Old 3rd October 2014, 23:57   #21381  |  Link
sonate
I apologize in advance for being off topic, I thought I'd give this a shot here as I'm not having much luck elsewhere. I want to add a subtitle track to a bluray movie which originally has no subtitles and find there is no way to access the muxed subtitles. I've replaced subtitles consistently successfully if there was a subtitle track already on the original. Just hoping if someone has any ideas they can steer me in the right direction. I find myself buying many European and Asian Blurays which don't have English or US counterparts.
Thank you in advance, and sorry for the sidetracking.
sonate is offline   Reply With Quote
Old 4th October 2014, 00:03   #21382  |  Link
Sharc
Can't you add a subtitle with tsMuxeR?
Old 4th October 2014, 00:13   #21383  |  Link
DoctorM
(removed until I can figure this out)
Old 4th October 2014, 00:18   #21384  |  Link
sonate
Yes, and that's what I use. It works fine when you replace an existing subtitle with a new one. But when I add one where none previously existed , I can't get it to display using the subtitle command on the remote.
Old 4th October 2014, 00:24   #21385  |  Link
DoctorM
Is MIN_M2TS_SIZE and MIN_PLAYLIST_MINS supposed to be ignored for BD25 and BD50 targets?
I've got a 2:30 length trailer I can't get to show up on the streams tabs no matter if I use zero or one for those values.
It DOES show up if I go to a DVD sized output though. I know it's minimal, I just assumed it would work for all output sizes.
The 9 and 22 second warning screens do show up though (I assume their attached to a longer playlist though).
Old 4th October 2014, 04:21   #21386  |  Link
MajorEvent
Passed Newbie Inquisition
MajorEvent's Avatar
Audio out of sync with LAV filters
Greetings!
I'm trying to switch over to the LAV filters. ffdshow and Haaili were working great for me but I see you're talking about using LAV filters so I figured i'd give it a shot. Thing is I've tried several re-encodes and they're all coming out with the audio way out of sync. When I had the problem on the first couple attempts, I figured something didn't take right so I completely uninstalled Avisynth, Haali, ffdshow and LAV filters and tried setting up from scratch using only Avisynth and LAV filters but I still have the issue with the audio being way out of sync by a couple seconds or more. Any ideas?
Re-encoding using 49.02 to target size BD-25, Movie Only backup keeping HD audio at 2-pass highest quality.
Setting Check:
- Working Path Free Space: 383.06GB
- LAVFILTERS: Ok
- AnyDVD settings check: Ok.
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[10/03/14] Systems Settings Check complete
[Options]
VERSION=0.49.0.2
MODE=3
ENCODE_QUALITY=3
ONEPASS_ENCODING=0
AUTO_QUALITY=0
TARGET_SIZE=23500
PRIORITY_CLASS=0
AUDIO_TO_KEEP=chi;eng;zho;
SUBS_TO_KEEP=chi;eng;zho;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
DEINTERLACE=1
SD_TO_1080=0
CONVERT_WIDE=0
DTS_REENCODE=1
AC3_REENCODE=1
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AVCHD=1
REMOVE_WORKFILES=1
MOVIE_ONLY_LOOP=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
USE_LAVF=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
UNMASK_CHAPTER=0
COMPLETION_BEEP=1
DGDECNV=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=8780
QUICK_EXTRAS=0
OUTPUT_3D=0
RESIZE_1440=0
RESIZE_720=0
NEROAAC=0
SUPTITLE=0
OUTPUT_SBS=0
ENCODER=0
IGNORE_3D=0
DECODER=0
FRIMSOURCE=0
[Paths]
SOURCE_PATH=D:\IMAGES\BLU-RAY\NON STOP\
WORKING_PATH=D:\IMAGES\BLU-RAY\PROCESSING TEMP\
MajorEvent is offline   Reply With Quote
Old 4th October 2014, 07:05   #21387  |  Link
Glarioo
I've also installed the Lav filters. I've tried to re-encode "Red Dragon" using alternate MKV 1920x1080 output and the audio was out of sync.
Running inspect tells me everything is ok.
Today i'm gonna uninstall Avisynth, Haali, ffdshow, LAV and run BD-RB again with only Avisynth and LAV filters installed.
