Old 1st September 2010, 08:18   #9381  |  Link
setarip_old
setarip_old's Avatar
@ChldsPlay
Of course no files are missing. Re-read what I said:
In the "BDMV" folder, check to make certain that all files and folders that are supposed to be are properly duplicated in the "BACKUP" folder. If any "originals" or "backups" are missing or damaged, see if you can copy from one to the other (Copy a good "original" file to the "Backup" folder or vice-versa). Look for the same situation in the "CERTIFICATE" folder and its "Backup" folder.
Old 1st September 2010, 19:24   #9382  |  Link
A.Fenderson
With AnyDVD running and the physical disc in the drive, use TeraCopy to copy all files from the disc to you HDD--at the very least, its informative error-reporting will let you know the nature of the problem during the copy.
A.Fenderson is offline   Reply With Quote
Old 2nd September 2010, 01:47   #9383  |  Link
At the very least it is telling you that for some reason AnyDVD is having issues with the source.
Old 2nd September 2010, 11:33   #9384  |  Link
AGKnotUser
34.07 Bug
With Automatic Quality Settings selected, in Log: Auto Quality shows "Good (Very Fast), Two Pass" when in fact it does One Pass.
AGKnotUser is offline   Reply With Quote
Old 3rd September 2010, 03:49   #9385  |  Link
techno1
Will 64bit be coming soon?
CURRENT VERSION 0.34.07 (August 10th, 2010)
9. Please DO NOT replace the versions of software included in the BD-RB ZIP with other versions (e.g. replacing the 32 bit X264 with a 64 bit version). In doing so you are very likely creating a self-inflicted injury that will not be addressed as a bug.
J_DOBBS, I did exactly what you indicated above with a new Win7 64bit intall and got error after error. My question is: Will BD-RB eventually be able to use 64bit execuables and is it that much different to make it happen? How much time can be saved by going 64bit (x264)? This inquiring mind would be wanting to know. Great work btw, JD on BD_RB! ....carry-on
techno1 is offline   Reply With Quote
Old 3rd September 2010, 07:30   #9386  |  Link
chompy
LAVF fails decoding VC-1 streams
after doing a full backup to BD-25 of Peter Jackson’s King Kong and getting some pixelations in m2ts junctions, I’ve done some tests and I’ve detected that LAVF fails decoding the penultimate frame on VC-1 streams (lavf [warning]: video decoding failed on frame xxxx), on H264 streams it works ok, but the only two blu-rays I have encoded using VC-1 (King Kong and Clash of the Titans, been both seamless branching) have this problem and those pixelations at the end of m2ts are sometimes quite obvious, and this warning lets me think that it's the problem of the pixelations I'm having.
So my conclusion, but only based on to movies is that LAVF cannot be used to demux VC-1 seamless branching movies… Could anybody please do any test with any other VC-1 film and corroborate this problem?
Greetings
Edit: Could it be possible that BD-Rebuilder collects those x264 warnings in its log in order to just looking to it we could have an idea if something have been wrong during encoding?
chompy is offline   Reply With Quote
Old 3rd September 2010, 14:17   #9387  |  Link
Very little time is saved. That's why it's a low priority. But the next release will include the 64 bit version of X264 and will use it (on 64 bit systems) with the LAVF demuxer on most sources. On my system I saw about a 5% speed increase.
Old 3rd September 2010, 14:21   #9388  |  Link
Originally Posted by chompy View Post
Greetings
Hmmm... I personally haven't seen any pixelation. I'll check it out.
Old 3rd September 2010, 17:24   #9389  |  Link
Bystander
Having problems with Sphere NA Blu-ray when selecting TrueHD audio track only. It only results in standard DD 5.1 640kbps.
Log:
[01:00:02] BD Rebuilder v0.34.07 (beta)
- Source: SPHERE
- Input BD size: 26.89 GB
- Approximate total content: [02:14:12.836]
- Target BD size: 58.59 GB
- Windows Version: 6.1 [7600]
- MOVIE-ONLY mode enabled
- Auto Quality: Good (Very Fast), Two Pass
- Audio [1] set to default.
