#1523 | Link | |
Life's clearer in 4K UHD
While within the resize filter widow: - Under 'Aspect ratio' select 'Disabled'. Under 'Filter mode' select the resize filter that best suits your needs. Under 'New size' select 'Absolute (pixels)' and enter the required pixel values in the two boxes.
#1524 | Link |
Unused internal filters = outdated, useless, ...?
I'm using VD2 since a long time to improve (mostly older) videos
from all kind of devices. Mostly I use internal and Anton's filters, additional a few special ones (ACOBW and NDF, DeLogo, Deshaker and some MSU filters). Some of the internal filters I never used. Maybe I miss something with them, so I would like to ask for hints when/ if these filters are useful: 2:1 reduction (high quality) Which differences to filte "resize (50%)"? Quality? Speed? convert to floating point Useful when ...? gamma correct? Useful when ...? warp sharp, warp resize? Both seem to produce bad results... BTW What does the "Save" button in filter dialog do? (There is no "Load" etc.) TIA Last edited by nji; 5th February 2025 at 11:31. |
#1525 | Link |
VirtualDub2 v2.2.0.755
Changes: The auxsetup utility now has two versions: for win32 and x64. Removed "64" prefixes for exe and dll files. Improved HiDPI support. Fixed output of system messages in vdub2.exe. Code refactoring for modern compilers. Updated avlib-1.vdplugin to version 0.7.1.220. - Video files with incorrect (or unrecognized) frame rates are not supported. This fixes the plugin crash. - Code refactoring for modern compilers. Updated scripted.vdplugin to version 0.2.1.92. - Fixed script saving. - Now uses Avisynth+ header files. Minimum supported version of Avisynth is 2.6. - Code refactoring for modern compilers. Also available is old VirtualDub2 44282 with updated avlib.vdplugin. |
#1526 | Link |
It's very strange, but 32-bit scripted.vdplugin 0.2.1.92 for some unknown reason scores 9-12 points on VirusTotal. There is no such problem with the 64-bit version.
I used Visual Studio 2019 v16.11.42 and Windows SDK 10.0.19041.0. Added Rebuilt scripted.vdplugin 0.2.1.92 on a clean virtual machine with Visual Studio 2019 v16.11.42 and Windows SDK 10.0.19041.0 - nothing changed.
MPC-BE 1.8.3 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 4th February 2025 at 10:04. |
#1527 | Link |
Is the offending file compressed with UPX ?,
if so try virustotal scan without UPX. EDIT: Damn, false +ve's growing, 19/71 (I did a rescan on VirusTotal original file, was original [for me] 17/70]) https://www.virustotal.com/gui/file/...989f005de3059d EDIT: Maybe of interest (for Microsoft defender "Win32/Wacapew.C!ml" false +ve) :- https://www.purebasic.fr/english/viewtopic.php?t=84192 shows VirusTotal:BEHAVIOUR/Memory Pattern Domains/ and BEHAVIOUR/Memory Pattern Urls as "upx.sf.net" EDIT: VirusTotal:BEHAVIOUR/Full Reports/Zenbox/ Shows, "Uses 32bit PE files", in pink, so just being 32 bit seems to now be cause for concern.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 4th February 2025 at 17:16. |
#1528 | Link | |
No packagers are used.
I tried to build in Visual Studio 2022 and got the same result. I can also try another Windows SDK, but I doubt it will help. Quote:
The 64-bit version is still clean. This is very strange. As if these antiviruses can't work with 64-bit code. ![]() Maybe antiviruses don't like the large list of built-in AviSynth functions. ![]()
MPC-BE 1.8.3 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 4th February 2025 at 18:02. |
#1529 | Link | |
by me.