LABEL=RED_DRAGON
VERSION=v0.49.02 (beta)
SOURCE_SIZE=41433391104
SOURCE_VIDEO_SIZE=41433391104
TARGET_SIZE=49666850816
REDUCTION=1.19871556473216
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=all
BACKUP_MODE=1
MOVIEONLY_TYPE=10
USE_LAVF=0
INSTANCES=1
DGDECNV=0
DGDECIM=0
FRIMSOURCE=0
FFMS2=0
SSIF_MODE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=1
[00009]
AUDIO=10000000
PGS=11111111111111100000000000000000
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=49666850816
SPLITS=1
NSIZE=0
FLINK=0
MLINK=0
[Options]
VERSION=0.49.0.4
TWEAK_ALTERNATE=--vbv-maxrate 35000 --vbv-bufsize 30000
SHOW_ENCODER=1
MKV_CHAPTERS=1
MKV_MUXSUPS=1
MOVIE_ONLY_LOOP=0
USE_ZLIB=0
ENCODER=0
MODE=3
ENCODE_QUALITY=0
ONEPASS_ENCODING=0
AUTO_QUALITY=0
MOVIEONLY_TYPE=10
ALTCRF=20
ALT_TARGET=10205
ALTMETHOD=2
ALTAUTOCROP=0
PRIORITY_CLASS=2
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=1
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
DECODER=0
AVCHD=1
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=1
IVTC_PULLDOWN=1
ASSUME_DVD_PAL=1
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=23500
TARGET_SIZE=47366
[Paths]
SOURCE_PATH=D:\BLU-RAY\RED_DRAGON\
WORKING_PATH=D:\BD-RB WORK\
[10/01/14] BD Rebuilder v0.49.02 (beta)
[18:11:26] Source:  RED_DRAGON_00000
  - Input BD size: 38,59 GB
  - Approximate total content: [02:04:26.375]
  - Windows Version: 6.1 [7601]
  - Mode: MKV Container, 1920x1080, 640Kbs DD5.1
  - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640
[18:11:28] PHASE ONE, Encoding
 - [18:11:28] Processing: VID_00009 (1 of 1)
 - [18:11:28] Extracting A/V streams [VID_00009]
 - [18:25:36] Reencoding video [VID_00009]
   - Rate/Length: 23,976fps, 179.014 frames
   - Bitrate: 10.557 Kbs
 - [18:25:36] Reencoding: VID_00009, Pass 1 of 2
 - [19:27:53] Reencoding: VID_00009, Pass 2 of 2
 - [22:12:53] Video Encode complete
 - [22:12:53] Processing audio tracks
[22:16:02]PHASE ONE complete
[22:16:02]PHASE TWO - Rebuild Started
 - [22:16:02] Building ALTERNATE OUTPUT Structure
[22:20:15] - Encode and Rebuild complete
[22:20:19] JOB: RED_DRAGON finished.
Old 4th October 2014, 12:34   #21388  |  Link
Glarioo
Uninstalling Avisynth, Haali, ffdshow & LAV Filters, then
re-installing Avisynth and LAV Filters didn't work. Audio is still out of sync, about 2-3 seconds too late.
[Status]
LABEL=RED_DRAGON
VERSION=v0.49.04 (beta)
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=all
BACKUP_MODE=1
MOVIEONLY_TYPE=10
USE_LAVF=0
INSTANCES=1
DGDECNV=0
DGDECIM=0
FRIMSOURCE=0
FFMS2=0
SSIF_MODE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=1
[00009]
AUDIO=10000000
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
SPLITS=1
NSIZE=0
FLINK=0
MLINK=0
[Options]
VERSION=0.49.0.4
SHOW_ENCODER=1
MKV_CHAPTERS=1
MKV_MUXSUPS=1
MOVIE_ONLY_LOOP=0
USE_ZLIB=0
ENCODER=0
MODE=3
ENCODE_QUALITY=0
ONEPASS_ENCODING=0
AUTO_QUALITY=0
MOVIEONLY_TYPE=10
ALTCRF=20
ALT_TARGET=10205
ALTMETHOD=2
ALTAUTOCROP=0
PRIORITY_CLASS=2
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=1
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
DECODER=0
AVCHD=1
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=1
IVTC_PULLDOWN=1
ASSUME_DVD_PAL=1
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
AUDIO_TRACK_LIMIT=1
TARGET_SIZE=47366
[Paths]
[10/04/14] Checking System Settings
  - BD-Rebuilder v0.49.04 (beta)
  - Working Path Free Space: 474,68GB
  - LAVFILTERS:  Ok
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
[10/04/14] Systems Settings Check complete
[10/04/14] BD Rebuilder v0.49.04 (beta)
[11:07:49] Source:  RED_DRAGON_00000
[11:07:49] PHASE ONE, Encoding
 - [11:07:49] Processing: VID_00009 (1 of 1)
 - [11:07:49] Extracting A/V streams [VID_00009]
 - [11:21:57] Reencoding video [VID_00009]
 - [11:21:57] Reencoding: VID_00009, Pass 1 of 2
 - [12:13:10] Reencoding: VID_00009, Pass 2 of 2
 - [13:02:19] Video Encode complete
 - [13:02:19] Processing audio tracks
[13:05:26]PHASE ONE complete
[13:05:26]PHASE TWO - Rebuild Started
 - [13:05:26] Building ALTERNATE OUTPUT Structure
[13:09:48] - Encode and Rebuild complete
[13:09:48] JOB: RED_DRAGON finished.
