Old 15th January 2022, 06:30   #4621  |  Link
poisondeathray
Originally Posted by lewyturn View Post
How to use "std.SplitPlanes(vnode clip)'", I can't find an example, can anyone give me an example?
e.g for YUV clip, . Y plane would be [0], U plane would be [1], V would be [2] ; similar for RGB (0,1,2)
s = core.std.SplitPlanes(clip)
s[0].set_output() #output Y plane
Old 15th January 2022, 19:42   #4622  |  Link
Jukus
I'm trying to get QTGMC to work on Debian, I installed everything need from http://deb-multimedia.org/dists/stab.../binary-amd64/ and separately the scripts, I get this error:
Failed to evaluate the script:
Python exception: znedi3: error reading weights
File "vapoursynth.pyx", line 2242, in vapoursynth.vpy_evaluateScript
File "vapoursynth.pyx", line 2243, in vapoursynth.vpy_evaluateScript
File "/usr/local/lib/python3.9/dist-packages/havsfunc.py", line 1314, in QTGMC
edi1 = QTGMC_Interpolate(ediInput, InputType, EdiMode, NNSize, NNeurons, EdiQual, EdiMaxD, pscrn, int16_prescreener, int16_predictor, exp, alpha, beta, gamma, nrad, vcheck,
File "/usr/local/lib/python3.9/dist-packages/havsfunc.py", line 1595, in QTGMC_Interpolate
interp = nnedi3(Input, field=field, planes=planes)
File "vapoursynth.pyx", line 2067, in vapoursynth.Function.__call__
vapoursynth.Error: znedi3: error reading weights
What to do?
Jukus is offline   Reply With Quote
Old 15th January 2022, 19:54   #4623  |  Link
poisondeathray
[CODE]Failed to evaluate the script:
does the package include nnedi3_weights.bin ?
https://github.com/dubhater/vapoursy...i3_weights.bin
Old 15th January 2022, 20:02   #4624  |  Link
Jukus
Yes
/usr/share/nnedi3/nnedi3_weights.bin
Old 16th January 2022, 17:59   #4625  |  Link
Jukus
Need to move nnedi3_weights.bin to
/usr/lib/x86_64-linux-gnu/vapoursynth/
Anyway, something is very bad, before that I used everything new on Arch from AUR and the performance was 2 times better
Old 16th January 2022, 20:47   #4626  |  Link
mastrboy
Could someone help explain how trim and slice works in vapoursynth?
I am struggling converting a simple avisynth script where I replace a segment of a clip with some frames from a different clip and are unable to get it to work in vapoursynth.
video_a = core.dgdecodenv.DGSource(f"E:\video_a.dgi")
video_b = core.dgdecodenv.DGSource(f"E:\video_b.dgi")
video_b = video_b[12:2156] # 2156 - 12 = 2144 frames
#Neither of the following works at all in vapoursynth, I can't figure out how to reference "end of clip/last frame" in vapoursynth trim...
video = core.std.Trim(video_a,0,5298) + video_b + core.std.Trim(video_a,7444,-1)
video = core.std.Trim(video_a,0,5298) + video_b + core.std.Trim(video_a,7444,0)
#The following returns a video, but returns fewer frames than expected (7443 - 5299 = 2144 frames):
video = video_a[0:5298] + video_b + video_a[7444:-1]
Original clip has 34311 frames, but using vapoursynth slice the returned clip only has 34308.
So in python/vapoursynth either 1+1 does not equal 2 or I have forgotten how to do simple math...
(i have a tendency to drunk post)
mastrboy is offline   Reply With Quote
Old 16th January 2022, 20:50   #4627  |  Link
ChaosKing
http://www.vapoursynth.com/doc/pytho...yntactic-sugar
clip = clip[5:11] <=> clip = core.std.Trim(clip, first=5, last=10)
Old 16th January 2022, 21:16   #4628  |  Link
mastrboy
Wait... You are telling me that the code for slice subtracts 1 for the second argument? What exactly is the purpose for that?
I would then absolutely prefer to just use Trim rather than remembering that -1 stuff, but does anyone know how to reference the last frame in Trim like slice does with "-1" or avisynth does with trim(10,0)?
Old 16th January 2022, 21:22   #4629  |  Link
ChaosKing
(untested) I think it's just std.Trim(10)
Old 16th January 2022, 21:54   #4630  |  Link
mastrboy
Thanks, that worked, and I feel like an idiot for not testing it without the second argument
It's a lot better than the "solution" I found in my own: core.std.Trim(video,10,video.num_frames - 1)
Old 16th January 2022, 22:11   #4631  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
Hi, folks.
