Old 30th September 2014, 09:09   #661  |  Link
madshi
Looks like a little bug in XySubFilter, but it's not dramatic, IMHO. Why double checking the type if the parameter is already hard coded to ISubRenderFrame? Yeah, sure, doesn't hurt to double check, I guess. But if XySubFilter sent in something other than ISubRenderFrame, incorrectly type-converted to ISubRenderFrame, that would be a dramatic bug, IMHO. FWIW, madVR doesn't check the parameter type, IIRC, and it works just fine.
In any case, fixing this in XySubFilter should be a 2 minute job, it should definitely be done.
Old 30th September 2014, 09:17   #662  |  Link
Zachs
Suptitle, MediaPlayer.NET
This is critical if it is to be used in. NET. You can't cast it to the right type otherwise.
Old 30th September 2014, 10:15   #663  |  Link
madshi
Why would you need to cast it *at all*? The DeliverFrame() method should already provide the interface in the right type. So a cast should not be necessary.
Anyway, as I said, it should be easy to fix. Unfortunately the XySubFilter developer is currently not active. If you need this fix urgently, you may have to implement the fix yourself...
Old 30th September 2014, 10:30   #664  |  Link
Zachs
You don't have to cast it. .NET Framework does it internally when the callback occurs. In which case invalid cast exception will be thrown (i.e. cast in .NET on com objects is actually a QI. Marshaling also checks for the correct type before allowing the type to be what the declaration claims it to be).
Edit: not complaining. Just informing. Took me an hour to figure out it's xysubfilter missing a QI export but a minute to fix it.
Old 30th September 2014, 11:23   #665  |  Link
madshi
Ah, I see, thanks. I've zero experience with .NET.
Old 30th September 2014, 11:32   #666  |  Link
Zachs
You should try c# someday. It was created by the same guy who created turbo pascal and Delphi. Anders Hejlsberg. He simply took Delphi to the next level.
Old 30th September 2014, 12:05   #667  |  Link
madshi
I like Delphi a lot. But I dislike the whole .NET concept. I much prefer native compiling/linking over JIT compilation. That's just my personal opinion, of course. And slightly OT here...
Old 30th September 2014, 17:08   #668  |  Link
cyberbeing
Broadband Junkie
Looking through the code, I can only assume this was overlooked because the dev wrapped ISubRenderFrame within XySubRenderIntf.h as IXySubRenderFrame (ISubRenderFrame is never used directly anywhere in the code) and it seems he did remember to include IXySubRenderFrame in NonDelegatingQueryInterface.
So is this just a simple fix of adding a single line for ISubRenderFrame to xy_sub_filter.h & xy_sub_filter.cpp or is there more to it than that? As madshi mentioned the developer isn't really active right now, but I could certainly commit trivial changes or merge pull requests myself from github and release a new hotfix build if necessary.
Old 30th September 2014, 23:26   #669  |  Link
Zachs
Yeah its a single line fix. HotFix would be great! Thanks!
Old 1st October 2014, 13:29   #670  |  Link
SecurityBunny
I would also appreciate a hotfix.
Been noticing quite a few subtitle changes in MPC-HC the last couple of weeks. Hopefully XySubFilter is still faster and preferred for quality. Hoping development kicks back up again sometime soon.
SecurityBunny is offline   Reply With Quote
Old 1st October 2014, 19:37   #671  |  Link
cyberbeing
Broadband Junkie
I was only thinking of merging our outstanding pull requests along with the change Zachs requested. I haven't noticed any critically important bugfix in the recent MPC-HC commits, but if I've overlooked something which can be reproduced in XySubFilter, please point out the related MPC-HC commit and I'll look into it.
The XySubFilter developer remains inactive, so development starting back up soon seems very unlikely.
Old 29th October 2014, 02:15   #672  |  Link
ahaha2013
This shared file.
http://pan.baidu.com/s/1c0b9tfi
neither xyvsfilter nor xysubfilter can dispay correctly.
mpc-hc built-in: http://i2.tietuku.com/7f9932a98be51711.png
can you fix it...
ahaha2013 is offline   Reply With Quote
Old 29th October 2014, 05:41   #673  |  Link
cyberbeing
Broadband Junkie
Originally Posted by ahaha2013 View Post
This shared file.
can you fix it...
I'm not seeing an issue with XySubFilter, at least on our end. Correct 1920x1080 PGS bitmaps are being sent to the subtitle consumer, and are displayed with EVR-CP & madVR. Though both are resizing the bitmap vertically to 1920x800 to match the video resolution, which messes up the aspect ratio and positioning. You'd need to file a bug report with madVR & MPC-HC about that.
With xy-VSFilter, the video needs to be 1920x1080 for Blu-ray PGS subtitles to display. A workaround for cropped video like that one, is to set Vertical Padding to Extend to 16:9.
Old 30th October 2014, 01:15   #674  |  Link
kasper93
MPC-HC Developer
Fixed. Will be in next nightly.
kasper93 is offline   Reply With Quote
Old 30th October 2014, 13:28   #675  |  Link
ahaha2013
thks.
Old 30th October 2014, 13:29   #676  |  Link
ahaha2013
thks
Old 11th November 2014, 08:13   #677  |  Link
salam2009
Why does xySubFilter get replaced by DirectVobSub when MadVR is disabled?
salam2009 is offline   Reply With Quote
Old 11th November 2014, 09:35   #678  |  Link
cyberbeing
Broadband Junkie
xySubFilter requires a subtitle consumer to function.
madVR, EVR-CP (MPC-HC), and VMR9 Renderless (MPC-HC) are currently the only consumers available.
Old 11th November 2014, 10:30   #679  |  Link
andyvt
+ EVR-CP in MediaBrowser Theater
babgvant.com
Missing Remote
andyvt is offline   Reply With Quote
Old 11th November 2014, 20:43   #680  |  Link
salam2009
I know! I'm using EVR-CP and that's the weird thing!
