Old 18th September 2017, 20:40   #1581  |  Link
stax76
stax76's Avatar
Can somebody point me to a sample containing:
MaxCLL - Maximum Content Light Level
MaxFALL - Maximum Frame-Average Light Level
Old 29th October 2017, 12:27   #1582  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
MediaInfoXP v2.27 (MediaInfo v0.7.99):
https://sourceforge.net/projects/mul...9.zip/download
* MediaInfo updated to v0.7.99 (2017-09-11)
* Build environment upgraded to Visual Studio 2017 (15.4)
Old 29th October 2017, 16:41   #1583  |  Link
StainlessS
StainlessS's Avatar
Praise the Lord
Thanx
I sometimes post sober.
Old 2nd November 2017, 21:59   #1584  |  Link
It looks like that method of numbering versions has been changed to YEAR.MONTH
https://sourceforge.net/projects/med...ary/mediainfo/
Old 12th November 2017, 10:33   #1585  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Hi Zenitram !
Many thanks for your continued work !
While going through my testfiles I found mediainfo recognising multichannel MPEG Audio Layer 2 streams
(I got 4-CH, 5-CH, 6-CH as 5.1, up to 8 shall be possible) as 2 channel streams.
I can supply some testfiles, if needed.
Old 12th November 2017, 14:36   #1586  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by Emulgator View Post
Hi Zenitram !
AFAIK, MPEG Audio Layer II only supports channel modes "Stereo" (00), "Joint Stereo" (01), "Dual Channel" (10) and "Single Channel" (11). Same for Layer III, by the way.
https://web.archive.org/web/20150208...at/mpeghdr.htm
The so-called "MPEG Multichannel" extension uses a “channel matrixing scheme, where the additional channels are mixed into the two backwards compatible channels”, similar (but apparently not compatible to) Dolby Pro Logic.
So, technically, this would still be a Stereo file, just with the signals for the additional "sourround" channels mixed into the actual two (Stereo) channels...
Old 12th November 2017, 20:25   #1587  |  Link
Emulgator
Emulgator's Avatar
Ah, thank you, that clears it up and at the same time explains why these multichannel files can be decoded with a stereo decoder.
I found Center mixed 50/50 into L/R, SL into L, SR into R.
Old 18th December 2017, 14:40   #1588  |  Link
What are string codes for these items?
Mastering display color primaries        : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000
Mastering display luminance              : min: 0.0050 cd/m2, max: 4000.0000 cd/m2
Maximum Content Light Level              : 1529 cd/m2
Maximum Frame-Average Light Level        : 380 cd/m2
I'm checking list of parameters in documentation (Developers\List_Of_Parameters\Video.csv) and I can't find anything related to above items.
Old 18th December 2017, 16:55   #1589  |  Link
Zenitram
they are currently not MediaInfo "standard" (they could in the future, maybe slightly modified). Field names can be seen with command line and " --Language=raw" or XML output in the GUI, e.g.:
<MasteringDisplay_ColorPrimaries>R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000</MasteringDisplay_ColorPrimaries>
<MasteringDisplay_Luminance>min: 0.0050 cd/m2, max: 4000.0000 cd/m2</MasteringDisplay_Luminance>
<MaxCLL>10000 cd/m2</MaxCLL>
<MaxFALL>111 cd/m2</MaxFALL>
Want to know all about your media files? http://mediaarea.net/MediaInfo
Zenitram is offline   Reply With Quote
Old 19th December 2017, 17:41   #1590  |  Link
What is equivalent of
Transfer characteristics                 : PQ
in x265 settings
--transfer <string>           Specify transfer characteristics from bt709, unknown, reserved, bt470m, bt470bg, smpte170m,
                                 smpte240m, linear, log100, log316, iec61966-2-4, bt1361e, iec61966-2-1,
                                 bt2020-10, bt2020-12, smpte2084, smpte428, arib-std-b67. Default undef
According to this I'm guessing that smpte2084.
Old 19th December 2017, 17:44   #1591  |  Link
Zenitram
in x265 settings
smpte2084
Old 19th December 2017, 17:58   #1592  |  Link
It would be much easier for user if you used well known values like in x264/x265 documentation. In this case smpte2084 instead of PQ,
bt2020nc, bt2020c instead of BT.2020 non-constant/constant.
--colorprim <string>          Specify color primaries from  bt709, unknown, reserved, bt470m, bt470bg, smpte170m,
                                 smpte240m, film, bt2020, smpte428, smpte431, smpte432. Default undef
--colormatrix <string>        Specify color matrix setting from undef, bt709, fcc, bt470bg, smpte170m,
                                 smpte240m, GBR, YCgCo, bt2020nc, bt2020c, smpte2085, chroma-derived-nc, chroma-derived-c, ictcp. Default undef
Old 19th December 2017, 20:25   #1593  |  Link
Zenitram
I am in good mood, so let's go.
Sure, as soon as you can prove that what x264/x265 do is "well known" for all people involved with colors.