LASTCMD: "C:\BD_Rebuilder\tools\x264.exe" "D:\BD-RB WORK\WORKFILES\VID_00009.AVS" --preset superfast --bluray-compat --b-pyramid none --weightp 1 --qpmin=0 --bitrate 10557 --level 4.1 --qpfile "D:\BD-RB WORK\WORKFILES\VID_00009.CHP" --aud --nal-hrd vbr --pic-struct --vbv-bufsize 15000 --keyint 48 --min-keyint 1 --ipratio 1.1 --pbratio 1.1 --vbv-maxrate 15000 --threads auto --slices 4 --thread-input --vbv-maxrate 35000 --vbv-bufsize 30000 --stats "D:\BD-RB WORK\WORKFILES\VID_00009.AVS.264.stats" --pass 2 --output "D:\BD-RB WORK\WORKFILES\VID_00009.AVS.264"
Old 4th October 2014, 14:17   #21389  |  Link
I certainly don't see how LAV can put the audio out-of-sync. In BD-RB the LAV filters aren't even used for audio. But I'll look at it.
Old 4th October 2014, 14:22   #21390  |  Link
@Glarioo & MajorEvent
Uninstall LAV and AVISYNTH, and then install AVISYNTH, FFDSHOW, and HAALI -- and let know if going back to FFDSHOW fixes your problem.
Do you have any "CODEC packs" or other software that might interfere with video installed on your system? In the past that's the only thing I've see that could cause out-of-sync issues. But I'd hoped that it wouldn't be something we'd see with LAV.
@MajorEvent: Can you please post your log?
Old 4th October 2014, 15:03   #21391  |  Link
MajorEvent
MajorEvent's Avatar
I had already tried this since I needed to get a couple movies processed. Re-installing the ffdshow and haali after removing LAVfilters does fix the problem for me. When LAVfilters is installed the problem occurs, without LAVfilters, no problem. I didn't need to remove AVIsynth to recover but tried both ways.
I also updated to 49.04 last night and ran the re-encode with the same issue occuring. I didn't post a movie log since they don't seem to show anything out of the ordinary but I have tried on 3 different movie re-encodes.
LOG file
[10/03/14] BD Rebuilder v0.49.04 (beta)
[23:50:43] Source:  NON_STOP_00800
  - Input BD size: 29.88 GB
  - Approximate total content: [01:46:37.390]
  - Target BD size: 22.95 GB
  - MOVIE-ONLY mode enabled
  - Quality: Highest (Very Slow), Two Pass
  - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640
[23:50:43] PHASE ONE, Encoding
 - [23:50:43] Processing: VID_00023 (1 of 1)
 - [23:50:43] Extracting A/V streams [VID_00023]
 - [00:07:13] Reencoding video [VID_00023]
   - Rate/Length: 23.976fps, 153,384 frames
   - Bitrate: 23,861 Kbs
 - [00:07:13] Reencoding: VID_00023, Pass 1 of 2
 - [00:37:19] Reencoding: VID_00023, Pass 2 of 2
 - [02:54:19] Video Encode complete
 - [02:54:19] Processing audio tracks
   - Track 4355 (eng): Keeping original audio
[02:54:19]PHASE ONE complete
[02:54:19]PHASE TWO - Rebuild Started
 - [02:54:20] Rebuilding BD file Structure
[03:07:50] - Encode and Rebuild complete
 - WORKFILES folder removed.
[03:07:51] JOB: NON_STOP finished.
INF file
[Status]
LABEL=NON_STOP
SOURCE_SIZE=32078813184
SOURCE_VIDEO_SIZE=32078813184
TARGET_SIZE=24641536000
REDUCTION=.76815609912559
RESIZE_1080=0
RESIZE_1440=0
KEEP_HD_AUDIO=-1
BACKUP_MODE=1
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=0
DGDECIM=0
FRIMSOURCE=0
FFMS2=0
SSIF_MODE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=1
[00023]
AUDIO=1001
PGS=10000
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=24641536000
RATE=23861
SPLITS=1
NSIZE=0
FLINK=0
MLINK=0
Edit: Hmmm, I see the USE_LAVF=0. Could that be the issue?
FYI, the audio is out of sync from the beginning of the movie, it doesn't "fall" out of sync as the movie progresses. I'm also running Win 7 x64 Pro SP1.
Let me know if I should post anything, look at anything etc.
TIA.
BTW, what's with the random question BS. It sucks and discourages people from posting their issues here.
Last edited by MajorEvent; 4th October 2014 at 15:12. Reason: Add LOG and INF files
Old 4th October 2014, 15:28   #21392  |  Link
The only way I can imagine this happening is if the LAV filters are losing a large group of frames at the beginning of the encode... but that doesn't seem likely. It has to be something particular to your individual system -- as I'm not seeing any issues at all. The hard part is finding what that might be.
I'll try loading your config on my system and see if that makes a difference.
The USE_LAVF is not related to LAVFilters, it applies to X264's internal demuxing.
Old 4th October 2014, 15:33   #21393  |  Link
MajorEvent
MajorEvent's Avatar
Greetings!