[01:00:03] PHASE ONE, Encoding
- [01:00:03] Extracting A/V streams [VID_00013]
- [01:37:11] Reencoding: VID_00013 (1 of 1)
- [01:37:11] Collecting video information
- [01:37:11] Keeping original video (no reencode)
- [01:37:11] Reencoding audio tracks (if req'd)
- [01:37:11] Multiplexing M2TS
[01:46:12]PHASE ONE complete
[01:46:12]PHASE TWO - Rebuild Started
- [01:46:12] Rebuilding BD file Structure
[01:56:07] - Encode and Rebuild complete
[01:56:07] Writing BD structure to ISO file
- ImgBurn completed successfully
- SPHERE folder removed.
- WORKFILES folder removed.
[02:07:32]JOB: SPHERE finished.
Any thoughts? I did it twice with the same result.
INF file:
[Status]
LABEL=SPHERE
VERSION=v0.34.07 (beta)
SOURCE_SIZE=28874127360
SOURCE_VIDEO_SIZE=28874127360
TARGET_SIZE=62914560000
REDUCTION=2.17892507072463
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;
BACKUP_MODE=1
MOVIEONLY_TYPE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=1
[00013]
USE_ORIGINAL=1
AUDIO=1000
PGS=010000
M2TS_TARGET=62914560000
NSIZE=24180842496
FLINK=0
MLINK=0
I only have the 2 options for blu-ray audio checked. When I checked the bottom one to keep HD audio for BD-25 I now see HD=1 along with Kbs=640. I wont know what the end result is until I get home again tonight.
Bystander is offline   Reply With Quote
Old 3rd September 2010, 22:05   #9390  |  Link
HWK
HWK's Avatar
Log:
- Source: SPHERE
INF file:
[Status]
LABEL=SPHERE
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;
BACKUP_MODE=1
MOVIEONLY_TYPE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=1
[00013]
USE_ORIGINAL=1
AUDIO=1000
PGS=010000
NSIZE=24180842496
FLINK=0
MLINK=0
Something is not quite right
- Source: SPHERE
- Target BD size: 58.59 GB (How come it shows target higher that 50 GB disc.)
You requested HD Audio but haven't selected in the setup.
Old 3rd September 2010, 22:58   #9391  |  Link
Bystander
- Source: SPHERE
I just got back and I see I now have TrueHD 5.1 when I selected "Keep HD audio for BD-25". This seems odd since I told it not to re-encode AC3 or DTS with the top two "Blu-ray" options. If I select the DTS MA HD audio track I would expect it not to re-encode and use that track. To additionally have to select the Keep HD Audio for BD-25 seems contrary to the idea of selecting the HD audio track and telling it not to re-encode.
The reason I use 60GB is so that there is no loss in video. I know it's overkill but its easy to remember.
Bottom line is it works and I'm happy. I don't change the settings that much. I had to download the latest beta which means starting over with the settings. By the way.... this brings me to another point. Is there a way to set the settings in the registry? So when upgrading to different version, you would not need to modify settings from scratch. Or something similar.
Old 3rd September 2010, 23:36   #9392  |  Link
AGKnotUser
I use "Save Project" / "Open Project" in the File Menu.
Old 4th September 2010, 00:51   #9393  |  Link
Capsbackup
Just don't delete the BD-RB.ini from the folder where BD-RB is located, if you are copying over the old files. Or, when you unzip a fresh new version of BD-RB, just copy the previous version's .ini from the old folder to the new unzipped folder. Make sure you do this before you run BD-RB for the first time from the new unzipped folder. BD-RB will create a new .ini if one does not exist, so if you copy your old one over to the new folder, it will use these settings.
Old 4th September 2010, 13:39   #9394  |  Link
DrKajun
Error in attempt to extract audio/subs
Trying to process 2 different Full BD's and I get the same error "Error in attempt to extract audio/subs"
Tried just selecting Eng Subs but still same issue. Any thoughts?
