Old 16th November 2013, 22:19   #18341  |  Link
colinhunt
I had a 3TB hard drive go bad this morning.
Let me guess: Seagate?
Old 16th November 2013, 22:37   #18342  |  Link
AmigaFuture
AmigaFuture's Avatar
No such luck. I had a 3TB hard drive go bad this morning. It had a huge number of various sources on it used for testing. I don't want to have to try and create all those again. I'm in the middle of trying to recover it.
This is why a clone backup is a good idea. I've been there, it's sometimes very challenging when a drive's circuit board is failing. I hope that's it and not platters. Replace that, which I'm sure you know, and usually good to go. Anyway, BEST wishes.
Using the BD-9 output option, since the iPad 2 files are functioning well, I thought I'd try Die Hard 4 again. Which, I see more files accessible...so trying a hunch/test..
Old 16th November 2013, 22:53   #18343  |  Link
No, Western Digital. I've had the same experience, though, with Seagate, in fact I had my last one go bad about a month ago -- that's one of the reasons I try to stay with WD. But, even the best laid plans of mice and men...
Old 16th November 2013, 23:18   #18344  |  Link
HWK
HWK's Avatar
Ouch, it must be painful to loose countless number of hours work. Well I wish you luck in salvage process.
Also have you thought of using raid 10 or similar for critical files.
Old 17th November 2013, 00:41   #18345  |  Link
mparade
You can set those manually, but it's a bit of a pain. But it really needs to be done for BD-RB to run correctly. If you have admin privileges, all you have to do is right click on the BD-RB executable and select "Run as Administrator".
I see. The problem can be described as follows (sorry but in hungarian English): I set up each of the decoding packages required for the BD-RB to function according to your "manual". Then right-clicked on the icon and run as administrator. Then I accepted so that BD-RB can do modifications on my computer. After that, BD-RB asked me if it can make some changes to the Directshow registry. Clicked "Yes". And then virtually nothing happened with BD-RB, even not opened. (But actually they are opened after each attempt and started to "eat" my CPU's capacity, according to my task manager the CPU usage was on constant 100%, as if I was encoding with each). If now, I try to open it without admin privileges it again asks if it can make some changes to the Directshow registry. If I click on "Yes", it says that sorry, but you do not have administrative privileges, and exit. Then the "story" is the same for each attempt to open BD-RB again. I do could work with your program recently because after starting it as an administrator I told the program to not make any changes to the Directshow registry. (It has been working until I tried to encode the "Lord of the Rings BD disk with VC-1 content".
I know it is not a bug related problem but if anyone have already been in such an issue, please help. Thanks for any help in advance.
Old 17th November 2013, 00:49   #18346  |  Link
AmigaFuture
@ mparade
Hi. Are you able to create a new user Administrator account with that computer? If so, do that..and try running BD-RB from it.
Old 17th November 2013, 01:13   #18347  |  Link
@jdobbs
Thanks for the update.
Some issues which I found with v0.45.04, Quick-Play backup to BD9:
- The CERTIFICATE folder is still missing. (I did NOT select Strict AVCHD).
- The menu background video has been replaced by the static stars picture. I have the "Attempt to find original Background" selected. The former version included the video. Did you replace the video by the static picture because of the too high bitrate of the original Video for BD9? If so, any plans to compress the video in future?
- It seems that the menu still got messed up in my case. I did NO threshold changes.
My configuration: (titles.inf of the source; looks correct to me))
[Titles]
Title=BREAKING BAD Season 5 Disk 1
Threshold=21600000
00090=Extra 1 [00:12:38.799]
00092=Extra 3 [00:11:00.701]
00099=Extra 2 [00:10:37.036]
00121=LEBE FREI ODER STIRB
00122=MADRIGAL
00123=GEFAHRENZULAGE
00124=51
[Position]
00090=5
00092=0
00099=6
00121=1
00122=2
00123=3
00124=4
[Selected]
00090=-1
00092=0
00099=-1
00121=-1
00122=-1
00123=-1
00124=-1
What I got after encoding: (titles.inf of the target; looks incorrect to me)
[Titles]
00000=Extra 3 [00:11:00.701]
00001=LEBE FREI ODER STIRB
00002=MADRIGAL
00003=GEFAHRENZULAGE
00005=Extra 1 [00:12:38.799]
00006=Extra 2 [00:10:37.036]
- Episode 4 (item 00124 with name 51) is missing in the titles.inf on the target, but the corresponding .m2ts file for Episode 4 does exist on the target.