Here's my list of all installed video, audio drivers and filters via InstalledCodec:
AC3 Parser Filter	DirectShow Filter	DirectShow MPEG-2 Splitter.	6.6.7601.17528 (win7sp1_gdr.101222-1504)
ACM Wrapper	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
AudioRecorder WAV Dest	DirectShow Filter	Windows Sound Recorder	6.1.7601.17514 (win7sp1_rtm.101119-1850)
AudioRecorder Wave Form	DirectShow Filter	Windows Sound Recorder	6.1.7601.17514 (win7sp1_rtm.101119-1850)
AVI Decompressor	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
AVI Mux	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
AVI Splitter	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
AVI/WAV File Source	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
BDA MPEG2 Transport Information Filter	DirectShow Filter	Microsoft Transport Information Filter for MPEG2 based networks.	6.6.7601.17669 (win7sp1_gdr.110816-1502)
CBVA DMO wrapper filter	DirectShow Filter	Windows Media Center Content Analysis Filter Module	6.1.7600.16385 (win7_rtm.090713-1255)
Closed Captions Analysis Filter	DirectShow Filter	CCA DirectShow Filter.	6.6.7601.17514 (win7sp1_rtm.101119-1850)
Color Space Converter	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
DV Muxer	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
DV Splitter	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
DV Video Decoder	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
DVD Navigator	DirectShow Filter	DirectShow DVD PlayBack Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
Enhanced Video Renderer	DirectShow Filter	Enhanced Video Renderer DLL	6.1.7600.16385 (win7_rtm.090713-1255)
File Source (Async.)	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
File Source (URL)	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
File stream renderer	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
File writer	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
Fraunhofer IIS MPEG Layer-3 Codec	Driver - Audio 	MPEG Layer-3 Audio Codec for MSACM	1, 9, 0, 0401
Infinite Pin Tee Filter	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
Internal Script Command Renderer	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
iTV Data Capture filter	DirectShow Filter	iTV Data Filters.	6.6.7601.17514 (win7sp1_rtm.101119-1850)
iTV Data Sink	DirectShow Filter	iTV Data Filters.	6.6.7601.17514 (win7sp1_rtm.101119-1850)
LAV Audio Decoder	DirectShow Filter	LAV Audio Decoder - DirectShow Audio Decoder	0.62.0
LAV Splitter	DirectShow Filter	LAV Splitter - DirectShow Media Splitter	0.62.0
LAV Splitter Source	DirectShow Filter	LAV Splitter - DirectShow Media Splitter	0.62.0
LAV Video Decoder	DirectShow Filter	LAV Video Decoder - DirectShow Video Decoder	0.62.0
Line 21 Decoder	DirectShow Filter
Line 21 Decoder 2	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
LogMeIn Video Decoder	DirectShow Filter
LogMeIn Video Encoder	DirectShow Filter
Media Center Extender Encryption Filter	DirectShow Filter	Media Center Extender Filter	6.1.7601.17514 (win7sp1_rtm.101119-1850)
Microsoft AC3 Encoder	DirectShow Filter	Microsoft AC-3 Encoder	6.1.7601.17514 (win7sp1_rtm.101119-1850)
Microsoft DTV-DVD Audio Decoder	DirectShow Filter	Microsoft DTV-DVD Audio Decoder	6.1.7140.0 (fbl_multimedia(bld4act).090528-1617)
Microsoft DTV-DVD Video Decoder	DirectShow Filter	Microsoft DTV-DVD Video Decoder	12.0.9200.17037 (win8_gdr(wmsebld).140620-1645)
Microsoft MPEG-2 Audio Encoder	DirectShow Filter	Microsoft MPEG-2 Encoder	6.1.7600.16385 (win7_rtm.090713-1255)
Microsoft MPEG-2 Encoder	DirectShow Filter	Microsoft MPEG-2 Encoder	6.1.7600.16385 (win7_rtm.090713-1255)
Microsoft MPEG-2 Video Encoder	DirectShow Filter	Microsoft MPEG-2 Encoder	6.1.7600.16385 (win7_rtm.090713-1255)
Microsoft TV Captions Decoder	DirectShow Filter	Media Center Captioning Module	6.1.7601.17715 (win7sp1_gdr.111028-1502)
Microsoft TV Subtitles Decoder	DirectShow Filter	Media Center Captioning Module	6.1.7601.17715 (win7sp1_gdr.111028-1502)
MIDI Parser	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
MJPEG Decompressor	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
MPEG Audio Decoder	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
MPEG Video Decoder	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
