23rd November 2016, 07:09 | #4421 | Link |
I did a quick test with the revised -tu-limit settigs in 2.1+59. I had both inter and intra TU levels set at 4. No point using anything less since the whole point of this is to be able to make use of a higher inter TU without the performance penalty, right? So 4 makes sense, and likewise therefore 4 for intra as well.
What I found was --limit-tu 3 appeared the nicest to look at without any penalty of file size worth mentioning. I redid the tests with PSNR and SSIM stats enabled. Yes I know that with psy etc this isn't exactly a good way of testing, but --limit-tu 3 had better PSNR and SSIM, which matched what I saw visually. Do take into mind that I did the subjective visual test first without seeing the results. |
23rd November 2016, 11:12 | #4422 | Link |
x265 2.1+59-a895b6344a82
CLI changes: Code:
(new) --scenecut-bias <0..100.0> Bias for scenecut detection. Default 5.00 (changed descr.) --[no-]vui-timing-info Emit VUI timing information in the bistream. Default enabled --[no-]vui-hrd-info Emit VUI HRD information in the bistream. Default enabled --[no-]opt-qp-pps Dynamically optimize QP in PPS (instead of default 26) based on QPs in previous GOP. Default enabled --[no-]opt-ref-list-length-pps Dynamically set L0 and L1 ref list length in PPS (instead of default 0) based on values in last GOP. Default enabled |
23rd November 2016, 11:40 | #4423 | Link | |
--limit-tu <0..4> Enables early exit from TU depth recursion, for inter coded blocks. Level 1 - decides to recurse to next higher depth based on cost comparison of full size TU and split TU. Level 2 - based on first split subTU’s depth, limits recursion of other split subTUs. Level 3 - based on the average depth of the co-located and the neighbor CUs’ TU depth, limits recursion of the current CU. Level 4 - uses the depth of the neighbouring/ co-located CUs TU depth to limit the 1st subTU depth. The 1st subTU depth is taken as the limiting depth for the other subTUs. Default: 0 Not quite a direct quote as I think it is easier to read like above instead of all being in one paragraph. I simply changed it so each level is represented as a new line. As I said previously, I believe 'level 3' which I bolded above gives the most favourable results IMO. Last edited by burfadel; 23rd November 2016 at 11:43. |
23rd November 2016, 12:45 | #4424 | Link |
Megablock very bad impact on the formation of each of the second frame (wood edge demonstrates). > test(p-b).mkv
23rd November 2016, 14:30 | #4425 | Link |
x265 v2.1+59-a895b6344a82 (MSYS/MinGW, GCC 6.2.0, 32 & 64bit 8/10/12bit multilib EXEs)
23rd November 2016, 16:38 | #4426 | Link | |
Can you share your command-lines so that we can comment? |
23rd November 2016, 17:30 | #4427 | Link | |
Pig on the wing
vspipe.exe --y4m "c:\x265\hotfuzz.vpy" - | C:\sources\x265\build\vc14-x86_64\Release\x265.exe --input - --y4m --input-depth 16 --dither --sar 1:1 --profile main10 --keyint 480 --ref 5 --rskip --colormatrix "bt709" --colorprim "bt709" --transfer "bt709" --preset slower --rc-lookahead 60 --deblock -3:-1 --no-strong-intra-smoothing --limit-refs 3 --limit-modes --limit-tu 0 --tu-inter-depth 4 --tu-intra-depth 4 --merange 38 --tune grain --crf 21 --csv q:\hotfuzz_limittu0.csv --csv-log-level 2 --output "q:\hotfuzz_limittu0.hevc" In my tests, the bitrate and encoding speed was as follows: --limit-tu 0 : 4875.60 kbps, 1.64 fps --limit-tu 1 : 4899.45 kbps, 1.84 fps --limit-tu 2 : 4990.49 kbps, 1.93 fps --limit-tu 3 : 5037.98 kbps, 1.99 fps --limit-tu 4 : 5044.37 kbps, 2.02 fps The black mattes were cropped and the result downsized to 1280x544. The original source clip is here: https://drive.google.com/open?id=0Bz...khsX3RuZGhWcjA
And if the band you're in starts playing different tunes I'll see you on the dark side of the Moon... Last edited by Boulder; 23rd November 2016 at 17:35. |
24th November 2016, 04:59 | #4429 | Link |
Pig on the wing
It's really hard to tell. I could even say that there is no clear winner there, especially if you don't use still frames to compare.