- Extra 3 (which I unselected) is put in first position and still exists as encoded .m2ts file on the target i.e. it was not removed for authoring.
It's just what I see from the titles.inf. As it looks wrong to me I didn't burn the disc ...... (wrong conclusion?)
Added:
And when I now open the encoded BD9 in DB-RB and start the Quick Play Menu Editor, I am getting again something different, and right clicking / Preview This Item even plays the wrong files ....
Well, that's the result of another one of those "this won't hurt anything" last minute changes before release. You think I'd learn. I've fixed it. The CERTIFICATE thing was fixed as well (there was two changes that needed to be made -- I'd only changed one).
Old 17th November 2013, 01:59   #18348  |  Link
HWK
HWK's Avatar
Which antivirus you are using, I recently had case where program was being blocked by AV and all I had to do was turn of AV shield and BD-RB was able to make change.
I hate it when AV suppose to protect computer, instead the make user life miserable.
Old 17th November 2013, 02:19   #18349  |  Link
Amen to that. I've never had much of a problem from viruses... but I've had lots of issues caused by antivirus software. I have to disable it whenever I'm doing anything productive locally (like backups) because it slows the system down so terribly.
Old 17th November 2013, 02:42   #18350  |  Link
HWK
HWK's Avatar
Sometime I do wonder if every time there is problem and it is caused by AV, how many lawsuit will be for manufacturer.
To make matter worse some AV companies even don't allow expert mode or similar apparently because in their opinion end user is dumb.
I understand their point of view but at least include with warning, rather than completely taking it of the program
Old 17th November 2013, 03:16   #18351  |  Link
AmigaFuture
The need for an Anti-Virus, flu shots, "Soul" servicing, and much more is based on fear...mostly. I have most Avast Shields off unless I deem needed. My systems are quick that way. I'm not into trading security for freedom and awareness.
Pptthh.... Update: I tried the BD-9 output with reencoding and FORCE_NOENCODE=1 but BD-RB (or tsMuxeR still) damages an extra I want to keep from Die Hard 4. Oh well....for now, I have to BD-50 backup or my original when little people are visiting. It's really cool having the Quick-Play and choice of sequential or not. Thanks a LOT for that! Like a small person playing in Toys'R'Us.
Old 17th November 2013, 08:20   #18352  |  Link
Sharc
@mparade
Maybe it has already been said but don't install BD-RB into the standard programs folder. Just put it somewhere else.
Old 17th November 2013, 11:08   #18353  |  Link
rendez2k
rendez2k's Avatar
jdobbs, did you see my post yesterday about the menus not working on my Sony player (fine on PowerDVD)? Heres the log:
[11/16/13] BD Rebuilder v0.45.04 (beta)
[07:17:33] Source:  PACIFIC.RIM.2013
  - Input BD size: 41.77 GB
  - Approximate total content: [03:19:23.284]
  - Target BD size: 22.95 GB
  - Windows Version: 6.2 [9200]
  - Quick-Play Reauthoring mode enabled
  - Resize SD to HD 720p enabled
[07:17:33] PHASE ONE, Encoding
 - [07:17:33] Processing: VID_00002 (1 of 15)
 - [07:17:33] Extracting A/V streams [VID_00002]
 - [07:17:43] Reencoding video [VID_00002]
   - Rate/Length: 23.976fps, 6,889 frames
   - Bitrate: 7,227 Kbs
 - [07:17:43] Reencoding: VID_00002, Pass 1 of 1
 - [07:19:39] Video Encode complete
 - [07:19:39] Processing audio tracks
 - [07:19:39] Multiplexing M2TS
 - [07:19:46] Processing: VID_00011 (2 of 15)