MPEG-2 Demultiplexer	DirectShow Filter	DirectShow MPEG-2 Splitter.	6.6.7601.17528 (win7sp1_gdr.101222-1504)
MPEG-2 Sections and Tables	DirectShow Filter	Microsoft MPEG-2 Section and Table Acquisition Module	6.6.7601.17514 (win7sp1_rtm.101119-1850)
MPEG-2 Splitter	DirectShow Filter	DirectShow MPEG-2 Splitter.	6.6.7601.17528 (win7sp1_gdr.101222-1504)
MPEG-2 Video Stream Analyzer	DirectShow Filter	DirectShow Stream Buffer Filter.	6.6.7601.17528 (win7sp1_gdr.101222-1504)
MPEG-I Stream Splitter	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
msacm.imaadpcm	Driver - Audio 	IMA ADPCM CODEC for MSACM	6.1.7600.16385 (win7_rtm.090713-1255)
msacm.msadpcm	Driver - Audio 	Microsoft ADPCM CODEC for MSACM	6.1.7600.16385 (win7_rtm.090713-1255)
msacm.msg711	Driver - Audio 	Microsoft CCITT G.711 (A-Law and u-Law) CODEC for MSACM	6.1.7600.16385 (win7_rtm.090713-1255)
msacm.msgsm610	Driver - Audio 	Microsoft GSM 6.10 Audio CODEC for MSACM	6.1.7600.16385 (win7_rtm.090713-1255)
Multi-file Parser	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
NetBridge	DirectShow Filter	Media Center NetBridge	6.1.7601.17514 (win7sp1_rtm.101119-1850)
Null Renderer	DirectShow Filter	DirectShow Editing.	6.6.7600.16385 (win7_rtm.090713-1255)
Overlay Mixer	DirectShow Filter
Overlay Mixer2	DirectShow Filter
RDP DShow Redirection Filter	DirectShow Filter	RDP Renderer Filter (redirector)	1.00
RivaTuner Video Codec	Driver - Video
SAMI (CC) Parser	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
SampleGrabber	DirectShow Filter	DirectShow Editing.	6.6.7600.16385 (win7_rtm.090713-1255)
SBE2FileScan	DirectShow Filter	DirectShow Stream Buffer Filter.	6.6.7601.17528 (win7sp1_gdr.101222-1504)
SBE2MediaTypeProfile	DirectShow Filter	DirectShow Stream Buffer Filter.	6.6.7601.17528 (win7sp1_gdr.101222-1504)
Screen Capture filter	DirectShow Filter	WMPSrcWp Module	12.0.7601.17514 (win7sp1_rtm.101119-1850)
Smart Tee	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
SoundRecorder Null Renderer	DirectShow Filter	Windows Sound Recorder	6.1.7601.17514 (win7sp1_rtm.101119-1850)
StreamBufferSink	DirectShow Filter	DirectShow Stream Buffer Filter.	6.6.7601.17528 (win7sp1_gdr.101222-1504)
StreamBufferSink2	DirectShow Filter	DirectShow Stream Buffer Filter.	6.6.7601.17528 (win7sp1_gdr.101222-1504)
StreamBufferSource	DirectShow Filter	DirectShow Stream Buffer Filter.	6.6.7601.17528 (win7sp1_gdr.101222-1504)
VBI Codec	DirectShow Filter	Microsoft VBI Codec	6.6.7601.17514 (win7sp1_rtm.101119-1850)
VBI Surface Allocator	DirectShow Filter	VBI Surface Allocator Filter	6.1.7601.17514 (win7sp1_rtm.101119-1850)
VGA 16 Color Ditherer	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
vidc.i420	Driver - Video	Intel Indeo(R) Video YUV Codec	6.1.7600.16385 (win7_rtm.090713-1255)
vidc.iyuv	Driver - Video	Intel Indeo(R) Video YUV Codec	6.1.7600.16385 (win7_rtm.090713-1255)
vidc.mrle	Driver - Video	Microsoft RLE Compressor	6.1.7600.16385 (win7_rtm.090713-1255)
vidc.msvc	Driver - Video	Microsoft Video 1 Compressor	6.1.7600.16385 (win7_rtm.090713-1255)
vidc.uyvy	Driver - Video	Microsoft UYVY Video Decompressor	6.1.7601.17514 (win7sp1_rtm.101119-1850)
vidc.yuy2	Driver - Video	Microsoft UYVY Video Decompressor	6.1.7601.17514 (win7sp1_rtm.101119-1850)
vidc.yvu9	Driver - Video	Toshiba Video Codec	6.1.7601.17514 (win7sp1_rtm.101119-1850)
vidc.yvyu	Driver - Video	Microsoft UYVY Video Decompressor	6.1.7601.17514 (win7sp1_rtm.101119-1850)
Video Mixing Renderer 9	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
Video Port Manager	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
Video Renderer	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
VPS Decoder	DirectShow Filter	Microsoft Teletext Server	6.6.7601.17514 (win7sp1_rtm.101119-1850)
Wave Parser	DirectShow Filter	DirectShow Runtime.	6.6.7600.16385 (win7_rtm.090713-1255)
WM ASF Reader	DirectShow Filter	DirectShow ASF Support	12.0.7600.16385 (win7_rtm.090713-1255)
WM ASF Writer	DirectShow Filter	DirectShow ASF Support	12.0.7600.16385 (win7_rtm.090713-1255)
WST Pager	DirectShow Filter	Microsoft Teletext Server	6.6.7601.17514 (win7sp1_rtm.101119-1850)
Xvid MPEG-4 Video Codec	Driver - Video
Xvid MPEG-4 Video Decoder	DirectShow Filter
Old 4th October 2014, 16:16   #21394  |  Link
MajorEvent
MajorEvent's Avatar
Greetings!