File Type: txt Inspect.txt (438 Bytes, 24 views)
DrKajun is offline   Reply With Quote
Old 4th September 2010, 14:51   #9395  |  Link
What kind of audio does it have?
Old 4th September 2010, 15:22   #9396  |  Link
bluestarCVO
Are you sure there is enough available space on your hard drive? Will sometimes display that message if running too low on space.
bluestarCVO is offline   Reply With Quote
Old 4th September 2010, 22:27   #9397  |  Link
worknstiff
I don't know if this is a BD_Rebuilder or a multiAVCHD prob so forgive me if it turns out to misposted...:I have used both of these programs to preprocess BD's before and have never had any errors. --I took a movie with some "short films" in it. I used multiAVCHD to snatch each of the 13 small m2ts files from the original rip to create a simple strict AVCHD with menu. After I created this BD image it came to about 11gb's and I input this into BD_Rebuilder and created a (FULL) BD-9 copy with a "WORKING" menu. I said "WORKING" because 12 of the titles work when selected from the menu. If I try to select the final 13th title it crashes the player. This does not happen on the original multiAVCHD BD, just the BD_Rebuilder copy. If I let the disk play thru from the 12th title everything is fine and it finishes playing the 13th title and then the player crashes instead of going back to the menu like it's supposed too. When I was using BD_Rebuilder as it was on the last VID_80130, I get a Haali Media Splitter error box, that says ERROR can't open file VID_80130. After I click on it to close it, BD_Rebuilder finishes normally without any mention of this in the log file? Why if the menu works after multiAVCHD creates it does haali not like the menu structure when being processed with BD_Rebuilder?
____________________________________________________________
- [13:17:12] Extracting A/V streams [VID_00012]
- [13:17:29] Reencoding: VID_00012 (13 of 14)
- [13:17:29] Collecting video information
- Rate/Length: 23.976fps, 7,248 frames
- Bitrate: 15,000 Kbs
- [13:17:29] Reencoding: VID_00012, Pass 1 of 1
- [13:23:59] Video Encode complete
- [13:23:59] Reencoding audio tracks (if req'd)
- [13:24:11] Multiplexing M2TS
- [13:24:37] Extracting A/V streams [VID_80130]
- [13:24:38] Reencoding: VID_80130 (14 of 14)
- [13:24:38] Collecting video information
- Rate/Length: 23.976fps, 1 frames
- [13:24:38] Reencoding: VID_80130, Pass 1 of 1
- [14:31:01] Video Encode complete
- [14:31:01] Reencoding audio tracks (if req'd)
- [14:31:01] Multiplexing M2TS
[14:31:01]PHASE ONE complete
[14:31:01]PHASE TWO - Rebuild Started
- [14:31:01] Rebuilding BD file Structure
[14:31:02] - Encode and Rebuild complete
[14:31:02]JOB: *****_SHORT_FILMS_MULTIAVCHD finished.
I think it has to do with the way the files being created are numbered because there is no VID_80130 since the m2ts files multiAVCHD creates start at VID_00000 and stop at VID_00012 for the 13 files. Also the VID_80130 is only 1 frame so Haali can't open it. Any solutions will be appreciated, worknstiff
Old 5th September 2010, 00:07   #9398  |  Link
DrKajun
@jdobbs and bluestarCVO
Thanks, looks to have been a combo of Drive space and too many selected subs.
Old 5th September 2010, 01:14   #9399  |  Link
Capsbackup
This is definately not a BD-RB problem. BD-RB is intended for original retail authored Blu-rays. As you have witnessed, multiAVCHD does not follow original Blu-ray authoring.
Why not just create the entire project with multiAVCHD, letting it reencode the files to the desired bitrate/file size. What you are trying to do is exactly what deank has developed, so it is able to do it all.
Old 5th September 2010, 04:05   #9400  |  Link
Is that the real volume label? I'm not sure, but I think the "*'s" are illegal -- at least for creating a filename.
BD-RB can only be aware of a HAALI error if it is passed back through AVISYNTH.
What version of HAALI are you using? If it isn't the recommended one from the first post of this thread -- fix it. I recently tried the most recent one and ran into issues.