 - [07:19:46] Extracting A/V streams [VID_00011]
 - [07:26:34] Reencoding video [VID_00011]
   - Rate/Length: 23.976fps, 188,857 frames
   - Bitrate: 17,756 Kbs
 - [07:26:34] Reencoding: VID_00011, Pass 1 of 1
 - [08:28:36] Video Encode complete
 - [08:28:36] Processing audio tracks
 - [08:28:36] Multiplexing M2TS
 - [08:38:28] Processing: VID_00013 (3 of 15)
 - [08:38:28] Extracting A/V streams [VID_00013]
 - [08:38:39] Reencoding video [VID_00013]
   - Rate/Length: 23.976fps, 7,029 frames
   - Bitrate: 7,299 Kbs
 - [08:38:39] Reencoding: VID_00013, Pass 1 of 1
 - [08:40:29] Video Encode complete
 - [08:40:29] Processing audio tracks
 - [08:40:29] Multiplexing M2TS
 - [08:40:36] Processing: VID_00014 (4 of 15)
 - [08:40:36] Extracting A/V streams [VID_00014]
 - [08:40:47] Reencoding video [VID_00014]
   - Rate/Length: 23.976fps, 6,491 frames
   - Bitrate: 7,693 Kbs
 - [08:40:47] Reencoding: VID_00014, Pass 1 of 1
 - [08:42:33] Video Encode complete
 - [08:42:33] Processing audio tracks
 - [08:42:33] Multiplexing M2TS
 - [08:42:40] Processing: VID_00015 (5 of 15)
 - [08:42:40] Extracting A/V streams [VID_00015]
 - [08:42:52] Reencoding video [VID_00015]
   - Rate/Length: 23.976fps, 8,281 frames
   - Bitrate: 7,220 Kbs
 - [08:42:52] Reencoding: VID_00015, Pass 1 of 1
 - [08:45:03] Video Encode complete
 - [08:45:03] Processing audio tracks
 - [08:45:03] Multiplexing M2TS
 - [08:45:11] Processing: VID_00016 (6 of 15)
 - [08:45:11] Extracting A/V streams [VID_00016]
 - [08:45:22] Reencoding video [VID_00016]
   - Rate/Length: 23.976fps, 8,150 frames
   - Bitrate: 7,269 Kbs
 - [08:45:22] Reencoding: VID_00016, Pass 1 of 1
 - [08:47:30] Video Encode complete
 - [08:47:30] Processing audio tracks
 - [08:47:30] Multiplexing M2TS
 - [08:47:38] Processing: VID_00017 (7 of 15)
 - [08:47:38] Extracting A/V streams [VID_00017]
 - [08:47:48] Reencoding video [VID_00017]
   - Rate/Length: 23.976fps, 5,785 frames
   - Bitrate: 7,246 Kbs
 - [08:47:48] Reencoding: VID_00017, Pass 1 of 1
 - [08:49:18] Video Encode complete
 - [08:49:18] Processing audio tracks
 - [08:49:18] Multiplexing M2TS
 - [08:49:26] Processing: VID_00018 (8 of 15)
 - [08:49:26] Extracting A/V streams [VID_00018]
 - [08:49:36] Reencoding video [VID_00018]
   - Rate/Length: 23.976fps, 6,625 frames
   - Bitrate: 7,278 Kbs
 - [08:49:36] Reencoding: VID_00018, Pass 1 of 1
 - [08:51:18] Video Encode complete
 - [08:51:18] Processing audio tracks
 - [08:51:18] Multiplexing M2TS
 - [08:51:24] Processing: VID_00020 (9 of 15)
 - [08:51:24] Extracting A/V streams [VID_00020]
 - [08:51:34] Reencoding video [VID_00020]
   - Rate/Length: 23.976fps, 5,977 frames
   - Bitrate: 7,150 Kbs
 - [08:51:34] Reencoding: VID_00020, Pass 1 of 1
 - [08:53:02] Video Encode complete
 - [08:53:02] Processing audio tracks
 - [08:53:02] Multiplexing M2TS
 - [08:53:09] Processing: VID_00026 (10 of 15)
 - [08:53:09] Extracting A/V streams [VID_00026]
 - [08:53:19] Reencoding video [VID_00026]
   - Rate/Length: 23.976fps, 6,697 frames
   - Bitrate: 7,247 Kbs
 - [08:53:19] Reencoding: VID_00026, Pass 1 of 1
 - [08:55:03] Video Encode complete
 - [08:55:03] Processing audio tracks
 - [08:55:03] Multiplexing M2TS
 - [08:55:10] Processing: VID_00027 (11 of 15)
 - [08:55:10] Extracting A/V streams [VID_00027]
 - [08:55:26] Reencoding video [VID_00027]
   - Rate/Length: 23.976fps, 12,817 frames
   - Bitrate: 7,260 Kbs
 - [08:55:26] Reencoding: VID_00027, Pass 1 of 1
 - [08:58:47] Video Encode complete
 - [08:58:47] Processing audio tracks