Spoiler: you won't be able to prove that, as I already had the opposite complain ("please use PQ wording, please use well know values, instead of this crazy SMPTE number") during some beta version.
Ho, BTW, please hint x265 people to change their name, because they do HEVC, look at the URL here https://en.wikipedia.org/wiki/High_E...y_Video_Coding , "265" is not known by everyone, look it is not in the URL of Wikipedia English (but it is in the French version, funny isn't it?), why do they mislead people with "265" thing? (I use "HEVC" word, sorry "H.265" people)
(A bit) more seriously, please don't do assumption that x265 people have the "real truth", they are not the center of the universe and they don't represent the industry as a whole (because the industry is not a whole), and in the case of "PQ" it is the "well known value" used by one of my sponsor, a lot known in this industry, and actually my policy is to try to avoid SMPTE number (side note: this is "SMPTE ST 2084", not "SMPTE 2084") when I can because they are difficult to memorize (and are less known than the BT ones), beside prioritizing American names (MPEG ones: AVC, HEVC...) other ITU names (H.264, H.265) when it is a joint venture with only different names in their respective standard bodies.
Warning, in the next release there is a change in order to meet this policy, as I was not aware of "well known names" (remark: someone complained about the exact opposite of your remark when he indicated new names, because I was using SMPTE numbers, the ones used by x265, and not "well known names" from his point of view, he wanted me to replace by his "well known values"), I used SMPTE numbers 431-2 and 432-1 (funny isn't it that such numbers are difficult to differentiate? Worse, one is "RP" and the other is "EG" and 431 alone does not exist, it is 431-2) only because I was not aware of "well known names" and I'll replace them by "DCI P3" and "Display P3" (commit).
summary: your "well known values" are not the "well known values" of some other people, and whatever I choose, someone will complain, this is not the first time and it will not be the last time, as MediaInfo is used by a lot of very different people in this industry, each "community" having different "well known value", when I choose a name I am sure another "community" will complain. I may add option "choose your community" in the future if people are crazy enough for paying for seeing their "well known values" instead of the ones I chose.
PS: bt2020nc means exactly "BT.2020 non-constant", I just show something more "readable", why should I limit the display to a limitation of the command line? I may use "codes" (short names without spaces) internally in the future, but nothing says that I would use x264/x265 choices vs other tools choices.
PPS: in an ideal world, everyone would speak the same language and everyone would use the same "well known values", unfortunately we are not in this ideal world so if you don't do any "translation", someone else will do the same remark about his need to have a translation between your values and his values.
Old 19th December 2017, 20:40   #1594  |  Link
Do you have a full list of "your well known codes" so I could translate them to "my well known codes" for x264/x265 use?
I just need to know that I pass correct codes to encoder. That's all.
Old 19th December 2017, 21:06   #1595  |  Link
Zenitram
Here for MPEG related value, Here for DPX values.
but right, definitely a need of better doc (not in code)
Old 20th December 2017, 18:17   #1596  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
#MediaInfo users, we need some testers of #MediaInfoOnline technology preview.
MediaInfo in your browser, without installing any software and everything stays on your machine.
mediaarea.net/MediaInfoOnline
Old 21st December 2017, 14:59   #1597  |  Link
Q-the-STORM
what kind of testing do you need? Testing various files and comparing to local mediainfo output, or testing with various browsers, OS, etc...
Text output slightly differs from v17.12 in this line:
v17.12
Format settings, RefFrames
online
Format settings, ReFrames
Q-the-STORM is offline   Reply With Quote
Old 21st December 2017, 15:03   #1598  |  Link
Zenitram
testing with various browsers and report if something does not work, ideas for improvement...
v17.12
online
Hum... old bug, should not be there anymore, we'll work on that, thanks.
Old 21st December 2017, 16:51   #1599  |  Link
Q-the-STORM
I tested a few more files just to see if I could find more differences, only found two:
I got an old folder with 8 calibration mp4s.
Online doesn't show x264 settings and nominal bitrate on 7 of them
https://www.diffchecker.com/oUUJHGmc
the 8th does correctly show x264 settings and nominal bitrate, it's the only one of them that is larger than 1MB, the rest are smaller than 1MB.
This one doesn't show source duration and Source stream size online
https://www.diffchecker.com/cgPO4RsV
though in this case source duration and duration are the same so it doesn't matter much, though it would be nice to have the exact same output online if possible.
I tested old youtube downloads, some old xvids, vobs from DVDs, some more recent x264 mkvs, hevc hdr video, TV recordings, and some more unusual video like vfr cellphone video, unusual framerates, various containers (mp4, mkv, ts, flv, m2ts), also besides video, some flac, mp3, png, gif and some other files, all had the same output as 17.12.
btw I'm using Win 10 + chrome x64
Old 21st December 2017, 16:55   #1600  |  Link
Zenitram
Thank you for the test, it is useful. Is it possible to get the file?
(...) though it would be nice to have the exact same output online if possible.
We agree! It is the goal.
