Old 1st June 2014, 21:54   #20381  |  Link
colinhunt
Someone please remind me: is it possible to configure BD-RB to make 3D ISO image files with an SSIF directory in them? I've got two media players that play 3D ISOs just fine, but don't support in-mux .m2ts 3D :/
Old 1st June 2014, 22:18   #20382  |  Link
Ch3vr0n
Jup but AFAIK only for movie only. You'd have to ask over at doom9 for the exact command though. You can't shrink full disc AND keep ssif folder. Its one or the other
Verstuurd vanaf mijn Nexus 7 met Tapatalk
Old 2nd June 2014, 00:48   #20383  |  Link
colinhunt
Yeah, I'm happy with movie-only ISO.
Old 2nd June 2014, 01:55   #20384  |  Link
Ch3vr0n
from hiddenopts.txt OUTPUT_3D_ISO=n n = 0/1 - 1=ON (default) - if set to "0", output is to a folder rather than ISO
since 1 = default, afaik it should default to iso output with movie-only unless you state otherwise
Old 2nd June 2014, 10:32   #20385  |  Link
colinhunt
Thanks. That's interesting, because that line was not in my .INI so I suppose BD-RB should have output to ISO by default. I added OUTPUT_3D_ISO=1 to .INI now.
Old 2nd June 2014, 16:10   #20386  |  Link
Ch3vr0n
if it isn't there then you're not using 47.06 cause it is in mine. Besides you shouldn't NEED to add that line at all 1=on is the default. It's if you want it OFF that you have to add that line
Old 2nd June 2014, 16:45   #20387  |  Link
colinhunt
My .ini file originates from at least a couple of years ago, meaning I've used the same one by copying it from old installations into new versions. I added the line to the .ini - and now BD-RB makes ISO files of 3D movie-only backups. (Well, tries to, FRIMEncoder keeps on crashing...)
Old 2nd June 2014, 17:30   #20388  |  Link
Ch3vr0n
i've used the same settings since the start as well. What i said was if that settings wasn't in your hiddenopts.txt file (which is inside your bdrb installation folder) than you're not using 47.06. and you don't need to add that line in your settings ini file as iso output for 3D movie only is default.
Old 2nd June 2014, 17:59   #20389  |  Link
colinhunt
Ah, yes, the line is in hiddenopts.txt, certainly. Thought you meant the .ini file.
Old 2nd June 2014, 19:48   #20390  |  Link
I think the HIDDENOPTS.TXT file may be wrong and "0" is the default. I'm away from my office so I can't check to be sure.
Old 2nd June 2014, 20:01   #20391  |  Link
Ch3vr0n
probably then, cause in the current version it states 1 = default
Old 2nd June 2014, 23:52   #20392  |  Link
ricoman
ricoman's Avatar
I'm not sure what the problem is, maybe it's not BDRB but I figured I'd ask. I just processed an iso of Walter Mitty made with AnyDVDHD. I did movie only and burned it to a BD25 with Imgburn. When I play it, it plays fine up until about 2 min. left in the movie, then the video freezes but the audio continues. If you've seen the movie, the last minute is very important. When I play the iso from the hard drive, it plays to the end, no problem. I reprocessed it with the same result except it also had an audio sync problem. I then tried the iso with DVDFABHD Decryptor with the same results, freezes in the same spot. I've wasted 3 BD25 blanks. Any idea what the problem may be? Thanks.
ricoman is offline   Reply With Quote
Old 3rd June 2014, 05:51   #20393  |  Link
omegaman7
omegaman7's Avatar
Very likely a bad rip. I've seen that behavior several times.
Old 3rd June 2014, 12:16   #20394  |  Link
sebnutt
Hi everyone,
So far, I used BD rebuilder to reencode blu-rays on DVD-5 with AVCHD structure successfully on each attempt
I'm doing it from blu-ray ripped from MAKEMKV > disc backup.
Rips just look great on my BD player. Great tool ! Even if reencode process is a bit slow with default settings.
Considergin making a donation
sebnutt is offline   Reply With Quote
Old 3rd June 2014, 22:35   #20395  |  Link
ricoman
ricoman's Avatar
The ripped iso plays fine to the end. It's only the compressed disc, both BDRB and DVDFAB that stop with 2 min. left.
Old 3rd June 2014, 22:44   #20396  |  Link
omegaman7
omegaman7's Avatar
When I said "that behavior", I was being 100% truthful Rips can play fine with players, but encodes will end up showing the rip problems. Encoders, and tools used in muxing have to acknowledge bit for bit all the data. Players ignore problems, that may seem either trivial, or non noticeable.
There is a chance it's something else, but I'm leaning towards a bad rip myself.
Old 4th June 2014, 00:58   #20397  |  Link
jfcarbel
Programmer
Possible Bug or did I take wrong approach?
Nurse Jackie R1 S5 D1
- settings to reduce to 1280x720p and AC3
- movies and menus (auto blank extras)
- Edit Mode Manual Blanking checked
- BD25 target
Now I went thru and un-blanked two streams as they were extras I wanted to keep and also unblanked 2 AC3 streams as they were commentary and it made the final size go to 23.6 GB
Did I approach this wrong? If I try checking full backup with edit mode manual blanking then I don't see all those misc short streams listed that auto blank extras shows.
jfcarbel is offline   Reply With Quote
Old 4th June 2014, 08:10   #20398  |  Link
stereo55
Since update 47.06 , my settings for Image Burn are all greyed out and unusable (settings shown below) ; anyone else ?
Burn current Disc (with ImgBurn)
and
Auto burn to disc (with ImgBurn)
Write to ISO file ( with ImgBurn)
stereo55 is offline   Reply With Quote
Old 4th June 2014, 16:22   #20399  |  Link
Ch3vr0n
well the obvious question here is: do you (still) have IMGBurn installed?
Old 4th June 2014, 17:36   #20400  |  Link
stereo55
Yes (ofcourse ) the latest version 2.5.8.0 .
However , I just decided to uninstall , reinstall Image Burn and that seemed to fix the problem of being unavailable to use in the BDR menu.
For some reason I think that happened to me in the past while also doing a BDR update , and the fix was the same (uninstall/reinstall ImageBurn) . I'll just have to remember to do the same IF there is a next time .
