Old 9th July 2019, 17:13   #121  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
I'd really appreciate it if someone could take the time to manually update the https://github.com/HomeOfVapourSynth...h-Waifu2x-w2xc packages since it's a complicated one.
The best strategy is probably to keep both w2xc.json and w2xc_models.json and simply make them both point to the same file.
Old 9th July 2019, 18:33   #122  |  Link
ChaosKing
done, see PR.
Old 9th July 2019, 18:53   #123  |  Link
Myrsloik
Myrsloik's Avatar
Originally Posted by ChaosKing View Post
done, see PR.
Nice. I guess the other small tasks I've got lying around would be to go through this rejected pull request and do things correctly. After that we're up to date again.
https://github.com/vapoursynth/vsrepo/pull/98
Old 12th July 2019, 00:51   #124  |  Link
MeteorRain
結城有紀
https://github.com/HomeOfVapourSynth...urSynth-DeLogo
is deprecated in favor of
https://github.com/HomeOfAviSynthPlusEvolution/DelogoHD
DelogoHD supports both AviSynth+ and VapourSynth interfaces, and has SIMD optimizations and native HBD support from YUV420P8 up to YUV444P16.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 12th July 2019, 08:20   #125  |  Link
ChaosKing
PR is ready. Should vsrepo show a warning if a package is deprecated? I mean should we add a new field like "deprecated": "deleogohd" to vsrepo. Would then show "Delogo is deprecated, better install/use DelogoHD". But it won't happen very often...
Old 12th July 2019, 12:45   #126  |  Link
Myrsloik
Myrsloik's Avatar
I'll add some kind of deprecation warning then now that we actually have something to deprecate...
Old 17th August 2019, 11:37   #127  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Muvsfunc fetched by VSRepo is a very old version. Is there any way to make VSRepo use the one from github?
Old 17th August 2019, 21:46   #128  |  Link
Myrsloik
Myrsloik's Avatar
Just tell the maintainer to make an actual github release and it'll be picked up automatically.
Old 26th August 2019, 00:39   #129  |  Link
lansing
There is a more up to date descale plugin from one of its fork
https://github.com/BluBb-mADe/vapour...scale/releases
Old 30th August 2019, 10:22   #130  |  Link
Myrsloik
Myrsloik's Avatar
The original author is still around so it has to be renamed or I won't include it.
Old 30th August 2019, 10:23   #131  |  Link
Myrsloik
Myrsloik's Avatar
We're missing l-smash source I think. No surprise considering how elusive the binaries and releases are but lots of people use it so it'd be nice to have.
Old 30th August 2019, 10:29   #132  |  Link
ChaosKing
The only github repo with "vsrepo auto update compatibility" is this one https://github.com/HomeOfAviSynthPlu.../L-SMASH-Works
I could make a PR, a package exists already https://github.com/theChaosCoder/avs...al/lsmash.json
p.s. yes, the binary supports both avs and vs
Old 30th August 2019, 10:30   #133  |  Link
Myrsloik
Myrsloik's Avatar
That'd be nice. It's not ancient either so better than nothing.
Old 30th August 2019, 10:40   #134  |  Link
ChaosKing
Arghh it was a different one. This one only supports avisynth
Old 2nd September 2019, 19:50   #135  |  Link
ChaosKing
I made a handy script to quickly check for new dependencies in VS-scripts. Maybe it can also be added to vsrupdate.
It downloads the latest script und searches for all known namespaces.
EDIT: maybe it would be also a good idea to track removed plugins (namespaces)?
PHP Code:
print('Checking dependencies')
with open('vspackages.json''r'encoding='utf-8') as vsp:
packages json.load(vsp)['packages'
    for
plugin in packages:
        if (
plugin['type'] == 'PyScript'):
os.system("vsrepo.py -p -d install " plugin.get('modulename'))
            print(
"\nDependencies for: "plugin.get('modulename'))
            print(
filename = list(plugin['releases'][0]['script']['files'].keys())[0]
with open(filename'r'encoding='utf-8') as module:
current_script module.read()
deps = []
deps_new = []
                for
p in packages:
                    if (
p['type'] == 'VSPlugin'):
search "." p['namespace'] + "." # search for core .dfttest. DFTest() and clip .dfttest. DFTest(). Seems to be reliable enough...
if search in current_script:
deps.append(p['identifier'])
                            if
not p['identifier'in plugin['dependencies']:
deps_new.append(p['identifier'])
                            print(
p['identifier'])
                print(
"NEW: "deps_new
Old 2nd September 2019, 20:36   #136  |  Link
Myrsloik
Myrsloik's Avatar
What do you even mean by "track removed plugins"? Either they're there or not...
Old 2nd September 2019, 20:54   #137  |  Link
ChaosKing
If a script gets updated and does not use plugin xy anymore. There is no need to keep it as a dependency then? (it won't happen very often)
Old 2nd September 2019, 21:46   #138  |  Link
Myrsloik
Myrsloik's Avatar
That's so rare doing it manually is fine. Just like adding additional dependencies manually generally is fine too since they're rarely added.
Since VSRepo uses unique strategies (keeps no state and tries to figure out the mess you've got) there's only so much you can with regards to tracking these no longer required plugins for removal.
Old 21st October 2019, 18:59   #139  |  Link
Myrsloik
Myrsloik's Avatar
Package requests:
https://github.com/Irrational-Encodi...th-RemapFrames
and f3kdb
Old 21st October 2019, 19:37   #140  |  Link
ChaosKing
Pushed remapframes.
There is no f3kdb repo with releases. But we have neo_f3kdb which is basically f3kdb + two more modes