Could somebody help me with vapoursynth?
It's been a while since I left the world of publishing but recently I took up a project that I would like to have ready for when my son is born. The fact is that I wanted to install vapoursynth and what used to work for me now doesn't.
I have checked the script and VSEdit says it is correct. The video is fine because I had to install AVS+ and it loads without any problems.
My system is: Windows 11 x64
Python installed: 3.9.9 and 3.10.1 (use VSC)
Vapoursynth: R57
from vapoursynth import core
import vapoursynth as vs
core = vs.core
#video = core.ffms2.Source(source=r"C:\xxx\Movie.mkv") #,format=vs.YUV420P8)
video = core.lsmas.LWLibavSource(r"C:\xxx\Movie.mkv", format=vs.YUV420P8)
video.set_output()
Problem:
Error forming pixmap from frame. Expected format CompatBGR32. Instead got 'YUV420P8'.
I have also tried VSEdit2 and when previewing the program it closes.
Thanks in advance.
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite
Overdrive80 is offline   Reply With Quote
Old 16th January 2022, 22:27   #4632  |  Link
poisondeathray
Overdrive80 - are you using vsedit mod for API4 and r57 ?
https://github.com/YomikoR/VapourSynth-Editor/releases
Old 17th January 2022, 01:49   #4633  |  Link
Overdrive80
Anime addict
@Poison
Nop, for VSEditor was using https://bitbucket.org/mystery_keeper...tor/downloads/ and for V2 https://bitbucket.org/gundamftw/vapo...r-2/downloads/
Then, do you think that could be for VSeditor??
EDIT: I have tried the version that you post and is the same result, close of application.
Old 17th January 2022, 05:53   #4634  |  Link
_Al_
As soon ,as there is a programming involved, it just works. Indexing is always from zero. So for example you need to slice an interval and you know it starts on 10th frame including and length is 5 frames, so it is:
frame=10
length = 5
clip[frame:frame+length]
If both frames were included you'd need to use clip[frame:frame+length-1]. Imagine more intervals, easily turning it into nightmare as well.
Slicing is still better, as long as you remember this rule, because, you do not need to specify position if slicing from beggining:
clip[:100] #slicing first 100 frames (you see again, you want just first 100 frames, you do this and not confusing: clip[:100-1]
or more importandly, better if slicing from a middle to the end:
clip[10:] # using 10th frame index to the end
so
clip = clip.std.Trim(first=10, last=clip.num_frames-1)
is the same as:
clip = clip[10:]
If using keyword arguments always and not just:
clip = clip.std.Trim(10, clip.num_frames-1)
is better way, because above line is not readable much. Avisynth users do that all the time, using lines like: filter(3,56, -1, 45, 1000, 0) is just a nightmare to read. :-)
Prone to make mistakes.
_Al_ is offline   Reply With Quote
Old 17th January 2022, 13:15   #4635  |  Link
Overdrive80
Anime addict
@poisondeathray
If I trying open script with vdub2 I get this message: "AVI import filter error: (Unknown) (80040154)"
EDIT: Solved. I had uninstall all and I had followed the instructions of https://www.l33tmeatwad.com/vapoursy...software-setup, with sames versions of files (python and vapoursynth). I could investigate what caused the problem, whether VS or Python
Old 27th January 2022, 06:09   #4636  |  Link
~ VEGETA ~
The cult of personality
~ VEGETA ~'s Avatar
when I try running a simple scrip which has hafsfunc in it (and other wrappers) it gives me that there is no module named packaging. I installed python 3.9.7 for all users as well as vapoursynth 57.
plus, vs editor 2 stops working right after i press preview... while vs edit 1 works, but it doesn't show the output..
~ VEGETA ~ is offline   Reply With Quote
Old 28th January 2022, 14:24   #4637  |  Link
Julek
Julek's Avatar
You need LibP2P library for vsedit 2.
Julek is offline   Reply With Quote
Old 28th January 2022, 17:54   #4638  |  Link
Jukus
I built everything new from git, updated proprietary Nvidia drivers from backports and still performance is almost 2 times less on Debian than it was on Arch, it looks magical.
Old 28th January 2022, 21:45   #4639  |  Link
~ VEGETA ~
~ VEGETA ~'s Avatar
it is installed, everything should be fine but still doesn't work.
I read that it doesn't work after vapoursynth 54.
can you verify?
Old 29th January 2022, 16:29   #4640  |  Link
DJATOM
DJATOM's Avatar
Try to load explicitly via core.std.LoadPlugin. That way you will see an error if plugin fails to load.
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
speed, vaporware, vapoursynth
