Old 30th October 2020, 21:17   #1  |  Link
benwaggoner
AV1 hardware decoder implementations
As we're on the verge of lots of devices with hardware AV1 decode, I think it's time for a sticky about this in particular.
As Chrome and Firefox explicitly block HEVC decode even if the OS supports it, PC browsers are where AV1 is going to have the biggest improvement delta. Most other platforms (including Edge and Safari) have HEVC today, where the quality @ perf of HEVC and AV1 are pretty equivalent given relative maturity of encoders. While SW encoders do work, performance is going to be a limitation for 4K and 10-bit (which HDR requires). And the lack of HW DRM provides lots of limitations on premium content availability.
The Intel 11th gen Ice Lake CPUs are the first shipping PC implementation. Here's the best analysis of AV1 decode with Ice Lake I've seen: https://www.pcworld.com/article/3576...yzen-4000.html.
I've not seen a test of DRM on Ice Lake, but I imagine it should work, and if it doesn't, a software bug fix is probably sufficient.
tl;dr works great, and as expected.
Ben Waggoner
My Compression Book
Old 25th November 2020, 00:02   #2  |  Link
benwaggoner
Has anyone tested to see if any of the below support AV1 decode?
PlayStation 5
Xbox Series X|S
Apple M1 processor in the new Mac mini, MacBook Air, and MacBook Pro 13"
Ben Waggoner
My Compression Book
Old 25th November 2020, 10:01   #3  |  Link
hajj_3
some info about apple m1 possibly have a 4k av1 hardware decoder or hybrid decoder: https://forums.macrumors.com/threads...oding.2269938/
Old 28th November 2020, 00:02   #4  |  Link
Yups
Tigerlake not Icelake, big difference.
I have tested a few AV1 youtube videos in Chrome with my Tigerlake laptop and it works really good so far.
Yups is offline   Reply With Quote
Old 28th November 2020, 09:53   #5  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
https://en.wikipedia.org/wiki/AV1#Hardware
Old 3rd December 2020, 01:33   #6  |  Link
benwaggoner
Bad news: it appears that Qualcomm isn't doing HW AV1 in its 2021 chipsets.
https://www.anandtech.com/show/16271...88-deep-dive/3
AV1 decoding didn’t make the cut this year unfortunately, which means wide-spread adoption in mobile for the codec will be delayed for another year.
Ben Waggoner
My Compression Book
Old 18th December 2020, 06:19   #7  |  Link
rubait
Has anyone tried benchmarking the AV1 decoder performance on Tigerlake using DXVA Checker?
rubait is offline   Reply With Quote
Old 18th December 2020, 06:20   #8  |  Link
rubait
Did you try playing back on DXVA checker? It can't seem to recognize the clip.
Old 19th December 2020, 20:40   #9  |  Link
Yups
When I use D3D11 playback in DXVA Checker there are image artifacts on both LAV Decoder as well as Microsoft AV1 extension. DXVA2 runs on both but only with LAV Decoder it appears to use the GPU.
Using MPC Home Cinema playback runs fine using D3D11 AV1 in LAV.
Old 20th January 2021, 02:25   #10  |  Link
Pepsi_Doggo
RTX 3060Ti decoding 4K HDR(10-bit)@60fps above just 2ms render time:
Last edited by Pepsi_Doggo; 20th January 2021 at 13:53. Reason: Space between post and image for easier visibility.
Pepsi_Doggo is offline   Reply With Quote
Old 20th January 2021, 03:22   #11  |  Link
hajj_3
Android tv boxes featuring Amlogic S905X4 chips are now available for as little as £30/$40 delivered from china. These can hardware decode AV1.
Old 20th January 2021, 04:06   #12  |  Link
quietvoid
Originally Posted by hajj_3 View Post
Android tv boxes featuring Amlogic S905X4 chips are now available for as little as £30/$40. These can hardware decode AV1.
Personally waiting on certified devices for streaming with hwdec.. hopefully this year.
Old 20th January 2021, 18:05   #13  |  Link
benwaggoner
Has anyone tried the Xbox Series X|S hybrid decoder yet? It's obviously complex to get working, but I can imagine the next gen game consoles are going to be a big share of the AV1 capable living room devices in 2021.
Ben Waggoner
My Compression Book
Old 20th January 2021, 19:14   #14  |  Link
hajj_3
Are you sure it can hybrid decode AV1?
Old 21st January 2021, 01:17   #15  |  Link
benwaggoner
I am asking because I am not sure. But this sure sounded promising: https://forum.doom9.org/showthread.p...ox#post1929168
Ben Waggoner
My Compression Book
Old 4th February 2021, 09:02   #16  |  Link
soresu
If you look at the system requirements section of the PDF it doesn't actually mention either XSS or XSX.
"Hardware: Xbox One, Xbox One S, or Xbox One X"
The googlesource repo is also labelled " GPU-accelerated AV1 decoder for the Xbox One".
So if someone can integrate this into Kodi or Plex for UWP, and Jaguar is enough to cover entropy decoding there are actually millions of devices in living rooms already.
I wouldn't expect MS to be any help on that score for obvious profit based reasons of pushing people to XSS and XSX.
Hopefully if it does get ported to the new console gen they use as much dav1d AVX2 asm as possible for the entropy decoding stage, I've no idea how much SSSE3 asm is in the current implementation to use on the Jaguar cores.
soresu is offline   Reply With Quote
Old 4th February 2021, 20:28   #17  |  Link
benwaggoner
Entropy decoding isn't that complex, and well suited to fast single cores, and IIRC AV1's mandatory slices for high resolutions allow for parallelized entropy decode. This is a huge improvement from VP8-9, which were very hard to parallelize in decode.
I'm very confident that Microsoft is not worried about lack of demand for the new consoles! And they are putting a big emphasis on a uniform ecosystem. If they see material value in AV1, I'd expect them try to backport it. The real question is if they see value in AV1 over HEVC, which is supported in HW since Xbox One S.
Jaguar doesn't have AVX2, alas.
https://en.wikipedia.org/wiki/Jaguar...architecture):
SSE4.1, SSE4.2, AES, CLMUL, MOVBE, AVX, F16C, BMI1
So, that would be friction for backporting dav1d to PS4 or Xbox One. SSSE3 may be sufficient for 4Kp60, though, which is all the previous generation supports anyway. I'm sure an AVX implementation would still be better than SSSE3, and probably less incremental work to develop once there are already SSSE3 and AVX2 implementations to upgrade/downgrade from.
Xbox Series and PS5 have AVX2.
Ben Waggoner
My Compression Book
Old 6th February 2021, 05:26   #18  |  Link
RanmaCanada
So I wonder how much longer we have to wait for Amazon to release a new fire device that can decode AV1 haha. I believe the MECOOL boxes are Google certified, so they should work with almost everything but Netflix..
RanmaCanada is offline   Reply With Quote
Old 8th October 2021, 16:37   #19  |  Link
quietvoid
FireTV Stick 4K Max:
AV1: Hardware accelerated up to 3840x2160p (4K) @60fps, 100Mbps, Main Profile Level 5.1, Color space 8-bit and 10-bit input with HDR10, HDR10+, and HLG.
Plays smoothly with Youtube 4K 60fps HDR clips on Kodi 20 Nexus.
LG C2 OLED | GitHub Projects
Old 13th October 2021, 00:37   #20  |  Link
benwaggoner
Turns out "seven months."
Ben Waggoner
My Compression Book
av1, av1 hardware decode, hardware decoders