Here's the report on Codecs from Media Player (Help/About Media Player/Technical Support Information):
Operating System
Version:	6.1.7601	System Locale:	en-US
Service Pack:	1.0	User Locale:	en-US
Build Lab:	7601.win7sp1_gdr.140303-2144	Geo ID:	United States
Type:	Workstation	DRM Version:	11.0.7600.16385
Architecture:	x86	Indiv Version:	2.9.0.1
Processors:	12  <--Sweet! :D
Media Player Binaries
Name	Version	Name	Version	Name	Version
wmp.dll	12.0.7601.18150	wmlaunch.exe	12.0.7601.17514	wmpconfig.exe	12.0.7601.17514
wmplayer.exe	12.0.7601.18150	wmpcm.dll	12.0.7600.16385	wmvcore.dll	12.0.7601.17514
wmploc.dll	12.0.7601.18150	mpvis.dll	12.0.7600.16385	mf.dll	12.0.7601.17514
wmpps.dll	12.0.7601.17514	wmpdxm.dll	12.0.7601.17514
wmpeffects.dll	12.0.7601.17514	wmpshell.dll	12.0.7601.17514
Other Binaries
msnetobj.dll	11.0.7601.17514	FirewallAPI.dll	6.1.7600.16385	AUDIOSES.DLL	6.1.7601.17514
msxml6.dll	6.30.7601.18431	dhcpcsvc6.DLL	6.1.7601.17970	AVRT.dll	6.1.7600.16385
windowscodecsext.dll	6.2.9200.16492	wmpnssci.dll	12.0.7600.16385	MFPlat.DLL	12.0.7600.16385
cscapi.dll	6.1.7601.17514	msxml3.dll	8.110.7601.18431	MMDevApi.dll	6.1.7601.17514
srvcli.dll	6.1.7601.17514	credssp.dll	6.1.7601.18489	WLDAP32.dll	6.1.7601.17514
ntshrui.dll	6.1.7601.17755	wmdmps.dll	12.0.7600.16385	ntmarta.dll	6.1.7600.16385
PhotoMetadataHandler.dll	6.1.7600.16385	cewmdm.dll	12.0.7600.16385	propsys.dll	7.0.7601.17514
mp3dmod.dll	6.1.7600.16385	dhcpcsvc.DLL	6.1.7600.16385	DEVOBJ.dll	6.1.7601.17621
msdmo.dll	6.6.7601.17514	wshtcpip.dll	6.1.7600.16385	CFGMGR32.dll	6.1.7601.17621
drmv2clt.dll	11.0.7600.16385	webio.dll	6.1.7601.17725	SETUPAPI.dll	6.1.7601.17514
wmdrmsdk.dll	11.0.7601.17514	WINHTTP.dll	6.1.7601.17514	profapi.dll	6.1.7600.16385
bcryptprimitives.dll	6.1.7600.16385	upnp.dll	6.1.7601.17514	MSIMG32.dll	6.1.7600.16385
bcrypt.dll	6.1.7600.16385	PSAPI.DLL	6.1.7600.16385	WindowsCodecs.dll	6.2.9200.16809
DAVHLPR.dll	6.1.7600.16385	WLIDNSP.DLL	6.500.3165.0	SXS.DLL	6.1.7601.17514
davclnt.dll	6.1.7601.18201	mdnsNSP.dll	3.0.0.10	RpcRtRemote.dll	6.1.7601.17514
ntlanman.dll	6.1.7601.17514	DNSAPI.dll	6.1.7601.17570	rsaenh.dll	6.1.7600.16385
drprov.dll	6.1.7600.16385	WINNSI.DLL	6.1.7600.16385	CRYPTSP.dll	6.1.7600.16385
MPR.dll	6.1.7600.16385	IPHLPAPI.DLL	6.1.7601.17514	VERSION.dll	6.1.7600.16385
NetworkExplorer.dll	6.1.7601.17514	wship6.dll	6.1.7600.16385	jscript.dll	5.8.9600.16428
fwpuclnt.dll	6.1.7601.18283	mswsock.dll	6.1.7601.18254	CLBCatQ.DLL	2001.12.8530.16385
LINKINFO.dll	6.1.7600.16385	mswmdm.dll	12.0.7600.16385	COMCTL32.dll	6.10.7601.17514
XmlLite.dll	1.3.1001.0	MSASN1.dll	6.1.7601.17514	dwmapi.dll	6.1.7600.16385
rasadhlp.dll	6.1.7600.16385	CRYPT32.dll	6.1.7601.18277	OLEAUT32.dll	6.1.7601.17676
provsvc.dll	6.1.7601.17514	WINTRUST.dll	6.1.7601.18205	ole32.dll	6.1.7601.17514
ksuser.dll	6.1.7600.16385	imapi2.dll	6.1.7601.17514	gdiplus.dll	6.1.7601.18455
ATL.DLL	3.5.2284.0	slc.dll	6.1.7600.16385	SHLWAPI.dll	6.1.7601.17514
apphelp.dll	6.1.7601.17514	urlmon.dll	11.0.9600.17280	SHELL32.dll	6.1.7601.18517
mlang.dll	6.1.7600.16385	api-ms-win-downlevel-advapi32-l2-1-0.dll	6.2.9200.16492	uxtheme.dll	6.1.7600.16385
WMASF.DLL	12.0.7600.16385	api-ms-win-downlevel-ole32-l1-1-0.dll	6.2.9200.16492	MSCTF.dll	6.1.7600.16385