![]() Your Remote Desktop SUCKS!! Try this instead (FREE + Open Source):- https://www.youtube.com/watch?v=EXL8mMUXs88 Which suggests RustDesk as a cross platform Open Source Remote Desktop app. https://github.com/rustdesk/rustdesk/ PC/MAC/Linux/Android/IOS/WEB x64 no problem, but x86 exe download produces (maybe) false +ve with Comodo Internet Security antimalware. O.T. @Wonkey-Monkey, I remember that you were searching for good Linux VNC, some years back, have you tried this one (RustDesk) ? EDIT: I will not be installng Rustdesk any time soon, got too much to do already.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 4th February 2025 at 20:13. |
#1530 | Link | |
Formerly davidh*****
![]() I switched back to Windows nn my work desktop in the end. I do successfully (mostly) use VNC on Ubuntu with virtual desktops. |
#1531 | Link |
I remember that I used to use TigerVNC (by same guys as TightVNC on Windows) on Linux Mint (Ubuntu based).
#1532 | Link | |
1) x86 version works OK under Win7 x64. But x64 version gives error at start: "The procedure entry point kernel32.WaitOnAddress could not be located in the dynamic link library api-ms-win-core-synch-|1-2-0.dll", it starts but on video load gives: "Couldn't locate decompressor for format 'H264' (unknown)
Also I used VirtualDub.exe /queryVersion to detect old version if less than 42475; but newer version gives 219 when I expect something bigger than 44282 which is the one I use now. Win7 compatibility is important due to a lot of users (as me) use it with vintage capture cards to get VHS/Video8. Most of them needs WinXP, and some can be hacked to work with win7 which is my system for main Vdub usage. Last edited by isidroco; 5th February 2025 at 01:56. |
#1533 | Link | ||
Minimum system requirements x64 compatible CPU Windows 8.1 x64 or newer VirtualDub2 v2.1 can work on Windows 7 if you replace the FFmpeg DLL files with Windows 7 compatible ones. My VirtualDub2 x64 kit uses only official release shared builds of FFmpeg. There are three possible solutions for Windows 7 users. I won't double check these solutions, Windows 7 users will have to do it themselves and use the one that suits them. The VirtualDub2 Win32 kit uses the ffmpeg-n7.1-latest-win32-gpl-shared-7.1.zip build from the yt-dlp project. I haven't tested these builds on Windows 7 and don't plan to. Quote:
I would recommend creating a shared folder that will contain several different folders with different versions of VirtualDub/VirtualMod/VirtualDub2. This folder can be added to PATH and you can use a relative path from this folder to different versions of VD. This will be a more correct solution.
MPC-BE 1.8.3 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
#1534 | Link | |
2:1 reduction (high quality): it uses 3*3 sample matrix, which is (I guess) something in between bilinear and bicubic of the resize filter. Never used/touched. convert to floating point: this is to force fp32 quality for next filter (e.g. gamma correct). gamma correct: "Converts video color representation between gamma space and linear space." Some operations (resize) make more sense in linear. Somewhat HDR-related. warp sharp, warp resize: no idea. What does the "Save" button in filter dialog do: same as File->Save project. I mostly forgot why, maybe to have it at hand while making complex filter adjustment, which may lead to crash or adverse result requiring backup. |
#1536 | Link | |
Indeed, "Save" saves the project. But only if you have a project defined/ loaded. Otherwise "Save" button does (without message) not save anything! ==> If crash, the valuable filter chain is lost. Something for the (non-existing ![]() |
#1537 | Link | |
But changing VirtualDub64.exe to VirtualDub.exe IMO is a mistake. My script tries to findout where VDUB is located, and which version is installed, and changes it's bahaviour according to that (even choosing x32 or x64 depending on desired filters). Having the same name for both x32/x64 versions makes correct version usage very hard from batch. Same with your chosen version to return: older VDUB v1.07.8 returns 28346; v1.10.2 returns 34807, v1.10.4 35491; newer VDUB2 returns 44282; I use 42475 as cut point to use or not use some functions (ie: VirtualDub.video.SetInputMatrix ). But your chosen return value: 219 completly breaks version ascending order. I'm puzzled of why you decide to do those arbitrary breaking changes with no benefit at all. I have to do a lot of useless changes to adapt to the new naming/version scheme and at the same time being able to run on older versions. |
#1538 | Link |
I've been solving my problems with building, debugging and testing. I'm happy with everything now and I'm not going to complicate this process.
