28th December 2019, 04:00 | #29081 | Link |
It does not. Look at the web page again. It supports 3D Audio, not 3D video.
Plus, it does not support lens shift, a needed requirement to avoid the use of keystone correction. Sorry, but IMHO, the projector that I pointed out, fits my needs. YMMV.
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 28th December 2019 at 04:10. |
28th December 2019, 04:09 | #29082 | Link | |
I discovered something yesterday. While a majority of movie theater projectors are 4K, the DCI spec for 3D is that they are only 2K. Could be why there is no UHD 3D Blu-ray, since there will never be a 3D movie in 4K. |
28th December 2019, 13:57 | #29083 | Link | |
Was it an imported source or UHD-BD? Was it a movie-only or full backup? Is is BD output? MP4? MKV? Was it reencoded, or did you keep the original? A bug report with nothing to go on leaves me with no choice but to ignore it. Last edited by jdobbs; 28th December 2019 at 14:49. |
28th December 2019, 17:14 | #29084 | Link |
We've had the same report over at the redfox forums that there's problems with DV support. (in the german section) users. I don't understand enough german to actually read it. I just understand a word here and there. I can link to the topic if wanted
28th December 2019, 20:34 | #29086 | Link |
When editing the config file, the version is still listed as 0.60.0.29.
I'm doing a test UHD of Hunger Games to BD50, pretty much using the defaults, except that the minimum import threshold is 1. I have no idea if it is going to do a single pass or a two-pass encoding. |
28th December 2019, 21:25 | #29087 | Link | |
If you want to do it faster, change the settings to "One Pass (ABR)" and "Good (Fast)". If you that isn't fast enough, you can edit the INI and set ENCODE_QUALITY=5. That will run X265 at it's highest speed. No UHD encode is going to go very fast compared to HD -- but it will be faster that HQ mode. Honestly, if you are outputting to BD-25 or BD-50, you are unlikely see a noticeable quality difference when compared to HQ. Sorry about the version thing, I forgot to update the internal version number to v0.61.01... it won't hurt anything. Last edited by jdobbs; 28th December 2019 at 21:57. |
28th December 2019, 21:40 | #29089 | Link | |
1. Download the executable at this link (v0.61.02). 2. Replace the EXE in the BD-RB folder 3. Add the following line to the [Options] area of your BDREBUILDER.INI file: UHD_TSMUXER=0 4. Report back and let me know the results. If it works, it will help me in determining what is wrong with the tsmuxer4k Dolby output. That line in the INI tells BD-RB to use the old method (using the old TSMUXER version and remuxing it within BD-RB). It has some fixes that weren't in v0.60.29. You need this new version, though, as that line will cause a problem in v0.61.01. Last edited by jdobbs; 28th December 2019 at 21:54. |
28th December 2019, 21:45 | #29090 | Link |
The computer that it is being recoded on is pretty much only used for this kind of stuff, so it can take as long as it wants.
I don't have the UHD player yet. That won't happen until early next year. This is to just test the whole recoding process. The audio is Dolby Atmos and I will be setting up for that capability. At least that is the plan. Certain things must take place first. |
28th December 2019, 22:45 | #29091 | Link |
The log-file of the DV disc Cold Pursuit:
[12.28.19] BD Rebuilder v0.61.01 [15:57:21] Source: COLD_PURSUIT - Input BD size: 78,62 GB - Approximate total content: [02:04:46.291] - Target BD size: 46,26 GB - Windows Version: 6.2 [9200] - Quality: Good (Fastest, BD-25+), CRF - Decoding/Frame serving: FFMPEG - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 [15:57:29] PHASE ONE, Encoding - [15:57:29] Processing: VID_00000 (1 of 14) - [15:57:29] Extracting A/V streams [VID_00000] - [15:57:34] Reencoding video [VID_00000] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 1.046 frames - [15:57:34] Performing CRF Prediction... - Analyzing 1,00 13,25 12,75 [13,00] - [15:57:54] Encoding using constant rate factor. - [15:59:10] Video Encode complete - [15:59:10] Processing audio tracks - Track 4356 (deu): Keeping original audio - [15:59:10] Multiplexing M2TS - [15:59:14] Processing: VID_00001 (2 of 14) - [15:59:14] Extracting A/V streams [VID_00001] - [15:59:18] Reencoding video [VID_00001] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 631 frames - [15:59:18] Performing CRF Prediction... - Analyzing 10,50 5,75 3,38 2,19 1,59 1,30 1,15 1,07 1,04 [1,00] - [16:02:36] Encoding using constant rate factor. - [16:03:21] Video Encode complete - [16:03:21] Processing audio tracks - Track 4356 (deu): Keeping original audio - [16:03:21] Multiplexing M2TS - [16:03:24] Processing: VID_00002 (3 of 14) - [16:03:24] Extracting A/V streams [VID_00002] - [16:03:48] Reencoding video [VID_00002] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 8.582 frames - [16:03:48] Performing CRF Prediction... - Analyzing 1,00 9,95 8,00 [8,30] - [16:04:12] Encoding using constant rate factor. - [16:14:16] Video Encode complete - [16:14:16] Processing audio tracks - Track 4356 (deu): Keeping original audio - [16:14:16] Multiplexing M2TS - [16:14:25] Processing: VID_00003 (4 of 14) - [16:14:25] Extracting A/V streams [VID_00003] - [16:14:29] Reencoding video [VID_00003] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 211 frames - Bitrate: 35.000 Kbs - [16:14:29] Reencoding: VID_00003, Pass 1 of 2 - [16:14:43] Reencoding: VID_00003, Pass 2 of 2 - [16:15:00] Video Encode complete - [16:15:00] Processing audio tracks - Track 4356 (deu): Keeping original audio - [16:15:00] Multiplexing M2TS - [16:15:04] Processing: VID_00008 (5 of 14) - [16:15:04] Extracting A/V streams [VID_00008] - Extracting video streams [VID_00008] - Extracting secondary video [VID_00008] - Extracting audio/subtitle streams [VID_00008] - [16:33:58] Reencoding video [VID_00008] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 160.215 frames - [16:33:58] Performing CRF Prediction... - Analyzing 1,00 8,90 8,15 8,53 8,34 8,43 8,38 [8,35] - Aborted... [17:32:36]PHASE ONE aborted by user request ---------------------- [12.28.19] BD Rebuilder v0.61.01 [17:32:41] Source: COLD_PURSUIT - Input BD size: 78,62 GB - Approximate total content: [02:04:46.291] - Target BD size: 46,26 GB - Windows Version: 6.2 [9200] - Quality: Good (Fastest, BD-25+), ABR - Decoding/Frame serving: FFMPEG - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 - Resuming from previously started job. [17:32:42] PHASE ONE, Encoding - [17:32:42] Processing: VID_00008 (5 of 14) - [17:33:14] Reencoding video [VID_00008] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 160.215 frames - Bitrate: 35.000 Kbs - [17:33:14] Reencoding: VID_00008, Pass 1 of 1 - [21:57:07] Video Encode complete - [21:57:07] Processing audio tracks - Track 4356 (deu): Keeping original audio - [21:57:07] Multiplexing M2TS - [21:59:06] Processing: VID_00020 (6 of 14) - [21:59:06] Extracting A/V streams [VID_00020] - [21:59:10] Reencoding video [VID_00020] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 240 frames - Bitrate: 1.489 Kbs - [21:59:10] Reencoding: VID_00020, Pass 1 of 1 - [21:59:26] Video Encode complete - [21:59:26] Processing audio tracks - [21:59:26] Multiplexing M2TS - [21:59:29] Processing: VID_00021 (7 of 14) - [21:59:29] Extracting A/V streams [VID_00021] - [21:59:33] Reencoding video [VID_00021] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 