#15741 | Link |
Brawl in Cell Block 99 is no longer being identified as HDR after the update. I am encoding now and will report back the results. Thanks Atak for the quick resolution on the issue.
UPDATE: Encode turned out great! Problem solved. Any idea about my audio issue? Strangely when I tried to break down one of the films to provide a sample, the sample worked. So I tried remuxing the whole film to see if that helped. The whole film remuxed still does not work. When I look in the test file for the job I see this: [avisynth @ 0000025e2cd3d100] FFAudioSource: No audio track found (C:\Temp\RipBot264temp\job2\getinfo.avs, line 4) C:\Temp\RipBot264temp\job2\getinfo.avs: Unknown error occurred The audio track is in the directory, but FFAudioSource is not recognizing it, yet MediaInfo correctly recognizes it as a TrueHD/Atmos track. This file plays fine on all of my end devices and PC so I really don't think it is the file itself. In the interim I have started remuxing the questionable titles without audio and running them through RipBot and remuxing the final product. Works, but a definite pain. Fortunately I don't have many (yet) with the issue. I have completed 52 encodes and have 214 to go with 3 titles not working properly. Last edited by Balthazar2k4; 16th April 2018 at 15:06. |
#15742 | Link |
Maybe there is something unusual at the beginning or end of that audio track.
#15745 | Link |
Latest x265 builds have avx-512 support.
#15747 | Link |
"Update" overwriting files it shouldn't
A recent update downgraded my mkvtoolnix from 64 bit to 32 and overwrote my mkvtoolnix-gui.ini file, containing my preferences.
Please prevent this. Last edited by FuzzyNutz; 17th April 2018 at 01:42. |
#15748 | Link | |
Where, using BT2020-BT709, the video is awful, and using No Tone Mapping, I get a black screen. The only way I knew how to "fix" it, was to run it thru Handbrake, converting the x265 back to x264, with basic audio settings, then afterwards, running it thru Ripbot again, with the default settings, which I think had changed to No Tone Mapping, and the end result was good ![]() If you would like me to send you a sample of said movie, please refresh my memory on how to do a small "grab" of the original. |
#15749 | Link |
Yes! Sample please!
#15751 | Link |
OK, I have done a 350mb sample, but I couldn't find or get DGSplit, so I had to use MKVToolNix.
Where can I get DGSplit ?? all the links I found are all dead ![]() So hopefully that's worked, and I hope you find a problem. http://www.mediafire.com/file/6n6yas....World.2017.7z ![]() |
#15752 | Link | |
http://rationalqm.us/mine.html
#15753 | Link | |
#15754 | Link |
Hi. In version 1.23 I'm missing the "x264LowPriority" - setting. If I set it to "1" in the .ini it gets reset. Within the RipBot-Settings I can't find it.
I'm currently testing the golem-network which should get the CPU - power it needs so ripbots encoding show be at low priority. I know I can change it manually from taskmanager but I have several encodings which should run over night and every job would start a new x264-process which then would run with normal priority. |
#15755 | Link | |
ByteShare
Do you already have a variable frame rate solution in RipBot? |
#15756 | Link |
I'm having a bit of an issue, when using DE.
It's kinda random, but towards the very end of an encode, one or maybe 2 "chunk's" stop being processed, and when I try to stop the particular server that is processing that chunk, it won't, or worst case it will abort the whole process, and start the next Job. But if you don't attend to it, it will continue "forever" and not get anywhere ![]() Is there someway, that the server's or chunks can be "refreshed", or a warning, if a "stall" happen's. ??? |
#15757 | Link | |
![]() @byteshare no. @burt123 What do you mean exactly? Encoding server hangs (frozen progress) while x264/x265 is still doing it's job?
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 20th April 2018 at 12:22. |
#15758 | Link | |
But you can't stop the server that is processing the stalled chunk. It's only random, but that's the pain of it...if you don't check it every so often, it could be "sitting" there for hours ![]() |
#15759 | Link | |
Does MPC-HC play that file correctly?
#15760 | Link | |
![]() P.S. Accidentally captured the ffmpeg - process (which also could run in lower priority). Here is the x264-process: ![]() Last edited by klopsknoedel; 20th April 2018 at 21:41. |
