26th September 2016, 12:51 | #39541 | Link |
That leeperry will find some esoteric setting that he really can't live without, madshi will ask for opinions on it and end up deprecating it thus removing his preferred setting
forcing him to hold on to what he believes is the "perfect" madVR build. |
26th September 2016, 13:22 | #39543 | Link | |
26th September 2016, 14:07 | #39546 | Link | |
26th September 2016, 15:35 | #39547 | Link | |
Test patterns: Grayscale yuv444p16le perceptually spaced gradient v2.1 (8-bit version), Multicolor yuv444p16le perceptually spaced gradient v2.1 (8-bit version) |
26th September 2016, 16:11 | #39551 | Link |
I'm hoping for a anti-ringing solution for SupeRes that works as good as the deringing filter, but without the bad effects combined with SuperRes. madshi said he didn't remove the anti-ringing checkbox for SR because he has plans to improve it.
26th September 2016, 21:47 | #39553 | Link |
You can make profiles for devices now so you can make profiles for 3DLUTS now.
madVR options explained |
27th September 2016, 00:53 | #39556 | Link | |
madshi has told us that line in the OSD can be ignored if using smooth motion.
27th September 2016, 00:54 | #39557 | Link |
So I tried the 3d mvc again. It appears to work, but basically only if I skip a little bit in the movie, like move the movie back a little on the slider, than it seems to play correctly. Anyone know why this is? Otherwise I get the phenomenon where the eyes are slightly out of sync. Basically the 3d looks fine until there is any movement, then you can tell its a little blurry and the scene changes are obviously messed up.
27th September 2016, 01:09 | #39558 | Link |
Why isn't this activating for 60 fps?
if (srcWidth <= 800) "SD" if (srcWidth >= 801) "HD" if (fps = 60.000) "Live Stream" Can someone simply fix this? Thanks I've tried reordering it too (assuming it looks for 60 fps first) if (srcWidth <= 800) "SD" if (fps = 60.000) "Live Stream" if (srcWidth >= 801) "HD" Somehow it needs to not activate HD before looking at the fps if (srcWidth <= 800) "SD" else if (srcWidth >= 801) and (fps = 60.000) "Live Stream" else "HD" This doesn't work either. Is something bugged? Last edited by JarrettH; 27th September 2016 at 01:24. |
27th September 2016, 11:31 | #39560 | Link | ||
