8th June 2015, 16:30 | #13561 | Link |
Well I can prepare special version for you where you can force smaller chunks in 2-pass mode. Your method could be very risky because one chunk could be smaller than 1 min. This would be a disaster for quality.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 8th June 2015 at 16:34. |
9th June 2015, 18:52 | #13563 | Link |
9th June 2015, 19:37 | #13565 | Link | |
Server1 Allow Shut Down=true Server2 Allow Shut Down=false Server3 Allow Shut Down=true If yes then no. I thought that people want to save energy therefore encodingclient shutdowns all nodes.
9th June 2015, 21:45 | #13567 | Link | |
10th June 2015, 01:52 | #13568 | Link | |
Thanks Atak, keep up the excellent work, and keeping us "happy" |
10th June 2015, 07:17 | #13569 | Link |
None of my PC's are ever shut down, but they are always put to sleep, so the option to specify Sleep or Shut down would be great.
Something like. Server1 = Sleep Server2 = Sleep Server3 = StayOn (or whatever makes more sense) Server4 = Shutdown |
10th June 2015, 16:07 | #13570 | Link | |
http://www.mediafire.com/download/06...wn_Patch_v2.7z
11th June 2015, 20:10 | #13572 | Link | |
http://www.mediafire.com/download/av...other_Patch.7z This has been added in EncodingClient.ini Code:
//in seconds. 0=one chunk per node with equal number of frames to process. May be useful if servers have similar processing speed. ChunkSizeFor2passMode=600
12th June 2015, 09:19 | #13575 | Link | |
the source is a mov file 1920x1280 made by an iPhone 5. file info: http://pastebin.com/1N7EzxC2 |
12th June 2015, 11:11 | #13576 | Link | |
\IMG_0001.MOV",audio=false,fps=29.97,convertfps=true).ConvertToYV12()
13th June 2015, 00:43 | #13578 | Link |
Okay, I have a weird issue.
I use Distributed Encoding across four (4) PC. When I try version 1.18.2 for re-encoding my blu rays to MKV, I am getting a strange issue on Pass 2. Pass 1 works well not problem, nice and fast. When I get to Pass 2, three or four servers drop to 1.2 - 2.0 fps and hangs there. If I cancel that slow server and activate another one it raises back to 10 fps and higher. I have tried this on three separate movies with the same result. I went back to version 1.18.1 and all works perfectly. FPS hangs around 12 and higher. Is anyone having this issue and if so how can I fix this... The .ini files are the same as far as options. Thank you in advance... |
13th June 2015, 10:57 | #13579 | Link |
for testing purposes disable firewalls on every pc.
14th June 2015, 19:01 | #13580 | Link |
Glitches/Pixellation Question
Have been using ripbot successfully for quite a while now, but recently I have been having an issue where there are brief glitches/pixelation across the screen in practically every encode. It normally happens only about once per 1 - 2 hour encode and is seemingly in a random place during the result. I've checked back at the preview afterwards, and sometimes there is a glitch in exactly the same place, (but also sometimes not) and on checking the source material there is no glitch at all on that.
I've been using 4.1 slower film 2 pass profile the whole time since before the problem began, reinstalled windows, fresh installs of all required software etc, and it is still happening. There have been no changes to hardware or anything like that. Also is there any way to scan a final encode to detect isssues like these? As it's impractical to have to sit through the file in real time with eyes glued to the screen to detect a random glitch. Thank you for any help or advice! |