167 frames - Bitrate: 1.244 Kbs - [21:59:33] Reencoding: VID_00021, Pass 1 of 1 - [21:59:44] Video Encode complete - [21:59:44] Processing audio tracks - [21:59:44] Multiplexing M2TS - [21:59:47] Processing: VID_00022 (8 of 14) - [21:59:47] Extracting A/V streams [VID_00022] - [21:59:51] Reencoding video [VID_00022] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 168 frames - Bitrate: 1.339 Kbs - [21:59:51] Reencoding: VID_00022, Pass 1 of 1 - [22:00:01] Video Encode complete - [22:00:01] Processing audio tracks - [22:00:01] Multiplexing M2TS - [22:00:05] Processing: VID_00025 (9 of 14) - [22:00:05] Extracting A/V streams [VID_00025] - [22:00:08] Reencoding video [VID_00025] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 120 frames - Bitrate: 791 Kbs - [22:00:08] Reencoding: VID_00025, Pass 1 of 1 - [22:00:16] Video Encode complete - [22:00:16] Processing audio tracks - [22:00:16] Multiplexing M2TS - [22:00:20] Processing: VID_00026 (10 of 14) - [22:00:20] Extracting A/V streams [VID_00026] - [22:00:23] Reencoding video [VID_00026] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 192 frames - Bitrate: 2.790 Kbs - [22:00:23] Reencoding: VID_00026, Pass 1 of 1 - [22:00:35] Video Encode complete - [22:00:35] Processing audio tracks - [22:00:35] Multiplexing M2TS - [22:00:39] Processing: VID_00027 (11 of 14) - [22:00:39] Extracting A/V streams [VID_00027] - [22:00:42] Reencoding video [VID_00027] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 192 frames - Bitrate: 1.400 Kbs - [22:00:42] Reencoding: VID_00027, Pass 1 of 1 - [22:00:55] Video Encode complete - [22:00:55] Processing audio tracks - [22:00:55] Multiplexing M2TS - [22:00:58] Processing: VID_00028 (12 of 14) - [22:00:58] Extracting A/V streams [VID_00028] - [22:01:02] Reencoding video [VID_00028] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 120 frames - Bitrate: 500 Kbs - [22:01:02] Reencoding: VID_00028, Pass 1 of 1 - [22:01:10] Video Encode complete - [22:01:10] Processing audio tracks - [22:01:10] Multiplexing M2TS - [22:01:13] Processing: VID_00029 (13 of 14) - [22:01:13] Extracting A/V streams [VID_00029] - [22:01:17] Reencoding video [VID_00029] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 480 frames - Bitrate: 29.360 Kbs - [22:01:17] Reencoding: VID_00029, Pass 1 of 1 - [22:02:13] Video Encode complete - [22:02:13] Processing audio tracks - Track 4352 (eng): Keeping original audio - [22:02:13] Multiplexing M2TS - [22:02:17] Processing: VID_00031 (14 of 14) - [22:02:17] Extracting A/V streams [VID_00031] - [22:02:21] Reencoding video [VID_00031] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 168 frames - Bitrate: 16.925 Kbs - [22:02:21] Reencoding: VID_00031, Pass 1 of 1 - [22:02:34] Video Encode complete - [22:02:34] Processing audio tracks - [22:02:34] Multiplexing M2TS [22:02:38]PHASE ONE complete [22:02:38]PHASE TWO - Rebuild Started - [22:02:38] Rebuilding BD file Structure [22:02:46] - Encode and Rebuild complete [22:02:46] Writing BD structure to ISO file - ImgBurn completed successfully - COLD_PURSUIT folder removed. - WORKFILES folder removed. [22:03:56] JOB: COLD_PURSUIT finished. Last edited by jdobbs; 29th December 2019 at 20:35. |
29th December 2019, 03:55 | #29094 | Link |
Special SeeD
I'm getting a "Bitstream exception Unknown exception. It does not have to be! Please contact application support team for more information" error msg:
[12/28/19] BD Rebuilder v0.61.01 [13:13:29] Source: GUASON - Input BD size: 52.45 GB - Approximate total content: [02:13:01.807] - Target BD size: 22.95 GB - Windows Version: 6.2 [9200] - MOVIE and MENUS mode enabled - Quality: Better (Faster), Two Pass - Decoding/Frame serving: FFMPEG - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [13:13:29] PHASE ONE, Encoding - [13:13:29] Blanking: VID_00000 (1 of 15) - [13:13:29] Blanking: VID_00001 (2 of 15) - [13:13:29] Blanking: VID_00002 (3 of 15) - [13:13:29] Blanking: VID_00003 (4 of 15) - [13:13:29] Blanking: VID_00004 (5 of 15) - [13:13:29] Processing: VID_00005 (6 of 15) - [13:13:29] Extracting A/V streams [VID_00005] - [13:13:33] Reencoding video [VID_00005] - Source Video: HEVC, 3840x2160 - Rate/Length: 23.976fps, 6 frames - Bitrate: 500 Kbs - [13:13:33] Reencoding: VID_00005, Pass 1 of 2 - [13:13:34] Reencoding: VID_00005, Pass 2 of 2 - [13:13:35] Video Encode complete - [13:13:36] Processing audio tracks - [13:13:36] Multiplexing M2TS - [13:13:39] Blanking: VID_00006 (7 of 15) - [13:13:39] Blanking: VID_00008 (8 of 15) - [13:13:39] Blanking: VID_00009 (9 of 15) - [13:13:39] Blanking: VID_00010 (10 of 15) - [13:13:39] Processing: VID_00011 (11 of 15) - [13:13:39] Extracting A/V streams [VID_00011] - [13:13:43] Reencoding video [VID_00011] - Source Video: HEVC, 3840x2160 - Rate/Length: 23.976fps, 302 frames - Bitrate: 17,304 Kbs - [13:13:43] Reencoding: VID_00011, Pass 1 of 2 - [13:14:03] Reencoding: VID_00011, Pass 2 of 2 - [13:14:21] Video Encode complete - [13:14:21] Processing audio tracks - Track 4352 (eng): Keeping original audio - [13:14:21] Multiplexing M2TS - [13:14:25] Blanking: VID_00013 (12 of 15) - [13:14:25] Processing: VID_00014 (13 of 15) - [13:14:25] Extracting A/V streams [VID_00014] - Extracting video streams [VID_00014] - Extracting secondary video [VID_00014] - Extracting audio/subtitle streams [VID_00014] - [13:22:05] Reencoding video [VID_00014] - Source Video: HEVC, 3840x2160 - Rate/Length: 23.976fps, 175,243 frames - Bitrate: 15,299 Kbs - [13:22:05] Reencoding: VID_00014, Pass 1 of 2 - [16:41:36] Reencoding: VID_00014, Pass 2 of 2 - [19:46:33] Video Encode complete - [19:46:33] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (eng): Keeping original audio - Track 4355 (fra): Keeping original audio - Track 4356 (spa): Keeping original audio - [19:46:33] Multiplexing M2TS - Bitstream exception. Adjusting... - Error in attempt to multiplex: MUX_00014.meta - Bitstream exception Unknown exception. It does not have to be! Please contact application support team for more information. [19:48:26] - Failed to build structure, aborted |
29th December 2019, 05:00 | #29095 | Link |
Muxing error with 61.02 and old tsmuxer:
[12.28.19] BD Rebuilder v0.61.02 [22:50:56] Source: COLD_PURSUIT - Input BD size: 78,62 GB - Approximate total content: [02:04:46.291] - Target BD size: 46,26 GB - Windows Version: 6.2 [9200] - Quality: Good (Fastest, BD-25+), ABR - Decoding/Frame serving: FFMPEG - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 [22:50:56] PHASE ONE, Encoding - [22:50:56] Processing: VID_00000 (1 of 14) - [22:50:56] Extracting A/V streams [VID_00000] - [22:51:01] Reencoding video [VID_00000] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 1.046 frames - Bitrate: 24.020 Kbs - [22:51:01] Reencoding: VID_00000, Pass 1 of 1 - [22:52:23] Video Encode complete - [22:52:23] Processing audio tracks - Track 4356 (deu): Keeping original audio - [22:52:23] Multiplexing M2TS - [22:52:30] Processing: VID_00001 (2 of 14) - [22:52:30] Extracting A/V streams [VID_00001] - [22:52:34] Reencoding video [VID_00001] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 631 frames - Bitrate: 9.355 Kbs - [22:52:34] Reencoding: VID_00001, Pass 1 of 1 - [22:53:18] Video Encode complete - [22:53:18] Processing audio tracks - Track 4356 (deu): Keeping original audio - [22:53:18] Multiplexing M2TS - [22:53:22] Processing: VID_00002 (3 of 14) - [22:53:22] Extracting A/V streams [VID_00002] - [22:53:45] Reencoding video [VID_00002] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 8.582 frames - Bitrate: 35.000 Kbs - [22:53:46] Reencoding: VID_00002, Pass 1 of 1 - [23:03:43] Video Encode complete - [23:03:43] Processing audio tracks - Track 4356 (deu): Keeping original audio - [23:03:43] Multiplexing M2TS - [23:04:39] Processing: VID_00003 (4 of 14) - [23:04:39] Extracting A/V streams [VID_00003] - [23:04:43] Reencoding video [VID_00003] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 211 frames - Bitrate: 35.000 Kbs - [23:04:43] Reencoding: VID_00003, Pass 1 of 1 - [23:04:58] Video Encode complete - [23:04:58] Processing audio tracks - Track 4356 (deu): Keeping original audio - [23:04:58] Multiplexing M2TS - [23:05:03] Processing: VID_00008 (5 of 14) - [23:05:03] Extracting A/V streams [VID_00008] - Extracting video streams [VID_00008] - Extracting secondary video [VID_00008] - Extracting audio/subtitle streams [VID_00008] - [23:23:57] Reencoding video [VID_00008] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 160.215 frames - Bitrate: 35.000 Kbs - [23:23:57] Reencoding: VID_00008, Pass 1 of 1 - [02:17:03] Video Encode complete - [02:17:03] Processing audio tracks - Track 4356 (deu): Keeping original audio - [02:17:03] Multiplexing M2TS - [02:33:31] Processing: VID_00020 (6 of 14) - [02:33:31] Extracting A/V streams [VID_00020] - [02:33:34] Reencoding video [VID_00020] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 240 frames - Bitrate: 1.489 Kbs - [02:33:34] Reencoding: VID_00020, Pass 1 of 1 - [02:33:49] Video Encode complete - [02:33:49] Processing audio tracks - [02:33:49] Multiplexing M2TS - [02:33:52] Processing: VID_00021 (7 of 14) - [02:33:52] Extracting A/V streams [VID_00021] - [02:33:56] Reencoding video [VID_00021] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 167 frames - Bitrate: 1.244 Kbs - [02:33:56] Reencoding: VID_00021, Pass 1 of 1 - [02:34:06] Video Encode complete - [02:34:06] Processing audio tracks - [02:34:06] Multiplexing M2TS - [02:34:11] Processing: VID_00022 (8 of 14) - [02:34:11] Extracting A/V streams [VID_00022] - [02:34:14] Reencoding video [VID_00022] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 168 frames - Bitrate: 1.339 Kbs - [02:34:14] Reencoding: VID_00022, Pass 1 of 1 - [02:34:24] Video Encode complete - [02:34:24] Processing audio tracks - [02:34:24] Multiplexing M2TS - [02:34:29] Processing: VID_00025 (9 of 14) - [02:34:29] Extracting A/V streams [VID_00025] - [02:34:33] Reencoding video [VID_00025] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 120 frames - Bitrate: 791 Kbs - [02:34:33] Reencoding: VID_00025, Pass 1 of 1 - [02:34:40] Video Encode complete - [02:34:40] Processing audio tracks - [02:34:40] Multiplexing M2TS - [02:34:48] UHD_Correct_M2TS() 00005 8102 [04:57:11]PHASE ONE aborted by user request |
29th December 2019, 12:28 | #29096 | Link |
With much mention of tsmuxer; The 1st post in this thread does not specifically state if the user needs to download and install the latest version - in addition to BDRB. A clarification there would perhaps be helpful to all.
29th December 2019, 15:45 | #29099 | Link | |
Though perhaps my 'otherwise' could have been a bit more precise and mention the exact 'subtools' such as mp4box etc. I'll not talking about the lav filters... Sent from my Pixel 3 XL using Tapatalk |
29th December 2019, 17:12 | #29100 | Link | |
If you follow the directions (exactly) as they are outlined in the first post, you should be ok. Any changes to those instructions are done at your own risk and can result in self-inflicted problems. That includes changing versions for any of the helper apps. Last edited by jdobbs; 29th December 2019 at 17:22. |