api-ms-win-downlevel-shlwapi-l2-1-0.dll	6.2.9200.16492	Secur32.dll	6.1.7601.18526	IMM32.DLL	6.1.7601.17514
mpst.dll	8.0.0.214	USERENV.dll	6.1.7601.17514	NSI.dll	6.1.7600.16385
POWRPROF.dll	6.1.7600.16385	api-ms-win-downlevel-advapi32-l1-1-0.dll	6.2.9200.16492	WS2_32.dll	6.1.7601.17514
TCPConnection.dll	8.0.0.214	iertutil.dll	11.0.9600.17280	USP10.dll	1.626.7601.18454
rasman.dll	6.1.7600.16385	normaliz.DLL	6.1.7600.16385	LPK.dll	6.1.7601.18177
RASAPI32.dll	6.1.7600.16385	api-ms-win-downlevel-normaliz-l1-1-0.dll	6.2.9200.16492	GDI32.dll	6.1.7601.18577
MSVCP100.dll	10.0.40219.332	api-ms-win-downlevel-version-l1-1-0.dll	6.2.9200.16492	USER32.dll	6.1.7601.17514
MSVCR100.dll	10.0.40219.332	api-ms-win-downlevel-shlwapi-l1-1-0.dll	6.2.9200.16492	CRYPTBASE.dll	6.1.7600.16385
credui.dll	6.1.7601.18276	api-ms-win-downlevel-user32-l1-1-0.dll	6.2.9200.16492	SspiCli.dll	6.1.7601.18526
bthprops.cpl	6.1.7601.17514	WININET.dll	11.0.9600.17280	RPCRT4.dll	6.1.7601.18532
utils.dll	8.0.0.214	WINSTA.dll	6.1.7601.17514	sechost.dll	6.1.7600.16385
ipc.dll	8.0.0.214	WTSAPI32.dll	6.1.7601.17514	msvcrt.dll	7.0.7601.17744
CommApi.dll	8.0.0.214	WINMM.dll	6.1.7601.17514	ADVAPI32.dll	6.1.7601.18247
MSMPlugin.dll	8.0.0.214	SSDPAPI.dll	6.1.7600.16385	KERNELBASE.dll	6.1.7601.18409
DUI70.dll	6.1.7600.16385	upnphost.dll	6.1.7600.16385	kernel32.dll	6.1.7601.18409
DUser.dll	6.1.7600.16385	npmproxy.dll	6.1.7600.16385	ntdll.dll	6.1.7601.18247
explorerframe.dll	6.1.7601.17514	nlaapi.dll	6.1.7601.17761
pcwum.DLL	6.1.7600.16385	netprofm.dll	6.1.7600.16385
Audio Codecs
Type	Name	Format	Binary	Version
ACM	Microsoft IMA ADPCM CODEC	0011	imaadp32.acm	6.1.7600.16385
ACM	Microsoft CCITT G.711 A-Law and u-Law CODEC	0007	msg711.acm	6.1.7600.16385
ACM	Microsoft GSM 6.10 Audio CODEC	0031	msgsm32.acm	6.1.7600.16385
ACM	Microsoft ADPCM CODEC	0002	msadp32.acm	6.1.7600.16385
ACM	Fraunhofer IIS MPEG Layer-3 Codec (professional)	0055	l3codecp.acm	3.4.0.0
ACM	Microsoft PCM Converter	0001
DMO	WMAudio Decoder DMO	0160, 0161, 0162, 0163	WMADMOD.DLL	6.1.7601.17514
DMO	WMAPro over S/PDIF DMO	0162	WMADMOD.DLL	6.1.7601.17514
DMO	WMSpeech Decoder DMO	000A, 000B	WMSPDMOD.DLL	6.1.7601.17514
DMO	MP3 Decoder DMO	0055	mp3dmod.dll	6.1.7600.16385
Video Codecs
ICM	Microsoft RLE	MRLE	msrle32.dll	6.1.7601.17514
ICM	Microsoft Video 1	MSVC	msvidc32.dll	6.1.7601.17514
ICM	Microsoft YUV	UYVY	msyuv.dll	6.1.7601.17514
ICM	Intel IYUV codec	IYUV	iyuv_32.dll	6.1.7601.17514
ICM	Toshiba YUV Codec	Y411	tsbyuv.dll	6.1.7601.17514
ICM	Cinepak Codec by Radius	cvid	iccvid.dll	1.10.0.13
ICM	DivX 6.9.2 Codec (12 Logical CPUs)	divx	DivX.dll	6.9.2.26
ICM	DivX 6.9.2 YV12 Decoder	yv12	DivX.dll	6.9.2.26
ICM	Xvid MPEG-4 Codec	XVID
ICM	RivaTuner Video Codec	RTV1
DMO	Mpeg4s Decoder DMO	mp4s, MP4S, m4s2, M4S2, MP4V, mp4v, XVID, xvid, DIVX, DX50	mp4sdecd.dll	6.1.7600.16385
DMO	WMV Screen decoder DMO	MSS1, MSS2	wmvsdecd.dll	6.1.7601.17514
DMO	WMVideo Decoder DMO	WMV1, WMV2, WMV3, WMVA, WVC1, WMVP, WVP2	wmvdecod.dll	6.1.7601.18221
DMO	Mpeg43 Decoder DMO	mp43, MP43	mp43decd.dll	6.1.7600.16385
DMO	Mpeg4 Decoder DMO	MPG4, mpg4, mp42, MP42	mpg4decd.dll	6.1.7600.16385
MPEG/DVD Filters
Type	Name	Binary	Version
video	LAV Video Decoder	LAVVideo.ax	0.62.0.0