24th November 2016, 18:25 | #4430 | Link |
Hi anyone know if it is possible to use the x265 encoder on android devices?
I've got a Nvidia Shield (Tegra X1 cpu) which encodes x264 pretty well (via the plex app). So since x264 works on it, I 'assume' x265 is possible aswell? I googled it a few times and searched in the play store but I can't find any apps/tools available (yet).. Last edited by K.i.N.G; 24th November 2016 at 18:29. |
24th November 2016, 19:14 | #4431 | Link |
I assume Plex is using Nvidia's H.264/AVC encoder, not x264. Running x264 or x265 would be slow on the Shield's CPU. Likewise, you'd need an app that uses Nvidia's H.265/HEVC encoder for fast H.265/HEVC encoding. Maybe you can ask Plex developers if they are willing to add this functionality.
24th November 2016, 20:34 | #4432 | Link |
If you can compile x26* for this target OS and CPU architecture, you can probably also use the encoder on it; but I would not recommend using mobile devices for such time and energy consuming tasks. Such CPUs may preferably save energy, instead of executing highly efficient SIMD instructions. And x265 requires a magnitude more processing power than x264, and highly efficient instruction extensions (especially vector math extensions like AVX) help x265 a lot more. Tegra X1 is highly parallelized, but will probably have a lower complexity in available instructions. And x265 does not require maximum parallelizability, instead rather wide and purpose-relevant SIMD and vector instructions.
27th November 2016, 14:06 | #4434 | Link | ||
Plex also runs on multiple platforms which many aren't intel and/or nvidia related (windows, unix, my NAS, etc...) anyway, you're right about contacting them. Wil do so. Quote:
And the reason I want to use it for encoding is exactly the point you bring up: time & power... I dont need the power of my media station as much as I need my work station I wouldnt mind if it needs a whole week. As long as I can set it as a lower priority task so i can watch a movie from time to time in between. Last edited by K.i.N.G; 28th November 2016 at 01:29. |
27th November 2016, 17:20 | #4435 | Link |
OK, so I maybe confused the "controller tablet" with the host on one hand, and CPU with GPU on the other, when I first read another source of technical facts.
According to the English Wikipedia, the Tegra X1 has a Dual QuadCore structure (four ARM Cortex-A57 cores and four ARM Cortex-A53 cores in big.LITTLE configuration). And this "big.LITTLE" architecture may cause some issues, as I recently read: Threads can be shifted between either kind of CPU, depending on their processing power demand, and must always be aware of whether they run on a CPU with a small or a large cache line. And efficient use of cache lines is a very important speed optimization strategy. My conclusion for now would be that x265 developers would need to double-check strategies to support this architecture class. They would neither wish to get their threads shifted to a low-power core, nor would they enjoy data corruption due to false assumptions about cache line capacities in an unfortunate moment. |
28th November 2016, 02:35 | #4436 | Link |
Well,... I looked again and it's indeed using the x264 encoder.
Don't know why I missed the obvious the last time I checked... oh well And got a reply in the plex forums aswell (yes, i'm feeling stupid now) : "Yes, it is the x.264 library in a highly customized version of ffmpeg." So how hard would it be to include x265? Last edited by K.i.N.G; 28th November 2016 at 02:44. |
28th November 2016, 08:43 | #4437 | Link |
As I tried to explain: Probably harder than supporting multi-socket systems with identical CPUs. The CPUs in a big.LITTLE system are not identical, therefore its support needs special care.
Well, and if it can be supported at all ... then the PLEX team would have to release a new ffmpeg built for their specific purposes, and now including libx265. |
28th November 2016, 16:48 | #4438 | Link | |
To support x265 they need to heavily re-adjust it again? Too much difference between x264 and x265? Sounds like you're pretty sure it wont happen anytime soon... I think it will happen eventually at some point though... |
28th November 2016, 16:55 | #4439 | Link |
I don't know how "heavily" PLEX had to modify ffmpeg. I just assume they did not include libx265, like libx264. Possibly because there is no certain support for your platform (OS and CPUs) yet. Because x265 depends a lot on optimal use of the available CPU architecture, it would be a very bad idea to compile it without any assembler optimization; yet, it may be possible. But in this case, expecting a week per movie is not unrealistic. Nevertheless, the mentioned problems with the big.LITTLE architecture may also happen for code generated by C/C++ compilers only, this is a general risk factor.
