Old 17th June 2010, 22:13   #101  |  Link
sneaker_ger
Are we still talking about those you uploaded above?
Old 17th June 2010, 22:15   #102  |  Link
asarian
Indeed, we are. :) The English subs (0004 - 12), which I just renamed to 2010.sup in my script, thinking maybe the spaces in the name could cause the problem.
Old 17th June 2010, 22:32   #103  |  Link
sneaker_ger
Working fine here using the following script:
BlankClip(length=259200,width=1920,height=1080,fps=24000,fps_denominator=1001,color=000000)
SupTitle("00004 - 12 - Subtitle (PGS).sup")
Please note that the first subtitle appears as late as 0:49:56.410. ( 49 minutes, 56 seconds and 410 miliseconds!)
Old 18th June 2010, 02:25   #104  |  Link
asarian
Thanks, sneaker! I had assumed the subs would be there for every line (to be switched on or off by forcedOnly); so yeah, that could account for something. :P
Soon as the current job is done, I'll try again.
Old 21st June 2010, 15:11   #105  |  Link
asarian
Now that I've finished a series of other encodes, and got BDSup2Sub, I see indeed the sup file itself is borked: the conversation for the entire movie starts ~50mins too late! No wonder I couldn't find anything! I wonder whether's a way to shift back those times?
Old 21st June 2010, 15:23   #106  |  Link
sneaker_ger
On opening the file in BDSup2Sub you can set a negative delay in the "Converion Options" dialogue.
Old 22nd June 2010, 01:50   #107  |  Link
Zachs
Suptitle, MediaPlayer.NET
asarian, I can't reproduce the "Evaluate: Unrecognized Exception" error using either of your sups.
Your Japanese sub shows up with a proper exception complaining that it doesn't recognize the format:
"System.Exception: Not expecting more than one bitmap per descriptor!"
followed by stacktrace.
I'll take a look into this new format but I still can't get it to fail the same way.
Old 22nd June 2010, 03:53   #108  |  Link
Zachs
SupTitle v2.0.2 is now available. It should fix the problem with your jap sub - there's a sub frame in there that requires fade-out which SupTitle still doesn't support, but at least will render as static frame.
Old 22nd June 2010, 07:53   #109  |  Link
asarian
How strange indeed.
Last night I realized the only thing slightly 'older' on my install is a previous version of FFMS2 (for FFVideoSource); seems the latest version actually doesn't need ffdshow and/or haali splitter any more. Anyway, I can't see how that would affect anything, but I'll upgrade it regardless (after current job finishes, of course).
I really appreciate your program and your continual efforts, Zach. :) I'll try it out, later today. Thanks!
Old 22nd June 2010, 09:09   #110  |  Link
Zachs
I tried it with this script:
LoadPlugin("SupTitle.dll")
clip = blankclip(300000, 1920, 1080, "YV12", 24000, 1001, color=$442211)
clip.SupTitle("H:\00004 - 11 - Subtitle (PGS).sup", forcedOnly=false, swapCbCr=false, relocate=true, relocOffset="0, 0, 0, 0")
And v2.0.1 dumped out a very useful exception stacktrace.
Old 23rd June 2010, 13:58   #111  |  Link
asarian
@asarian: You can accomplish what you want by loading your SUP file in BDsup2sub, and select "EDIT/Move all captions". Then select "Move outside bounds" and set "Offset Y:" to bottom offset of your choice.
You'll get a new SUP file, which you can then use with SupTitle plugin.
Hmm, sadly this doesn't work. :( I tried it with the SUP for Wall-E, and the RESULT ís a no-show with SupTitle.
Old 4th October 2010, 19:49   #112  |  Link
asarian
Any change we can see a 64-bit version of this awesome plugin? Then I could move my entire scripts with MCTemporalDenoise to 64-bit (as I often need to build in the existing Blu-Ray subs).
Old 2nd December 2010, 12:49   #113  |  Link
Zachs
Yeah. x64 build is here - http://www.zachsaw.co.cc/?pg=suptitl...visynth_plugin
Old 29th December 2010, 01:06   #114  |  Link
greyshadow
Hi Zachs, I use megui gui 0.3.5.0 as I am not a script person, I encode from BR 1080p to 720p x264/AAC, then in mkvmerge add AC3 and soft .srt subtiles, is there a version of your script/plugin I could use with the gui to hardcode foreign .srt or .sup files which I extract with tsmuxer/supRip, I have win 7 (86x)
greyshadow is offline   Reply With Quote
Old 3rd January 2011, 06:01   #115  |  Link
Zavs
manually add the required info into the script created by megui's AVS Script Creator
Here is an example of the required info (from zachsaw's website)...
LoadPlugin("path_to_where_the_suptitle_dll_is.dll")
DirectShowSource("path_to_your_movie")
SupTitle("path_to_your_subtitle.sup", forcedOnly=false, swapCbCr=false, relocate=true, relocOffset="0,140,0,140")
forcedOnly=false/true, (true if you only want forced subs included)
swapCbCr=false/true, (not really sure on the use of this one...maybe someone can comment)
relocate=true/false, (do you need to move the subtitles? are you cropping?)
relocOffset="0,140,0,140" (where you want to move the subtitles to)
Hopefully this is what you were asking for...
Zavs is offline   Reply With Quote
Old 3rd January 2011, 21:57   #116  |  Link
greyshadow
Thanks, will give it a try tonight and report back
Old 12th April 2011, 07:57   #117  |  Link
Donholio
MeGUI Developers Hate Me
Donholio's Avatar
Unfortunately, the website hosting Suptitle is now offline. Does anyone have a copy of the script they can share?
Intel i7-9700k in an Asus Z390i
16GB Corsair memory | 1TB nvme
Nvidia Geforce RTX2070
Windows 10 Ultimate 64bit
Donholio is offline   Reply With Quote
Old 12th April 2011, 10:37   #118  |  Link
sneaker_ger
http://rapidshare.com/files/45704484...v2.0.2_x86.zip
http://rapidshare.com/files/45704486...v2.0.2_x64.zip
/edit:
Outdated. See start post again.
Old 12th April 2011, 18:23   #119  |  Link
Donholio
Donholio's Avatar
Thanks Sneaker_Ger
Old 11th April 2012, 21:54   #120  |  Link
Selur
Selur's Avatar
You'll need Microsoft .NET Framework 4 installed.
just wondering can't SubTitle be build statically to avoid the dependencies to .NET ?
avisynth, hard sub, plugin, subtitle, suptitle