 - [08:58:47] Multiplexing M2TS
 - [08:58:58] Processing: VID_00028 (12 of 15)
 - [08:58:58] Extracting A/V streams [VID_00028]
 - [08:59:06] Reencoding video [VID_00028]
   - Rate/Length: 23.976fps, 4,489 frames
   - Bitrate: 7,222 Kbs
 - [08:59:06] Reencoding: VID_00028, Pass 1 of 1
 - [09:00:20] Video Encode complete
 - [09:00:20] Processing audio tracks
 - [09:00:20] Multiplexing M2TS
 - [09:00:25] Processing: VID_00029 (13 of 15)
 - [09:00:25] Extracting A/V streams [VID_00029]
 - [09:00:34] Reencoding video [VID_00029]
   - Rate/Length: 23.976fps, 4,729 frames
   - Bitrate: 7,212 Kbs
 - [09:00:34] Reencoding: VID_00029, Pass 1 of 1
 - [09:01:52] Video Encode complete
 - [09:01:52] Processing audio tracks
 - [09:01:52] Multiplexing M2TS
 - [09:01:58] Processing: VID_00030 (14 of 15)
 - [09:01:58] Extracting A/V streams [VID_00030]
 - [09:02:08] Reencoding video [VID_00030]
   - Rate/Length: 23.976fps, 5,857 frames
   - Bitrate: 7,228 Kbs
 - [09:02:08] Reencoding: VID_00030, Pass 1 of 1
 - [09:03:42] Video Encode complete
 - [09:03:42] Processing audio tracks
 - [09:03:42] Multiplexing M2TS
 - [09:03:48] Processing: VID_00041 (15 of 15)
 - [09:03:48] Extracting A/V streams [VID_00041]
 - [09:03:55] Reencoding video [VID_00041]
   - Rate/Length: 23.976fps, 8,159 frames
   - Bitrate: 2,140 Kbs
 - [09:03:55] Reencoding: VID_00041, Pass 1 of 1
 - [09:04:54] Video Encode complete
 - [09:04:54] Processing audio tracks
 - [09:04:54] Multiplexing M2TS
[09:04:59]PHASE ONE complete
[09:04:59]PHASE TWO - Rebuild Started
 - [09:04:59] Rebuilding BD file Structure
 - [09:04:59] Creating Quick-Play Menu...
   - Encoding menu background...
   - Building menu structure...
[09:05:05] - Encode and Rebuild complete
[09:05:05] Writing BD structure to ISO file
 - ImgBurn completed successfully
[09:15:34] JOB: PACIFIC.RIM.2013 finished.
rendez2k is offline   Reply With Quote
Old 17th November 2013, 12:50   #18354  |  Link
Yes, I saw it. I'm not sure what I can do about it, but I saw it. I can go back to the spec and see if I find anything new -- but I've already gone over it very diligently. Have you tried more than one disc? Is it possible something went wrong in the burn?
I'll pick up "Pacific Rim" and give it a test -- but I don't expect to find anything. Can you post your settings so I can do an apples-to-apples test?
Old 17th November 2013, 13:04   #18355  |  Link
rendez2k
rendez2k's Avatar
Thanks. Testing a second disc later today. I think the burn is OK as it worked in Cyberlink. Tested the same disc in the latest version and the previous version.
I think somebody further back had a similar issue?
Old 17th November 2013, 13:12   #18356  |  Link
I don't think I remember any issues reported with standalone players other than yours. What is the default language on your player?
Old 17th November 2013, 13:13   #18357  |  Link
rendez2k
rendez2k's Avatar
I was thinking of this but might not be the same:
http://forum.doom9.org/showpost.php?p=1653456&postcount=18307
Old 17th November 2013, 13:28   #18358  |  Link
gonca
I have Pacific Rim sitting on the PC still. If you want I can use rendez2ks INI and test it.
Old 17th November 2013, 13:30   #18359  |  Link
Whenever I hear "my player" rather than a brand/model or the word "standalone" I assume it is something other than a standalone. For example, a playstation isn't a BD player. It is a game machine.
Old 17th November 2013, 14:01   #18360  |  Link
Thanks. But I need to pick that one up for testing anyway. It wouldn't hurt to have more than one test, though.
