of channels in mkv in mediainfo.
You see only 6 channels in gui because current decoder sees only core part.
Old 13th August 2015, 01:35   #13775  |  Link
g0th1ckn1ght
Thank you very much Atak.
I will give that try and see how it goes.
Thanks again
Old 13th August 2015, 03:53   #13776  |  Link
Jake802
Atak,
I got rid of the damn log file, but I originally checked it and it said the file was were it was supposed to be, but the file was not there. Let me run it again and I will keep and post the log this time.
Sorry!
Old 13th August 2015, 21:48   #13777  |  Link
Jake802
Ok I am not seeing a log file and nothing showed up still.....Alright even weirder When I just went to open up RipBot it opened to where the file is. I can now see the file but cannot do anything with it and it does not show in my Windows Explorer when I try to access it.......
Old 13th August 2015, 23:50   #13778  |  Link
fantasmanegro
Using aac 5.1 is too much for my 2.0 TV speakers... so do mixing to stereo is OK for me but, the voice is too low ...
is there a way to increase the volume in voice channel or decrease a little the background and effects?
fantasmanegro is offline   Reply With Quote
Old 14th August 2015, 05:41   #13779  |  Link
byteshare
ByteShare
byteshare's Avatar
You should try normalization 200% Or, you can use another program to process the audio the way you need.
Old 14th August 2015, 12:21   #13780  |  Link
Open DownMixAudio.avs in notepad
and increase this value
function DownMix2Stereo(clip a)
a=ConvertAudioToFloat(a)
fl = GetChannel(a, 1)
fr = GetChannel(a, 2)
c = GetChannel(a, 3)
lfe = GetChannel(a, 4)
sl = GetChannel(a, 5)
sr = GetChannel(a, 6)
l_sl = MixAudio(fl, sl, 0.2929, 0.2929)
c_lfe = MixAudio(lfe, c, 0.2071, 0.2071)
r_sr = MixAudio(fr, sr, 0.2929, 0.2929)
l = MixAudio(l_sl, c_lfe, 1.0, 1.0)
r = MixAudio(r_sr, c_lfe, 1.0, 1.0)
return MergeChannels(l, r)
Save and verify loudness in ripbot264 (Preview script). Audio Normalization set at 100%.