video	CyberLink Video/SP Decoder (PDVD9)
video	CyberLink Video/SP Decoder (PDVD10)
video	Microsoft DTV-DVD Video Decoder	msmpeg2vdec.dll	12.0.9200.17037
video	CyberLink Video Decoder (PDVD9)
video	CyberLink Video Decoder (PDVD10)
video	CyberLink Video/SP Decoder(PDVD10 UPnP)
video	CyberLink Video/SP Decoder(PDVD9 UPnP)
audio	LAV Audio Decoder	LAVAudio.ax	0.62.0.0
audio	Microsoft DTV-DVD Audio Decoder	msmpeg2adec.dll	6.1.7140.0
audio	CyberLink Audio Wizard
audio	CyberLink Audio Decoder (PDVD9)
audio	CyberLink Audio Decoder (PDVD10)
audio	CyberLink Audio Decoder(PDVD9 UPnP)
audio	CyberLink Audio Decoder(PDVD10 UPnP)
Plug-ins
Background	Avrcp MetaData plug-in	MSMPlugin.dll	8.0.0.214
Background	Bluetooth handsfree plug-in	mpst.dll	8.0.0.214
Services
Name	Key	Binary	Version
Audible.com	Audible
eMusic	emusic
FaroLatino Music and Video	FaroLatino11_EN
Media Guide	MediaGuide
MIXPLAY	MIXPLAY_USA
Old 4th October 2014, 16:22   #21395  |  Link
I'm running a backup now with Glarioo's INI settings. I'll post results when it completes.
Is anyone else out there having sync issues with LAV Filters?
Old 4th October 2014, 16:29   #21396  |  Link
I have no idea what that is?
Old 4th October 2014, 16:37   #21397  |  Link
omegaman7
omegaman7's Avatar
Probably about installing codec packs. Which is a legitimate question! 9 out of 10 times, that's the problem.
Old 4th October 2014, 16:48   #21398  |  Link
MajorEvent
MajorEvent's Avatar
When I go to post in this forum there's a random question that I have to answer or the post is refused. I'm not talking about anything you said, it's probably some newbie torture they impose in this forum.
My question right now: How many categories does this board have?...Man, this sucks...opening a new window to the top of the board...counting...entering the answer...oh damn it's wrong...new question...What is the name of the script-based frame server used for processing/filtering video?...what the f#%k?..man, this really sucks...get the picture?...they torture newbies on this board, quite discouraging.
Old 4th October 2014, 16:52   #21399  |  Link
Hmm... I wonder when that started? I've never seen it.
Old 4th October 2014, 17:00   #21400  |  Link
Starfiresg1
Starfiresg1's Avatar
I remember having to answer a question (to which you've to find the answer in the forum - e.g. something like "what is the name of the fifth sub-forum of this board") when you wanted to post - it either occurs randomly or only for new accounts. However it hasn't happened for me in a while. Probably something to prevent spamming accounts.
I had that negative experience about a year ago (I know it was not supported then) after my TV software installed the LAV-Filters without me discovering it -> every encode was suddenly out-of-sync from the beginning till the end of the movie (same delay - simple shifting the audio in the playback software would "fix" it). It only went away after I removed LAV (after I discovered it in the installed programs list).
Which is why I haven't switched over to LAV from Halli / ffdshow yet.
Maybe i will have time to try an encode using LAV-filters with the newest BD-Rebuilder version tomorrow.
Starfiresg1 is offline   Reply With Quote
