Old 9th April 2019, 18:12   #16861  |  Link
Ryushin
Ryushin's Avatar
If this happens at 4:00 mark then maybe you could cut out first 5 minutes from source video and send it to me?
I'm seeing random frame corruption even when not using DE. And it seems to be random. Doing another encode of the trimmed version did not show the same corruption in the same place.
I'll get you a trimmed 5 minute source of the source that I use for testing. Thing is, the new ffms2 fixed the decoding problem but not the DE corruption at the 4 minutes mark.
Old 9th April 2019, 19:22   #16862  |  Link
byteshare
ByteShare
byteshare's Avatar
Is the screenshot from VLC? Is it the same in MPC-HC (Media Player Classic Home Cinema)
Old 9th April 2019, 22:13   #16863  |  Link
Ryushin
Ryushin's Avatar
VLC, SMPlayer, MPlayer, MPV Player, and MPC-HC all have the same corruption.
The joy of VC-1.
Old 9th April 2019, 22:37   #16864  |  Link
byteshare
ByteShare
byteshare's Avatar
The joy of VC-1.
Just checking because I've seen that sort of visual issue with VLC but then not seen it with the same file in other players such as SMPlayer and MPC-HC.
Old 10th April 2019, 23:42   #16865  |  Link
Viper714
So, I am having an issue with my Encoding server on one machine out of three. Unfortunately it is the latest machine with the more powerful CPU & GPU. I start the encoding server and it it does not show on the taskbar or the system tray. If I go to the task manager it is there. Anybody have this issue?? It worked great about 3-4 weeks ago when I last used it. I recently updated to Windows 1809. could that be the issue? Would appreciate any help on this one!! Thanks
Viper714 is offline   Reply With Quote
Old 11th April 2019, 10:31   #16866  |  Link
Use Process Hacker or Process Explorer to check if EncodingServer.exe is not being blocked by other program.
https://forum.doom9.org/showthread.p...06#post1862506
Old 11th April 2019, 16:34   #16867  |  Link
Ryushin
Ryushin's Avatar
So I've trimmed it to 5, 10, and 15 minutes and the corruption does not show up. But it does every time I do the native source. I'll watch the 15 minutes source all the way through and see if it happens that I can repeat. This inconsistency with VC-1 is getting on my nerves. <grrrrrr>
Old 11th April 2019, 20:20   #16868  |  Link
byteshare
ByteShare
byteshare's Avatar
Have you tried remuxing the whole thing to see if maybe the container is causing some issue?
Old 12th April 2019, 09:06   #16869  |  Link
duffbeer
I've seen no problems with any of my VC-1 encodes and I have done quite a few recently. I don't use DE as I only have 1 PC.
I haven't seen any other reports of this issue so maybe the problem is local to your setup?
duffbeer is offline   Reply With Quote
Old 13th April 2019, 14:46   #16870  |  Link
Ryushin
Ryushin's Avatar
Well, for giggles I'll pull down the latest version and let it do updates and run my tests again.
Old 13th April 2019, 18:20   #16871  |  Link
stryker412
I'm building a new machine. I currently have an aging i7-950 and encodes take a little over an hour per episode for a 45 minute ep on 2-pass. What is Ripbot more dependent on, GPU or CPU/RAM?
stryker412 is offline   Reply With Quote
Old 13th April 2019, 18:23   #16872  |  Link
Cpu with many cores...
Old 13th April 2019, 18:28   #16873  |  Link
stryker412
With an 8 core, what types of speed increases would I see?
https://cpu.userbenchmark.com/Compar...-950/4030vs617
Old 13th April 2019, 18:29   #16874  |  Link
x264 or x265? Ryzen cpu?
Old 13th April 2019, 18:30   #16875  |  Link
stryker412
Just edited my previous post with a comparison. I mainly use x264, I haven't gotten into x265 just yet.
Old 13th April 2019, 18:34   #16876  |  Link
Something around 3x speed up
Old 13th April 2019, 18:35   #16877  |  Link
stryker412
Ok so like I said, my episodes take a little over an hour and they would decrease to ~20 minutes? Nice! Thanks.
Old 13th April 2019, 18:44   #16878  |  Link
IPC in 9gen is atleast 1.5x higher than in Nehalem. Furthermore You also get higher all core turbo clock + faster ram so 3x should be a minimum.
Old 18th April 2019, 01:54   #16879  |  Link
Ryushin
Ryushin's Avatar
I have a VC-1 source that is giving me corruption using DE or standalone. I've trimmed the Blu-ray source down and removed everything except trimmed m2ts file under STREAM.
There is also two samples along with a text file that outlines the corruption times. Link expires in two weeks:
https://cloud.chrisdos.com/index.php/s/TkXFnas6yMqtnE4
Please let me know if there is anything else I can provide.
Old 18th April 2019, 17:05   #16880  |  Link
Ryushin
Ryushin's Avatar
BTW, I installed fresh copies of the latest version of Ripbot. Only thing I backed up and restore were my two ini files. I also made a change in the profile to add --sar 1:1.