I don't know what kind of scripts you have, but I would do something like this at the beginning of the script. Code:
rem C:\Progs\VirtualDub-1.10.4\VirtualDub.exe rem C:\Progs\VirtualDub-1.10.4-AMD64\Veedub64.exe rem C:\Progs\VirtualDubMod\VirtualDubMod.exe rem C:\Progs\VirtualDub2_44282\VirtualDub.exe rem C:\Progs\VirtualDub2_44282\VirtualDub64.exe rem C:\Progs\VirtualDub2_v2.2\VirtualDub2.exe rem C:\Progs\VirtualDub2_v2.2_win32\VirtualDub2.exe SET VD_EXE="C:\Progs\VirtualDub2_v2.2\VirtualDub2.exe" %VD_EXE% "Test.avi"
MPC-BE 1.8.3 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 5th February 2025 at 17:06. |
#1539 | Link | |
set PARAM=_%*& REM _ avoid PARAM being empty if no param passed, %* are rest of parameters passed rem delete all spaces set PARAM=%PARAM: =% set vdloc=C:\VirtualDub\&REM ***prefered virtualdub path goes here*** set vDub=VirtualDub.exe set vDubCli=vdub.exe if defined ProgramFiles(x86^) ( REM defaults on x64 windows set vDub=VirtualDub64.exe set vDubCli=vdub64.exe ) IF not "%PARAM:x32=%" == "%PARAM%" ( REM x32 parameter forces 32b vdub set vDub=VirtualDub.exe set vDubCli=vdub.exe ) IF not "%PARAM:fdeblk=%" == "%PARAM%" ( REM deBlock only in 32b vdub echo ***& echo *** Using x32 vdub due to FDEBLK deblock parameter ***& echo *** set vDub=VirtualDub.exe set vDubCli=vdub.exe ) IF not "%PARAM:x64=%" == "%PARAM%" ( REM x64 parameter forces 64b vdub set vDub=VirtualDub64.exe set vDubCli=vdub64.exe ) FOR %%S in ( "%vdloc%","%ProgramFiles%\VirtualDub\"^ ,"C:\DVD\VirtualDub\" "C:\VirtualDub\","C:\DVD\VDUB\"^ ,"%ProgramFiles(x86)%\VirtualDub\" "C:\Archivos de programa\VirtualDub\" ) do ( set vdloc=%%~S& REM eliminate quotes" which are needed for spaces in dirs rem must use !vdloc! delayed expansion instead of %vdloc% here: IF exist "!vdloc!%vdub%" GOTO :vdfound ) set errorStatus=VirtualDub not found: Modify vdloc path in batch or install vDub GOTO :error :vdFound set oldVDub= & REM space: Enable newer VDub2 commands: use color matrix, hide i/o video in status window set xCompr=I& REM *I* default h264 vDub internal for new Vdub IF not "%PARAM:ch264v=%" == "%PARAM%" set xCompr=H& REM *H* h264 vfw IF exist "%vdloc%%vDubCli%" ( rem Check if old vdub version "%vdloc%%vDubCli%" /queryVersion >nul if not errorlevel 42475 ( REM if ver<42475 old version of virtualDub set noWavHeader= & REM don't use in new vdub versions set oldVDub=// & REM bars "// " comments out newer commands set xCompr=H& REM *H* default h264 vfw compressor for old Vdub ) ) IF "%vDub%" == "%vDub64%" IF not exist "%vdloc%plugins64\Deshaker_64.vdf" ( set errorStatus=Please copy deshaker plugin in: %vdloc%plugins64\Deshaker_64.vdf GOTO :error ) ELSE ( IF not exist "%vdloc%plugins32\Deshaker.vdf" ( set errorStatus=Please copy deshaker plugin in: %vdloc%plugins32\Deshaker.vdf GOTO :error ) ) ... Last edited by isidroco; 5th February 2025 at 19:47. |
#1540 | Link | |
@v0lt
Or open a "Save project" dialog? This would prevent possibly data loss at crash. |
