Old 13th January 2025, 11:48   #32121  |  Link
MrVideo
MrVideo's Avatar
Are the two files on the list part of a playlist with more files?
Yes. IMHO that should not make a difference. The two examples are 1 sec black clips added to the end of various videos. Pretty stupid, since they could have just encoded the 1 sec of black as part of all the files and just added a chapter mark at that location.
The 1 sec black doesn't need to be recoded, only the longer videos that use it. The non-recoded file will work in the playlist. The min-size setting should be honored, no matter what.
If there is a way to make it do that, please let me know.
Old 13th January 2025, 13:14   #32122  |  Link
gonca
In BD_RB if 1 file in a mpls has to be encoded then all the files will be encoded, if I remember correctly.
This keeps common specs (level etc) for all the files in the mpls.
Prevents possible playback issues, I guess.
Old 13th January 2025, 17:22   #32123  |  Link
DanDare1983
In regards to the 1 sec black clips, I genuinely can't believe how many movies have them. I'd like to find a way of removing them as I have many movies like this and it's always annoying when I go to backup a disc and the playlist has an extra m2ts for no reason whatsoever.
DanDare1983 is offline   Reply With Quote
Old 13th January 2025, 21:36   #32124  |  Link
MrVideo
MrVideo's Avatar
Well, that can cause issues.
Doing recoding during backups doesn't do any level changes, etc. That would certainly screw up any HDR/DV videos. Besides, these are short black videos.
I'd be happy to have a hidden option that overrides this behavior.
Old 13th January 2025, 21:41   #32125  |  Link
MrVideo
MrVideo's Avatar
Unfortunately, they do have a reason. If you look at the end of the video that precedes the 1 sec black, you will find that it ends without any black. That end piece is what allows you to skip to the end, as there is a chapter mark at that point. If that were removed, you would not be able to skip to the end and then do the next operation, be it going to the next episode/video or the menu. You'd have to press the menu key. They play a purpose, but they are a backup annoyance.
Old 13th January 2025, 22:48   #32126  |  Link
DanDare1983
Thank you for responding. I had no idea the 1 sec m2ts was needed. So the last chapter will be at the end of the 1 sec m2ts and not the main m2ts? I like to make remux, would it be best to keep the 1sec m2ts at the end or would it be beneficial to move it?
Old 13th January 2025, 23:31   #32127  |  Link
MrVideo
MrVideo's Avatar
The last chapter is actually at the end of the video preceding it/start of the 1 sec black. Best to leave it in place. If you are remuxing to a MKV file (for example), the 1 sec black will be added to the end, making it one continuous file.
Old 14th January 2025, 09:29   #32128  |  Link
MrVideo
MrVideo's Avatar
Backup video recode failure
Doing a backup of a UHD in which the main video is UHD and DV. Weird is that the log said the bitrate was 500kb.
The encoder didn't fail right at the start. It got a way in before failing.
Is there a last command somewhere that I can run to get the encoder's error?
ADDED INFO: I decided to recode the M2TS file and ended up with this error:
avcuvid: error occured while reading file: 591 frames, Resource temporarily unavailable
There is nothing wrong with the m2ts file as I was able to copy it to another HDD,
Old 16th January 2025, 07:16   #32129  |  Link
MrVideo
MrVideo's Avatar
No additional info regarding my UHD backup issue?
Old 16th January 2025, 08:12   #32130  |  Link
jz1276
After years of using this great program with numerous BluRays, I've run into my first issue. I've tried both BD-25 & 50 target sizes. Please let me know if more info is needed and any help is appreciated.
[01/16/25] BD Rebuilder v0.62.12
[02:09:32] Source: BLURAY
- Input BD size: 19.98 GB
- Approximate total content: [01:52:18.083]
- Target BD size: 46.26 GB
- Windows Version: 6.2 [9200]
- Auto Quality: Very Good (Very Fast), 1-Pass VBR
[02:09:34] PHASE ONE, Encoding
- [02:09:34] Processing: VID_00002 (1 of 2)
- [02:09:34] Extracting A/V streams [VID_00002]
- TSMUXER ERR: 0xFFFFFFFD
- Extracting video streams [VID_00002]
- Bitstream exception std::exception. It does not have to be! Please contact application support team for more information.
- Error in attempt to extract video.
[02:09:41] - Failed to retrieve audio, aborted
jz1276 is offline   Reply With Quote
Old 16th January 2025, 10:30   #32131  |  Link
MrVideo
MrVideo's Avatar
Attach mediainfo output of the video file. Code wrap the text file.
Old 16th January 2025, 16:33   #32132  |  Link
Not sure... but it sounds like a system error of some type.
Old 17th January 2025, 04:34   #32133  |  Link
MrVideo
MrVideo's Avatar
No idea either. I've never seen that error. Not sure how it is a system error, since this has never happened before. I'm suspecting with the file.
Old 22nd January 2025, 17:35   #32134  |  Link
Yes. The last command is always recorded in LASTCMD.TXT located in the BD-RB folder. You can cut-and-paste it into a CMD window to test it. You normally should to do it immediately after getting the error -- assuring that all involved files etc. are still accessible.
Old 23rd January 2025, 04:57   #32135  |  Link
MrVideo
MrVideo's Avatar
I know I've seen that file in the past, but for this UHD backup job, no such file.
